Battery Monitoring Control Module Fault
Adam Young
C?ID=315045
An Auto Scan identified a fault in my Battery Monitoring Control Module. Full scan attached
Sunday,31,December,2017,15:26:27:45944
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4407.4
Data version: 20171130 DS276.6
VIN: WAUZZZ4G8CN165114   License Plate: SM12 EKX
Mileage: 89513km-55620mi   Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 56 5F 62 69
          72
VIN: WAUZZZ4G8CN165114   Mileage: 89513km-55620miles
69-Trailer -- Status: Not registered 0001
Address 01: Engine (J623-CLAB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 311 D    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0003
   Revision: 53H37---
   Coding: 12194012052401020000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907311D 001007
   ROD: EV_ECM30TDI0114G0907311D.rod
   VCID: 2412E429EE50C8A71E9-8070
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 07A08701E005E1808B00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 36362E6148CC4A37B0D-8062
   Part No SW: 4H0 907 064 BG    HW: 4H0 907 064 BG
   Component: BCM2 2.0      H31 0333
   Coding: 03B93006000000000000
   VCID: 6FB8DB0577963BFFB3B-803A
   Serial number: 2312000061223016
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
   Component: KLIMA 2 ZONEN H10 0064
   Serial number: 16041200040477
   Coding: 3622000820
   ASAM Dataset: EV_AirCondiBasisUDS 002040
   ROD: EV_AirCondiBasisUDS_002.rod
0027 - Motor for Defroster Flap
          B1090 07 [008] - Mechanical Failure
                    Reset counter: 124
                    Mileage: 86791 km
                    Date: 2017.11.24
                    Time: 07:20:53
                    Voltage terminal 30: 14.23 V
                    Outside air temperature: 0.5 °C
                    Interior temperature: 4.45 °C
                    Defroster flap motor-Act.val.: 9996
                    Defroster flap motor-Specified value: 11581
                    Defroster flap motor-Stop open: 11280
                    Defroster flap motor-Stop closed: 10000
   Part No SW: 4H0 907 063 BJ    HW: 4H0 907 063 B
   Component: BCM1 2.0      H12 0111
   Revision: 13012002    Serial number: 00000001278715
   Coding: 690000108034A7600405008300005F5F0F9D860827080101000004402000
   VCID: 71BCDD7D61A22D0FA5F-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 120309  H35 0080
   Serial number:         120317110303
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 20136956
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
   Component: E1 - LDS  H07 0044
   Serial number: 04 04 2012  00000709
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 43788226000000000001
   Part No SW: 4H0 919 475 Q    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0060
   Revision: 11001001    Serial number: 55901209300226
   Coding: 090207
   ASAM Dataset: EV_EPHVA18AU57X0000 004005
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 40DA48B91A08F4871A1-8014
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG007Y8JK
   Coding: 30323436313330303537554A305234473053
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   Serial number: 3575HRB406718NQOG0N+
   Serial number: 3585HRB406918NQO39EV
   Serial number: 3515JRB40104UHL8E9OV
   Serial number: 3525JRB405H184CO3GD7
   Serial number: 3554VRB400M4UHPKGP5$
   Serial number: 3564VRB400M4UHPKIHA$
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20120413001477
   Coding: 000015
   VCID: 303A1879AA286407EA1-8064
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0009
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 982 K    HW: 4G8 920 982 K
   Component: TDieGb        H79 0416
   Revision: 28460177    Serial number: 658030412596020
   Coding: 33A4100003012600010000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   VCID: 3C223C4976E09067469-8068
   Part No SW: 4G5 907 468 A    HW: 4G5 907 468
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000457606
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001013
   ROD: EV_GatewPkoUDS_001.rod
   VCID: 333017755BBE5F1F973-8066
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790807976
   Voltage stabilizer:
0021 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 118
                    Mileage: 89513 km
                    Date: 2017.12.31
                    Time: 15:23:17
                    Voltage terminal 30: 11.4 V
                    Voltage terminal 15: 11.6 V
                    Control Module temperature: 8 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0009
   Revision: --------    Serial number: EJ1BPA32021L0N0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: 6B80CF15430EC7DF9F3-803E
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011C16204001620002080002
   VCID: 42DE42B11484E6970C5-8016
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0026467717
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323E1271A4A456179C5-8066
   Revision: 00002001    Serial number: 0174000125
   Coding: 013B062220B9044083200904000104000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 41DC4DBD1182FD8F15F-8014
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000316200
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2A0E0A118C741ED7245-807E
   Part No SW: 4G0 035 056 E    HW: 4G0 035 056
   Component: Radio U STD   H60 0093
   Revision: AB001007    Serial number: 230DQ0C7556510
   Coding: 010003020100000001
   VCID: 2310E735EBDECF9F673-8076
   Part No SW: 4G0 035 670 H    HW: 4G0 035 670 H
   Component: H-BNT-EU      H49 0526
   Revision: --------    Serial number: 190DM0C7501016
   Coding: 050101010003A1ED05008B3E00000003000001000000000000
   VCID: 280AF01992F82CC7321-807C
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC94017AAC
   Subsystem 3 - Part No SW: 4G2 919 710 C    HW: 4G2 919 710 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LD500108
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010814204001620002080002
   VCID: 44D244A90E90E8A73E9-8010
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Towbar module H07 0100
   Coding: 0100000100000000
   Component: TSG HR        H04 0212
End----(Elapsed Time: 01:58, VBatt start/end: 11.7V/11.9V. VIgn 11.9V)-----
The timing of it coincided with when I installed an aftermarket trailer module. I thought perhaps it was because I'd had the battery disconnected and had read on the Ross-Tech Wiki paghe about programming the battery details. When I checked there were no battery details in my module so I entered them as per the instructions, cleared all codes, re-ran the auto-scan and still have the same fault, so Iguess I was barking up the wrong tree. Any advice on what this fault actually is and how I can rectify it would be appreciated.
Many thanks
Adam
The fault is is from the Gateway, not the Battery Monitoring module. The latter is a sub-system of the former, and subs-systems don't have their own faults.
You might want to tell the Gateway that you've installed a trailer module. I suspect that will make it happy again.
Adam Young
C?ID=315045
Thank you very much Uwe, you were spot on. :)
