2000 Jetta Airbag Codes
tmcorasaniti
C?ID=316943
Hey guys,
I have a couple airbag codes on my car that I cant get to clear. Any help pointing me in the right direction for what parts to check/change would be greatly appreciated!
Control Module Part Number: 6Q0 909 605 A
Component and/or Version: 09 AIRBAG VW5 0003
Software Coding: 12345
Work Shop Code: WSC 00066
VCID: 3522FE480D262AEE72-4B5C
Fault Codes have been Erased
01221 - Crash Sensor Side Airbag; Driver Side (G179)
28-10 - Short to Plus - Intermittent
32-10 - Resistance Too High - Intermittent
00589 - Airbag Igniter 1; Passenger Side (N131)
01217 - Side Airbag Igniter; Driver Side (N199)
NostraJackAss
Check control unit for water ingress and clean if needed or replace if all wiring/sensors are in order.
Check grounds for adequate ability to carry current.
raf0468
C?ID=120244
any history for the car accidents airbags replaced etc..
tmcorasaniti
C?ID=316943
no accidents no air bags replaced its a florida car has some rust under the dash looks like from salt in the air
I have checked all the wiring under the seats and behind the 2 front air bags all looks good
i swap the sensors from under the front seats and still have the same codes
thanks
tmcorasaniti
C?ID=316943
swapped the sensors from under the 2 front seats have the same codes
which ground wires are you referring to i have check all the obvious wires
NostraJackAss
Please observe RTFB for WD and observe JPPSG guide.
With sporadic codes such as this, I strongly reiterate..... I would seriously inspect the controller internally with a good visual inspection.
tmcorasaniti
C?ID=316943
which controller are you talking about
tmcorasaniti
C?ID=316943
i am sorry sir i don't know what 10x15 air bag means for me to do
tmcorasaniti
C?ID=316943
Thanks My steering wheel is on the opposite side I will look around At least now i know what i am looking for
Thanks Again
Should be applicable to a 2000 Jetta:
tmcorasaniti
C?ID=316943
thanks for your help Thats is where it was and that was also the problem Looks like the box got wet at one point thanks again
NostraJackAss
I know .......... :D
Thank you for confirmation and getting back to the thread OP.
FOD strikes again!
