2013 Q7 TDI - Post Emission Fix - Unknown Error Code
mxitup
WA
C?ID=161832
Had the VW/Audi 3.0 TDI emission fix (ECR) performed on 11/22/17.
Since the fix was performed, "Address 01: Engine" keeps registering "38161 - ROD - Unknown Error Code"
Example Scan:
Wednesday,03,January,2018,16:47:55:59648
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
VIN: WA1LMAFEXDD******   License Plate: POST FIX CHK ENG
Mileage: 113050km-70246mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 42 46 47 4C 4F 52 55
          56 5F 62 69 6C 6D 6F 72
VIN: WA1LMAFEXDD013230   Mileage: 113050km-70246miles
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401 A    HW: 4L0 907 401 E
   Component: 3.0TDI FSA    H21 0012
   Revision: 54H21---    Serial number:
   Coding: 2A2A4012253600050000
   Shop #: WSC 46818 001 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
   ROD: EV_ECM30TDI0114L2910401A.rod
   VCID: 224B8EF93526F156A7-8076
          - 00 [237]
                    Mileage: 111891 km
                    Date: 2017.12.10
                    Time: 12:23:17
                    Engine speed: 2184.00 /min
                    Normed load value: 80.0 %
                    Vehicle speed: 90 km/h
                    Coolant temperature: 86 °C
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 14.400 V
                    Outside air temperature: 2.0 °C
                    Pressure sensor for reducing agent: measured pressure: 5104 hPa
                    SCR catalytic converter average temperature: 245.1 °C
                    Sensor for reducing agent tank temperature: temperature: 13.3 °C
                    Reducing agent pump: activation: 50.00 %
Readiness: 1 1 0 0 0
   Part No SW: 0C8 927 750 AQ    HW: 0C8 927 750 AQ
   Component: AL1000 AISIN  002 3399
   Coding: 001378
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 7BF5939DF20C609EC4-802E
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099441
   Shop #: WSC 31414 790 00001
   VCID: 346778A157D26FE645-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603702049174
   Coding: 0000131
   VCID: 254195E5EC08066EC2-8070
   Subsystem 1 - Part No: 4F0 910 132 J
   Component: FBSAUDIC6 EZS   H04 0020
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0054
01176 - Key
                    Reset counter: 11
                    Mileage: 112408 km
                    Date: 2017.12.21
                    Time: 09:29:06
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
   Revision: 00---031    Serial number: 00000030274399
   Coding: 0304A036
   VCID: 254195E52C08066EC2-8070
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Component: ILM Fahrer      H31 0400
   Coding: 0039123
   VCID: 6FEDB7CD7E740C3E78-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
            010 - Open or Short to Plus
                    Fault Status: 01111010
                    Fault Frequency: 8
                    Reset counter: 240
                    Mileage: 111672 km
                    Date: 2017.12.08
                    Time: 16:28:00
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55961306500406
   Coding: 25011E
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 346778A19FD26FE645-8060
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH44 0230
   Revision: 08H44000    Serial number: 0038QD0C2WBL
   Coding: 0014131
   VCID: 2B5563DD8AEC301E14-807E
   Subsystem 1 - Part No: 4L0 959 339 C
   Component: BF-Gewichtsens. H05 0040
   Subsystem 2 - Serial number: 6332QSME78294A4EX
   Subsystem 3 - Serial number: 6342QSME3C2B4344J
   Subsystem 4 - Serial number: 6352QSME07243C58I
   Subsystem 5 - Serial number: 6362QSME78291C64R
   Subsystem 6 - Serial number: 63734SME66284B5AA
   Subsystem 7 - Serial number: 63834SME662850680
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H08000    Serial number: 90026130200099
   Coding: 0002242
   VCID: 285F9CD19B1A1B06F9-807C
   Component: E0221           H03 0040
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 985 Q    HW: 4L0 920 985 Q
   Component: KOMBIINSTR.   H35 0317
   Revision: 00000000    Serial number: VJ450M73E
   Coding: 8BD764040100CF05020205
