AdBlue Adaptation
   #21
Now that the warning light is off I'd like to look at the measuring blocks to determine if the sensor is reading the correct fluid level in the AdBlue tank. Which measuring block should I be using? The info I've found online has measuring block #'s in the 500's & 600's. Mine only goes up to 254 in the standard measuring blocks and much less in the advanced measuring block section (can't remember the exact # at the moment).
Oh, OK. The 2009-2010 3.0L T'reg 3.0TDI EDC, and I'm pretty sure the same applies to the Q7, used traditional CAN. IMO that's the good stuff, you know normal MVBs, Basic Settings and (Long) Adaptation group numbers :)
2011+ however use UDS and all of the standardization (component identifiers in fault codes descriptions, normal numbering schemes for data, etc) is gone. I do not like UDS ... but that may have something to do with change and stubbornness. Either way, my attitude will adjust over time because UDS is becoming increasingly popular and I'm gonna need to deal with it.
I believe Peter has SCR/AdBlue MVB info and some kind of Output test procedure for CAN 3.0L EDCs so I'll mention it before I go digging.
I believe MVBs 170 through 186 are related to the SCR system but a Measuring Block (PLB) function Control Module Map would help. The resulting 01-7L0-907-401-T.PLB file can be opened with Notepad so you can wrap it in
 and paste it in reply.  Alternatively, you can sent it via email and I can paste the relevant MVBs here, proving I have permission from you to do so.
On a side note.. If you have that dealer level update in the future please send or post another map so we can see if they changed anything drastically.  For example, the early VW CAN protocol 2.0L CR had 4 updates and VW moved the DPF/Soot Mass groups to another group!
   #23
Sprocket
Detroit
C?ID=162267
The CEL & AdBlue warning came back on today. It's the first day I've really driven it since clearing the AdBlue warning the other night.
I'm at the local VW dealership now and am having them look the Touareg over. They said they were going to update the ECM software as well.
I didn't have my laptop or VCDS cable with me so I wasn't able to scan it before getting to the dealer.
I'll scan it and post the newest update sometime this weekend.
Fingers crossed that it's not major $$$ to repair.
   #24
Sprocket
Detroit
C?ID=162267
Hope I'm doing this correctly...
;SW:7L0-907-401-T   HW:7L0-907-401-K ---  Engine
;Component:3.0TDI EDC17G004AG  0100, Coding:0421002A590F0D68
;Thursday,23,October,2014,15:06:24:03916
;VCDS Version: Release 12.12.3 (x64)  Data version: 20140905
;VCID: 3C778E167C64EBFE875-5124
1,0,,
1,1,,,
;0 /min,,
1,2,,,
;0.0 mg/str,,
1,3,,,
;8.6 bar,,
1,4,,,
;28.8°C,,
2,0,,
2,1,,,
;0 /min,,
2,2,,,
;0.0 %,,
2,3,,,
; 0 01  0,,
2,4,,,
;28.8°C,,
3,0,,
3,1,,,
;0 /min,,
3,2,,,
;1439.4 mg/str,,
3,3,,,
;0.0 mg/str,,
3,4,,,
;99.6 %,,
4,0,,
4,1,,,
;0 /min,,
4,2,,,
;0.0 °BTDC,,
4,3,,,
;0.00 ms,,
4,4,,,
;8.6 bar,,
5,0,,
5,1,,,
;0 /min,,
5,2,,,
;0.0 mg/str,,
5,3,,,
;1.0,,
5,4,,,
;28.8°C,,
6,0,,
6,1,,,
;0.0 km/h,,
6,2,,,
;00001100,,
6,3,,,
;0.0 km/h,,
6,4,,,
;00000000,,
7,0,,
7,1,,,
;33.3°C,,
7,2,,,
;24.3°C,,
7,3,,,
;25.2°C,,
7,4,,,
;28.8°C,,
8,0,,
8,1,,,
;0 /min,,
8,2,,,
;0.0 Nm,,
8,3,,,
;356.0 Nm,,
8,4,,,
;799.5 Nm,,
9,0,,
9,1,,,
;0 /min,,
9,2,,,
;-1280.0 Nm,,
9,3,,,
;799.5 Nm,,
9,4,,,
;0.0 Nm,,
10,0,,
10,1,,,
;0.0 mg/str,,
10,2,,,
;989.4 mbar,,
10,3,,,
;979.2 mbar,,
10,4,,,
;0.0 %,,
11,0,,
11,1,,,
;0 /min,,
11,2,,,
;989.4 mbar,,
11,3,,,
;979.2 mbar,,
11,4,,,
;49.6 %,,
12,0,,
12,1,,,
;01010000,,
12,2,,,
;0.90 s,,
12,3,,,
;12.08 V,,
12,4,,,
;28.8°C,,
13,0,,
13,1,,,
;0.00 mg/str,,
13,2,,,
;0.00 mg/str,,
13,3,,,
;0.00 mg/str,,
13,4,,,
14,0,,
14,1,,,
;0.00 mg/str,,
14,2,,,
;0.00 mg/str,,
14,3,,,
;0.00 mg/str,,
14,4,,,
15,0,,
15,1,,,
;0 /min,,
15,2,,,
;-195.0 Nm,,
15,3,,,
;0.00 l/h,,
15,4,,,
;0.0 Nm,,
16,0,,
16,1,,,
;0.0,,
16,2,,,
16,3,,,
;0.0,,
16,4,,,
;0.0 %,,
18,0,,
18,1,,,
;0 /min,,
18,2,,,
;33.3°C,,
18,3,,,
;0.0,,
18,4,,,
19,0,,
19,1,,,
;0 /min,,
19,2,,,
;308.55,,
19,3,,,
;0.0 bar,,
19,4,,,
;1696.0,,
20,0,,
20,1,,,
;0 /min,,
20,2,,,
;292.4 bar,,
20,3,,,
;8.6 bar,,
20,4,,,
;7.8 %,,
21,0,,
21,1,,,
;0 /min,,
21,2,,,
;292.4 bar,,
21,3,,,
;8.6 bar,,
21,4,,,
;15.6 %,,
22,0,,
22,1,,,
;0 /min,,
22,2,,,
;00000100,,
22,3,,,
;00000000,,
22,4,,,
;00110100,,
23,0,,
23,1,,,
;0 /min,,
23,2,,,
;0.0 °BTDC,,
23,3,,,
;0.00 ms,,
23,4,,,
;3.0,,
24,0,,
24,1,,,
;0 /min,,
24,2,,,
;0.0 °BTDC,,
24,3,,,
;0.00 ms,,
24,4,,,
;8.6 bar,,
25,0,,
25,1,,,
;0 /min,,
25,2,,,
;0.0 °BTDC,,
25,3,,,
;0.00 ms,,
25,4,,,
;8.6 bar,,
26,0,,
26,1,,,
;0 /min,,
26,2,,,
;0.0 °BTDC,,
26,3,,,
;0.00 ms,,
26,4,,,
;8.6 bar,,
28,0,,
28,1,,,
;0 /min,,
28,2,,,
;0.0 °BTDC,,
28,3,,,
;0.00 ms,,
28,4,,,
;8.6 bar,,
29,0,,
29,1,,,
;0 /min,,
29,2,,,
;0.0 °BTDC,,
29,3,,,
;0.00 ms,,
29,4,,,
;8.6 bar,,
30,0,,
30,1,,,
;0.720 V,,
30,2,,,
;0.360 V,,
30,3,,,
; 0 01  0,,
30,4,,,
;0.0 %,,
31,0,,
31,1,,,
;56D4,,
32,0,,
32,1,,,
;0 /min,,
32,2,,,
;1.0,,
32,3,,,
;606.0°,,
32,4,,,
;690.0°,,
33,0,,
33,1,,,
;0 /min,,
33,2,,,
;29.5°C,,
33,3,,,
;1.00,,
33,4,,,
;1.00,,
34,0,,
34,1,,,
;0 /min,,
34,2,,,
;49.2 %,,
34,3,,,
;49.2 %,,
34,4,,,
;0.0 %,,
35,0,,
35,1,,,
;0 /min,,
35,2,,,
;1439.4 mg/str,,
35,3,,,
;0.0 mg/str,,
35,4,,,
;99.6 %,,
36,0,,
36,1,,,
;0 /min,,
36,2,,,
;9.4 %,,
36,3,,,
;0.8 %,,
36,4,,,
;0.0 %,,
37,0,,
37,1,,,
;0 /min,,
37,2,,,
;11.7 %,,
37,3,,,
;0.0 %,,
37,4,,,
;0.0 %,,
38,0,,
38,1,,,
;0 /min,,
38,2,,,
;99.6 %,,
38,3,,,
;-0.8 %,,
38,4,,,
;0.0 %,,
39,0,,
39,1,,,
;0 /min,,
39,2,,,
;0.0 mg/str,,
39,3,,,
;25.2°C,,
39,4,,,
;4.7 %,,
40,0,,
40,1,,,
;0 /min,,
40,2,,,
;4.7 %,,
40,3,,,
;4.7 %,,
40,4,,,
;4.7 %,,
41,0,,
41,1,,,
;4.7,,
41,2,,,
;0.000 V,,
41,3,,,
;0.6 %,,
41,4,,,
;1.0,,
42,0,,
42,1,,,
;0.6 %,,
42,2,,,
;1.6 %,,
42,3,,,
;3.300 V,,
42,4,,,
;25.40,,
43,0,,
43,1,,,
;0.0,,
43,2,,,
;15.3°C,,
43,3,,,
;0.0 mbar,,
43,4,,,
;0.000 V,,
44,0,,
44,1,,,
;0 /min,,
44,2,,,
;11001000,,
44,3,,,
;0.0,,
44,4,,,
;0.0,,
45,0,,
45,1,,,
;28.8°C,,
45,2,,,
;0.0 %,,
45,3,,,
;9.4 %,,
45,4,,,
;9.4 %,,
46,0,,
46,1,,,
;15.3°C,,
46,2,,,
;19.8°C,,
46,3,,,
;00000001,,
46,4,,,
;00000001,,
47,0,,
47,1,,,
;94.5°C,,
47,2,,,
;18.0°C,,
47,3,,,
;0.0 %,,
47,4,,,
;9.4 %,,
48,0,,
48,1,,,
;0 /min,,
48,2,,,
;0 /min,,
48,3,,,
;       0,,
48,4,,,
;1270.0 Nm,,
51,0,,
51,1,,,
;0 /min,,
51,2,,,
;0 /min,,
51,3,,,
;1.0,,
51,4,,,
52,0,,
52,1,,,
;0 /min,,
52,2,,,
;0.0,,
52,3,,,
;0.0,,
52,4,,,
53,0,,
53,1,,,
;00000000,,
53,2,,,
;00000000,,
53,3,,,
;00000000,,
53,4,,,
;00000100,,
57,0,,
57,1,,,
;0 /min,,
57,2,,,
;0.0 km/h,,
57,3,,,
;0.0 %,,
57,4,,,
;0.0 %,,
58,0,,
58,1,,,
;0 /min,,
58,2,,,
;0.0 km/h,,
58,3,,,
;100.6 %,,
58,4,,,
;100.6 %,,
59,0,,
59,1,,,
;0 /min,,
59,2,,,
;-195.0 Nm,,
59,3,,,
;46.8 Nm,,
59,4,,,
;0.0 Nm,,
60,0,,
60,1,,,
;46.8 Nm,,
60,2,,,
;-50.7 Nm,,
60,3,,,
;0.0 Nm,,
60,4,,,
;0.0,,
61,0,,
61,1,,,
;0 /min,,
61,2,,,
;24.3°C,,
61,3,,,
;39.0,,
61,4,,,
;64.77,,
62,0,,
62,1,,,
;0 /min,,
62,2,,,
;0.0 mg/str,,
62,3,,,
;0.0,,
62,4,,,
;0.0,,
70,0,,
70,1,,,
;166.0,,
70,2,,,
;166.0,,
70,3,,,
;167.0,,
70,4,,,
71,0,,
71,1,,,
;11110111,,
71,2,,,
;00111111,,
71,3,,,
71,4,,,
72,0,,
72,1,,,
;10.0 ms,,
72,2,,,
;6.0 ms,,
72,3,,,
;0.0 ms,,
72,4,,,
73,0,,
73,1,,,
;16.0 ms,,
73,2,,,
;11.0 ms,,
73,3,,,
;4.0 ms,,
73,4,,,
74,0,,
74,1,,,
;21.0 ms,,
74,2,,,
;15.0 ms,,
74,3,,,
;10.0 ms,,
74,4,,,
75,0,,
75,1,,,
;14.0 ms,,
75,2,,,
;9.0 ms,,
75,3,,,
;5.0 ms,,
75,4,,,
76,0,,
76,1,,,
;32.0 ms,,
76,2,,,
;11.0 ms,,
76,3,,,
;7.0 ms,,
76,4,,,
77,0,,
77,1,,,
;16.0 ms,,
77,2,,,
;7.0 ms,,
77,3,,,
;3.0 ms,,
77,4,,,
80,0,,
80,1,,,
;BPG-810 02.12.09 33H02--- 1479 0156,,
81,0,,
81,1,,,
;WVGAK7A94AD002442 VWX3Z0I6903246 <>     ,,
82,0,,
82,1,,,
;4857600140662 17.10.14 <>  <>   <>  <>  ,,
85,0,,
85,1,,,
;146910 km,,
85,2,,,
;70.0,,
85,3,,,
;22.0,,
85,4,,,
;61.0,,
86,0,,
86,1,,,
;11111111,,
86,2,,,
;11111111,,
86,3,,,
;11111111,,
86,4,,,
;11111111,,
87,0,,
87,1,,,
;11111111,,
87,2,,,
;11111111,,
87,3,,,
;11111111,,
87,4,,,
89,0,,
89,1,,,
;10000001,,
89,2,,,
;00001111,,
89,3,,,
;11101011,,
89,4,,,
;01100000,,
90,0,,
90,1,,,
;0 /min,,
90,2,,,
;0.0 mg/str,,
90,3,,,
;1439.4 mg/str,,
90,4,,,
;00000000,,
91,0,,
91,1,,,
;127.0,,
91,2,,,
;-128.0,,
91,3,,,
;1439.4 mg/str,,
91,4,,,
;127.0,,
93,0,,
93,1,,,
;00000000,,
93,2,,,
;1.89,,
93,3,,,
;0.0,,
93,4,,,
;0.0,,
94,0,,
94,1,,,
;01011001,,
94,2,,,
94,3,,,
94,4,,,
95,0,,
95,1,,,
;       0,,
95,2,,,
; 000   1,,
95,3,,,
;00010110,,
95,4,,,
;      10,,
96,0,,
96,1,,,
;       0,,
96,2,,,
;00000000,,
96,3,,,
;00100000,,
96,4,,,
;12.08 V,,
97,0,,
97,1,,,
;0 mbar,,
97,2,,,
;0 mbar,,
97,3,,,
97,4,,,
98,0,,
98,1,,,
;28.8°C,,
98,2,,,
;18.0°C,,
98,3,,,
;0.0 %,,
98,4,,,
;35.4°C,,
99,0,,
99,1,,,
;0 /min,,
99,2,,,
;29.5°C,,
99,3,,,
;-277.3°C,,
99,4,,,
;11.8°C,,
100,0,,
100,1,,,
;0 /min,,
100,2,,,
;17.7°C,,
100,3,,,
;0.0,,
100,4,,,
;       0,,
101,0,,
101,1,,,
;00000000,,
101,2,,,
;00000000,,
101,3,,,
;00000000,,
101,4,,,
;00000001,,
102,0,,
102,1,,,
;17.7°C,,
102,2,,,
;11.8°C,,
102,3,,,
;0 mbar,,
102,4,,,
;0 mbar,,
103,0,,
103,1,,,
;00000001,,
103,2,,,
;00010000,,
103,3,,,
;     000,,
103,4,,,
;      00,,
104,0,,
104,1,,,
;0.20,,
104,2,,,
;20.0,,
104,3,,,
;5.0,,
104,4,,,
;1160 km,,
105,0,,
105,1,,,
;0.0,,
105,2,,,
;3.0,,
105,3,,,
;19.0,,
105,4,,,
;104.0 l,,
106,0,,
106,1,,,
;00000000,,
106,2,,,
;00000000,,
106,3,,,
;00000000,,
106,4,,,
;00000000,,
107,0,,
107,1,,,
;51.0,,
107,2,,,
;34.0,,
107,3,,,
;23.5,,
107,4,,,
;0.0,,
109,0,,
109,1,,,
;23.6°C,,
109,2,,,
;354.0°C,,
109,3,,,
;17.7°C,,
109,4,,,
;11.8°C,,
110,0,,
110,1,,,
110,2,,,
;00000100,,
110,3,,,
;0.0 km/h,,
110,4,,,
111,0,,
111,1,,,
;0 /min,,
111,2,,,
;0.0 km/h,,
111,3,,,
;0.00,,
111,4,,,
;0.0,,
112,0,,
112,1,,,
;2.17,,
112,2,,,
