2008 GTI (Canadian) - TPMS import to USA
   #61
Duck dive
San Diego, USA
C?ID=345556
Ok. I went back to work at it today. Did a battery disconnect overnight. No comm to ccm. Then I removed new -CT ccm and reconnected. Got comm to cmm back. Hooray. Looking promising as long as it doesn't get weird again. Hope it was just the connection being temperamental.
I'm now going to reset the key remote. Also, a message about the radio too (it won't turn on). After that, I'll do some tests to verify no other mysteries or things not working. If all good, then source some OEM TPMS stem sensors and get installed at tire shop. Posting autoscan below in case anybody has tips on radio...
I found remote program instructions here (http://www.ross-tech.com/vag-com/cars/vw-remote-matching.html), but I'm such an amateur that I can't get it to work (using first method). I'll keep trying, but if anybody knows which method on this model MK5 GTI 2008, please let me know.
   #62
Duck dive
San Diego, USA
C?ID=345556
In reading about the remote matching issue, I came across this thread. https://forums.ross-tech.com/showthread.php?807-key-adaptation-trouble
When I try to "learn" the remote, I do not get any dash confirmation and it doesn't work.
Since my previous CCM was -CA and the new one is -CT, I think that my remote key (1K0 959 753 H, 315mhz) might be a problem. Are there any remote key gurus that know if what I suspect is true? and how to find out what remote key replacement part number to use?
   #63
Duck dive
San Diego, USA
C?ID=345556
Is the antenna (315mhz) part of the CCM?
   #64
Duck dive
San Diego, USA
C?ID=345556
So I decided to order the $30 new remote key to try to get it to match/learn with VCDS. I could not get 1K0 959 753 H (the original) to be matched with the new -CT CCM.
Here is the new remote key PN
1K0 959 753 P
I'll report when I find out if it works.
Does anybody have the part number of the TPMS sensors for the tires that would be from a USA based MK5 2008 GTI with the -CT CCM? I know there are a few different PNs and I want to be sure I get the correct OEM ones.
I would like to order those and get them installed/mounted in the tires asap.
   #65
golfi_vend
Tartu, Estonia
C?ID=195131
1K0 959 753 P
1K0907253D - Before installing them, it would be good practice to write down the ID from sensor and mark to which wheel it went.
New remote code seems good. Looks like different remote is used when 7K4 TPMS system is in use.
screencapture
Duck dive
San Diego, USA
C?ID=345556
Thank you for the tip. Good idea.
I have ordered TPMS sensors today.
I will continue to report back as progress (hopefully) is made.
   #67
Duck dive
San Diego, USA
C?ID=345556
I'm wondering... before I mount the TPMS sensors in the tires... is there a test to verify communication?
   #68
golfi_vend
Tartu, Estonia
C?ID=195131
You would need special tool to wake them up and read ID.
Duck dive
San Diego, USA
C?ID=345556
   #72
golfi_vend
Tartu, Estonia
C?ID=195131
I thought that this wake up procedure might work, but I wanted to know if anybody has tried it... or if there is another method. Thank you for the link. I'd prefer to not have to buy another tool. Have you used this technique? Seems like the tool would be faster though...
http://wiki.ross-tech.com/wiki/index.php/VW_TPMS_Systems_without_Wheel_Position_Recognition
Little bit of info here. I did similar retrofit on my B6.
https://forums.ross-tech.com/showthread.php?8337-Passat-B6-TPMS-retrofit&highlight=tpms
Pictures are dead though. :(
   #73
Duck dive
San Diego, USA
C?ID=345556
Sadly, the new remote key matching is not working with the -P part number and the -CT CCM.
Getting quite discouraged that this simple isn't possible. And thinking that if the remote key cannot be matched that the TPMS sensors probably won't work either.
   #74
I searched our files for 1K0 959 433 CT and narrowed my results down to US market Golfs with TPMS. 1K0 959 753 P (4 buttons, 315 MHz) was the factory remote for the first few VINs I checked so it should be correct. One of the most common 46 coding strings appears to be: 139006885103281B0904058FB0080A04889C00
You might not want to paste that entire string into your module but you could use it, of the GTI scan in back in post 10, to check the current coding. Posting another scan with it communicating couldn't hurt.
