2012 Audi A8 MMI visible only for a few seconds after screen comes up
Stew
C?ID=163538
I have a similar problem that seems to have many answers, which one is right for me? My MMI only displays for a few seconds after the screen rotates up, then goes dark. If I lower the screen then it will do the same thing again when I raise it. I have the 02259 Information Display fault and Control Head (Front) (J685). I bought the Fiber Optic loops to troubleshoot as the optic tester in VCDS does not seem to work for me. I have bypassed all the units I found in the trunk (Amplifier, Backup Camera and one other not sure what it is) with no change in symptoms. All the displays seem to work, in the cluster, plus I can see the backup camera for those brief few seconds when the screen pops up. I believe I need to replace this unit (J685) is this my first step, and can I test this somehow?
Stew
C?ID=163538
Sunday,31,December,2017,17:05:00:30886
VCDS Version: 17.1.3.0 (x64)
VIN: WAUAVAFD2CN008675   License Plate:
Chassis Type: FD (4H0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 1B 22 28 34 36 3B 42 46
          47 52 53 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
VIN: WAUAVAFD2CN008675   Mileage: 92818km-57674miles
Address 01: Engine (------CDRA)       Labels: None
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0004
   Revision: N5H07---
   Coding: 0106000A290F0168
   Shop #: WSC 22145 444 13987
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
   ROD: EV_ECM42FSI0114H0907560C.rod
   VCID: 2A5BBB454D878F1197-807E
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 K
   Component: 0BK 42 FSIUSA H08 1001
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMALX51011 002018
   ROD: EV_TCMALX51011_002.rod
   VCID: 01093CE99071AC49E6-8054
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 B    HW: 4H0 907 379 B
   Component: ESP PREMIUM   H10 0273
   Coding: 44FEB200227F4D00E200
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 005006
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 3169AC296051FCC956-8064
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 BD
   Component: BCM2 2.0      H31 0510
   Coding: 0D872000000000000000
   Shop #: WSC 41337 001 1048576
   VCID: 6ED37755B9EFA3310B-803A
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000111128001
Address 06: Seat Mem. Pass
Address 08: Auto HVAC
Address 09: Cent. Elect.
Address 10: Park/Steer Assist
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H41 0041
   Revision: --------    Serial number: 003JS00158S6
   Coding: 303143303230303030344A55304C34483053
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 377D92318E3522F918-8062
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Serial number: 5850000R11706015V7
   Serial number: 3575HRB405T0IRE24GI/
   Serial number: 3585HRB405H0JR9Q703L
   Serial number: 3515JRB404R0M38E3P7G
   Serial number: 3525JRB404T0M38E9HEO
   Serial number: 3554VRB40550LMIQCPKT
   Serial number: 3564VRB40550LMIQF930
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90815KGB0000S
   Coding: 000434
   VCID: 387F910D8B2B2D8111-806C
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Component: E221 - MFL  H06 0009
   Serial number: 01 02 2011  11103630
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4H0 920 920 E    HW: 4H0 920 920 E
   Component: TBenUSA------ H36 0373
   Revision: 32480030    Serial number: 658280711593038
   Coding: 0B660801B300D705020000
   Shop #: WSC 02313 785 00200
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
   VCID: 275D42715E95B27988-8072
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
   Component: Analoguhr D4  H05 0224
   Serial number: 1110707000150
   Part No SW: 4H0 907 468 F    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000198870
   Coding: 00C1034A00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3467A53D9F43C9E13D-8060
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650927867
   Part No SW: 4H0 907 144 B    HW: 4H0 907 144 B
   Component: DYNAMIKLENK.  H06 0090
   Revision: 51001005    Serial number: --------------
   Coding: 8B0000
   VCID: 275D42715695B27988-8072
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H14 0013
   Serial number: 000807110001018
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
Address 28: HVAC, Rear (E265)       Labels: None
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Component: Klima Fond    H15 0062
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck_AU64.rod
Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0096
   Coding: 008004
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2C57BD5D4773912165-8078
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000010262958
   Coding: C0183B0085053201010001010101112131313333203333
   VCID: 356198399C39D0E90A-8060
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
   Component: SARA 6D red   H02 0015
   Revision: --------    Serial number: EJ1BPA3700FZBM0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D51B0597C69982972-8078
   Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
   Component: TSG FA        H02 0166
   Revision: --------    Serial number: 0000118373747
   Coding: 011F1F205E0062C202000006
   Shop #: WSC 02312 785 00200
   VCID: 4385F6E1C2ED7E59B4-8016
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0155050077
   Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000040548
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.028  H07 0006
   Serial number:     WOO12681585
   Coding: 001F00
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H11 0080
   Serial number: A2011000000000448584
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS010  H05 0005
   Serial number:     WOO1000HPY8
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000033986
   Coding: 030000
   VCID: 1C376D9D1FD361A115-8048
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Component: TSG BF        H02 0166
   Revision: --------    Serial number: 0000118563049
   VCID: 3A7B8B05B5273F91E7-806E
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000117835
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H0 035 082 B    HW: 4H0 035 082
   Component: Radio U SIRIU H52 0076
   Revision: AB001007    Serial number: 155GR0B7510504
   Coding: 020007010000000001
   VCID: 204F596D33BB4541C9-8074
