Intermittent issues with DSG
NitrousOxide
Jamaica
C?ID=269481
Greetings,
I have developed an issue with my DSG since yesterday where it just did what I'd call a "neutral dump" where it somehow falls out of "gear". In other words, I was cruising along and it was as though the transmission went from Drive to Neutral where the engine RPM shot straight up. I brought the car to a stop and placed the shifter in Park, but couldn't get it out of Park. I switched the engine off, but couldn't restart as though the interlock was preventing me from being able to do so. I did a combination of locking and unlocking the car with the key-fob and clearing the error codes using a third party tool that I had on-hand at the time. The car started and I was able to complete my journey problem free. One of the errors I saw on the dashboard at the point the issue occured was something about the brakes overheating (which was impossible on the basis that I was previously driving up a slight incline after sitting in traffic).
Fast forwarding to today: I drove my car to work issue free. I did the VCDS clutch adaptation (group 60) since both the engine and DSG was at operating temperature in the parking lot. I did not do a test drive.
Later this evening (going home time) when I drove out the parking lot, I noticed the car was stuck in first gear and the PRNDS lights were blinking to alert me to a DSG error. The DSG does not select a gear when I place it in Reverse. I pulled out the VCDS to do a scan on the car below. I checked all fuses and those were good. I haven't tested the relays as yet.
Thursday,28,December,2017,18:19:42:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.12.0.1 (x64)
Data version: 20171213 DS285.1
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ1KZ8W111078   License Plate: 3395 GY
Mileage: 173240km-107646mi   Repair Order: Matthew Taylor3
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
VIN: WVWZZZ1KZ8W111078   Mileage: 173240km-107646miles
77-Telephone -- Status: Not registered 0001
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
   Coding: 040300101C070160
   Shop #: WSC 66565 257 00032
   VCID: 354FD8585CDD5E822C4-8060
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
                    Mileage: 173234 km
                    Time: 08:14:31
                    RPM: 1410 /min
                    Load: 11.0 %
                    Speed: 38.0 km/h
                    Temperature: 63.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow
                    Fault Status: 01100010
                    Mileage: 173239 km
                    Time: 08:23:54
                    RPM: 752 /min
                    Load: 14.9 %
                    Temperature: 85.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 008 -
                    Fault Status: 01101000
                    Mileage: 173241 km
                    Time: 18:04:11
                    RPM: 1143 /min
                    Load: 25.9 %
                    Temperature: 36.0°C
                    Temperature: 31.0°C
                    Voltage: 14.097 V
Readiness: 0110 0101
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1407
   Revision: 04808020    Serial number: 00000907050136
   Shop #: WSC 09537 809 89632
   VCID: 1C192DFCDF37EFCA33A-8048
            000 -  -
                    Fault Frequency: 255
                    Reset counter: 60
                    Mileage: 173241 km
19143 - Unexpected / Implausible Mechanical Gear Disengagement
            P2711 - 005 -  - MIL ON
                    Fault Status: 11100101
                    Mileage: 173241 km
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900B2C20-8026
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: 79D7146830457AE288C-802C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 01000007456322
   Coding: F70E8F2F000415000F140AFF1400FFE48019FD07FF10010C000000000000
   Shop #: WSC 11111 111 45725
   VCID: 71C72C48683532A230C-8024
   Component: Wischer 300807 021  0501
   Coding: 00038837
   Shop #: WSC 11111
   Component: RLS     130907 046  0204
   Coding: 00208933
   Shop #: WSC 11111
                    Fault Status: 01101100
                    Reset counter: 127
                    Mileage: 173234 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.70 V
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1FKU0T
   Coding: 0013121
   Shop #: WSC 01269 785 00200
   VCID: 3D5FC07864ED86C2E44-8068
   Subsystem 1 - Serial number: 6332MSME2C406B29H
   Subsystem 2 - Serial number: 6342MSME2C42223ED
   Subsystem 3 - Serial number: 6352QSME3D213635D
   Subsystem 4 - Serial number: 6362QSME3C0B0C41L
7 Faults Found:
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
            007 - Short to Ground - Intermittent - MIL ON
00589 - Airbag Igniter 1; Passenger Side (N131)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012122
   VCID: 01277C8858952222C0C-8054
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G83NA8OV
   Coding: 0006103
   Revision:   H07 01    Serial number: 040907F1000254
   Coding: ED811F060002020001
   Shop #: WSC 11111 123 12345
   VCID: 3041E94CA3BF7BAA7F2-8064
            000 -  -
                    Fault Frequency: 9
                    Mileage: 173214 km
                    Time: 20:00:39
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 120B