   VCID: 428B2E79DD66D156C7-8016
   Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0058
   Revision: LB600036    Serial number: 3600L132210272
   Coding: 00C303
   VCID: 3E735A89A99EB5B6A3-806A
   Component: J367-BDM  H07 0125
   Serial number: 40060J01544120270835
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
   Revision: 00---011    Serial number: 00000030274167
   Coding: 0000006
   VCID: 68DFDCD15B9ADB0639-803C
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000052682777
   Coding: 00581300000011110000
   VCID: 326B7EB96DC661D657-8066
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000054208788
   Coding: 011F07205E40440004
   VCID: 489F3C51FB5AFB0619-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01922799520000
   Coding: 3570077
   VCID: 387F4C914BBA8B8669-806C
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004000    Serial number: 00000000017619
   Coding: 030000
   VCID: 295999D54010220EE6-807C
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005190078359
   Coding: 0758477
   VCID: 23458BFDE23CF85EAC-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000135975
   Coding: 0012001
   VCID: 5EB3FA0989DE95B6C3-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000050596381
   VCID: 479D3F6DF644F47E10-8012
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 130228-0004-122
   Coding: 1147A71010020400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 428B2E79D566D156C7-8016
   Revision: AB001007    Serial number: 156CO0D7701410
   Coding: 020007010000000000
   VCID: 244788E12732FF66D5-8070
   Part No SW: 4L2 035 746 G    HW: 4L2 035 746 A
   Component: H-BNT-NA      H44 0901
   Revision: --------    Serial number: 224C$0D7518585
   Coding: 180200060004E3EF410023456F632003140000000100000000
   Subsystem 1 - Part No: 8R0 060 884 CS
   Component: NAR 2015  1201
   Component: DU7 High  H42 0104
   Serial number: A130C-0D2670997
   Subsystem 3 - Part No SW: 4L0 919 614 B    HW: 4L0 919 614 B
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002097712
   Component: CD-Database  4949
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000053459995
   Coding: 010E07204040230004
   VCID: 46833269F14EED76EB-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000192828906
   Coding: 0200000000000000
   VCID: 316971B568C05ACE2E-8064
   Revision: --H07---    Serial number: 525PA8-J3240I0
   Coding: 1021201
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7A0C14F62F7265D-8038
ó
   Subsystem 3 - Serial number: RD02.03.13--H57001002G0024ÿ
   Subsystem 4 - Serial number: 2G0024ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 131038889-----
   Coding: 0003851
   VCID: 264392E9910E0D76CB-8072
   Component: J_245_EE16_SKB10H14 0220
   Component: J_394_EE16_SKB10H14 0220
   Component: J_392_EE16_SKB10H14 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000053460106
End-------------------------(Elapsed Time: 04:16)--------------------------
Yes, that's because the "fix" changes the ECU ID info.
Please try Beta 17.12, which has newer data. You can download it from this page.
mxitup
WA
C?ID=161832
Thank you, I ran Beta 17.12.0.1
New Auto Scan
VIN: WA1LMAFEXDD******   Mileage: 113160km-70314miles
4C-Tire Pressure II -- Status: Malfunction 0010
   VCID: 224B8EF93526F13AF96-8076
38161 - Reductant Metering Module
          P20FE 00 [096] - Malfunction
                    Mileage: 113101 km
                    Date: 2018.01.04
                    Time: 17:28:24
                    Engine speed: 1803.00 /min
                    Normed load value: 78.0 %
                    Vehicle speed: 61 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 14.480 V
                    Outside air temperature: 9.0 °C
                    Pressure sensor for reducing agent: measured pressure: 5039 hPa
                    SCR catalytic converter average temperature: 246.0 °C
                    Sensor for reducing agent tank temperature: temperature: 12.3 °C
                    SCRPOD p Cns De Mon Avrg: 738 hPa
Readiness: 0 0 0 1 0
   Coding: 001378
   VCID: 7BF5939DF20C60F29A0-802E
   Revision: 00H02001
   Coding: 0099441