;-830.0 Nm,,
112,3,,,
;-1280.0 Nm,,
112,4,,,
;0.0 Nm,,
113,0,,
113,1,,,
;00000100,,
113,2,,,
;00000000,,
113,3,,,
;00000000,,
113,4,,,
;00000000,,
114,0,,
114,1,,,
;255.0,,
114,2,,,
;255.0,,
114,3,,,
;2.17,,
114,4,,,
;0.00,,
120,0,,
120,1,,,
;288.0,,
120,2,,,
;17.7°C,,
120,3,,,
;00000100,,
120,4,,,
;2.420 V,,
121,0,,
121,1,,,
;-0.8 %,,
121,2,,,
;7.0 %,,
121,3,,,
;00000100,,
121,4,,,
;0.800 V,,
122,0,,
122,1,,,
;0.8 %,,
122,2,,,
;1.6 %,,
122,3,,,
;00000100,,
122,4,,,
;0.940 V,,
123,0,,
123,1,,,
;-0.0 %,,
123,2,,,
;00000100,,
123,3,,,
;00000010,,
123,4,,,
;4.060 V,,
124,0,,
124,1,,,
124,2,,,
124,3,,,
;00000000,,
124,4,,,
;2.680 V,,
125,0,,
125,1,,,
;Transm. 1,,
125,2,,,
;ABS 1,,
125,3,,,
;Instruments 1,,
125,4,,,
;Airbag 1,,
126,0,,
126,1,,,
;HVAC 1,,
126,2,,,
126,3,,,
126,4,,,
127,0,,
127,1,,,
;AWD 1,,
127,2,,,
;Level 1,,
127,3,,,
;El.Ign.Lock 1,,
127,4,,,
;St. Wheel 1,,
128,0,,
128,1,,,
;Gateway 1,,
128,2,,,
128,3,,,
;Steer. ang. 1,,
128,4,,,
129,0,,
129,1,,,
129,2,,,
129,3,,,
;NOx-S1 1,,
129,4,,,
;NOx-S2 1,,
133,0,,
133,1,,,
;1.00,,
133,2,,,
;1.00,,
133,3,,,
;1.00,,
133,4,,,
;1.00,,
135,0,,
135,1,,,
;73.7 %,,
135,2,,,
;35.1°C,,
135,3,,,
;42.3°C,,
135,4,,,
140,0,,
140,1,,,
;0.0 Nm,,
140,2,,,
;0.0 Nm,,
140,3,,,
140,4,,,
141,0,,
141,1,,,
;0.0 bar,,
141,2,,,
;0.0 bar,,
141,3,,,
141,4,,,
142,0,,
142,1,,,
;0.00,,
142,2,,,
;0.00,,
142,3,,,
142,4,,,
143,0,,
143,1,,,
;0.0°,,
143,2,,,
;0.0°,,
143,3,,,
143,4,,,
144,0,,
144,1,,,
;0.0°,,
144,2,,,
;0.0°,,
144,3,,,
144,4,,,
145,0,,
145,1,,,
;361.4 °,,
145,2,,,
;361.4 °,,
145,3,,,
145,4,,,
146,0,,
146,1,,,
;7.00,,
146,2,,,
;11.00,,
146,3,,,
146,4,,,
147,0,,
147,1,,,
;00000000,,
147,2,,,
;00000000,,
147,3,,,
147,4,,,
148,0,,
148,1,,,
;00000000,,
148,2,,,
;00000000,,
148,3,,,
148,4,,,
150,0,,
150,1,,,
;10010111,,
150,2,,,
;10010000,,
150,3,,,
;00000001,,
150,4,,,
;00000000,,
151,0,,
151,1,,,
;2919 /min,,
151,2,,,
;-0.10 mg/str,,
151,3,,,
;20.0 mg/str,,
151,4,,,
166,0,,
166,1,,,
;1.03,,
166,2,,,
;1.03,,
166,3,,,
;1.01,,
166,4,,,
;1.01,,
167,0,,
167,1,,,
;1.00,,
167,2,,,
;1.00,,
167,3,,,
167,4,,,
169,0,,
169,1,,,
;0 /min,,
169,2,,,
;4.7 %,,
169,3,,,
;-90.6 %,,
169,4,,,
;4.7 %,,
170,0,,
170,1,,,
;0.0 %,,
170,2,,,
;0.0,,
170,3,,,
;0.0 %,,
170,4,,,
;0.0 bar,,
172,0,,
172,1,,,
;       0,,
172,2,,,
;       0,,
172,3,,,
;11.7°C,,
172,4,,,
;80.1 %,,
174,0,,
174,1,,,
;00000100,,
174,2,,,
;       0,,
174,3,,,
;0.000 V,,
174,4,,,
;0.000 V,,
175,0,,
175,1,,,
;0.3,,
175,2,,,
;0.000 A,,
175,3,,,
;0.000 A,,
175,4,,,
;24.0°C,,
176,0,,
176,1,,,
;0 ppm,,
176,2,,,
;0.000 V,,
176,3,,,
;0.00,,
176,4,,,
177,0,,
177,1,,,
;0 ppm,,
177,2,,,
;0.000 V,,
177,3,,,
;0.00,,
177,4,,,
178,0,,
178,1,,,
;5100 km,,
178,2,,,
;10.0,,
178,3,,,
178,4,,,
179,0,,
179,1,,,
;156.0 kg,,
179,2,,,
179,3,,,
179,4,,,
180,0,,
180,1,,,
180,2,,,
;0 ppm,,
180,3,,,
180,4,,,
181,0,,
181,1,,,
;0.0,,
181,2,,,
;0.0,,
181,3,,,
;0.0,,
181,4,,,
182,0,,
182,1,,,
182,2,,,
182,3,,,
;00000000,,
182,4,,,
183,0,,
183,1,,,
;1.23,,
183,2,,,
183,3,,,
183,4,,,
186,0,,
186,1,,,
;0.480 V,,
186,2,,,
;0.0 s,,
186,3,,,
;1.480 V,,
186,4,,,
;0.0 s,,
187,0,,
187,1,,,
;    0 01,,
187,2,,,
;0.0 s,,
187,3,,,
;0.0 s,,
187,4,,,
;0.0 s,,
188,0,,
188,1,,,
;    0 10,,
188,2,,,
;89.9 s,,
188,3,,,
;99.8 s,,
188,4,,,
200,0,,
200,1,,,
;0.0,,
200,2,,,
;0.0,,
200,3,,,
;0.0,,
200,4,,,
201,0,,
201,1,,,
;0.0,,
201,2,,,
;0.0,,
201,3,,,
;0.0,,
201,4,,,
202,0,,
202,1,,,
;0 /min,,
202,2,,,
;0.0,,
202,3,,,
;    0   ,,
202,4,,,
;   0    ,,
203,0,,
203,1,,,
;00000000,,
203,2,,,
;00000000,,
203,3,,,
;0.00,,
203,4,,,
;0.0 Nm,,
204,0,,
204,1,,,
;-330.0 Nm,,
204,2,,,
;0.0 Nm,,
204,3,,,
;00000000,,
204,4,,,
205,0,,
205,1,,,
;0.0,,
205,2,,,
;0.00,,
205,3,,,
205,4,,,
206,0,,
206,1,,,
;00000000,,
206,2,,,
;1250 km,,
206,3,,,
;00000000,,
206,4,,,
207,0,,
207,1,,,
;1.01,,
207,2,,,
207,3,,,
207,4,,,
208,0,,
208,1,,,
;00000000,,
208,2,,,
208,3,,,
208,4,,,
218,0,,
218,1,,,
218,2,,,
;0 km,,
218,3,,,
;0.0,,
218,4,,,
;0.0,,
219,0,,
219,1,,,
;-277.3°C,,
219,2,,,
;-277.3°C,,
219,3,,,
;0.0 km/h,,
219,4,,,
;0.0 km/h,,
220,0,,
220,1,,,
;0.0,,
220,2,,,
220,3,,,
220,4,,,
225,0,,
225,1,,,
;0.0,,
225,2,,,
;0.0,,
225,3,,,
;0.0,,
225,4,,,
;0.0,,
226,0,,
226,1,,,
;0.0,,
226,2,,,
226,3,,,
;0.0,,
226,4,,,
;0.0,,
227,0,,
227,1,,,
;0.0,,
227,2,,,
;0.0,,
227,3,,,
;0.0,,
227,4,,,
;0.0,,
228,0,,
228,1,,,
;0.0,,
228,2,,,
;0.0,,
228,3,,,
;0.0,,
228,4,,,
;0.0,,
229,0,,
229,1,,,
229,2,,,
229,3,,,
;0.0,,
229,4,,,
;0.0,,
   #25
Excellent, it looks like they updated you from SWL 0090 to SWL 0100:
Component: 3.0TDI EDC17G004AG 0090
Component: 3.0TDI EDC17G004AG 0100
I'll take some time to dig through that map to isolate the SCR system groups. In the meanwhile, are the issues resolved and did the VW dealer toss any parts at it?
   #26
Sprocket
Detroit
C?ID=162267
Thanks for going through the map to isolate the SCR system!
VW dealership did the software update and said that the rear NOX sensor needs to be replaced. Part# 059-907-807-G @ $438.91 (list price) + $60.00 labor. I'm not sure how the low AdBlue warning & the rear NOX sensor are related, but that's what I'm being told from VW.
I'm waiting for a response from the used car dealership I purchased the vehicle through to see if they are going to cover the cost of the repair. They should as the vehicle has a 60 day 3k mile warranty.
   #27
Gone But Not Forgotten
Here is a tip.
With alternate solutions............
Remove NOX probe and heat element with propane torch for 30 seconds to 1 minute.
This in many cases.............. cleans off impurities and may result with no need for a sensor replacement.
We have come up with a probe only solution that saves about 75-250 USD depending on application.
Genuine OEM NGK Japan................not the cheapo pile.
http://www.ebay.com/itm/VW-AUDI-CLZ...907807G-/231344640901?ssPageName=STRK:MESE:IT
   #28
Sprocket
Detroit
C?ID=162267
Here is a tip.
Thank you Jack!
I don't think the VW dealership did the reset procedure after the sofrware update (outlined on page 2 of this thread). I tried that this morning and want to see if this solves the problem first.
I'll try your tip the next time I'm under the vehicle or if the AdBlue warning comes on right away.
If that fails to work then it's replacement time for the probe and or sensor.
Thanks again!
   #29
Peter and I are digging into theses CAN controllers to see if we can fill in the gaps and update the label file. In the meanwhile I wanted to let you know we didn't forget about you. Please do bump this back up if fault codes return, and if so, another scan clip from 01-Engine and perhaps another map couldn't hurt.
-Dana
   #30
barbarmi
C?ID=217814
Dana, thanks for the input so far. Some new data. After all the trouble I was having and the Adblue mileage counter continuing to decrease (until start wouldn't be possible) I capitulated and took the vehicle to a local shop (not the dealer). The shop did some basic trouble shooting couldn't find anything wrong with the AdBlue system and did an AdBlue "reset". I asked and the shop has a different tool (Autel I believe) and indicated their tool has an "automatic" function for resetting/adapting the AdBlue system. They performed the reset and all problems went away (or so I thought). I checked the adaptation values in Channel 80 and A80;0 read 2.
That was 3000 miles ago. The AdBlue light came back on yesterday (I will upload the PLA and PLB maps and scan files and send them tonight).
I refilled the AdBlue tank (only would take about 1 gal of fluid) I tried long adaptation again (seeing if I could set it to 2 like when I got it back from the shop) and was not successful. Using the "New Value" up/dn buttons the "New Value" will not go lower then 2. I can manually enter a new value of 1 the test value changes to 4 (without selecting test, in fact the test button is grayed out). When I enter a value of 2 the test button is active, when selected the test value changes to 4 and the save button stays grayed out. when I enter a value of 3 (same as current stored value) the test button is active, when selected the test value changes to 3 and the Save button becomes active.
Was doing this on the fly last night late. I will step through your instructions above and record actions/results methodically tonight.
Would be really really nice if the Ross-Tech VCDS had a AdBlue reset function built in similar to the Service Reset Function.
   #31
Personally........... I think the OEM should be required to have a reset button on the dash in addition to TPMS for these type of resets........ so critical to drive.
Seems like another class action lawsuit in the making "like high security keys" coming............ it is absolutely possible to produce or retrofit.
Talk about extortion and thank god that VCDS exists to deal with this crap........... as an option.
That Autel tool you reference is a pile of dog turds
Please post a complete auto-scan.
   #32
I agree however all of this is related to flaky EDC software...and now we have age on our side when dealing with 2009/2010 model year vehicles so parts are failing. I'm not sure a VCDS auto pilot test plan would help much. For instance, the fuse location shenanigans for your US market Q7 alone are enough to cause confusion and I didn't even look at RoW market stuff.
It sounds like something is very wrong though if the AdBlue system is causing drama again after that mileage and the little that you could get into it. Please post the most recent scan and maps at some point, even if repeating all of those steps resolve the issue (perhaps temporarily).
Yeah Jack, this was his thread (and it may be the go-to 3.0TDI Q7 and T'reg AdBlue thread now) but seeing the latest values will help.