   Coding: 0000564
   Shop #: WSC 11111 111 45799
   VCID: 3851D16C4BCFA3EA372-806C
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H15000
   VCID: 2F43EA30BE816452668-807A
   Coding: 9890020851030C7F42CC0F0FF0085A2670B840
   VCID: 032B768042893032D20-8056
                    Reset counter: 126
                    Mileage: 173234 km
                    Time: 08:10:58
   Coding: 0000596
   VCID: 3957D46870C5BAE2C8C-806C
00121 - Outside Warning Light/Door exit Light Passenger Side
   Part No: 1T0 907 357
   Coding: 0000003
   Shop #: WSC 00000 785 00200
   VCID: 74C9255C1727078ADBA-8020
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L3180243
   Coding: 01000401000000
   VCID: 63EB560062C99032B20-8036
                    Reset counter: 125
                    Mileage: 173214 km
                    Time: 20:00:44
02633 - Antenna for Satellite Tuner
                    Reset counter: 125
                    Mileage: 173214 km
                    Time: 20:03:13
            000 -  -
                    Reset counter: 125
                    Mileage: 173214 km
                    Time: 20:03:18
Address 77: Telephone
End-------------------------(Elapsed Time: 01:12)--------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
NitrousOxide
Jamaica
C?ID=269481
It is important for me to declare that the DSG transmission fluid is due for a change now and as such I'll have to get it done this weekend.
I'm just trying to avoid the thought of a mechatronic failure as that would be a repair bill that would be difficult to swallow. It just seemed weird that the car took me to work quite fine (changing gears and everything). Now it just only goes into Reverse briefly when I clear ALL the error codes from all the modules (before flashing the PRNDS lights again then getting stuck in neutral). In Drive, the car stays in first gear so I can't even complete the documented test drive procedure. There needs to be an easier method of draining the DSG fluid other than pulling the bung underneath the DSG. I'm wondering if there is a way for the majority of it to be siphoned out of the filter hole up top underneath the battery. I don't have the fancy dealer tool to drain the "inner" reservoir.
Gone But Not Forgotten
Every time I see this it results in..........drum roll please!
Time for a DSG don't even bother with the fluid........ it won't help & is waste of money.......... :rolleyes:
NitrousOxide
Jamaica
C?ID=269481
I'm in Jamaica, so ordering and importing one is an arm and a leg. The car have an error message about "brakes overheating, check service manual", even though the car has been parked for hours. I suspect that it is an electrical issue. Which component other than fuses and relays should I be checking first? Where is the brake temperature being measured exactly?
Dukedesmo
C?ID=288946
Is the battery OK? I ask because I had an early (2004) A3, 3.2 DSG and I had the 'neutral dump' 3 times in the time that I owned it, and every time it happened it was shortly after start-up when the battery had been on the low side.
It had a battery drain problem that got worse as it got older, never did work out why but (car's gone now so doesn't matter). It was OK if used every day or two but if left a week or so the battery would be low on charge, usually it would still start but then it, it would (sometimes) cycle through multiple errors; steering, ABS, coolant etc. they would all clear after maybe a minute and it would be OK but on the 3 occasions where the gearbox messed up it happened shortly after such an event.
Each time after I switched off and restarted it was fine.
I looked into mechatronic unit replacement at the time but fortunately mine never needed it (maybe would have later?) expensive new but can be repaired by some specialists for a fraction of the price.
NitrousOxide
Jamaica
C?ID=269481
I've suspected my battery for months. Sometimes the car will do a very slow start randomly once every month. My battery goes through batteries quite frequently (completely dead and can't crank).
I got a random TPMS low light as though it was reset, and one Xenon headlight will sometimes go out and be re-lit quickly as though the ballast was failing. Swapping the ballasts for testing does not rectify the issue (the bulbs are new). Some errors that I do get using a third party tool (OBDeleven) insufficient voltage for some modules, but the situation doesn't stay long enough when I scan with VCDS. In Jamaica, we don't have specialists who "repair" mechatronic units. The dealer (ATL Jamaica) will only do custom orders for new mechatronic units from Germany. Before I buy a brand new battery for testing, I just want to have an idea which relays control the distribution of power to the rest of the car. I'm willing to bet that it is a relay issue that is causing all this. I had a battery test done on the existing battery where a 500-Amp load was applied to it and the voltage did drop to 11.xx volts. It starts the car, but I don't know if it is enough to get everything else going once the alternator kicks in. I have done no testing whatsoever of the alternator, however my third party app claims that my terminal voltage is 14.1 with the engine running (where it used to be between 13.5-13.8 volts before).
