- Mar 9, 2015
- 413
- 274
- Australia
- C?ID=241363
Hi All,
First post with my shiny new Hex V2 interface
I'm in the process of trying to finish off what should be a fairly straight forward retrofit - PLA 2.0.
I've installed the new side sensors front and rear, routed the new wiring and installed the new PLA module.
I can't for the life of me however get the new front side sensors to work...rears seem OK in that they don't log any faults but I can't actually test them yet.
Wondering if anyone has had a similar issue or otherwise any ideas as I'm now at a bit of a dead end.
I have routed new power, ground and signal wires to bypass the existing and new harnesses.
Confirmed power at the connectors with a multimeter.
If I disconnect the new front side sensors I get exactly the same open/short to ground error as if they are plugged in.
If I connect the side front sensor pins to other working sensors, I still have open/short to ground on side front sensors.
I have tested one of the new sensors in the place of an existing front sensor, and it looks like it works fine.
The new sensors are part number 1T0919297A.
I have tried software upgrading the PLA module to 1K8919475E however got the same sensor errors.
I've quadruple checked the pinouts (front side assist sensors are connected to T18/2 and T18/13)
At this point the only thing I haven't tried is replacing the PLA module as the only other one I have is the older 8 channel PDC module.
Autoscan below, its not fully configured for park assist in terms of coding and adaptation of ABS, steering rack etc but I am just trying to get the sensors working firstly for OPS.
Monday,01,January,2018,13:30:29:58930
VCDS Version: 17.12.0.1 (x64) HEX-V2 CB: 0.4411.4
Data version: 20171213 DS285.1
VIN: WVWZZZ3CZ9E08 License Plate:
Mileage: 116040km-72103mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 36 42 44 46 47 52 53
55 5F 62 65 6C 6D 72
VIN: WVWZZZ3CZ9E08 Mileage: 116040km-72103miles
Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 AM HW: 03H 906 032 AB
Component: R3.6-FSI-EU4 F 3488
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 52104 002 1048576
VCID: 6D87377FB19F9D494484-8038
Part No SW: 02E 300 012 E HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1903
Revision: 04844002 Serial number: 00000810231260
Coding: 0000024
Shop #: WSC 05311 000 00000
VCID: 127D4483C861E2B13976-8046
Address 03: ABS Brakes Labels: None
Part No SW: 3AA 698 109 N HW: 3AA 614 109 AL
Component: J104 C2 450M VE1F 0042
Revision: --H07--- Serial number: 00000007379684
Coding: 0119716
Shop #: WSC 11111 111 45799
VCID: 44D1B2DBC295BC01FB6A-8010
Part No SW: 3AD 907 044 G HW: 3AD 907 044 G
Component: Climatronic H03 0404
Coding: 0031040004
Shop #: WSC 12345 123 61029
VCID: 372BD5178FC3E7996EE8-8062
13701424 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Bordnetz - kein Signal/Kommunikation]
Reset counter: 31
Mileage: 116043 km
Date: 2018.01.01
Time: 13:26:18
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000009027172
Coding: 668E8F0700041A00470000001E000000000B79435C400120000000000000
Shop #: WSC 12345 123 00000
VCID: 3333E107973B0BB952C0-8066
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 100908 022 0601
Coding: 00047029
Shop #: WSC 12345
Component: RLS 121108 054 0402
Coding: 00208936
Shop #: WSC 12345
Part No SW: 1K8 919 475 D HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0480
Revision: -------- Serial number: 39431711102403
Coding: 0121167011
ASAM Dataset: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00_VW36.rod
VCID: 3B23C927B3EBC3F98A90-806E
1111572 - Side Front Left Parking Aid Sensor
B10F6 14 [009] - Open or Short to Ground
Reset counter: 31
Mileage: 116043 km
Date: 2018.01.01
Time: 13:26:48
1112852 - Side Front Right Parking Aid Sensor