   #33
barbarmi
C?ID=217814
Ok,
Here we go;
The Auto Scan from this evening before doing anything
Wednesday,12,November,2014,20:31:12:32095
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
Dealer/Shop Name: MJ's Garage
VIN: WA1LMAFEXAD008198   License Plate: TQNC
Mileage: 143090km-88912mi   Repair Order:
Chassis Type: FE (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 28 36 42 46 47 4C 4F 52 55
          56 5F 62 69 6C 6D 6F 72 76
VIN: WA1LMAFEXAD008198   Mileage: 143090km-88912miles
Address 01: Engine (CAT)       Labels: NONE
   Part No SW: 4L1 910 401 G    HW: 4L0 907 401 B
   Component: 3.0TDI EDC17G004AG  0080
   Revision: 31H04---    Serial number:
   Coding: 0121002A190F0968
   Shop #: WSC 02325 210 01865
   VCID: 275DE0C196904B190E1-8072
005075 - Cylinder 2 Internal Pressure Sensor
               P13D3 - 004 - Implausible Signal
                    Fault Frequency: 8
                    Mileage: 143003 km
                    Date: 2014.11.12
                    Time: 10:02:33
                    RPM: 2289 /min
                    Speed: 31.4 km/h
                    Bin. Bits: 00001000
                    Absolute Pres.: 44.0 bar
                    (no units): -12.80
                    Angle: 361.4 °
                    (no units): 0.20
Address 02: Auto Trans        Labels: 09D-927-750.LBL
   Part No SW: 09D 927 750 LL    HW: 09D 927 750 LL
   Component: AL 750 6A           1579
   Revision: 00H92000    Serial number:
   Coding: 0001016
   Shop #: WSC 31414 790 00001
   VCID: 0305945142684739729-8056
Address 03: ABS Brakes        Labels: 4L0-910-517-V2.CLB
   Part No SW: 4L0 910 517 K    HW: 4L0 614 517 K
   Revision: 00H30001
   Coding: 0099473
   VCID: 326B0195AD523EB1A9F-8067
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.CLB
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601569521
   Coding: 0000131
   VCID: 2541EAC9EC9C59093CD-8070
   Subsystem 1 - Part No: 4F0 910 132 J
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0054
Address 08: Auto HVAC (J255)       Labels: NONE
   Part No SW: 4L0 910 043 C    HW: 4L0 820 043 AB
   Component: KLIMA 4 ZONEN H12 0030
   Revision: 00---017    Serial number: 00000000233733
   Coding: 022036
   VCID: 2447F7CD27A6A0012B3-8071
Address 09: Cent. Elect.        Labels: 4F0-910-279.LBL
   Part No SW: 4F0 910 279 R    HW: 4F0 907 279
   Component: ILM Fahrer      H26 0340
   Coding: 0039123
   VCID: 387F33BD4B2ED4E197B-806D
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H17 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.LBL
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 1521DA09FCFCC989ACD-8040
Address 15: Airbags        Labels: 4L0-910-655.LBL
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09FARP
   Coding: 0014131
   VCID: 2B551CF18A786F79EA9-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME215C1D02B
   Subsystem 3 - Serial number: 6342QSME265E141EN
   Subsystem 4 - Serial number: 6352QSME165E2328I
   Subsystem 5 - Serial number: 6362QSME165E2114C
   Subsystem 6 - Serial number: 63734SME71562036V
   Subsystem 7 - Serial number: 63834SME5052012EV
Address 16: Steering wheel        Labels: 4F0-910-549.LBL
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026101070012
   Coding: 0002042
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels: 4L0-920-XXX-17.CLB
   Part No SW: 4L0 920 982 P    HW: 4L0 920 982 P
   Component: KOMBIINSTR.   H09 0147
   Revision: 00000000    Serial number: DKY25V35A
   Coding: 8BD664040100CF05020201
   VCID: 3E7325A5A90AEAD15D7-806B
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.CLB
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L1041580AB
   Coding: 000303
   VCID: 397936B9B024CDE9685-806C
   Component: J367-BDM  H07 0125
Address 28: HVAC, Rear        Labels: NONE
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AA
   Revision: 00---010    Serial number: 00000030150382
   Coding: 0000006
   VCID: 68DFA3FD5B0E8461C7B-803D
Address 36: Seat Mem. Drvr (J136)       Labels: NONE
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010140320
   Coding: 00581300000011110000
   VCID: 31690E99685405A9D05-8064
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.CLB
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000103867623
   Coding: 011F07205E40440004
   VCID: 46834D45F1DAB211157-8013
Address 46: Central Conv.        Labels: 4L0-910-289.LBL
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01297220310000
   Coding: 3569693
   VCID: 35613A895C3C29898CD-8060
03073 - Rear Lid Closed Sensor 1
                    Fault Status: 01101000
                    Reset counter: 152
                    Mileage: 124054 km
                    Date: 2014.03.22
                    Time: 13:07:03
Address 47: Sound System (J525)       Labels: REDIR FAIL!
   Part No SW: 4L0 035 223 E    HW: 4L0 035 223 E
   Component: BOSE G3 AU716 H01 0100
   Revision: AH001500    Serial number: 00000000024138
   Coding: 0D000000
16349 - Control Module - Error in Output Stage
                    Fault Status: 00101110
                    Mileage: 65 km
                    Date: 2010.07.28
                    Time: 17:58:35
                    Bin. Bits: 00001000
Address 4C: Tire Pressure II        Labels: 4F0-910-274.CLB
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H03 0110
   Revision: 00000276    Serial number: 00002760010047
   Coding: 0696013
   VCID: 2345F4D1E2A8A739529-8076
Address 4F: Centr. Electr. II        Labels: 4F0-910-280.LBL
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000066645
   Coding: 0012001
   VCID: 5EB38525894ACAD13D7-800B
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.CLB
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000103783307
   VCID: 45814A49CCDCB9091CD-8010
Address 55: Headlight Range        Labels: 8P0-907-357.LBL
   Part No: 8P0 907 357 H
   Coding: 0000007
   VCID: 3F8D58A16E00E3D9561-806A
Address 56: Radio (R)       Labels: REDIR FAIL!
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335D-0A7568307
   Coding: 020000010000000000
   VCID: 1D31C22904CC91C964D-8048
Address 5F: Information Electr. (J794)       Labels: NONE
   Part No SW: 4L0 035 664 A    HW: 4L0 035 664 A
   Component: H-BN-NA       H47 0042
   Revision: --------    Serial number: 489E00A7532177
   Coding: 010200060004E3EF41002305EF6300030000
   VCID: 2959E6F940847D69185-807C
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 B
   Component: E0380 Bedient  H05 0060
   Component: CD-Database  1293
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.CLB
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000010600354
   Coding: 010E07204040230004
   VCID: 43855451C2E88739329-8016
Address 69: Trailer        Labels: 4E0-907-383.CLB
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Component: Anhaenger     H08 0070
   VCID: 31690E99685405A9D05-FFFF
Address 6C: Back-up Cam.        Labels: 4L0-910-441.CLB
   Revision: --H04---    Serial number: 525PA8-J0441A1
   Coding: 1021201
Address 6D: Trunk Elect.        Labels: NONE
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H55 0500
   Revision: --H55001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7DFED4FF6A841A33-8039
   Subsystem 3 - Serial number: RD06.05.10--H55001001B0058ÿ
   Subsystem 4 - Serial number: 1B0058ÿ
Address 6F: Centr. Conv. II        Labels: 4L0-910-290.LBL
   Component: ILM HINTEN 2    H05 0070
   Revision: AAH05061    Serial number: 103774799-----
   Coding: 0003595
   VCID: 2643EDC5919A5211357-8073
   Component: J_245_EE16_SKB10H10 0220
   Component: J_394_EE16_SKB10H10 0220
   Component: J_392_EE16_SKB10H10 0220
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.CLB
   Revision:             Serial number: 0000010602095
Address 76: Park Assist        Labels: 4FX-910-283.LBL
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H02 0500
   Revision: 00H02000    Serial number: 12631012008902
   Coding: 0231266
   VCID: 2A5B19F58582767111F-807F
The Measuring Block File before doing anything:
;SW:4L1-910-401-G   HW:4L0-907-401-B ---  Engine
;Component:3.0TDI EDC17G004AG  0080, Coding:0121002A190F0968
;Wednesday,12,November,2014,19:52:43:32095
;VCDS Version: Release 14.10.0 (x64)  Data version: 20141022
;VCID: 275DE0C196904B190E1-8072
1,0,,
1,1,,,
;0 /min,RPM,
1,2,,,
;0.0 mg/str,Inj. Quantity,
1,3,,,
;8.6 bar,Pressure,
1,4,,,
;54.9°C,Temperature,
2,0,,
2,1,,,
;0 /min,RPM,
2,2,,,
;0.0 %,Load,
2,3,,,
; 0 01  0,Bin. Bits,
2,4,,,
3,0,,
3,1,,,
;0 /min,RPM,
3,2,,,
;1274.9 mg/str,Mass Air / Rev.,
3,3,,,
;0.0 mg/str,Mass Air / Rev.,
3,4,,,
;99.6 %,Duty Cycle,
4,0,,
4,1,,,
;0 /min,RPM,
4,2,,,
;0.0 °BTDC,Ign. Timing,
4,3,,,
;0.00 ms,Time,
4,4,,,
;8.6 bar,Pressure,
5,0,,
5,1,,,
;0 /min,RPM,
5,2,,,
5,3,,,
;1.0,(no units),
5,4,,,
6,0,,
6,1,,,
;0.0 km/h,Speed,
6,2,,,
;00101100,Bin. Bits,
6,3,,,
;0.0 km/h,Speed,
6,4,,,
;10000001,Bin. Bits,
7,0,,
7,1,,,
;57.6°C,Temperature,
7,2,,,
;49.5°C,Temperature,
7,3,,,
;46.8°C,Temperature,
7,4,,,
8,0,,
8,1,,,
;0 /min,RPM,
8,2,,,
;0.0 Nm,Torque,
8,3,,,
;356.0 Nm,Torque,
8,4,,,
;799.5 Nm,Torque,
9,0,,
9,1,,,
;0 /min,RPM,
9,2,,,
;-1280.0 Nm,Torque,
9,3,,,
;799.5 Nm,Torque,
9,4,,,
;0.0 Nm,Torque,
10,0,,
10,1,,,
10,2,,,
;1009.8 mbar,Absolute Pres.,
10,3,,,
;999.6 mbar,Absolute Pres.,
10,4,,,
;0.0 %,Load,
11,0,,
11,1,,,
;0 /min,RPM,
11,2,,,
;989.4 mbar,Absolute Pres.,
11,3,,,
11,4,,,
;49.6 %,Duty Cycle,
12,0,,
12,1,,,
;01010000,Bin. Bits,
12,2,,,
;0.00 s,Time,
12,3,,,
;12.08 V,Voltage,
12,4,,,
13,0,,
13,1,,,
;0.00 mg/str,Inj. Quantity,
13,2,,,
13,3,,,
13,4,,,
14,0,,
14,1,,,
14,2,,,
14,3,,,
14,4,,,
15,0,,
15,1,,,
;0 /min,RPM,
15,2,,,
;-195.0 Nm,Torque,
15,3,,,
;0.00 l/h,Fuel Consump.,
15,4,,,
;0.0 Nm,Torque,
16,0,,
16,1,,,
;0.0,(no units),
16,2,,,
16,3,,,
;0.0,(no units),
16,4,,,
;0.0 %,Lambda,
18,0,,
18,1,,,
;0 /min,RPM,
18,2,,,
18,3,,,
;0.0,(no units),
18,4,,,
19,0,,
19,1,,,
;0 /min,RPM,
19,2,,,
;313.65,(no units),
19,3,,,
;0.0 bar,Pressure,
19,4,,,
;1696.0,(no units),
20,0,,
20,1,,,
;0 /min,RPM,
20,2,,,
;292.4 bar,Pressure,
20,3,,,
;0.0 bar,Pressure,
20,4,,,
;7.8 %,Lambda,
21,0,,
21,1,,,
;0 /min,RPM,
21,2,,,
21,3,,,
;0.0 bar,Pressure,
21,4,,,
;16.4 %,Lambda,
22,0,,
22,1,,,
;0 /min,RPM,
22,2,,,
;00000100,Bin. Bits,
22,3,,,
;00000000,Bin. Bits,
22,4,,,
;00110100,Bin. Bits,
23,0,,
23,1,,,
;0 /min,RPM,
23,2,,,
23,3,,,
;0.00 ms,Time,
23,4,,,
;3.0,(no units),
24,0,,
24,1,,,
;0 /min,RPM,
24,2,,,
24,3,,,
;0.00 ms,Time,
24,4,,,
;8.6 bar,Pressure,
25,0,,
25,1,,,
;0 /min,RPM,
25,2,,,
25,3,,,
;0.00 ms,Time,
25,4,,,
;8.6 bar,Pressure,
26,0,,
26,1,,,
;0 /min,RPM,
26,2,,,
26,3,,,
;0.00 ms,Time,
26,4,,,
;8.6 bar,Pressure,
28,0,,
28,1,,,
;0 /min,RPM,
28,2,,,
28,3,,,
;0.00 ms,Time,
28,4,,,
;8.6 bar,Pressure,
29,0,,
29,1,,,
;0 /min,RPM,
29,2,,,
29,3,,,
;0.00 ms,Time,
29,4,,,
;8.6 bar,Pressure,
30,0,,
30,1,,,
;0.720 V,Voltage,
30,2,,,
;0.360 V,Voltage,
30,3,,,
; 0 01  0,Bin. Bits,
30,4,,,
;0.0 %,Load,
31,0,,
31,1,,,
;EFD5,Voltage,
32,0,,
32,1,,,
;0 /min,RPM,
32,2,,,
;1.0,(no units),
32,3,,,
;606.0°,Steering Angle,
32,4,,,
;690.0°,Steering Angle,
33,0,,
33,1,,,
;0 /min,RPM,
33,2,,,
;59.0°C,Temperature,
33,3,,,
;1.00,(no units),
33,4,,,
;1.00,(no units),
34,0,,
34,1,,,
;0 /min,RPM,
34,2,,,
;49.2 %,Lambda,
34,3,,,
;49.2 %,Lambda,
34,4,,,
;0.0 %,Lambda,
35,0,,
35,1,,,
;0 /min,RPM,
35,2,,,
;1280.8 mg/str,Mass Air / Rev.,
35,3,,,
35,4,,,
;99.6 %,Duty Cycle,
36,0,,
36,1,,,
;0 /min,RPM,
36,2,,,
;11.7 %,Lambda,
36,3,,,
;0.8 %,Lambda,
36,4,,,