Hmmm lets see....... what's the icon say? Oh yeah RTFB and JPPSG.
Trace for bad grounds & fuses using WD and read SSP too, for design and function & if in oppositional order to question.
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
By all means........... take all apart and inspect everything, further using RTFB and don't forget to purchase all the precision testing measuring devices and other tools to fix the DSG, versus changing the entire DSG unit like a dealer does.
Not going to be a battery on this unless it is shorted but I don't see a whiff of codes for low voltage unless you are supplying FOD scans
Dukedesmo
C?ID=288946
If you are certain it is the mechatronic and can manage without the car for whatever the turn-around time is then there are places here (UK) that can repair for significantly less than the new price, may not be practical though due to leaving the car hanging around with the gearbox apart plus the shipping costs?
Wouldn't hurt to fit a new battery if yours is suspect. My A3 got through 3 batteries in the time I had it and when I got rid of it, the battery was definitely on the way out again.
NitrousOxide
Jamaica
C?ID=269481
When you say shorted, do you mean an internally bad cell, or are you suggesting a wiring fault. I'll try a doing a jump-start with another battery to see if the issues are the same. The scans I've submitted are for my car which was previously flashed but restored to stock DSG and ECU settings months ago.
NitrousOxide
Jamaica
C?ID=269481
My A3 got through 3 batteries in the time I had it.
My car has been through 4 batteries now (same brand) and I've only had the car for 2 years (daily driven). I'll try doing a jump-start (just to ensure that the current is good) then do the auto scan again.
Trowbridge, UK
Then something is taking far too much current when the ignition is off.
My previous Audi RS4 was only driven once a week and the battery on that lasted 7 years, so 4 batteries in 2 years is very wrong.
NitrousOxide
Jamaica
C?ID=269481
Yesterday, I thought I had a "breakthrough" when I used the circuit tester to find fuses in my car un-blown, yet un-powered (no 12 volts). I then realised that these were just spare fuses sitting in the lot. I no have to do some basic testing of the relays, but first need to learn how each of them work (by relay number).
NitrousOxide
Jamaica
C?ID=269481
My car's symptoms are different now where I was able to drive the car home in limp mode (stuck in first gear with no reverse gear).
The codes I get now are:
VIN: WVWZZZ1KZ8W111078   Mileage: 145950km-90689miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Coding: 040300101C070060
   Shop #: WSC 80182 411 444102
   VCID: 354FD8585CDD5E9692-8060
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
                    Mileage: 145809 km
                    Time: 21:23:26
                    RPM: 752 /min
                    Load: 28.6 %
                    Temperature: 85.0°C
                    Temperature: 35.0°C
                    Voltage: 13.589 V
                    Mileage: 145809 km
                    Time: 21:23:37
                    RPM: 764 /min
                    Load: 27.8 %
                    Temperature: 85.0°C
                    Temperature: 35.0°C
                    Voltage: 13.843 V
   VCID: 1C192DFCDF37EFDE8D-8048
18149 - Clutch Pressure Adaptation
            P1741 - 002 - Limit Reached
                    Reset counter: 2
                    Mileage: 145809 km
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900A67C-8026
01487 - System Function Test
            000 -  -  - Intermittent
01486 - System Function Test Activated
            000 -  -
            013 - Check DTC Memory
   VCID: 79D7146830457AF636-802C
   Coding: E78C8B2F00041500471400041400000000097D075C100100000000000000
   VCID: 71C72C48683532B68E-8024
   Coding: 00038805
   Shop #: WSC 11111
   Coding: 00221517
   Shop #: WSC 11111
02498 - Left Low Beam Reflector Motor (V294)
                    Fault Status: 01111100
                    Reset counter: 232
                    Mileage: 145811 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.85 V
02499 - Right Low Beam Reflector Motor (V295)
                    Reset counter: 232
                    Mileage: 145811 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.85 V
01335 - Drivers Seat/Mirror Position Control Module (J543)
                    Fault Status: 01110100
                    Reset counter: 232
                    Mileage: 145809 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.50 V
                    Reset counter: 232