   VCID: 346778A157D26F8A1BA-8060
   Coding: 0000131
   VCID: 254195E5EC0806029C4-8070
   Coding: 0304A036
   VCID: 254195E52C0806029C4-8070
   Coding: 0039123
   VCID: 6FEDB7CD7E740C52268-803A
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Fault Status: 00111010
                    Reset counter: 25
                    Mileage: 113048 km
                    Date: 2018.01.03
                    Time: 16:51:00
   Coding: 25011E
   VCID: 346778A19FD26F8A1BA-8060
   Coding: 0014131
   VCID: 2B5563DD8AEC30724A0-807E
   Coding: 0002242
   VCID: 285F9CD19B1A1B6AA72-807C
   VCID: 428B2E79DD66D13A996-8016
   Coding: 00C303
   VCID: 3E735A89A99EB5DAFDE-806A
   Coding: 0000006
   VCID: 68DFDCD15B9ADB6A672-803C
   VCID: 326B7EB96DC661BA096-8066
   VCID: 489F3C51FB5AFB6A472-801C
   Coding: 3570077
   VCID: 387F4C914BBA8BEA372-806C
   Coding: 030000
   VCID: 295999D540102262B8C-807C
   Coding: 0758477
   VCID: 23458BFDE23CF832F20-8076
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
                    Reset counter: 28
                    Mileage: 113064 km
                    Date: 2018.01.04
                    Time: 07:22:08
                    Hex Value: 0x0040
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 14.40 V
                    Temperature: 4.0°C
                    (no units): 46.0
   Coding: 0012001
   VCID: 5EB3FA0989DE95DA9DE-800A
   VCID: 479D3F6DF644F4124E8-8012
   VCID: 428B2E79D566D13A996-8016
   VCID: 244788E12732FF0A8BA-8070
   VCID: 46833269F14EED1AB5E-8012
   VCID: 316971B568C05AA270C-8064
   Coding: 1021201
   VCID: 6CD7A0C14F62F74A03A-8038
ó
   Coding: 0003851
   VCID: 264392E9910E0D1A95E-8072
End-------------------------(Elapsed Time: 04:30)--------------------------
And now there's data for the new software in your ECU and your fault code is decipherable. :cool:
tuningbyamg
Canada
C?ID=230173
Hey what is the 3.0 Settlement details for the USA?
Nothing yet in Canada for these :(
Gone But Not Forgotten
Bullshit RTFB
https://www.audi.ca/ca/web/en/service/3-tdi.html
Audi 3.0L V6 TDI Information
Volkswagen and Canadian class counsel have reached a nationwide proposed class settlement regarding approximately 20,000 affected 3.0L diesel vehicles. If approved, the 3.0L settlement program in Canada will include the following benefits:
• Cash payments to owners and lessees of model year 2013-2016 Volkswagen, Audi and Porsche 3.0L diesel vehicles (so-called Generation Two vehicles) who receive the recall for an emissions repair to bring their vehicle into full compliance with originally certified emissions standards, as well as an extended warranty.
• Cash payments to owners and lessees of model year 2009-2012 Volkswagen and Audi 3.0L diesel vehicles (so-called Generation One vehicles), as well as additional options that include buyback, trade-in, early lease termination or, if approved by the U.S. EPA and available by recall in Canada, a modification to reduce emissions.
• Cash payments for certain owners and lessees who no longer own or lease their Generation One or Generation Two 3.0L diesel vehicle.
The proposed nationwide 3.0L settlement is subject to approval by both the Ontario and Québec courts. Approval hearings will take place in April 2018 before the Ontario Superior Court of Justice in Toronto and the Superior Court of Québec in Montreal.
Current and former owners and lessees who wish to make a claim for benefits under the 3.0L settlement do not need to take any action at this time. The period to submit a claim will not begin until after the proposed settlement receives approval by the Courts.
However, owners and lessees in possession of a Generation Two (model year 2013-2016) vehicle do not need to wait to receive the emissions repair that has already been approved by the U.S. EPA. Notice is being provided when recalls for those repairs launch in Canada and are available at authorized Volkswagen, Audi and Porsche dealerships. Owners and lessees who choose to receive this emissions repair before the 3.0L claims program begins will not lose any right to an eligible cash payment under the proposed settlement.