;0.0 %,Lambda,
37,0,,
37,1,,,
;0 /min,RPM,
37,2,,,
;13.3 %,Lambda,
37,3,,,
;0.0 %,Lambda,
37,4,,,
;0.0 %,Lambda,
38,0,,
38,1,,,
;0 /min,RPM,
38,2,,,
;99.6 %,Duty Cycle,
38,3,,,
;-0.8 %,Lambda,
38,4,,,
;0.0 %,Lambda,
39,0,,
39,1,,,
;0 /min,RPM,
39,2,,,
39,3,,,
39,4,,,
;4.7 %,Lambda,
40,0,,
40,1,,,
;0 /min,RPM,
40,2,,,
;4.7 %,Lambda,
40,3,,,
;4.7 %,Lambda,
40,4,,,
;4.7 %,Lambda,
41,0,,
41,1,,,
;4.7,Ohms,
41,2,,,
;0.000 V,Voltage,
41,3,,,
;1.7 %,Lambda,
41,4,,,
;1.0,(no units),
42,0,,
42,1,,,
;1.7 %,Lambda,
42,2,,,
;1.6 %,Lambda,
42,3,,,
;3.300 V,Voltage,
42,4,,,
;25.40,(no units),
43,0,,
43,1,,,
;0.0,(no units),
43,2,,,
;18.0°C,Temperature,
43,3,,,
;0.0 mbar,Absolute Pres.,
43,4,,,
;0.000 V,Voltage,
44,0,,
44,1,,,
;0 /min,RPM,
44,2,,,
;11001000,Bin. Bits,
44,3,,,
;0.0,(no units),
44,4,,,
;0.0,(no units),
45,0,,
45,1,,,
;53.1°C,Temperature,
45,2,,,
;0.0 %,Duty Cycle,
45,3,,,
;9.4 %,Lambda,
45,4,,,
;9.4 %,Lambda,
46,0,,
46,1,,,
46,2,,,
;19.8°C,Temperature,
46,3,,,
;00000001,Bin. Bits,
46,4,,,
47,0,,
47,1,,,
;94.5°C,Temperature,
47,2,,,
;38.7°C,Temperature,
47,3,,,
;0.0 %,Duty Cycle,
47,4,,,
;9.4 %,Lambda,
48,0,,
48,1,,,
;0 /min,RPM,
48,2,,,
;0 /min,RPM,
48,3,,,
;       0,Bin. Bits,
48,4,,,
;1270.0 Nm,Torque,
51,0,,
51,1,,,
;0 /min,RPM,
51,2,,,
;0 /min,RPM,
51,3,,,
;1.0,(no units),
51,4,,,
52,0,,
52,1,,,
;0 /min,RPM,
52,2,,,
;0.0,(no units),
52,3,,,
;0.0,(no units),
52,4,,,
53,0,,
53,1,,,
53,2,,,
53,3,,,
53,4,,,
57,0,,
57,1,,,
;0 /min,RPM,
57,2,,,
;0.0 km/h,Speed,
57,3,,,
;0.0 %,Duty Cycle,
57,4,,,
;0.0 %,Duty Cycle,
58,0,,
58,1,,,
;0 /min,RPM,
58,2,,,
;0.0 km/h,Speed,
58,3,,,
;100.6 %,Duty Cycle,
58,4,,,
59,0,,
59,1,,,
;0 /min,RPM,
59,2,,,
;-195.0 Nm,Torque,
59,3,,,
;39.0 Nm,Torque,
59,4,,,
;0.0 Nm,Torque,
60,0,,
60,1,,,
;39.0 Nm,Torque,
60,2,,,
;-42.9 Nm,Torque,
60,3,,,
;0.0 Nm,Torque,
60,4,,,
;0.0,(no units),
61,0,,
61,1,,,
;0 /min,RPM,
61,2,,,
61,3,,,
;39.0,(no units),
61,4,,,
;-0.51,(no units),
62,0,,
62,1,,,
;0 /min,RPM,
62,2,,,
62,3,,,
;0.0,(no units),
62,4,,,
;0.0,(no units),
70,0,,
70,1,,,
;178.0,(no units),
70,2,,,
;178.0,(no units),
70,3,,,
;178.0,(no units),
70,4,,,
71,0,,
71,1,,,
;11110111,Bin. Bits,
71,2,,,
;00111111,Bin. Bits,
71,3,,,
71,4,,,
72,0,,
72,1,,,
;-9.0 ms,Time Corr.,
72,2,,,
;1.0 ms,Time Corr.,
72,3,,,
;-10.0 ms,Time Corr.,
72,4,,,
73,0,,
73,1,,,
;18.0 ms,Time Corr.,
73,2,,,
;4.0 ms,Time Corr.,
73,3,,,
73,4,,,
74,0,,
74,1,,,
;-4.0 ms,Time Corr.,
74,2,,,
;1.0 ms,Time Corr.,
74,3,,,
74,4,,,
75,0,,
75,1,,,
;-5.0 ms,Time Corr.,
75,2,,,
;-1.0 ms,Time Corr.,
75,3,,,
;-7.0 ms,Time Corr.,
75,4,,,
76,0,,
76,1,,,
;-12.0 ms,Time Corr.,
76,2,,,
;-6.0 ms,Time Corr.,
76,3,,,
;-15.0 ms,Time Corr.,
76,4,,,
77,0,,
77,1,,,
;-17.0 ms,Time Corr.,
77,2,,,
;-8.0 ms,Time Corr.,
77,3,,,
;-16.0 ms,Time Corr.,
77,4,,,
80,0,,
80,1,,,
;BPG-810 29.04.10 31H04--- 1328 0001, ,
81,0,,
81,1,,,
;WA1LMAFEXAD008198                <>     , ,
82,0,,
82,1,,,
;9999944409228 20.07.12 <>  <>   <>  <>  , ,
85,0,,
85,1,,,
;143090 km,Mileage,
85,2,,,
;70.0,(no units),
85,3,,,
;1626.0,(no units),
85,4,,,
;5022.0,(no units),
86,0,,
86,1,,,
;11111111,Bin. Bits,
86,2,,,
86,3,,,
86,4,,,
87,0,,
87,1,,,
87,2,,,
87,3,,,
87,4,,,
89,0,,
89,1,,,
89,2,,,
;00001111,Bin. Bits,
89,3,,,
;11101011,Bin. Bits,
89,4,,,
;01100001,Bin. Bits,
90,0,,
90,1,,,
;0 /min,RPM,
90,2,,,
90,3,,,
;1286.6 mg/str,Mass Air / Rev.,
90,4,,,
91,0,,
91,1,,,
;127.0,(no units),
91,2,,,
;-128.0,(no units),
91,3,,,
91,4,,,
;127.0,(no units),
93,0,,
93,1,,,
93,2,,,
;1.89,(no units),
93,3,,,
;0.0,(no units),
93,4,,,
;0.0,(no units),
94,0,,
94,1,,,
;01011001,Bin. Bits,
94,2,,,
94,3,,,
94,4,,,
95,0,,
95,1,,,
;       0,Bin. Bits,
95,2,,,
; 001   1,Bin. Bits,
95,3,,,
;00011110,Bin. Bits,
95,4,,,
;      10,Bin. Bits,
96,0,,
96,1,,,
;       0,Bin. Bits,
96,2,,,
96,3,,,
96,4,,,
;12.08 V,Voltage,
97,0,,
97,1,,,
;0 mbar,Pressure,
97,2,,,
;0 mbar,Pressure,
97,3,,,
97,4,,,
98,0,,
98,1,,,
;52.2°C,Temperature,
98,2,,,
98,3,,,
;0.0 %,Lambda,
98,4,,,
;70.8°C,Temperature,
99,0,,
99,1,,,
;0 /min,RPM,
99,2,,,
99,3,,,
;-277.3°C,Temperature,
99,4,,,
;35.4°C,Temperature,
100,0,,
100,1,,,
;0 /min,RPM,
100,2,,,
;41.3°C,Temperature,
100,3,,,
;0.0,(no units),
100,4,,,
;       0,Bin. Bits,
101,0,,
101,1,,,
101,2,,,
101,3,,,
101,4,,,
102,0,,
102,1,,,
102,2,,,
102,3,,,
;0 mbar,Pressure,
102,4,,,
;0 mbar,Pressure,
103,0,,
103,1,,,
103,2,,,
;00010000,Bin. Bits,
103,3,,,
;     000,Bin. Bits,
103,4,,,
;      00,Bin. Bits,
104,0,,
104,1,,,
;0.20,(no units),
104,2,,,
;22.0,(no units),
104,3,,,
;1.0,(no units),
104,4,,,
;740 km,Mileage,
105,0,,
105,1,,,
;0.0,(no units),
105,2,,,
;3.0,(no units),
105,3,,,
;14.0,(no units),
105,4,,,
;71.0 l,Tank Cont.,
106,0,,
106,1,,,
106,2,,,
106,3,,,
106,4,,,
107,0,,
107,1,,,
;52.0,(no units),
107,2,,,
;34.5,(no units),
107,3,,,
;24.0,(no units),
107,4,,,
;0.0,(no units),
109,0,,
109,1,,,
109,2,,,
;354.0°C,Temperature,
109,3,,,
109,4,,,
110,0,,
110,1,,,
110,2,,,
;00000110,Bin. Bits,
110,3,,,
;0.0 km/h,Speed,
110,4,,,
111,0,,
111,1,,,
;0 /min,RPM,
111,2,,,
;0.0 km/h,Speed,
111,3,,,
;0.00,(no units),
111,4,,,
;0.0,(no units),
112,0,,
112,1,,,
;0.00,(no units),
112,2,,,
;-700.0 Nm,Torque,
112,3,,,
;-1280.0 Nm,Torque,
112,4,,,
;0.0 Nm,Torque,
113,0,,
113,1,,,
113,2,,,
113,3,,,
113,4,,,
114,0,,
114,1,,,
;255.0,(no units),
114,2,,,
;255.0,(no units),
114,3,,,
;0.00,(no units),
114,4,,,
;0.00,(no units),
120,0,,
120,1,,,
;126.0,(no units),
120,2,,,
120,3,,,
120,4,,,
;2.440 V,Voltage,
121,0,,
121,1,,,
;-1.6 %,Lambda,
121,2,,,
;4.7 %,Lambda,
121,3,,,
121,4,,,
;0.860 V,Voltage,
122,0,,
122,1,,,
;3.1 %,Lambda,
122,2,,,
;0.8 %,Lambda,
122,3,,,
122,4,,,
;0.960 V,Voltage,
123,0,,
123,1,,,
;-0.0 %,Lambda,
123,2,,,
123,3,,,
;00000010,Bin. Bits,
123,4,,,
;3.920 V,Voltage,
124,0,,
124,1,,,
124,2,,,
124,3,,,
124,4,,,
;2.680 V,Voltage,
125,0,,
125,1,,,
;Transm. 1, ,
125,2,,,
;ABS 1, ,
125,3,,,
;Instruments 1, ,
125,4,,,
;Airbag 1, ,
126,0,,
126,1,,,
;HVAC 1, ,
126,2,,,
126,3,,,
126,4,,,
127,0,,
127,1,,,
127,2,,,
127,3,,,
;El.Ign.Lock 1, ,
127,4,,,
;St. Wheel 1, ,
128,0,,
128,1,,,
;Gateway 1, ,
128,2,,,
128,3,,,
;Steer. ang. 1, ,
128,4,,,
129,0,,
129,1,,,
129,2,,,
129,3,,,
;NOx-S1 1, ,
129,4,,,
;NOx-S2 1, ,
133,0,,
133,1,,,
;1.00,(no units),
133,2,,,
;1.00,(no units),
133,3,,,
;1.00,(no units),
133,4,,,
;1.00,(no units),
135,0,,
135,1,,,
;72.2 %,Load,
135,2,,,
;37.8°C,Temperature,
135,3,,,
;62.1°C,Temperature,
135,4,,,
140,0,,
140,1,,,
;0.0 Nm,Torque,
140,2,,,
;0.0 Nm,Torque,
140,3,,,
140,4,,,
141,0,,
141,1,,,
;0.0 bar,Absolute Pres.,
141,2,,,
141,3,,,
141,4,,,
142,0,,
142,1,,,
;0.00,(no units),
142,2,,,
;0.00,(no units),
142,3,,,
142,4,,,
143,0,,
143,1,,,
;0.0°,Steering Angle,
143,2,,,
143,3,,,
143,4,,,
144,0,,
144,1,,,
144,2,,,
144,3,,,
144,4,,,
145,0,,
145,1,,,
;361.4 °,Angle,
145,2,,,
;361.4 °,Angle,
145,3,,,
145,4,,,
146,0,,
146,1,,,
;0.20,(no units),
146,2,,,
;-4.90,(no units),
146,3,,,
146,4,,,
147,0,,
147,1,,,
147,2,,,
147,3,,,
147,4,,,
148,0,,
148,1,,,
148,2,,,
148,3,,,
148,4,,,
150,0,,
150,1,,,
;10000011,Bin. Bits,
150,2,,,
;01001101,Bin. Bits,
150,3,,,
;01100011,Bin. Bits,
150,4,,,
151,0,,
151,1,,,
;2520 /min,RPM,
151,2,,,
151,3,,,
;15.0 mg/str,Inj. Quantity,
151,4,,,
166,0,,
166,1,,,
;1.05,(no units),
166,2,,,
;1.04,(no units),
166,3,,,
;1.03,(no units),
166,4,,,
;1.05,(no units),
167,0,,
167,1,,,
;1.05,(no units),
167,2,,,
;1.05,(no units),
167,3,,,
167,4,,,
169,0,,
169,1,,,
;0 /min,RPM,
169,2,,,
;4.7 %,Duty Cycle,
169,3,,,
;-90.6 %,Lambda,
169,4,,,
;4.7 %,Lambda,
170,0,,
170,1,,,
;88.2 %,Load,
170,2,,,
170,3,,,
;0.0 %,Load,
170,4,,,
;0.0 bar, ,
172,0,,
172,1,,,
;       0,Bin. Bits,
172,2,,,
;       0,Bin. Bits,
172,3,,,
;22.5°C,Temperature,
172,4,,,
;1.860 V,Voltage,
174,0,,
174,1,,,
;00000011,Bin. Bits,
174,2,,,
;       0,Bin. Bits,
174,3,,,
;0.0,(no units),
174,4,,,
;0.0,(no units),
175,0,,
175,1,,,
;0.3,Ohms,
175,2,,,
;0.000 A,Current,
175,3,,,
;0.000 A,Current,
175,4,,,
;54.0°C,Temperature,
176,0,,
176,1,,,
;0 ppm, ,
176,2,,,
;0.000 V,Voltage,
176,3,,,
;0.00,(no units),
176,4,,,
177,0,,
177,1,,,
;0 ppm, ,
177,2,,,
;0.000 V,Voltage,
177,3,,,
;0.00,(no units),
177,4,,,
178,0,,
178,1,,,
;5100 km,Mileage,
178,2,,,
;10.0,(no units),
178,3,,,
178,4,,,
179,0,,
179,1,,,
;120.0 kg,Mass/Weight,
179,2,,,
179,3,,,
179,4,,,
180,0,,
180,1,,,
180,2,,,
;0 ppm, ,
180,3,,,
180,4,,,
181,0,,
181,1,,,
;0.0,(no units),
181,2,,,
;0.0,(no units),
181,3,,,
;0.0,(no units),
181,4,,,
182,0,,
182,1,,,
182,2,,,
182,3,,,
;0.0,(no units),
182,4,,,
183,0,,
183,1,,,
;0.86,(no units),
183,2,,,
183,3,,,
183,4,,,
186,0,,
186,1,,,
;0.980 V,Voltage,
186,2,,,
;109.8 s,Time,
186,3,,,
;0.700 V,Voltage,
186,4,,,
;0.0 s,Time,
187,0,,
187,1,,,
;    0 01,Bin. Bits,
187,2,,,
;0.0 s,Time,
187,3,,,
;0.0 s,Time,
187,4,,,
;0.0 s,Time,
188,0,,
188,1,,,
;    0 10,Bin. Bits,
188,2,,,
;39.9 s,Time,
188,3,,,
;59.9 s,Time,
188,4,,,
200,0,,
200,1,,,
;0.0,(no units),
200,2,,,
;0.0,(no units),
200,3,,,
;0.0,(no units),
200,4,,,
201,0,,
201,1,,,
;0.0,(no units),
201,2,,,
;0.0,(no units),
201,3,,,
;0.0,(no units),
201,4,,,
202,0,,
202,1,,,
;0 /min,RPM,
202,2,,,
;0.0,(no units),
202,3,,,
;    0   ,Bin. Bits,
202,4,,,
;   1    ,Bin. Bits,
203,0,,
203,1,,,
203,2,,,
203,3,,,
;0.00,(no units),
203,4,,,
;0.0 Nm,Torque,
204,0,,
204,1,,,
;-330.0 Nm,Torque,
204,2,,,
;0.0 Nm,Torque,
204,3,,,
204,4,,,
205,0,,
205,1,,,
;70.0,(no units),
205,2,,,
;-0.01,(no units),
205,3,,,
205,4,,,
206,0,,
206,1,,,
206,2,,,
;1250 km,Mileage,
206,3,,,
206,4,,,
207,0,,
207,1,,,
;0.99,(no units),
207,2,,,
207,3,,,
207,4,,,
208,0,,
208,1,,,
208,2,,,
208,3,,,
208,4,,,
218,0,,
218,1,,,
218,2,,,
;0 km,Mileage,
218,3,,,
;0.0,(no units),
218,4,,,
;0.0,(no units),
219,0,,
219,1,,,
219,2,,,
219,3,,,
;0.0 km/h,Speed,
219,4,,,
;0.0 km/h,Speed,
220,0,,
220,1,,,
;0.0,(no units),
220,2,,,
220,3,,,
220,4,,,
225,0,,
225,1,,,
;0.0,(no units),
225,2,,,
;0.0,(no units),
225,3,,,
;0.0,(no units),
225,4,,,
;0.0,(no units),
226,0,,
226,1,,,
;0.0,(no units),
226,2,,,
226,3,,,
;0.0,(no units),
226,4,,,
;0.0,(no units),
227,0,,
227,1,,,
;0.0,(no units),
227,2,,,
;0.0,(no units),
227,3,,,
;0.0,(no units),
227,4,,,
;0.0,(no units),
228,0,,
228,1,,,
;0.0,(no units),
228,2,,,
;0.0,(no units),
228,3,,,
;0.0,(no units),
228,4,,,
;0.0,(no units),
229,0,,
229,1,,,
229,2,,,
229,3,,,
;0.0,(no units),
229,4,,,
;0.0,(no units),
The Adaptation Map File before doing anything:
;Wednesday,12,November,2014,19:53:16:32095
;01 N/A
;02 N/A
;03 N/A
;04 N/A
;05 N/A
A06,0,
;20
A06,1,
;0.00
A06,2,
A06,3,
;-1280.0 Nm
A06,4,
;0.0 Nm
;07 N/A
;08 N/A
;09 N/A
;10 N/A
;11 N/A
;12 N/A
A13,0,
;0
A13,1,
;0.00
A13,2,
;0.0°
A13,3,
;361.4 °
A13,4,
;0.0°
A14,0,
;0
A14,1,
A14,2,
A14,3,
A14,4,
;15 N/A
;16 N/A
;17 N/A
;18 N/A
;19 N/A
;20 N/A
;21 N/A
A22,0,
;1
A22,1,
A22,2,
A22,3,
A22,4,
A23,0,
;0
A23,1,
A23,2,
A23,3,
A23,4,
A24,0,
;0
A24,1,
A24,2,
A24,3,
A24,4,
A25,0,
;0
A25,1,
;0.0 Nm
A25,2,
A25,3,
A25,4,
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
A40,0,
;86
A40,1,
;0.86
A40,2,
A40,3,
A40,4,
;41 N/A
A42,0,
;0
A42,1,
;0.00
A42,2,
;0.0°
A42,3,
;361.4 °
A42,4,
;0.0°
;43 N/A
;44 N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
A50,0,
A50,1,
;ERROR:
A50,2,
;Security
A50,3,
;access
A50,4,
;required
;51 N/A
;52 N/A
;53 N/A
A54,0,
;4
A54,1,
;00010000
A54,2,
;64.77
A54,3,
;39.0
A54,4,
;00000000
A55,0,
;0
A55,1,
A55,2,
A55,3,
A55,4,
A56,0,
;25
A56,1,
;1.00
A56,2,
;       0
A56,3,
A56,4,
A57,0,
;0000FFFF
A57,1,
;00000000
A57,2,
A57,3,
A57,4,
;00000000
A58,0,
;32767
A58,1,