Also, did you clear all remotes in channel 00 before attempting to match the P remote? http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Comfort_System#Adaptation
somedude
Yuengling Country
C?ID=306296
OP
I apologize for not reading all 8 pages, so what I will post here might be redundant.
I am in a similar situation and I did the following:
- obtained a letter of compliance with DOT from vehicle manufacturer (call them, customer service should be able to direct you)
- depending on what that says, act accordingly
- in regards to TPMS, I had to do the same, but fortunately, I had the right ABS module with support, so I enabled it
- one thing my letter says is that speed must be able to be read in mph. I don't have the dual unit dial, but I set the MMI to digital speed in mph, so I'll see if that goes.
I hope this helps.
   #76
Duck dive
San Diego, USA
C?ID=345556
We tried, but the vehicle in its original state was not compliant. VW sent a letter stating that it is not compliant. I called nearly every Registered Importer in the USA, many dealerships, and VW of America and Canada, but nobody was willing to help or even give a price to install Direct TPMS. I also focused on ones around the border.
In my research, it appears that maybe the CBP/Import authorities have some ability to make an exception, if you don't have the letter.
My strategy at this point is to get the Direct TPMS installed and enabled. Then go to a dealer to have them run their scan so I can show that it is there and working. I do not think I will receive anything from VW of A, they are not willing to help.
Finally, I will go back down to the CBP/Import with a stack of documentation (and a tire pressure gauge) to show how much of an effort I've made, and assuming it is working, hope that they will approve the import.
   #77
somedude
Yuengling Country
C?ID=306296
Oh wow, what an ordeal! I sympathize.
I will keep my fingers crossed for you. Any good vibe might actually help.
Good luck with the direct monitor.
Duck dive
San Diego, USA
C?ID=345556
Dana, I tried the recode of the 46-CCM -CT with the long code 139006885103281B0904058FB0080A04889C00 that you provided. It was accepted, but still not able to remote match. Yes, I did use channel 0 to clear first. Right now, we are not driving the car because it is not able to be insured... and I have the old -CA CCM that I can swap back in... so I'm ok with making code changes to try.
I did notice that the original code and the code you provided have a 93 vs a 13 to begin.
Also wondering if there is an actual physical antenna difference that might be preventing the comm?
Next two posts will be latest autoscans
   #79
Duck dive
San Diego, USA
C?ID=345556
Original code
Thursday,20,September,2018,18:05:55:15635
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: WVWEV71K88W168445   License Plate:
Mileage: 111840km-69494mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K88W168445   Mileage: 111840km-69494miles
   Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0GN3N67YR
   Coding: 0403010A18070160
   Shop #: WSC 01279 785 00200
   VCID: 363525885444AC879B8-8062
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -  - Intermittent
                    Fault Status: 00111000
                    Mileage: 106103 km
                    Time: 02:03:52
                    RPM: 1940 /min
                    Load: 36.5 %
                    Speed: 17.0 km/h
                    Temperature: 72.0°C
                    Temperature: 35.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
Readiness: 0110 0101
   Revision: 00H11001
   Coding: 0021122
   VCID: 73B3DC9C07B6F9AF7C6-8026
   Part No SW: 1K0 907 044 CQ    HW: 1K0 907 044 CQ
   Component: ClimatronicPQ35 130 1212
   Revision: 00130022    Serial number: 00000000000000
   VCID: 78A9EBB01ED09AF7494-802C
   Revision: 00H54000    Serial number: 01000007715840
   Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
   Shop #: WSC 91511 999 72883
   VCID: 71BFD6947DAACBBF8EA-8024
   Component: Wischer 071107 021  0501
   Coding: 00038805
   Shop #: WSC 91511
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0179201
   VCID: 2E050DE8AC149447D38-807A
            000 -  -
                    Fault Frequency: 21
                    Reset counter: 190
                    Mileage: 111272 km
                    Time: 18:27:15