More detailed information about the options available to Settlement Class Members is available at:www.VWCanadaSettlement.ca
FAQ
What is the issue with Audi’s 3.0L V6 TDI engines?-
On November 2, 2015, the Environmental Protection Agency (EPA) and California Air Resources Board (CARB) issued a notice of violation regarding our 3.0L V6 TDI engines. The notice indicated that emissions control devices were not sufficiently described and explained in our applications for regulatory approval. Audi has worked directly with EPA on this and has committed to document the emissions devices in detail and resubmit the revised applications.
Which Audi vehicles are covered by this proposed settlement agreement?-
The proposed settlement agreement applies to all 3.0L diesel vehicles that Volkswagen, Audi or Porsche marketed or sold in Canada for Model Years 2009 through 2016. The Audi vehicles are divided into two generations, as follows:
Generation 1 Vehicles:
• 2009-2012 Audi Q7 models
Generation 2 Vehicles:
• 2013-2015 Audi Q7 models
• 2014-2016 Audi A6, A7, A8, A8L, Q5 models
tuningbyamg
Canada
C?ID=230173
Come on Jack, bullshit detector really ? :P
April 2018 is the key date, we're not there yet
All in good fun.......
Again it is clear it is under warranty and will further be with extension..........
tuningbyamg
Canada
C?ID=230173
Yes absolutely, i did fight them for a sensor that burned right after the ECU update on a 2.0 Passat, stand your ground firm, and do not let them bill you for anything.
They even lent me a 2017 Golf for a whole week until they figured out the warranties, free of charge :)
ULEV2 yes it does!
Title: Application for AUDI 2013 model year test group DADXT03.03UG
Abstract: This test group contains a 3.0 liter engine certified to Federal Tier 2 Bin 5 standards. List of vehicle divisions and models: AUDI: Q7
Document Date: 06/05/2012
MB180DC
C?ID=217320
I’m new to this forum and I did not want to post same thread again in new user section. I did auto scan today on my 2013 Audi Q7 TDI and got same unknown error code, no MIL but I have 1000 miles AdBlue warning light (def fluid is all the way to top) and have no idea what might be an issue. Is it bad Nox sensor or injector nozzel for urea (which i think was replaced during emission fix). Can someone pin point what could be an issue.
Welcome to the Forum MB180DC
It is under warranty, get it done for free at dealer...........
Post an auto-scan.........PLEASE!
MB180DC
C?ID=217320
Here is an auto scan. Thank you for all help.
Wednesday,31,January,2018,08:43:48:61721
VCDS Version: 18.1.0.2 (x64)
Data version: 20180122 DS285.1
VIN: WA1WMAFE8DD016043   License Plate:
Mileage: 78050km-48498mi   Repair Order:
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3C 42 46 47 4C
          4F 52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1WMAFE8DD016043   Mileage: 78050km-48498miles
   Component: 3.0TDI FSA    H22 0012
   Revision: 54H22---    Serial number:
   Coding: 2A2A4012257600050000
   Shop #: WSC 52065 001 1048576
   VCID: 224A6462353EE85583-8076
                    Fault Frequency: 8
                    Mileage: 75480 km
                    Date: 2017.12.03
                    Time: 13:04:57
                    Engine speed: 1515.50 /min
                    Normed load value: 66.7 %
                    Vehicle speed: 63 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 14.440 V
                    Unlearning counter according OBD: 35
                    Outside air temperature: 6.5 °C
                    Pressure sensor for reducing agent: measured pressure: 4994 hPa
                    SCR catalytic converter average temperature: 255.8 °C
                    Sensor for reducing agent tank temperature: temperature: 5.7 °C
                    SCRPOD p Cns De Mon Avrg: 747 hPa
   Coding: 001378
   VCID: 7BF47906F214799DE0-802E
   Revision: 00H02001
   Coding: 0627825
   VCID: 3466923A57CA76E561-8060
   Revision: 00H08000    Serial number: 10603702060819
   Coding: 0000135
   VCID: 25407F7EEC101F6DE6-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0053
00190 - Driver's Door Handle Touch Sensor (G415)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 121
                    Mileage: 74825 km
                    Date: 2017.11.22