A58,2,
A58,3,
A58,4,
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
A66,0,
;0
A66,1,
;0.0
A66,2,
A66,3,
A66,4,
;67 N/A
;68 N/A
;69 N/A
;70 N/A
A71,0,
;8SALFNF
A71,1,
A71,2,
A71,3,
A71,4,
A72,0,
;8SA1ENF
A72,1,
A72,2,
A72,3,
A72,4,
A73,0,
;8SAIDEF
A73,1,
A73,2,
A73,3,
A73,4,
A74,0,
;8SAUBWF
A74,1,
A74,2,
A74,3,
A74,4,
A75,0,
;ASA1E5F
A75,1,
A75,2,
A75,3,
A75,4,
A76,0,
;8IIB7NF
A76,1,
A76,2,
A76,3,
A76,4,
;77 N/A
;78 N/A
;79 N/A
A80,0,
;3
A80,1,
A80,2,
;00010001
A80,3,
;0.0
A80,4,
;0.0 %
A81,0,
;0
A81,1,
;0.00
A81,2,
;0.0°
A81,3,
;361.4 °
A81,4,
;0.0°
A82,0,
;0
A82,1,
;0.00
A82,2,
;0.0°
A82,3,
;361.4 °
A82,4,
;0.0°
A83,0,
;0
A83,1,
A83,2,
A83,3,
A83,4,
A84,0,
;0
A84,1,
A84,2,
A84,3,
A84,4,
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
A91,0,
;4
A91,1,
A91,2,
A91,3,
A91,4,
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
;98 N/A
A99,0,
;0
A99,1,
;0.00 ms
A99,2,
;00000000
A99,3,
A99,4,
;00000000
;100 N/A
;101 N/A
;102 N/A
A103,0,
;2767
A103,1,
A103,2,
A103,3,
A103,4,
;104 N/A
;105 N/A
A106,0,
;0
A106,1,
A106,2,
A106,3,
A106,4,
;107 N/A
A108,0,
;0
A108,1,
A108,2,
A108,3,
A108,4,
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
A117,0,
;0
A117,1,
A117,2,
A117,3,
A117,4,
;118 N/A
;119 N/A
A120,0,
;0
A120,1,
;1.00
A120,2,
;1.00
A120,3,
;1.00
A120,4,
;120.0 kg
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
The Readiness File;
Wednesday,12,November,2014,20:49:43:32095
VIN:    License Plate: TQNC
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Failed or Incomplete
Heated catalyst monitoring:  Passed
Evaporative system monitoring: Not installed.
Secondary air system monitoring:  Passed
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Failed or Incomplete
Oxygen sensor heater monitoring:  Failed or Incomplete
Exhaust Gas Recirculation:  Passed
Log File for Bank 1 Sensor 1 status (think this is the O2 Sensor), Cat Temp, DPF deltaP and NOx;
Wednesday,12,November,2014,20:55:55:32095
Wednesday,12,November,2014,20:55:49
VCDS Release 14.10.0 (x64):  Generic OBD2
Mode 1:Read Data
36:Bank 1 Sensor 1 Status     0.214 Lambda  0.841 V
60:B1S1 Cat. Temp.     137.7 °C
122:DPF Bank 1 Delta/In/Out     0.50/---/--- kPa
131:NOx Sensor Bank 1/2     NOx11:303 ppm  NOx21:65535 ppm
Now the fun,
Module 01 Long Adaptation Channel 80
Stored Value 3
Any New Value (1, 0001, 2, 0002, 4, 0004, 5, 0005) Test button generally does not become active, test value changes to 4 then back to 3
New Value of 4 Test Value momentarily changes to 4 Test button is not active, but Save button is active (short lived). Select Save, warning comes up asking about changing the value to 4, at the same time Test value changes back to 3, select OK and re-read channel, value still at 3.
Didn't try pulling the fuse etc. since 1) AdBlue warning is currently off (after adding ~1gal of urea), Channel 80 already showing a value of 3 and can't seem to change value period.
Inspecting the main AdBlue tank can't see any leakage any bad or broken connects, etc. Tanks exterior is very clean.
My understanding of the system is the small tank on top of the wheel well is the active tank. Injection pump is connected to this tank as well as level indication for the AdBlue low warning. Main tank stores bulk of AdBlue and pumps urea up to active tank. is it possible the transfer pump isn't working properly? The main tank is almost full (which is why I can only add enough urea to fill the active tank (or so it seems). As the urea is consumed from the active tank it is not replenished from the main tank, hence the short duration between AdBlue warnings. Any thoughts or troubleshooting tips around this theory? Would the bad transfer pump be the reason I can't change the value in channel 80?
If I had any hair left I would be pulling it out........
Any thoughts or help anyone can provide is greatly appreciated.
barbarmi
C?ID=217814
Thanks for sending the maps!
I have 2 suggestions and the first would be easier:
1) Per the PLA file Adaptation Channel 080 reads:
I realize a single 1 was not accepted but please try to save a new value of 0001 (or some variant of that with preceding zeros).
The 2009/2010 VW Touareg 3.0L EDC17 reports a value of 0004 after 0001 is accepted so please let us know what happens if this controller allows you to save at all.​
Also, take a look at MVB 174 to see if it changes at all, perhaps from 00000011 -to- 00000100 after the Long Adaptation modification.​
Couldn't get the controller to take any values, currently A80;0 reports 3 and nothing will change that value. The MVB 174 data does not change either
This has fixed several Audi vehicles with our phone based support services but I'm not aware of an official Audi TSB or Tech Tip so I'd consider it experimental at best. This involves removing a fuse for the AdBlue system (Reducing Agent system components) and those vary based on the vehicle and production date. Official Factory Repair Information can be obtained by using the appropriate erWin website.
In this particular case the NAR Q7 CCMA and CATA engines codes through May 2010 production happen to use Fuse S17 for the components in question:
Reducing Agent Metering System Pressure Sensor G686
Reducing Agent Pump V437
Reducing Agent Pump Heater Z103
The VW Touareg used an entirely different fuse and the June 2010+ Q7 does as well
Went through the entire procedure and recorded AutoScan and Controller Adpatation and Measure Block Maps at:
1) Pre-Test
Autoscan
Sunday,16,November,2014,14:37:03:32095
Mileage: 143270km-89023mi   Repair Order: pre-test
VIN: WA1LMAFEXAD008198   Mileage: 143270km-89023miles
Address 01: Engine (CAT)       Labels: None
                    Fault Frequency: 17
                    Mileage: 143003 km
                    Date: 2014.11.12
                    Time: 10:02:33
                    RPM: 2289 /min
                    Speed: 31.4 km/h
                    Bin. Bits: 00001000
                    (no units): -12.80
                    Angle: 361.4 °
                    (no units): 0.20
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Coding: 0001016
Address 03: ABS Brakes        Labels: 4L0-910-517-V2.clb
   Revision: 00H30001
   Coding: 0099473
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Coding: 0000131
   Coding: 022036
   Coding: 0039123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Revision: AA001001
   Coding: 0014131
   Coding: 0002042
Address 17: Instruments (J285)       Labels: 4L0-920-xxx-17.clb
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Coding: 000303
   Coding: 0000006
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Coding: 3569693
                    Reset counter: 160
                    Mileage: 124054 km
                    Date: 2014.03.22
                    Time: 13:07:03
Address 47: Sound System (J525)       Labels: Redir Fail!
   Coding: 0D000000
                    Mileage: 65 km
                    Date: 2010.07.28
                    Time: 17:58:35
                    Bin. Bits: 00001000
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Coding: 0696013
   Coding: 0012001
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Coding: 0000007
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
Address 69: Trailer (J345)       Labels: 4E0-907-383.clb
   Revision: 2A001001    Serial number: 00000129414550
   Coding: 0200000000000000
   Coding: 1021201
Address 6D: Trunk Elect.        Labels: None
Address 6F: Centr. Conv. II        Labels: 4L0-910-290.lbl
   Coding: 0003595
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Coding: 0231266
MVB file:
;Component:3.0TDI EDC17G004AG  0080	 Coding:0121002A190F0968
;Sunday	16	November	2014	14:39:13:32095
Group	Field 1	Data type	Field 2	Data type	Field 3	Data type	Field 4	Data type
1	0 /min	RPM	0.0 mg/str	Inj. Quantity	8.6 bar	Pressure	29.7°C	Temperature
2	0 /min	RPM	0.00%	Load	 0 01  0	Bin. Bits	29.7°C	Temperature
3	0 /min	RPM	1457.0 mg/str	Mass Air / Rev.	0.0 mg/str	Mass Air / Rev.	99.60%	Duty Cycle
4	0 /min	RPM	0.0 °BTDC	Ign. Timing	0.00 ms	Time	8.6 bar	Pressure
5	0 /min	RPM	0.0 mg/str	Inj. Quantity	1	(no units)	29.7°C	Temperature
6	0.0 km/h	Speed	101100	Bin. Bits	0.0 km/h	Speed	10000001	Bin. Bits
7	22.5°C	Temperature	28.8°C	Temperature	23.4°C	Temperature	29.7°C	Temperature
8	0 /min	RPM	0.0 Nm	Torque	356.0 Nm	Torque	799.5 Nm	Torque
9	0 /min	RPM	-1280.0 Nm	Torque	799.5 Nm	Torque	0.0 Nm	Torque
10	0.0 mg/str	Mass Air / Rev.	1009.8 mbar	Absolute Pres.	999.6 mbar	Absolute Pres.	0.00%	Load
11	0 /min	RPM	989.4 mbar	Absolute Pres.	999.6 mbar	Absolute Pres.	49.60%	Duty Cycle
12	1010000	Bin. Bits	0.90 s	Time	11.48 V	Voltage	29.7°C	Temperature
13	0.00 mg/str	Inj. Quantity	0.00 mg/str	Inj. Quantity	0.00 mg/str	Inj. Quantity
14	0.00 mg/str	Inj. Quantity	0.00 mg/str	Inj. Quantity	0.00 mg/str	Inj. Quantity
15	0 /min	RPM	-195.0 Nm	Torque	0.00 l/h	Fuel Consump.	0.0 Nm	Torque
16	0	(no units)	 	 	0	(no units)	0.00%	Lambda
18	0 /min	RPM	22.5°C	Temperature	0	(no units)
19	0 /min	RPM	308.55	(no units)	0.0 bar	Pressure	1696	(no units)
20	0 /min	RPM	292.4 bar	Pressure	8.6 bar	Pressure	7.80%	Lambda
21	0 /min	RPM	292.4 bar	Pressure	8.6 bar	Pressure	16.40%	Lambda
22	0 /min	RPM	100	Bin. Bits	0	Bin. Bits	110100	Bin. Bits
23	0 /min	RPM	0.0 °BTDC	Ign. Timing	0.00 ms	Time	3	(no units)
24	0 /min	RPM	0.0 °BTDC	Ign. Timing	0.00 ms	Time	8.6 bar	Pressure
25	0 /min	RPM	0.0 °BTDC	Ign. Timing	0.00 ms	Time	8.6 bar	Pressure
26	0 /min	RPM	0.0 °BTDC	Ign. Timing	0.00 ms	Time	8.6 bar	Pressure
28	0 /min	RPM	0.0 °BTDC	Ign. Timing	0.00 ms	Time	8.6 bar	Pressure
29	0 /min	RPM	0.0 °BTDC	Ign. Timing	0.00 ms	Time	8.6 bar	Pressure
30	0.720 V	Voltage	0.360 V	Voltage	 0 01  0	Bin. Bits	0.00%	Load
31	EFD5	Voltage
32	0 /min	RPM	1	(no units)	606.0°	Steering Angle	690.0°	Steering Angle
33	0 /min	RPM	29.5°C	Temperature	1	(no units)	1	(no units)
34	0 /min	RPM	49.20%	Lambda	49.20%	Lambda	0.00%	Lambda
35	0 /min	RPM	1457.0 mg/str	Mass Air / Rev.	0.0 mg/str	Mass Air / Rev.	99.60%	Duty Cycle
36	0 /min	RPM	6.30%	Lambda	0.80%	Lambda	0.00%	Lambda
37	0 /min	RPM	7.00%	Lambda	0.80%	Lambda	0.00%	Lambda
38	0 /min	RPM	99.60%	Duty Cycle	-0.80%	Lambda	0.00%	Lambda
39	0 /min	RPM	0.0 mg/str	Mass Air / Rev.	22.5°C	Temperature	4.70%	Lambda
40	0 /min	RPM	4.70%	Lambda	4.70%	Lambda	4.70%	Lambda
41	4.7	Ohms	0.000 V	Voltage	1.60%	Lambda	1	(no units)
42	1.60%	Lambda	2.40%	Lambda	3.300 V	Voltage	25.4	(no units)
43	0	(no units)	16.2°C	Temperature	0.0 mbar	Absolute Pres.	0.000 V	Voltage
44	0 /min	RPM	11001000	Bin. Bits	0	(no units)	0	(no units)
45	29.7°C	Temperature	0.00%	Duty Cycle	9.40%	Lambda	9.40%	Lambda
46	16.2°C	Temperature	19.8°C	Temperature	1	Bin. Bits	1	Bin. Bits
47	94.5°C	Temperature	18.9°C	Temperature	0.00%	Duty Cycle	9.40%	Lambda
48	0 /min	RPM	0 /min	RPM	0	Bin. Bits	1270.0 Nm	Torque
51	0 /min	RPM	0 /min	RPM	1	(no units)
52	0 /min	RPM	0	(no units)	0	(no units)
53	0	Bin. Bits	0	Bin. Bits	0	Bin. Bits	100	Bin. Bits
57	0 /min	RPM	0.0 km/h	Speed	0.00%	Duty Cycle	0.00%	Duty Cycle
58	0 /min	RPM	0.0 km/h	Speed	100.60%	Duty Cycle	100.60%	Duty Cycle
59	0 /min	RPM	-195.0 Nm	Torque	42.9 Nm	Torque	0.0 Nm	Torque
60	42.9 Nm	Torque	-46.8 Nm	Torque	0.0 Nm	Torque	0	(no units)
61	0 /min	RPM	28.8°C	Temperature	39	(no units)	64.77	(no units)
62	0 /min	RPM	0.0 mg/str	Inj. Quantity	0	(no units)	0	(no units)
70	178	(no units)	178	(no units)	179	(no units)
71	11110111	Bin. Bits	111111	Bin. Bits
72	-9.0 ms	Time Corr.	0.0 ms	Time Corr.	-10.0 ms	Time Corr.