B10FB 14 [009] - Open or Short to Ground
Reset counter: 31
Mileage: 116043 km
Date: 2018.01.01
Time: 13:26:48
13639168 - Databus
[Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
Reset counter: 31
Mileage: 116043 km
Date: 2018.01.01
Time: 13:26:18
Address 13: Auto Dist. Reg Labels: 3AA-907-567.clb
Part No SW: 3AA 907 567 A HW: 3AA 907 567
Component: AC201 RDW A 036 0170
Revision: 00036000 Serial number: 00000000569541
Coding: 0010000
Shop #: WSC 00046 000 00000
VCID: 3829D62B8E5DE8E167F2-806C
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__00S VW10 HI 1815
Revision: 19013000 Serial number: 0039BPMPB81T
Coding: 0012371
VCID: 7AAD0C23F0D13AF1D106-802E
Subsystem 1 - Serial number: 6333FTS665962908
Subsystem 2 - Serial number: 6343FTS632552888
Subsystem 3 - Serial number: 6353ETS6NTCKVVNR
Subsystem 4 - Serial number: 6363ETS640PKVVNR
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BM HW: 5K0 953 569 T
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20160725000799
Coding: 199AA50003
VCID: 71BF2B0FA12779A960AC-8024
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0036
Coding: 830000
Address 17: Instruments (J285) Labels:. 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 881 HW: 3AA 920 881
Component: KOMBI H03 0705
Coding: 711F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 110114F2000857
Coding: 462007
VCID: 7BA30927F3EB03F9CA10-802E
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
Part No SW: 3AA 959 433 B HW: 3AA 959 433 B
Component: IMMO 052 0407
Revision: 00052000 Serial number: VWZCZ000000000
Shop #: WSC 12345 123 2097151
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F3BED777B132F593618-807A
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000691888917
Coding: 0005047
VCID: 71BF2B0FADA779A960AC-8024
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 143 3501
Revision: 00H15000
VCID: 392FD32FB557F1E998FC-806C
Component: KSG PQ47 ELV 052 0638
Coding: 00900A00D1034E7F000694157008DFCE607801
Component: Neigungssensor 004 0611
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 3C0 035 456 F HW: 3C0 035 456 F
Component: DSP 10 Kanal 0013
Revision: 00010000 Serial number: 00000000002780
VCID: 2313114727DB9B39A2A0-8076
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1518
Revision: 71009005 Serial number: 00000649588929
Coding: 0005046
VCID: 72BD2403A8A142B199B6-8026
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000248887
Coding: 0022157
Shop #: WSC 05311 000 00001
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0136
Coding: 2344193
VCID: 3431E21B92350C814BCA-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Part No SW: 5C0 035 680 E HW: 5C0 035 680 E
Component: MU-S-ND-ER H31 0363
Serial number: VWZAZ2T5074914
Coding: 027404080000000011111105440908001F0100D671F087003E
ROD: EV_MUStd4CTSAT_VW21.rod
VCID: 231311472B5B9B39A2A0-8076
Subsystem 1 - Part No SW: 3G0 919 866 BM HW: -----------
Component: MRM2 2018 --- 0915
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000699648
Coding: 0000144
VCID: 70B92E0BA6AD70A16FA2-8024
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000055443
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Coding: 01130608A201000700
Shop #: WSC 02572 003 1048576
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 3039EE0B6AAD30A12F22-8064
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 31
passive
Address 6D: Trunk Elect. Labels: None
Part No SW: 3C9 827 383 F HW: 3C9 827 383 F
Component: J605 HECKDECKEL 0720
Revision: 00H27001
Shop #: WSC 05311 000 08193
Subsystem 1 - Part No: 3C9 827 384 F
Component: J756 HECKDECKEL 0720
Subsystem 2 - Serial number: 0800H27001001B0148ÿ
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000693593
Coding: 0000144
End----(Elapsed Time: 01:53, VBatt start/end: 12.1V/12.1V. VIgn 11.9V)-----