                    Mileage: 145809 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.55 V
   Coding: 0013121
   VCID: 3D5FC07864ED86D65A-8068
7 Faults Found:
   Coding: 0012102
   VCID: 01277C88589522367E-8054
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
   Coding: 0004103
   Shop #: WSC 12345 111 45725
   Shop #: WSC 12345 785 00200
   VCID: 3041E94CA3BF7BBEC1-8064
   Coding: 0000564
   VCID: 3851D16C4BCFA3FE89-806C
   Revision: 00H15000
   VCID: 2F43EA30BE816446D8-807A
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 9890020851030C7F02CC0F0FF0085A2690BC00
   VCID: 032B7680428930266C-8056
                    Reset counter: 225
                    Mileage: 145809 km
                    Time: 21:23:41
   Coding: 0000564
   VCID: 3957D46870C5BAF676-806C
   Coding: 0000003
   VCID: 74C9255C1727079E65-8020
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio PM6       018 0035
   Revision: 00018000    Serial number: VWZ5Z7G2174742
   Coding: 0040400
   VCID: 2A75FB248563016E0F-807E
End-------------------------(Elapsed Time: 01:03)--------------------------
Monday,15,February,2016,20:05:44:39976
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
Adaptation Channel 009:
Stored value
Saturday,30,December,2017,18:43:19:39976
VCDS Version: 17.10.0.2 (x64)
Data version: 20171026 DS283.3
   VCID: 354FD8585CDD5E825FF-8060
Readiness: 0110 0001
   VCID: 1C192DFCDF37EFCA401-8048
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900B2B1B-8026
   VCID: 79D7146830457AE2FB7-802C
   VCID: 71C72C48683532A2437-8024
   Coding: 00038837
   Shop #: WSC 11111
   Coding: 00208933
   Shop #: WSC 11111
   Coding: 0013121
   VCID: 3D5FC07864ED86C297F-8068
            007 - Short to Ground - MIL ON
   Coding: 0012122
   VCID: 01277C8858952222B37-8054
00002 - Transmission Control Unit
   Coding: 0006103
   VCID: 3041E94CA3BF7BAA0C9-8064
            000 -  -
   Coding: 0000564
   VCID: 3851D16C4BCFA3EA449-806C
   Revision: 00H15000
   VCID: 2F43EA30BE816452153-807A
   VCID: 032B768042893032A1B-8056
   Coding: 0000596
   VCID: 3957D46870C5BAE2BB7-806C
   Coding: 0000003
   VCID: 74C9255C1727078AA81-8020
   VCID: 63EB560062C99032C1B-8036
            000 -  -
End-------------------------(Elapsed Time: 01:08)--------------------------
If I select reverse, then I get the error code about an implausible disengagement. I can't seem to get to group 60 or 61 to do the adaptation again.
ivagp
C?ID=95551
fix your engine faults first
NitrousOxide
Jamaica
C?ID=269481
Those harmless engine faults existed long before the issue occurred.
My priority is in fixing the transmission issue at the moment
ivagp
C?ID=95551
Ok see you :popcorn:
NitrousOxide
Jamaica
C?ID=269481
The odd thing I've noticed is that I can only access Group 60 and 61 in the transmission control module when the engine is off, but not when the engine is running.
If I start the engine while accessing group 60 or 61, then I'm kicked out with the error code saying something to the effect that this is unavailable.
By Thursday this week, I should have the funds to order a new clutch kit and mechatronics unit.
Let me see in this short break if I can ask the right question in run on sentence question okay? ;)
Did you know that some basic settings tests in VCDS are restricted & because they are not supposed to be done while the vehicle is running or without a login & that may reflect it in the stack of the controller or in some cases even when they are not, someone at RT figured it out that someone would do this and not follow directions of the RTFB and try anyway so they disabled certain requests in program?
NitrousOxide
Jamaica
C?ID=269481
I was unaware of this at the time. I thought it was something possibly relay related under the dashboard or engine bay. It wasn't after I had replaced the complete DSG (then did some reading) I understood this.
I forgot to close this thread years later by admitting as you stated, new dual-clutch kit, mechatronic unit, and fluid with filter change, didn't fix the issue (but allowed me to drive the car normally for an additional day).
I had ended up having to order a complete DSG (which included all above mentioned components) to resolve the issue.
However, I disagree with group 60 and 61 being made unavailable with a running engine as it would be impossible to do the adaptation although I entered the security code.
Thanks for reminding me that I need to post up the new clutch-kit and mechatronic unit somewhere online as they have been only used for under 24 hours to drive about 9 kilometers from the dealer to my house.