73	18.0 ms	Time Corr.	5.0 ms	Time Corr.	-9.0 ms	Time Corr.
74	-4.0 ms	Time Corr.	1.0 ms	Time Corr.	-10.0 ms	Time Corr.
75	-5.0 ms	Time Corr.	-2.0 ms	Time Corr.	-7.0 ms	Time Corr.
76	-12.0 ms	Time Corr.	-6.0 ms	Time Corr.	-15.0 ms	Time Corr.
77	-17.0 ms	Time Corr.	-8.0 ms	Time Corr.	-16.0 ms	Time Corr.
80	BPG-810 29.04.10 31H04--- 1328 0001
81	WA1LMAFEXAD008198                <>
82	9999944409228 20.07.12 <>  <>   <>  <>
85	143270 km	Mileage	70	(no units)	1630	(no units)	5034	(no units)
86	11111111	Bin. Bits	11111111	Bin. Bits	11111111	Bin. Bits	11111111	Bin. Bits
87	11111111	Bin. Bits	11111111	Bin. Bits	11111111	Bin. Bits
89	0	Bin. Bits	1111	Bin. Bits	11101011	Bin. Bits	1100001	Bin. Bits
90	0 /min	RPM	0.0 mg/str	Inj. Quantity	1457.0 mg/str	Mass Air / Rev.	0	Bin. Bits
91	127	(no units)	-128	(no units)	1457.0 mg/str	Mass Air / Rev.	127	(no units)
93	0	Bin. Bits	1.89	(no units)	0	(no units)	0	(no units)
94	1011001	Bin. Bits
95	0	Bin. Bits	 001   1	Bin. Bits	11110	Bin. Bits	10	Bin. Bits
96	0	Bin. Bits	0	Bin. Bits	0	Bin. Bits	11.40 V	Voltage
97	0 mbar	Pressure	0 mbar	Pressure
98	29.7°C	Temperature	18.9°C	Temperature	0.00%	Lambda	35.4°C	Temperature
99	0 /min	RPM	29.5°C	Temperature	-277.3°C	Temperature	17.7°C	Temperature
100	0 /min	RPM	17.7°C	Temperature	0	(no units)	0	Bin. Bits
101	0	Bin. Bits	0	Bin. Bits	0	Bin. Bits	1	Bin. Bits
102	23.6°C	Temperature	17.7°C	Temperature	0 mbar	Pressure	0 mbar	Pressure
103	1	Bin. Bits	10000	Bin. Bits	0	Bin. Bits	0	Bin. Bits
104	0.2	(no units)	23	(no units)	1	(no units)	920 km	Mileage
105	0	(no units)	3	(no units)	17	(no units)	88.0 l	Tank Cont.
106	0	Bin. Bits	0	Bin. Bits	0	Bin. Bits	0	Bin. Bits
107	52	(no units)	34.5	(no units)	24	(no units)	0	(no units)
109	23.6°C	Temperature	354.0°C	Temperature	23.6°C	Temperature	17.7°C	Temperature
110	 	 	110	Bin. Bits	0.0 km/h	Speed
111	0 /min	RPM	0.0 km/h	Speed	0	(no units)	0	(no units)
112	0	(no units)	-730.0 Nm	Torque	-1280.0 Nm	Torque	0.0 Nm	Torque
113	110	Bin. Bits	0	Bin. Bits	0	Bin. Bits	0	Bin. Bits
114	255	(no units)	255	(no units)	0	(no units)	0	(no units)
120	225	(no units)	17.7°C	Temperature	100	Bin. Bits	2.440 V	Voltage
121	-2.30%	Lambda	5.50%	Lambda	100	Bin. Bits	0.840 V	Voltage
122	3.10%	Lambda	0.80%	Lambda	100	Bin. Bits	0.980 V	Voltage
123	0.00%	Lambda	100	Bin. Bits	10	Bin. Bits	3.940 V	Voltage
124	 	 	 	 	0	Bin. Bits	2.680 V	Voltage
125	Transm. 1	 	ABS 1	 	Instruments 1	 	Airbag 1
126	HVAC 1
127	 	 	 	 	El.Ign.Lock 1	 	St. Wheel 1
128	Gateway 1	 	 	 	Steer. ang. 1
129	 	 	 	 	NOx-S1 1	 	NOx-S2 1
133	1	(no units)	1	(no units)	1	(no units)	1	(no units)
135	72.20%	Load	27.9°C	Temperature	62.1°C	Temperature
140	0.0 Nm	Torque	0.0 Nm	Torque
141	0.0 bar	Absolute Pres.	0.0 bar	Absolute Pres.
142	0	(no units)	0	(no units)
143	0.0°	Steering Angle	0.0°	Steering Angle
144	0.0°	Steering Angle	0.0°	Steering Angle
145	361.4 °	Angle	361.4 °	Angle
146	0.2	(no units)	-4.9	(no units)
147	0	Bin. Bits	0	Bin. Bits
148	0	Bin. Bits	0	Bin. Bits
150	11010110	Bin. Bits	10001101	Bin. Bits	1100011	Bin. Bits	0	Bin. Bits
151	1302 /min	RPM	-0.39 mg/str	Inj. Quantity	10.0 mg/str	Inj. Quantity
166	1.05	(no units)	1.04	(no units)	1.03	(no units)	1.05	(no units)
167	1.05	(no units)	1.05	(no units)
169	0 /min	RPM	4.70%	Duty Cycle	-90.60%	Lambda	4.70%	Lambda
170	88.20%	Load	 	 	0.00%	Load	0.0 bar
172	0	Bin. Bits	0	Bin. Bits	15.3°C	Temperature	1.860 V	Voltage
174	11	Bin. Bits	0	Bin. Bits	0	(no units)	0	(no units)
175	0.3	Ohms	0.000 A	Current	0.000 A	Current	18.0°C	Temperature
176	0 ppm	 	0.000 V	Voltage	0	(no units)
177	0 ppm	 	0.000 V	Voltage	0	(no units)
178	5100 km	Mileage	10	(no units)
179	121.0 kg	Mass/Weight
180	 	 	0 ppm
181	0	(no units)	0	(no units)	0	(no units)
182	 	 	 	 	0	(no units)
183	0.94	(no units)
186	0.980 V	Voltage	109.8 s	Time	0.880 V	Voltage	0.0 s	Time
187	    0 01	Bin. Bits	0.0 s	Time	0.0 s	Time	0.0 s	Time
188	    0 10	Bin. Bits	49.9 s	Time	59.9 s	Time
200	0	(no units)	0	(no units)	0	(no units)
201	0	(no units)	0	(no units)	0	(no units)
202	0 /min	RPM	0	(no units)	0	Bin. Bits	1	Bin. Bits
203	0	Bin. Bits	0	Bin. Bits	0	(no units)	0.0 Nm	Torque
204	-330.0 Nm	Torque	0.0 Nm	Torque	0	Bin. Bits
205	70	(no units)	-0.01	(no units)
206	0	Bin. Bits	1250 km	Mileage	0	Bin. Bits
207	0.99	(no units)
208	0	Bin. Bits
218	 	 	0 km	Mileage	0	(no units)	0	(no units)
219	-277.3°C	Temperature	-277.3°C	Temperature	0.0 km/h	Speed	0.0 km/h	Speed
220	0	(no units)
225	0	(no units)	0	(no units)	0	(no units)	0	(no units)
226	0	(no units)	 	 	0	(no units)	0	(no units)
227	0	(no units)	0	(no units)	0	(no units)	0	(no units)
228	0	(no units)	0	(no units)	0	(no units)	0	(no units)
229	 	 	 	 	0	(no units)	0	(no units)
Adaptation File
;Sunday	16	November	2014	14:39:46:32095
Channel		Field 1	Field 2	Field 3	Field 4
1		ERROR:	Channel 01	Not	Available
2		ERROR:	Channel 02	Not	Available
3		ERROR:	Channel 03	Not	Available
4		ERROR:	Channel 04	Not	Available
5		ERROR:	Channel 05	Not	Available
6	20	0	 	-1280.0 Nm	0.0 Nm
7		ERROR:	Channel 07	Not	Available
8		ERROR:	Channel 08	Not	Available
9		ERROR:	Channel 09	Not	Available
10		ERROR:	Channel 10	Not	Available
11		ERROR:	Channel 11	Not	Available
12		ERROR:	Channel 12	Not	Available
13	0	0	0.0°	361.4 °	0.0°
14	0
15		ERROR:	Channel 15	Not	Available
16		ERROR:	Channel 16	Not	Available
17		ERROR:	Channel 17	Not	Available
18		ERROR:	Channel 18	Not	Available
19		ERROR:	Channel 19	Not	Available
20		ERROR:	Channel 20	Not	Available
21		ERROR:	Channel 21	Not	Available
22	1
23	0
24	0
25	0	0.0 Nm
26		ERROR:	Channel 26	Not	Available
27		ERROR:	Channel 27	Not	Available
28		ERROR:	Channel 28	Not	Available
29		ERROR:	Channel 29	Not	Available
30		ERROR:	Channel 30	Not	Available
31		ERROR:	Channel 31	Not	Available
32		ERROR:	Channel 32	Not	Available
33		ERROR:	Channel 33	Not	Available
34		ERROR:	Channel 34	Not	Available
35		ERROR:	Channel 35	Not	Available
36		ERROR:	Channel 36	Not	Available
37		ERROR:	Channel 37	Not	Available
38		ERROR:	Channel 38	Not	Available
39		ERROR:	Channel 39	Not	Available
40	94	0.94
41		ERROR:	Channel 41	Not	Available
42	0	0	0.0°	361.4 °	0.0°
43		ERROR:	Channel 43	Not	Available
44		ERROR:	Channel 44	Not	Available
45		ERROR:	Channel 45	Not	Available
46		ERROR:	Channel 46	Not	Available
47		ERROR:	Channel 47	Not	Available
48		ERROR:	Channel 48	Not	Available
49		ERROR:	Channel 49	Not	Available
50		ERROR:	Security	access	required
51		ERROR:	Channel 51	Not	Available
52		ERROR:	Channel 52	Not	Available
53		ERROR:	Channel 53	Not	Available
54	4	10000	64.77	39	0
55	0
56	25	1	0
57	0000FFFF	0	 	 	0
58	32767
59		ERROR:	Channel 59	Not	Available
60		ERROR:	Channel 60	Not	Available
61		ERROR:	Channel 61	Not	Available
62		ERROR:	Channel 62	Not	Available
63		ERROR:	Channel 63	Not	Available
64		ERROR:	Channel 64	Not	Available
65		ERROR:	Channel 65	Not	Available
66	0	0
67		ERROR:	Channel 67	Not	Available
68		ERROR:	Channel 68	Not	Available
69		ERROR:	Channel 69	Not	Available
70		ERROR:	Channel 70	Not	Available
71	8SALFNF
72	8SA1ENF
73	8SAIDEF
74	8SAUBWF
75	ASA1E5F
76	8IIB7NF
77		ERROR:	Channel 77	Not	Available
78		ERROR:	Channel 78	Not	Available
79		ERROR:	Channel 79	Not	Available
80	3	 	10001	0	0.00%
81	0	0	0.0°	361.4 °	0.0°
82	0	0	0.0°	361.4 °	0.0°
83	0
84	0
85		ERROR:	Channel 85	Not	Available
86		ERROR:	Channel 86	Not	Available
87		ERROR:	Channel 87	Not	Available
88		ERROR:	Channel 88	Not	Available
89		ERROR:	Channel 89	Not	Available
90		ERROR:	Channel 90	Not	Available
91	4
92		ERROR:	Channel 92	Not	Available
93		ERROR:	Channel 93	Not	Available
94		ERROR:	Channel 94	Not	Available
95		ERROR:	Channel 95	Not	Available
96		ERROR:	Channel 96	Not	Available
97		ERROR:	Channel 97	Not	Available
98		ERROR:	Channel 98	Not	Available
99	0	0.00 ms	0	 	0
100		ERROR:	Channel 100	Not	Available
101		ERROR:	Channel 101	Not	Available
102		ERROR:	Channel 102	Not	Available
103	2767
104		ERROR:	Channel 104	Not	Available
105		ERROR:	Channel 105	Not	Available
106	0
107		ERROR:	Channel 107	Not	Available
108	0
109		ERROR:	Channel 109	Not	Available
110		ERROR:	Channel 110	Not	Available
111		ERROR:	Channel 111	Not	Available
112		ERROR:	Channel 112	Not	Available
113		ERROR:	Channel 113	Not	Available
114		ERROR:	Channel 114	Not	Available
115		ERROR:	Channel 115	Not	Available
116		ERROR:	Channel 116	Not	Available
117	0
118		ERROR:	Channel 118	Not	Available
119		ERROR:	Channel 119	Not	Available
120	0	1	1	1	121.0 kg
121		ERROR:	Channel 121	Not	Available
122		ERROR:	Channel 122	Not	Available
123		ERROR:	Channel 123	Not	Available
124		ERROR:	Channel 124	Not	Available
125		ERROR:	Channel 125	Not	Available
126		ERROR:	Channel 126	Not	Available
127		ERROR:	Channel 127	Not	Available
128		ERROR:	Channel 128	Not	Available
129		ERROR:	Channel 129	Not	Available
130		ERROR:	Channel 130	Not	Available
131		ERROR:	Channel 131	Not	Available
132		ERROR:	Channel 132	Not	Available
133		ERROR:	Channel 133	Not	Available
134		ERROR:	Channel 134	Not	Available
135		ERROR:	Channel 135	Not	Available
136		ERROR:	Channel 136	Not	Available
137		ERROR:	Channel 137	Not	Available
138		ERROR:	Channel 138	Not	Available
139		ERROR:	Channel 139	Not	Available
140		ERROR:	Channel 140	Not	Available
141		ERROR:	Channel 141	Not	Available
142		ERROR:	Channel 142	Not	Available
143		ERROR:	Channel 143	Not	Available
144		ERROR:	Channel 144	Not	Available
145		ERROR:	Channel 145	Not	Available
146		ERROR:	Channel 146	Not	Available
147		ERROR:	Channel 147	Not	Available
148		ERROR:	Channel 148	Not	Available
149		ERROR:	Channel 149	Not	Available
150		ERROR:	Channel 150	Not	Available
151		ERROR:	Channel 151	Not	Available
152		ERROR:	Channel 152	Not	Available
153		ERROR:	Channel 153	Not	Available
154		ERROR:	Channel 154	Not	Available
155		ERROR:	Channel 155	Not	Available
156		ERROR:	Channel 156	Not	Available
157		ERROR:	Channel 157	Not	Available
158		ERROR:	Channel 158	Not	Available
159		ERROR:	Channel 159	Not	Available
160		ERROR:	Channel 160	Not	Available
161		ERROR:	Channel 161	Not	Available
162		ERROR:	Channel 162	Not	Available
163		ERROR:	Channel 163	Not	Available
164		ERROR:	Channel 164	Not	Available
165		ERROR:	Channel 165	Not	Available
166		ERROR:	Channel 166	Not	Available
167		ERROR:	Channel 167	Not	Available
168		ERROR:	Channel 168	Not	Available
169		ERROR:	Channel 169	Not	Available
170		ERROR:	Channel 170	Not	Available
171		ERROR:	Channel 171	Not	Available
172		ERROR:	Channel 172	Not	Available
173		ERROR:	Channel 173	Not	Available
174		ERROR:	Channel 174	Not	Available
175		ERROR:	Channel 175	Not	Available
176		ERROR:	Channel 176	Not	Available
177		ERROR:	Channel 177	Not	Available
178		ERROR:	Channel 178	Not	Available
179		ERROR:	Channel 179	Not	Available
180		ERROR:	Channel 180	Not	Available
181		ERROR:	Channel 181	Not	Available
182		ERROR:	Channel 182	Not	Available
183		ERROR:	Channel 183	Not	Available
184		ERROR:	Channel 184	Not	Available
185		ERROR:	Channel 185	Not	Available