   Part No SW: 4H0 035 746 A    HW: 4H0 035 746
   Component: H-BNT-NA      H48 0380
   Revision: --------    Serial number: 035G 0B7501788
   Coding: 020200000001F1EF45128B0E00000003140001000000000000
   VCID: 26434F75519FAB71B3-8072
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4H1 919 600 F    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0064
   Serial number: 00000000045605
   Subsystem 3 - Part No: 8R0 060 961 B
   Component: CD-Database  3371
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 217
                    Mileage: 92818 km
                    Date: 2017.12.31
                    Time: 16:59:41
                    Voltage: 14.50 V
03787 - Rotation Mechanism for Display Module Front
            003 - Mechanical Failure
                    Reset counter: 217
                    Mileage: 92818 km
                    Date: 2017.12.31
                    Time: 16:59:41
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Component: TSG HL        H04 0162
   Revision: --------    Serial number: 0000118414450
   Coding: 010F1F20400062C202000006
   VCID: 39799409B0213489EE-806C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J17D3CB
   Coding: 1081002
   VCID: 26434F75919FAB71B3-8072
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0036
   Revision: 10011001    Serial number: 197100260
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001025
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3B758E01B21D0699FC-806E
Address 6F: Centr. Conv. II (J773)       Labels: None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000040791
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63C516616A2D1E5994-8036
   Component: TSG HR        H04 0162
   Revision: --------    Serial number: 0000118413875
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H07 0083
   Revision: 0L0D5012    Serial number: SN110607  0219
   ROD: EV_GSM2x3Mono.rod
   VCID: 2B55BE41427D96196C-807E
Address 88: Multicont. Seat Driver (J873)       Labels: None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00001145338002
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F6DAA517665EA3940-807A
Address 89: Multicont. Seat Pass. (J872)       Labels: None
   Serial number: 00001145336801
   Coding: 364FF2
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030801424CD8010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FED6A51B6E5AA3900-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70EF692DABDBB5C119-8024
End-------------------------(Elapsed Time: 05:55)--------------------------
Based on that scan, this does not seem to be an optical ("MOST") bus problem.
And 5F does report some faults related to the problem described:
Stew
C?ID=163538
So is the original question valid? Do I need to replace the J685 unit? Is there a way to test this, or do I replace and see if that solves the problem? That seems to be where I'm at. I just don't understand why the screen comes on every time it is raised. Has anyone had similar symptoms? I read all about the MOST ring and even purchased the bypasses, but that didn't change any of the symptoms. Everything works except the display, but the screen does function if only briefly.
If I had any personal experience that was relevant, I'd happily share it. :)
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
$5 says it's deploying and turning on as per normal, but there's some little microswitch that's supposed to tell it the screen has fully come out, and that isn't happening. So the display turns back off as it's not supposed to be on when inside the dash.
I don't know what the cheapest or easiest fix for that would be, but I bet that's the failure mode.
Stew
C?ID=163538
Well, I'll see what I can get to this weekend. Maybe when I start to disassemble the dash to pull the unit I'll see something obvious. Even if I need to replace the unit I need to pull it first because I'm not 100% sure on the part number or version if that makes any difference other than some programming. Thanks for the input.
MasterTommy
Amsterdam
C?ID=295586
Check the wiring first. It moves, so a broken or near-broken wire sounds a lot more plausible to me.
Stew
C?ID=163538
Well now its not any better, after spending a better part of the evening pulling out the trim from the dash, I was able to pull the head unit (cd player/sd card reader). The screen is still in the car because of a two wire connection on a ten pin connector doesn't seem to come undone, a youtube video definitely showed that they cut this wire. Anyway in all of my moving around components and wiring now the screen doesn't come on at all. Back at it on Monday.
MasterTommy
Amsterdam
C?ID=295586
Even more evidence that this could be ‘just’ a wiring issue.
Stew
C?ID=163538
First I had to cut what I believe is the power to the display. There are two micro switches. The fully raised switch is broken, the metal tab is missing and can not push the switch. Now that I have gotten this far, I still can't remove the unit because the switches don't have disconnects on them and I don't want to cut anymore wires. I am going to try and bypass the micro switch in a always on position (jump the wires together) and see if it will work this way. I can't really see replacing the micro switch as the unit is very hard to work on in the car. Hopefully I can get the unit working without having to reinstall it all the way so I can do some test runs.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
... There are two micro switches. The fully raised switch is broken, the metal tab is missing and can not push the switch.
I accept Paypal. :cool:
(no not really. good luck though.)
Stew
C?ID=163538
Well if I haven't destroyed something else on the process of getting this far. I broke a couple of plastic tabs getting the various pieces out. So will see. Still more confident than my local Audi dealer, as they can't even put the car back together correctly after warranty work.
Stew
C?ID=163538
Well turns out the power was intermittent to the screen. I don't know why, cabling or something. Anyway I tapped into another source and seems to be working. The micro switches have been removed, not sure of their exact function, maybe to position the screen just right, either way the motor stalls out in full up or down.