   Component: 6L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D09VZWB
   Coding: 0013900
   Shop #: WSC 01269 785 00200
   VCID: 6C81C7E05A882657BDC-8038
   Subsystem 1 - Serial number: 6332MSME315748627
   Subsystem 2 - Serial number: 6342MSME31530F087
   Subsystem 3 - Serial number: 6352QSME42232131
   Subsystem 4 - Serial number: 6362QSME446E0A0FV
   Subsystem 5 - Serial number: 63727SME107C4807%
   Subsystem 6 - Serial number: 63827SME0F1F2E61F
   Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
   Coding: 0002022
   VCID: 75B7E28409C2E79F522-8020
   Part No SW: 1K6 920 874 A    HW: 1K6 920 874 A
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0GN3N67YR
   Coding: 0007303
   Shop #: WSC 19410 444 98964
   VCID: 313F1694BD2A8BBFCEA-8064
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K07A27014F
   Coding: E9811F070013020000
   VCID: 30391390B62082B7C14-8064
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T28PM03
   VCID: 7DA7FAA431F2BFDF1A2-8028
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 38292BB05E505AF7894-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 353722844942A79F922-8060
            000 -  -
   Coding: 939006885103281B0904058FB0080A04889C00
   Shop #: WSC 12345 785 00200
   VCID: 04518F405218CE1755C-8050
01179 - Incorrect Key Programming
            000 -  -
                    Fault Frequency: 14
                    Reset counter: 217
                    Mileage: 111845 km
                    Time: 00:33:45
   Coding: 0001076
   VCID: 392F2EB4655A43FF76A-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B1DF8002B8FE9765C-8020
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio PM6       130 0037
   Revision: 00130000    Serial number: VWZ5Z7I2297042
   Coding: 0040401
   Shop #: WSC 39612 828 149130
   VCID: 290FFEF495FAF37F06A-807C
                    Reset counter: 217
                    Mileage: 111845 km
                    Time: 00:15:22
   Coding: 0100101
End----(Elapsed Time: 01:07, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Friday,21,September,2018,16:53:07:15635
                    Mileage: 106103 km
                    Time: 02:03:52
                    RPM: 1940 /min
                    Load: 36.5 %
                    Speed: 17.0 km/h
                    Temperature: 72.0°C
                    Temperature: 35.0°C
                    Voltage: 14.224 V
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 91511
            000 -  -
                    Fault Frequency: 21
                    Reset counter: 190
                    Mileage: 111272 km
                    Time: 18:27:15
   Coding: 0013900
   Coding: 0002022
   Coding: 0007303
   Coding: 0001077
            000 -  -
            000 -  -
                    Fault Frequency: 15
                    Reset counter: 217
                    Mileage: 111845 km
                    Time: 00:33:45
   Coding: 0001076
   Coding: 0000003
   Coding: 0040401
                    Reset counter: 217
                    Mileage: 111845 km
                    Time: 00:15:22
   Coding: 0100101
End----(Elapsed Time: 01:08, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
Duck dive
San Diego, USA
C?ID=345556
Code you provided
Friday,21,September,2018,16:55:43:15635
Mileage: 111840km-69494mi   Repair Order: -after code change
                    Mileage: 106103 km
                    Time: 02:03:52
                    RPM: 1940 /min
                    Load: 36.5 %
                    Speed: 17.0 km/h
                    Temperature: 72.0°C
                    Temperature: 35.0°C
                    Voltage: 14.224 V
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 91511
            000 -  -
                    Fault Frequency: 21
                    Reset counter: 190
                    Mileage: 111272 km
                    Time: 18:27:15
   Coding: 0013900
   Coding: 0002022
   Coding: 0007303
   Coding: 0001077
            000 -  -
   Coding: 139006885103281B0904058FB0080A04889C00
            000 -  -
                    Fault Frequency: 15
                    Reset counter: 217
                    Mileage: 111845 km
                    Time: 00:33:45
   Coding: 0001076
   Coding: 0000003
   Coding: 0040401
                    Reset counter: 217
                    Mileage: 111845 km
                    Time: 00:15:22
   Coding: 0100101
End----(Elapsed Time: 01:07, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