186		ERROR:	Channel 186	Not	Available
187		ERROR:	Channel 187	Not	Available
188		ERROR:	Channel 188	Not	Available
189		ERROR:	Channel 189	Not	Available
190		ERROR:	Channel 190	Not	Available
191		ERROR:	Channel 191	Not	Available
192		ERROR:	Channel 192	Not	Available
193		ERROR:	Channel 193	Not	Available
194		ERROR:	Channel 194	Not	Available
195		ERROR:	Channel 195	Not	Available
196		ERROR:	Channel 196	Not	Available
197		ERROR:	Channel 197	Not	Available
198		ERROR:	Channel 198	Not	Available
199		ERROR:	Channel 199	Not	Available
200		ERROR:	Channel 200	Not	Available
201		ERROR:	Channel 201	Not	Available
202		ERROR:	Channel 202	Not	Available
203		ERROR:	Channel 203	Not	Available
204		ERROR:	Channel 204	Not	Available
205		ERROR:	Channel 205	Not	Available
206		ERROR:	Channel 206	Not	Available
207		ERROR:	Channel 207	Not	Available
208		ERROR:	Channel 208	Not	Available
209		ERROR:	Channel 209	Not	Available
210		ERROR:	Channel 210	Not	Available
211		ERROR:	Channel 211	Not	Available
212		ERROR:	Channel 212	Not	Available
213		ERROR:	Channel 213	Not	Available
214		ERROR:	Channel 214	Not	Available
215		ERROR:	Channel 215	Not	Available
216		ERROR:	Channel 216	Not	Available
217		ERROR:	Channel 217	Not	Available
218		ERROR:	Channel 218	Not	Available
219		ERROR:	Channel 219	Not	Available
220		ERROR:	Channel 220	Not	Available
221		ERROR:	Channel 221	Not	Available
222		ERROR:	Channel 222	Not	Available
223		ERROR:	Channel 223	Not	Available
224		ERROR:	Channel 224	Not	Available
225		ERROR:	Channel 225	Not	Available
226		ERROR:	Channel 226	Not	Available
227		ERROR:	Channel 227	Not	Available
228		ERROR:	Channel 228	Not	Available
229		ERROR:	Channel 229	Not	Available
230		ERROR:	Channel 230	Not	Available
231		ERROR:	Channel 231	Not	Available
232		ERROR:	Channel 232	Not	Available
233		ERROR:	Channel 233	Not	Available
234		ERROR:	Channel 234	Not	Available
235		ERROR:	Channel 235	Not	Available
236		ERROR:	Channel 236	Not	Available
237		ERROR:	Channel 237	Not	Available
238		ERROR:	Channel 238	Not	Available
239		ERROR:	Channel 239	Not	Available
240		ERROR:	Channel 240	Not	Available
241		ERROR:	Channel 241	Not	Available
242		ERROR:	Channel 242	Not	Available
243		ERROR:	Channel 243	Not	Available
244		ERROR:	Channel 244	Not	Available
245		ERROR:	Channel 245	Not	Available
246		ERROR:	Channel 246	Not	Available
247		ERROR:	Channel 247	Not	Available
248		ERROR:	Channel 248	Not	Available
249		ERROR:	Channel 249	Not	Available
250		ERROR:	Channel 250	Not	Available
251		ERROR:	Channel 251	Not	Available
252		ERROR:	Channel 252	Not	Available
253		ERROR:	Channel 253	Not	Available
254		ERROR:	Channel 254	Not	Available
255		ERROR:	Channel 255	Not	Available
2) After Fuse Pulled
Autoscan
Sunday,16,November,2014,14:50:35:32095
Mileage: 143270km-89023mi   Repair Order: fuse pulled
                    Fault Frequency: 17
                    Mileage: 143003 km
                    Date: 2014.11.12
                    Time: 10:02:33
                    RPM: 2289 /min
                    Speed: 31.4 km/h
                    Bin. Bits: 00001000
                    (no units): -12.80
                    Angle: 361.4 °
                    (no units): 0.20
008332 - Control Circuit for Reductant Pump 1
               P208C - 000 - Short to Ground
                    Mileage: 143274 km
                    Date: 2014.11.16
                    Time: 14:46:15
                    Voltage: 10.41 V
                    Load: 2.0 %
                    Temperature: 16.2°C
                        8.7 bar
                    Temperature: 15.3°C
                    Voltage: 1.880 V
   Coding: 0001016
   Revision: 00H30001
   Coding: 0099473
   Coding: 0000131
   Coding: 022036
   Coding: 0039123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Revision: AA001001
   Coding: 0014131
   Coding: 0002042
   Coding: 000303
   Coding: 0000006
   Coding: 3569693
                    Reset counter: 160
                    Mileage: 124054 km
                    Date: 2014.03.22
                    Time: 13:07:03
   Coding: 0D000000
                    Mileage: 65 km
                    Date: 2010.07.28
                    Time: 17:58:35
                    Bin. Bits: 00001000
   Coding: 0696013
   Coding: 0012001
   Coding: 0000007
   Coding: 1021201
   Coding: 0003595
   Coding: 0231266
End-------------------------(Elapsed Time: 03:32)--------------------------
MVB file:
;Sunday	16	November	2014	14:51:08:32095
1	0 /min	RPM	0.0 mg/str	Inj. Quantity	8.6 bar	Pressure	27.0°C	Temperature
2	0 /min	RPM	0.00%	Load	 0 01  0	Bin. Bits	27.0°C	Temperature
3	0 /min	RPM	1462.9 mg/str	Mass Air / Rev.	0.0 mg/str	Mass Air / Rev.	99.60%	Duty Cycle
5	0 /min	RPM	0.0 mg/str	Inj. Quantity	1	(no units)	27.0°C	Temperature
7	22.5°C	Temperature	27.9°C	Temperature	22.5°C	Temperature	27.0°C	Temperature
12	1010000	Bin. Bits	0.90 s	Time	11.40 V	Voltage	27.0°C	Temperature
19	0 /min	RPM	306	(no units)	0.0 bar	Pressure	1696	(no units)
31	EFD5	Voltage
33	0 /min	RPM	23.6°C	Temperature	1	(no units)	1	(no units)
35	0 /min	RPM	1462.9 mg/str	Mass Air / Rev.	0.0 mg/str	Mass Air / Rev.	99.60%	Duty Cycle
36	0 /min	RPM	14.10%	Lambda	0.80%	Lambda	0.00%	Lambda
37	0 /min	RPM	12.50%	Lambda	0.80%	Lambda	0.00%	Lambda
45	27.0°C	Temperature	0.00%	Duty Cycle	9.40%	Lambda	9.40%	Lambda
52	0 /min	RPM	2	(no units)	0	(no units)
61	0 /min	RPM	27.9°C	Temperature	39	(no units)	64.77	(no units)
90	0 /min	RPM	0.0 mg/str	Inj. Quantity	1462.9 mg/str	Mass Air / Rev.	0	Bin. Bits
91	127	(no units)	-128	(no units)	1462.9 mg/str	Mass Air / Rev.	127	(no units)
98	27.0°C	Temperature	18.9°C	Temperature	0.00%	Lambda	35.4°C	Temperature
99	0 /min	RPM	23.6°C	Temperature	-277.3°C	Temperature	17.7°C	Temperature
112	0	(no units)	-740.0 Nm	Torque	-1280.0 Nm	Torque	0.0 Nm	Torque
120	243	(no units)	17.7°C	Temperature	100	Bin. Bits	2.420 V	Voltage
121	-2.30%	Lambda	5.50%	Lambda	100	Bin. Bits	0.860 V	Voltage
122	3.10%	Lambda	0.80%	Lambda	100	Bin. Bits	0.960 V	Voltage
126	HVAC 1
135	72.20%	Load	29.7°C	Temperature	62.1°C	Temperature
151	2520 /min	RPM	0.00 mg/str	Inj. Quantity	20.0 mg/str	Inj. Quantity
170	2.00%	Load	 	 	0.00%	Load	9.8 bar
180	 	 	0 ppm
182	 	 	 	 	0	(no units)
183	0.94	(no units)
186	4.640 V	Voltage	109.8 s	Time	0.880 V	Voltage	0.0 s	Time
188	    0 10	Bin. Bits	20.0 s	Time	59.9 s	Time
207	0.99	(no units)
208	0	Bin. Bits
220	0	(no units)
Adaptation file:
;Sunday	16	November	2014	14:51:42:32095
14	0
22	1
23	0
24	0
25	0	0.0 Nm
40	94	0.94
55	0
56	25	1	0
57	0000FFFF	0	 	 	0
58	32767
66	0	0
71	8SALFNF
72	8SA1ENF
73	8SAIDEF
74	8SAUBWF
75	ASA1E5F
76	8IIB7NF
80	3	 	10001	0	0.00%
83	0
84	0
91	4
99	0	0.00 ms	0	 	0
103	2767
106	0
108	0
117	0
3) After Fuse Reinstalled
Autoscan
Sunday,16,November,2014,15:03:32:32095
Mileage: 143270km-89023mi   Repair Order: fuse installed
                    Fault Frequency: 17
                    Mileage: 143003 km
                    Date: 2014.11.12
                    Time: 10:02:33
                    RPM: 2289 /min
                    Speed: 31.4 km/h
                    Bin. Bits: 00001000
                    (no units): -12.80
                    Angle: 361.4 °
                    (no units): 0.20
               P208C - 000 - Short to Ground - Intermittent
                    Mileage: 143274 km
                    Date: 2014.11.16
                    Time: 14:46:15
                    Voltage: 10.41 V
                    Load: 2.0 %
                    Temperature: 16.2°C
                        8.7 bar
                    Temperature: 15.3°C
                    Voltage: 1.880 V
   Coding: 0001016
   Revision: 00H30001
   Coding: 0099473
   Coding: 0000131
   Coding: 022036
   Coding: 0039123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Revision: AA001001
   Coding: 0014131
   Coding: 0002042
   Coding: 000303
   Coding: 0000006
   Coding: 3569693
                    Reset counter: 160
                    Mileage: 124054 km
                    Date: 2014.03.22
                    Time: 13:07:03
   Coding: 0D000000
                    Mileage: 65 km
                    Date: 2010.07.28
                    Time: 17:58:35
                    Bin. Bits: 00001000
   Coding: 0696013
   Coding: 0012001
   Coding: 0000007
   Coding: 1021201
   Coding: 0003595
   Coding: 0231266
MVB file:
;Sunday	16	November	2014	15:03:58:32095
1	0 /min	RPM	0.0 mg/str	Inj. Quantity	8.6 bar	Pressure	26.1°C	Temperature
2	0 /min	RPM	0.00%	Load	 0 01  0	Bin. Bits	26.1°C	Temperature
3	0 /min	RPM	1468.8 mg/str	Mass Air / Rev.	0.0 mg/str	Mass Air / Rev.	99.60%	Duty Cycle
5	0 /min	RPM	0.0 mg/str	Inj. Quantity	1	(no units)	26.1°C	Temperature
7	21.6°C	Temperature	27.0°C	Temperature	22.5°C	Temperature	26.1°C	Temperature
12	1010000	Bin. Bits	1.08 s	Time	11.32 V	Voltage	26.1°C	Temperature
18	0 /min	RPM	21.6°C	Temperature	0	(no units)
20	0 /min	RPM	292.4 bar	Pressure	8.6 bar	Pressure	8.60%	Lambda
31	EFD5	Voltage
35	0 /min	RPM	1468.8 mg/str	Mass Air / Rev.	0.0 mg/str	Mass Air / Rev.	99.60%	Duty Cycle
36	0 /min	RPM	15.60%	Lambda	0.80%	Lambda	0.00%	Lambda
37	0 /min	RPM	14.80%	Lambda	0.80%	Lambda	0.00%	Lambda
45	26.1°C	Temperature	0.00%	Duty Cycle	9.40%	Lambda	9.40%	Lambda
47	94.5°C	Temperature	18.0°C	Temperature	0.00%	Duty Cycle	9.40%	Lambda
61	0 /min	RPM	27.0°C	Temperature	39	(no units)	64.77	(no units)
90	0 /min	RPM	0.0 mg/str	Inj. Quantity	1468.8 mg/str	Mass Air / Rev.	0	Bin. Bits
91	127	(no units)	-128	(no units)	1468.8 mg/str	Mass Air / Rev.	127	(no units)
96	0	Bin. Bits	0	Bin. Bits	0	Bin. Bits	11.32 V	Voltage
98	26.1°C	Temperature	18.0°C	Temperature	0.00%	Lambda	29.5°C	Temperature
112	0	(no units)	-760.0 Nm	Torque	-1280.0 Nm	Torque	0.0 Nm	Torque
120	252	(no units)	17.7°C	Temperature	100	Bin. Bits	2.420 V	Voltage
126	HVAC 1
135	72.20%	Load	28.8°C	Temperature	62.1°C	Temperature
151	2100 /min	RPM	-0.39 mg/str	Inj. Quantity	35.0 mg/str	Inj. Quantity
180	 	 	0 ppm
182	 	 	 	 	0	(no units)
183	0.94	(no units)
186	0.960 V	Voltage	109.8 s	Time	0.880 V	Voltage	0.0 s	Time
207	0.99	(no units)
208	0	Bin. Bits
220	0	(no units)
Adaptation file:
;Sunday	16	November	2014	15:04:32:32095
14	0
22	1
23	0
24	0
25	0	0.0 Nm
40	94	0.94
55	0
56	25	1	0
57	0000FFFF	0	 	 	0
58	32767
66	0	0
71	8SALFNF
72	8SA1ENF
73	8SAIDEF
74	8SAUBWF
75	ASA1E5F
76	8IIB7NF
80	3	 	10001	0	0.00%
83	0
84	0
91	4
99	0	0.00 ms	0	 	0
103	2767
106	0
108	0
117	0
4) After DTCs cleared
Sunday,16,November,2014,15:18:34:32095
Mileage: 143270km-89023mi   Repair Order: dtc clearded
   Coding: 0001016
   Revision: 00H30001
   Coding: 0099473
   Coding: 0000131
   Coding: 022036
   Coding: 0039123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Revision: AA001001
   Coding: 0014131
   Coding: 0002042
   Coding: 000303
            000 -  -
                    Reset counter: 160
                    Mileage: 143274 km
                    Date: 2014.11.16
                    Time: 15:14:18