                    Time: 14:55:27
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Reset counter: 121
                    Mileage: 74825 km
                    Date: 2017.11.22
                    Time: 15:28:29
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 121
                    Mileage: 74825 km
                    Date: 2017.11.22
                    Time: 14:55:27
                    Reset counter: 235
                    Mileage: 78056 km
                    Date: 2018.01.31
                    Time: 08:22:57
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AQ
   Revision: 00---031    Serial number: 00000000373866
   Coding: 0304A036
   VCID: 25407F7E2C101F6DE6-8070
   Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0058983185
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
   Serial number:           0058983130
   Coding: 070000
                    Reset counter: 235
                    Mileage: 78056 km
                    Date: 2018.01.31
                    Time: 08:23:00
                    Voltage: 10.40 V
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Coding: 0133123
   VCID: 6ED2405279661C3557-803A
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Revision: 11001001    Serial number: 55961311701362
   Coding: 29011F
   VCID: 3466923A9FCA76E561-8060
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4L0 910 561 A    HW: 4L0 907 561
   Component: ABSTANDSREGELUNGH07 0160
   Revision: --------    Serial number: 00000000000000
   Coding: 0031111
   VCID: 275C7576961C0D7DD4-8072
   Revision: 08H44000    Serial number: 0038QD0C5KNO
   Coding: 0014131
   VCID: 2B5489468AF4291D30-807E
   Subsystem 2 - Serial number: 6332QSME5C311554B
   Subsystem 3 - Serial number: 6342QSME07304540%
   Subsystem 4 - Serial number: 6352QSME2D304278G
   Subsystem 5 - Serial number: 6362QSME1C3043528
   Subsystem 6 - Serial number: 63734SME1A300750R
   Subsystem 7 - Serial number: 63834SME1A304152S
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Revision: 00H08000    Serial number: 90026130910503
   Coding: 0012152
   VCID: 285E764A9B020205DD-807C
   Part No SW: 4L0 920 985 G    HW: 4L0 920 985 G
   Revision: 00000000    Serial number: VJ551EX4E
   Coding: 8BD664040D01CF05020205
   VCID: 387EA60A8BA292854D-806C
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB700037    Serial number: 3700M1342800B3
   Coding: 00C303
   VCID: 3F8CCD16AE8CA5BD8C-806A
   Serial number: 40098029584121207739
            000 -  -
                    Reset counter: 195
                    Mileage: 78056 km
                    Date: 2018.01.31
                    Time: 08:27:12
                    Bin. Bits:    10111
                    Voltage: 11.00 V
                    Count: 7
   Revision: 00---011    Serial number: 00000030282767
   Coding: 0000006
   VCID: 68DE364A5B82C2051D-803C
                    Reset counter: 235
                    Mileage: 78056 km
                    Date: 2018.01.31
                    Time: 08:23:00
                    Voltage: 10.60 V
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 195
                    Mileage: 78056 km
                    Date: 2018.01.31
                    Time: 08:23:05
Address 34: Level Control        Labels: None
   Part No SW: 4L0 910 553 J    HW: 4L0 907 553 E
   Component: LUFTFDR.-CDC    H04 7860
   Revision: --H04001    Serial number: 15.1528-0143.2
   Coding: 0015520
   VCID: 31689B2EA8D843CD0A-8064
00776 - Level Control System Sensor; Left Front (G78)
                    Reset counter: 226
                    Mileage: 77820 km
                    Date: 2018.01.20
                    Time: 15:17:54
                    Error Code: 24
                    Fault Status: 11100010
                    Reset counter: 195
                    Mileage: 77900 km
                    Date: 2018.01.24
                    Time: 18:36:05
                    Error Code: 13
   Revision: AA000000    Serial number: 00000058339578
   Coding: 00581B00000011110000
   VCID: 326A94226DDE78D573-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E528052B9E65C3517-807A
   Component: J0770_SWA_Slave_H02 0050
   Subsystem 3 - Serial number: 5F18.04.1300H02000AMS15556ÿ
   Subsystem 4 - Serial number: S15556ÿ
   Revision:             Serial number: 0000060200423
