Dear All,
I have retrofitted DSG gearbox on a 2013 Passat B7. It was initially fitted with manual gearbox.
I have some issues coding a few of the modules installed. ABS and EPB. Please see below an auto scan from the car. Can you please advise for proper coding?
Also the software incompatibility will be resolved with a new EDC SW number 03L 906 018 BM. Can you also confirm that this SW number is ok? Found that should be for CFFB, Bluemotion with AD Blue, DSG 6 speed.
Thank you in advance,
Best regards
Best regards
Friday,12,January,2018,15:36:47:28047
VCDS Version: 17.12.0.1 (x64)
Data version: 20171213 DS285.1
VIN: WVWZZZ3CZDE050120 License Plate: BV27RDX
Mileage: 207790km-129114mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56
61 62 72
VIN: WVWZZZ3CZDE050120 Mileage: 207790km-129114miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BL HW: 03L 907 309 Q
Component: R4 2,0L EDC H28 9910
Revision: 44H28--- Serial number: 00000000000000
Coding: 00190012042401080000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM20TDI01103L906018BL 003014
ROD: EV_ECM20TDI01103L906018BL.rod
VCID: 75E128D8D4ACB982EC4-8020
10092 - Neutral Gear Sensor
P15A0 00 [039] - Electrical Malfunction
Mileage: 207795 km
Date: 2018.01.12
Time: 00:14:41
Engine speed: 832.50 /min
Normed load value: 27.5 %
Coolant temperature: 50 °C
Intake air temperature: 20 °C
Ambient air pressure: 950 mbar
Voltage terminal 30: 12.580 V
Neutral position sensor: current transmission angle: 20.00 °
Neutral position sensor: adapted transmission angle: 0.00 °
Adaptation status for transmission neutral position sensor-Bits 0-7: 4
Transmission neutral position sensor voltage: 0 mV
Neutral position sensor: upper adaptation value: 0 mV
Neutral position sensor: lower adaptation value: 0 mV
7027 - Software Incompatibility with Transmission Control Module
U0302 00 [167] - -
Mileage: 207795 km
Date: 2018.01.12
Time: 00:14:41
Engine speed: 839.50 /min
Normed load value: 27.1 %
Voltage terminal 30: 12.660 V
selected gear-Bits 0-7: 0
Part No SW: 02E 300 054 J HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2604
Revision: 05351112 Serial number: 00001011130860
Shop #: WSC 44551 111 44551
VCID: 1D311078C4DC41C2C44-8048
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BK HW: 3AA 614 109 BK
Component: J104 C2 450M VD9F 0024
Revision: --H07--- Serial number: 00000006136993
Coding: 0003504
Shop #: WSC 05311 000 00000
VCID: 77FD22D006A0CB92FE8-8022
02757 - Learning Tire Pressures
Reset counter: 159
Mileage: 207795 km
Date: 2018.01.12
Time: 00:14:41
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.50 V
Bin. Bits: 00011111
Count: 194
Hex Value: 0x0000
Fault Status: 01101000
Reset counter: 159
Mileage: 207795 km
Date: 2018.01.12
Time: 00:14:42
Hex Value: 0x0000
Voltage: 12.50 V
Bin. Bits: 00011111
Count: 223
Hex Value: 0x0000
Reset counter: 159
Mileage: 207795 km
Date: 2018.01.12
Time: 00:14:42
Hex Value: 0x0000
Voltage: 12.25 V
Bin. Bits: 00011111
Count: 215
Hex Value: 0x0000
Part No SW: 3AA 907 044 AG HW: 3AA 907 044 AG
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0014004803
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 F HW: 3AA 937 087 F
Component: BCM PQ47 M 421 0465
Revision: BA421001
Coding: 0008000000000000009800805400006403510088426D85606480C7200041
VCID: 3D71F0F8A41C21C2E44-8068
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 06071 10 0603
Coding: 00B795
Component: RLS 010912 05 54 0403
Coding: 02302A
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H06 0016
Revision: -------- Serial number: 28261223601020
Coding: 108002
ASAM Dataset: EV_EPHVA18VW47X0000 001005
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3E73F7F4A11A3ADAFDE-806A
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__107 VW10 HI 2118
Revision: 24017000 Serial number: 003L7PHLF7PC
Coding: 0012343
VCID: 7CF73DFC3F86E8CA93A-8028
Subsystem 1 - Serial number: 6332MTS659172342
Subsystem 2 - Serial number: 6342MTS609032352
Subsystem 3 - Serial number: 6351HTS6UVQCABKJ
Subsystem 4 - Serial number: 6361HTS68UVDABKR
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BN HW: 5K0 953 569 AB
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120822201141
Coding: 118A250000
VCID: 76E32FD4C9AAB29AE5E-8022
Component: E221__MFL-TK6 H07 0022
Coding: E20000
Part No SW: 3AA 920 870 J HW: 3AA 920 870 J
Component: KOMBI H05 0705
Coding: 161F01
Shop #: WSC 05314 115 00000
VCID: 3979E4E8B8341DE2C8C-806C
Part No SW: 7N0 907 530 T HW: 7N0 907 530 K
Component: J533 Gateway H40 1632
Revision: H40 Serial number: 260812F1003385
Coding: 352006
Shop #: WSC 05314 123 12345
VCID: 41898C08D8E4452280C-8014
Mileage: 207795 km
Date: 2018.01.12
Time: 00:14:42
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 045 0400
Revision: 00045000 Serial number: VWZCZ000000000
VCID: 76E32FD401AAB29AE5E-8022
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Revision: A1001003 Serial number: 7663357196
Coding: 020100
Shop #: WSC 05314 000 00000
VCID: 2A5BCBA44592A67AB16-807E
Part No SW: 3C0 035 279 N HW: 3C0 035 279 N
Component: RNS315-EU H52 0319
Serial number: VWZAZ2M5986726
Coding: 040004110400110000011301
ROD: EV_RNS315EUV2UDS.rod
VCID: 2E53C7B4717ACA5A6DE-807A
Component: EUR_W_0038 0038
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0005589283
Coding: 0210B7
Shop #: WSC 05311 115 00000
VCID: 3561E8D8942CF9822C4-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0503
Serial number: 00000003092305
Coding: 010090
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 159
Mileage: 207795 km
Date: 2018.01.12
Time: 00:14:41
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 N HW: 5N1 909 148 G
Component: J500__APA-BS KL.309 1101
Revision: 1AH03735 Serial number: 00122310071401
Coding: 0000258
VCID: 3D71F0F8641C21C2E44-8068
Component: KSG PQ47 ELV 045 0634
Coding: 0091020052830E76340494157C084F0B605801
Shop #: WSC 05311 123 12345
Part No SW: 7N0 907 532 HW: 7N0 907 530 K
Component: EZE_2 H40 1632
Coding: 00000008
VCID: 6FED1AB0BEF08352268-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0005603463
Coding: 0210B6
VCID: 3663EFD4892AF29A25E-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0503
Serial number: 00000003098155
Coding: 010090
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000407604
Coding: 0022167
VCID: 3663EFD4412AF29A25E-8062
03182 - Clutch Position Sensor (G476)
010 - Open or Short to Plus
Fault Status: 01111010
Reset counter: 159
Mileage: 207795 km
Date: 2018.01.12
Time: 00:14:41
Voltage: 12.40 V
Count: 55
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Part No SW: 7N0 907 534 HW: 7N0 907 530 K
Component: Batt.regelung H40 1632
Coding: 030F1859
VCID: 71E91CC8A8C495A230C-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900058286
End-------------------------(Elapsed Time: 03:07)--------------------------