                    Bin. Bits:    10111
                    Voltage: 11.10 V
                    Count: 7
   Coding: 0000006
   Coding: 3569693
                    Reset counter: 160
                    Mileage: 124054 km
                    Date: 2014.03.22
                    Time: 13:07:03
   Coding: 0D000000
                    Mileage: 65 km
                    Date: 2010.07.28
                    Time: 17:58:35
                    Bin. Bits: 00001000
   Coding: 0696013
   Coding: 0012001
   Coding: 0000007
   Coding: 1021201
   Coding: 0003595
   Coding: 0231266
End-------------------------(Elapsed Time: 03:31)--------------------------
MVB file: (Battery was running low so I started the engine)
;Sunday	16	November	2014	15:20:02:32095
1	987 /min	RPM	10.0 mg/str	Inj. Quantity	283.8 bar	Pressure	35.1°C	Temperature
2	987 /min	RPM	0.00%	Load	 1 01  1	Bin. Bits	35.1°C	Temperature
3	987 /min	RPM	475.9 mg/str	Mass Air / Rev.	475.9 mg/str	Mass Air / Rev.	96.50%	Duty Cycle
4	966 /min	RPM	2.4 °ATDC	Ign. Timing	0.42 ms	Time	283.8 bar	Pressure
5	987 /min	RPM	24.0 mg/str	Inj. Quantity	48	(no units)	35.1°C	Temperature
7	28.8°C	Temperature	27.0°C	Temperature	25.2°C	Temperature	36.0°C	Temperature
8	966 /min	RPM	0.0 Nm	Torque	356.0 Nm	Torque	226.2 Nm	Torque
9	987 /min	RPM	-1280.0 Nm	Torque	799.5 Nm	Torque	226.2 Nm	Torque
10	470.0 mg/str	Mass Air / Rev.	1009.8 mbar	Absolute Pres.	1071.0 mbar	Absolute Pres.	0.00%	Load
11	987 /min	RPM	999.6 mbar	Absolute Pres.	1071.0 mbar	Absolute Pres.	99.60%	Duty Cycle
12	10110000	Bin. Bits	1.08 s	Time	13.60 V	Voltage	36.0°C	Temperature
13	0.19 mg/str	Inj. Quantity	-0.24 mg/str	Inj. Quantity	0.24 mg/str	Inj. Quantity
14	-0.19 mg/str	Inj. Quantity	0.05 mg/str	Inj. Quantity	-0.19 mg/str	Inj. Quantity
15	966 /min	RPM	89.7 Nm	Torque	1.86 l/h	Fuel Consump.	0.0 Nm	Torque
18	987 /min	RPM	28.8°C	Temperature	4	(no units)
19	966 /min	RPM	2.55	(no units)	258.0 bar	Pressure	1176	(no units)
20	987 /min	RPM	283.8 bar	Pressure	283.8 bar	Pressure	18.00%	Lambda
21	987 /min	RPM	283.8 bar	Pressure	275.2 bar	Pressure	34.40%	Lambda
22	966 /min	RPM	1010100	Bin. Bits	1010100	Bin. Bits	1010100	Bin. Bits
23	966 /min	RPM	2.4 °ATDC	Ign. Timing	0.42 ms	Time	3	(no units)
24	987 /min	RPM	15.3 °BTDC	Ign. Timing	0.24 ms	Time	275.2 bar	Pressure
25	987 /min	RPM	0.0 °BTDC	Ign. Timing	0.00 ms	Time	283.8 bar	Pressure
26	987 /min	RPM	6.5 °BTDC	Ign. Timing	0.28 ms	Time	283.8 bar	Pressure
28	987 /min	RPM	0.0 °BTDC	Ign. Timing	0.00 ms	Time	275.2 bar	Pressure
29	987 /min	RPM	0.0 °BTDC	Ign. Timing	0.00 ms	Time	283.8 bar	Pressure
30	0.720 V	Voltage	0.360 V	Voltage	 1 01  1	Bin. Bits	0.00%	Load
31	EFD5	Voltage
32	966 /min	RPM	48	(no units)	606.0°	Steering Angle	690.0°	Steering Angle
33	966 /min	RPM	171.1°C	Temperature	1	(no units)	1	(no units)
34	987 /min	RPM	99.20%	Lambda	98.40%	Lambda	0.00%	Lambda
35	987 /min	RPM	475.9 mg/str	Mass Air / Rev.	475.9 mg/str	Mass Air / Rev.	29.30%	Duty Cycle
36	987 /min	RPM	69.50%	Lambda	69.50%	Lambda	-19.50%	Lambda
37	987 /min	RPM	69.50%	Lambda	69.50%	Lambda	-18.80%	Lambda
38	987 /min	RPM	96.50%	Duty Cycle	3.10%	Lambda	-14.80%	Lambda
39	987 /min	RPM	470.0 mg/str	Mass Air / Rev.	25.2°C	Temperature	61.70%	Lambda
40	987 /min	RPM	62.50%	Lambda	62.50%	Lambda	62.50%	Lambda
41	6	Ohms	0.000 V	Voltage	1.60%	Lambda	1	(no units)
42	1.60%	Lambda	1.60%	Lambda	3.300 V	Voltage	3.19	(no units)
44	987 /min	RPM	11001000	Bin. Bits	0	(no units)	0	(no units)
45	36.0°C	Temperature	10.70%	Duty Cycle	14.80%	Lambda	18.00%	Lambda
46	16.2°C	Temperature	19.8°C	Temperature	0	Bin. Bits	0	Bin. Bits
47	94.5°C	Temperature	18.9°C	Temperature	0.00%	Duty Cycle	14.80%	Lambda
48	987 /min	RPM	945 /min	RPM	0	Bin. Bits	1270.0 Nm	Torque
51	966 /min	RPM	488 /min	RPM	48	(no units)
52	987 /min	RPM	0	(no units)	0	(no units)
57	987 /min	RPM	0.0 km/h	Speed	0.00%	Duty Cycle	0.00%	Duty Cycle
58	966 /min	RPM	0.0 km/h	Speed	0.00%	Duty Cycle	0.00%	Duty Cycle
59	966 /min	RPM	89.7 Nm	Torque	78.0 Nm	Torque	42.9 Nm	Torque
60	78.0 Nm	Torque	-81.9 Nm	Torque	23.4 Nm	Torque	3442.5	(no units)
61	987 /min	RPM	27.0°C	Temperature	41	(no units)	64.77	(no units)
62	987 /min	RPM	10.0 mg/str	Inj. Quantity	70.2	(no units)	15.6	(no units)
71	11111111	Bin. Bits	111111	Bin. Bits
85	143270 km	Mileage	70	(no units)	1630	(no units)	5035	(no units)
89	0	Bin. Bits	1111	Bin. Bits	11101011	Bin. Bits	11101011	Bin. Bits
90	966 /min	RPM	10.0 mg/str	Inj. Quantity	464.1 mg/str	Mass Air / Rev.	0	Bin. Bits
91	127	(no units)	-128	(no units)	464.1 mg/str	Mass Air / Rev.	-1	(no units)
93	0	Bin. Bits	1.17	(no units)	80	(no units)	84	(no units)
94	1011000	Bin. Bits
95	0	Bin. Bits	 001   1	Bin. Bits	1100	Bin. Bits	10	Bin. Bits
96	0	Bin. Bits	0	Bin. Bits	1	Bin. Bits	13.68 V	Voltage
98	36.9°C	Temperature	18.9°C	Temperature	94.50%	Lambda	59.0°C	Temperature
99	987 /min	RPM	171.1°C	Temperature	-277.3°C	Temperature	35.4°C	Temperature
100	987 /min	RPM	64.9°C	Temperature	0	(no units)	0	Bin. Bits
102	94.4°C	Temperature	35.4°C	Temperature	6 mbar	Pressure	0 mbar	Pressure
107	52	(no units)	34.5	(no units)	24	(no units)	75.2	(no units)
109	123.9°C	Temperature	354.0°C	Temperature	94.4°C	Temperature	35.4°C	Temperature
111	966 /min	RPM	0.0 km/h	Speed	0	(no units)	0	(no units)
112	0	(no units)	-1220.0 Nm	Torque	-1280.0 Nm	Torque	0.0 Nm	Torque
120	270	(no units)	53.1°C	Temperature	0	Bin. Bits	4.240 V	Voltage
121	-2.30%	Lambda	5.50%	Lambda	100	Bin. Bits	3.000 V	Voltage
122	3.10%	Lambda	0.80%	Lambda	100	Bin. Bits	3.140 V	Voltage
123	0.00%	Lambda	100	Bin. Bits	10	Bin. Bits	3.840 V	Voltage
124	 	 	 	 	0	Bin. Bits	4.180 V	Voltage
126	HVAC 1
140	50.7 Nm	Torque	58.5 Nm	Torque
141	27.0 bar	Absolute Pres.	28.0 bar	Absolute Pres.
142	-12.8	(no units)	-12.8	(no units)
143	-18.0°	Steering Angle	-18.0°	Steering Angle
144	12.0°	Steering Angle	12.0°	Steering Angle
147	1000	Bin. Bits	1000	Bin. Bits
151	2919 /min	RPM	-0.59 mg/str	Inj. Quantity	10.0 mg/str	Inj. Quantity
169	987 /min	RPM	94.50%	Duty Cycle	89.10%	Lambda	94.50%	Lambda
180	 	 	0 ppm
181	92	(no units)	92	(no units)	80	(no units)
182	 	 	 	 	0	(no units)
183	0.94	(no units)
200	11	(no units)	11	(no units)	8	(no units)
201	11	(no units)	9	(no units)	10	(no units)
202	987 /min	RPM	1	(no units)	0	Bin. Bits	1	Bin. Bits
203	1010001	Bin. Bits	0	Bin. Bits	0	(no units)	0.0 Nm	Torque
207	0.99	(no units)
208	0	Bin. Bits
220	0	(no units)
Adaptation file:
;Sunday	16	November	2014	15:20:36:32095
13	0	-12.8	-18.0°	361.4 °	-12.0°
14	0
22	1
23	0
24	0
25	0	7.8 Nm
40	94	0.94
42	0	2.2	-12.0°	361.4 °	-12.0°
54	4	10000	64.77	41	1
55	0
56	25	1	0
57	0000FFFF	0	 	 	0
58	32767
66	0	0
71	8SALFNF
72	8SA1ENF
73	8SAIDEF
74	8SAUBWF
75	ASA1E5F
76	8IIB7NF
80	3	 	0	70.5	0.00%
81	0	9	-12.0°	361.4 °	-12.0°
82	0	8.8	-12.0°	361.4 °	-12.0°
83	0
84	0
91	4
99	0	0.86 ms	0	 	11110
103	2767
106	0
108	1
117	0
The only thing that happened was the expected Module 01 Trouble Code;
P208C - 000 - Short to Ground.
After reinstalling the fuse the DTC was cleared.
Adaptation Channel 80 behaves the same way as before (Test button is only active when the New Value is 3 (same as saved value). Entering a 4 into new value makes Save button active, test value changes to 4 momentarily and then changes back to 3).
barbarmi
C?ID=217814
Posted Autoscan, Measuring Block, and Adaptation Files into the original post.
Looking at the files as posted I now see that Adaption Channel 80 changed Pre-test to post test:
Pre-test
80 3 10001 0 0.00%
Fuse Pulled
80 3 10001 0 0.00%
Fuse Reinstalled
80 3 10001 0 0.00%
After DTCs Cleared (with engine running)
80 3 0 70.5 0.00%
The adaptation channels don't have labels so not sure what channel 2 and 3 are but they are different
Going back to after the Shop cleared the AdBlue warning this is what Adaptation Channel 80 Read
80 2 10001 0 0.00%
So position 0 is different from the current value, but position 2 reads the same as at the start of the "experiment"
On 9/20 (before the shop reset) Adaptation Channel 80 Read (engine running)
80 3 11 79.9 0.00%
I assume position 2 has the leading 0's dropped (downloaded as a CSV file not a PLA file).
Well I am more confused though I do have to say the experiment outlined by Dana did change something.
Still in search of answers, but certainly something to chew on.
Can't wait to hear the ideas
Hello Dana,
send you a e-mail on support@ross-tech.com. measuring and basic settings for CATA.
Hope you can fill up some empty lines.
See you
Hi Wolfgang,
I looked for it when you posted and didn't see it .... but the email appeared last night in our Support folder. I suspect it was stuck on one of our Junk folders because the date stamp was correct.
So, my thanks is very late but that should help fill in some blanks :)
   #39
barbarmi
C?ID=217814
Well, still only able to go about 3000 mi before I would get the AdBlue low warning. Still can't seem to figure out why I can't do the adaptation even after trying experiment Dana outlined (see earlier post), I have to do something. So.......
I figured if the problem was not filling the reserve tank I need to check the reserve tank level. If there was no fluid in the reserve tank there was a problem or blockage in the tube/hose connections between the reserve and main tank. If the reserve tank was full, but not transferring fluid to the main tank, either the controller or the transfer pump was bad. With these potential problems only 1 thing to do, pull the reserve tank.
Well the reserve tank was full, so at least I confirmed I can fill the tank from the connection behind the fuel fill door.
Next was to test the transfer pump. I pulled the transfer pump and applied 12v to the terminals and the pump didn't run. The current draw was high so I am convinced the pump is frozen. I also checked the Autoscan of the controller with the transfer pump disconnected to see if there were any codes, but nothing showed up. Wanting to be thorough I checked the pump connector on the car to see if there was 12V at the connection. Unfortunately there was no voltage.
I confirmed the ground side was good (almost no resistance between the connector and the frame. so the open question is when does the controller tell the transfer pump to run? Is it only when the fluid level in the main tank is low (but not low enough to trip the dash warning)? Or does it run all the time?
Ordered the pump, but would hate to put everything back together only to find I need to take it all apart again to check something else.
Appreciate any help.
   #40
Gone But Not Forgotten
If you have applied current to transfer pump and it doesn't flow......... I would agree that would be an issue.
It may not be monitored by the diagnostics.
Another way to find out is to unplug and see if you get a DTC for short to open.
You may in fact be experiencing the tanks completing a gravity feed only to the one tank and is why you get the warning.
