I've recently upgraded the RNS-315 in my 2013 Golf TDI to an RNS-150 from a 2013 Passat. All is working as it shoud including the steering wheel controls, 9w7 bluetooth add-on, voice command, etc. I'm pretty proud of myself.
One item I'm having trouble with, however, is the 510 brightness - specifically, the autodimming is very aggressive. In bright daylight, the display is difficult to see even on the brightest setting. At night, it's fine, and it does respond correctly (going from day->night) when the headlights are switched on.
My question is, is there a coding that controls the autodimming factors or thresholds for the LCD screen? Or is it possible to disable autodim completely?
RNS-510 (3C0 035 684 G / HW: H02, SW: 3696)
(the malfunction items came from the head unit swap; they have since been cleared; if it would help to post a clean scan, I can do that over the weekend)
Thursday,18,September,2014,19:35:48:65402
VCDS Version: 12.12.3.0
Data version: 20140822
VIN: WVWNM7AJ6DW007239 License Plate:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
77-Telephone -- Status: Malfunction 1010
Part No SW: 03L 906 019 HB HW: 03L 907 309 AA
Component: R4 2,0L EDC G000SG 4422
Revision: 12H14--- Serial number:
Coding: 0050072
VCID: 72EB60EE6D505B8E9D9-8027
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 114B400C49220001880D02E792220042B70000
VCID: 7DF143D2E40E14F6F0B-8028
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010002002
ROD: EV_ACManueBHBVW36X_SE36.rod
VCID: 7BF54DCAF21A1AC6CEF-802E
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 T HW: 1K0 937 086 T
Component: BCM PQ35 M 111 0709
Revision: AB111709
Coding: 6F180A1A90272AC4008800C17000854448010386534D8560648020200040
VCID: 4189FF22D876B016D43-8014
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 16051 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA2AXBE
Coding: 00003131
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3F8DF9DAA682C6E6A27-806A
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00003KFJ00
Serial number: 3572MSME6E6E7268ZZZD
Serial number: 3582MSME1F707268ZZZ/
Serial number: 3512QSME5A051357ZZZR
Serial number: 3522QSME460A1353ZZZO
Serial number: 35527SME6744772CZZZP
Crash sensor for front airbag; passenger side:
Serial number: 35627SME5117012DZZZ7
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Revision: -------- Serial number: 90422LER0017Q
Coding: 108A140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 72EB60EEA5505B8E9D9-8027
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H07 0022
Serial number: 70000000000000493230
Coding: E20000
Part No SW: 5K0 920 973 C HW: 5K0 920 973 C
Component: KOMBI H05 0705
Coding: 270F01
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 3169AFE260D62096243-8064
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
Component: J533 Gateway H42 1632
Revision: H42 Serial number: 170512F1002176
Coding: 350002
VCID: 3F8DF9DAAE82C6E6A27-806A
Fault Status: 00101110
Fault Frequency: 20
Mileage: 39369 km
Date: 2026.14.06
Time: 21:39:34
Reset counter: 20
Mileage: 39369 km
Date: 2026.14.06
Time: 18:50:03
00469 - Infotainment Databus in Single Wire Operation
Fault Status: 00101100
Fault Frequency: 42
Reset counter: 17
Mileage: 39369 km
Date: 2026.14.06
Time: 21:45:39
Fault Status: 00110100
Reset counter: 20
Mileage: 39369 km
Date: 2026.14.05
Time: 21:47:15
Component: IMMO H05 0705
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADBF88E0D80134EA59-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662660870
Coding: 020100
VCID: 2A5BB88E4500534EE59-807F
00457 - Control Module for Network (J519)
Fault Frequency: 23
Reset counter: 21
01336 - Data Bus for Comfort System
Reset counter: 18
Reset counter: 18
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 G HW: 3C0 035 684 G
Component: RNS-MID H02 3696
Revision: AB001001 Serial number: VWZ6Z7N8015168
Coding: 04010402010000870005
Shop #: WSC 09003 957 00200
VCID: 275D41BA56126E26FA7-8072
01523 - Microphone for Telephone (R38)
Reset counter: 237
Mileage: 39493 km
Date: 2026.14.07
Time: 19:32:21
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 3169AFE2A8D62096243-8064
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
VCID: 377D91FA46B2FEA66A7-8062
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 326BA0EEADD01B8E5D9-8067
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Reset counter: 237
Mileage: 39493 km
Date: 2026.14.07
Time: 19:32:21
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 35619BF25CBE0CB678B-8060
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 36639CFE41B807AE711-8063
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664299469
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3A7B88CEBDA0E3CE959-806F
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Reset counter: 172
End ---------------------------------------------------------------------