   Coding: 011F57205E40440004
   VCID: 489ED6CAFB42E2053D-801C
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 225
                    Mileage: 77733 km
                    Date: 2018.01.19
                    Time: 16:32:03
02124 - Exterior Door Handle Switch
                    Reset counter: 225
                    Mileage: 77808 km
                    Date: 2018.01.20
                    Time: 07:49:25
   Revision: 0130 ---    Serial number: 01930823540000
   Coding: 3570077
   VCID: 387EA60A4BA292854D-806C
03073 - Rear Lid Closed Sensor 1
                    Reset counter: 234
                    Mileage: 69698 km
                    Date: 2017.08.14
                    Time: 06:55:08
   Revision: CH004000    Serial number: 00000000023266
   Coding: 030000
   VCID: 2958734E40083B0DC2-807C
   Revision: 00000519    Serial number: 00005191007510
   Coding: 0758733
   VCID: 23446166E224E15D88-8076
   Revision:             Serial number: 00000000140809
   Coding: 0012001
   VCID: 5EB2109289C68CB5E7-800A
   Revision:             Serial number: 0000059918941
   VCID: 479CD5F6F65CED7D34-8012
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000032
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156D20D7719259
   VCID: 224A64623D3EE85583-8076
   Part No SW: 4L2 035 746 C    HW: 4L2 035 746 A
   Component: H-BNT-NA      H44 0624
   Revision: --------    Serial number: 224DN0D7521340
   Coding: 180200060004FBEF710023456F632003140000000100000000
   VCID: 2E52805279E65C3517-807A
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Serial number: A130DK0D2718032
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Serial number: 00000002109138
                    Reset counter: 232
                    Mileage: 77961 km
                    Date: 2018.01.27
                    Time: 19:26:58
                    Bin. Bits: 00000000 00000010
                    Bin. Bits: 00000000 00000000
   Revision:             Serial number: 0000060225565
   Coding: 010E57204040230004
   VCID: 4682D8F2F156F475CF-8012
   Revision: 2A001001    Serial number: 00000193376539
   VCID: 31689B2E68D843CD0A-8064
   Part No SW: 4L0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0293
   Revision: 11001001    Serial number: 82330JF0085150
   Coding: 020C000001000100010102000000
   ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
   ROD: EV_CamSysteCorneViewAUDI.rod
   VCID: 6ED24052B1661C3557-803A
9617697 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 235
                    Mileage: 76754 km
                    Date: 2018.01.04
                    Time: 17:39:04
                    Voltage terminal 30: 6.5 V
                    Terminal 15 status: Terminal 15 on
   VCID: 6CD64A5A4F7AEE2579-8038
   Subsystem 3 - Serial number: RD26.04.13--H57001002E0254ÿ
   Subsystem 4 - Serial number: 2E0254ÿ
   Revision: AAH08080    Serial number: 0059444830----
   Coding: 0003595
   VCID: 2642787291161475EF-8072
   Revision:             Serial number: 0000060225657
End-------------------------(Elapsed Time: 04:18)--------------------------
Thank you for posting the auto-scan.
The required extra administration of the urea solution is causing the module to be overwhelmed or the module is damaged from FOD or Urea injector is crystalized requiring manual remediation at the pee pee orifice of injector.
Most likely is under warranty extension please see your dealer for free replacement and observe the list of parts covered or document the repair thoroughly and do it yourself and seek reimbursement if permissible within agreement.
iichel
Eindhoven, NB, NL
C?ID=284912
good to hear, fixed as Jack predicted
NOT AGAIN?
Yeah......... good to hear that asshole NJA is right, right? :rolleyes:
Hey if the aftermarket can't make money on it, do you really think I will stand by and let a franchise profit vicariously through an unjust enrichment scheme & that the OEM has yet again, twisted the regulations due to peoples poor interpretation, to perform a clear unfair issue for the, diagnostic tools, external shops, parts losses and the customers?
Fuck that ........right?
OP: See how VCDS saved you a ton of money, as did this forum & people which will read it?
Has anyone realized I have been questioning a lot lately, do you think you should expect more of it?
:D
