2008 GTI (Canadian) - TPMS import to USA
   #21
Duck dive
San Diego, USA
C?ID=345556
And when I took it to a VW dealer to have them run a scan on it... I got a lot of errors including VAG01330 (no signal/comm) and VAG01044 (incorrect programming).
   #22
Duck dive
San Diego, USA
C?ID=345556
Does anybody know what the two letter designation at the end of the CCM part number mean? I have seen the following... Are the geographic designations?
1K0 959 433 CA (the one the GTI had original from Canada)
1K0 959 433 CT (the one I bought from ebay, but from a USA Jetta, 99% sure)
1K0 959 433 AS
1K0 959 433 CD
1K0 959 433 DA
   #23
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
1K0 959 433 AS
1K0 959 433 CD
1K0 959 433 DA
Variants or revisions of the same basic part. Can mean anything. Here's what it means in your case:
Your car came with the -CA version. It's the only one that isn't grayed out, when querying VW's parts database using your VIN. Those PR codes are factory production codes that tell you when/why a particular variant would be fitted to your vehicle. You can look them up here: http://prsearch.planetvag.com/.
The only one with a PR code mentioning TPMS support is the -CT variant, the one you already bought. It also mentions some odd Mexico-only stuff, but that may just be because it was manufactured in Mexico. I pulled up a random USA 2008 GTI for sale on eBay:
https://www.ebay.com/itm/Volkswagen...ash=item4b495a421c:g:5BEAAOSwytFbb2Ow&vxp=mtr
And it looks like that vehicle indeed came with the -CT variant:
So you've bought the right thing. As for the sensors, here you go:
As for any programming/coding necessary, VCDS should be able to accomplish that. Not having VCDS available is going to be an issue. We're not going to be able to guide you through that blind, if you can't produce Auto-Scan data for us and let us see what changes are needed and then put those back in. May I suggest a trip to the Ross-Tech store for a HEX-V2 Enthusiast? It appears you've already spent more than half of that cost, or more, getting a dealer to just throw their hands up in confusion. :)
Duck dive
San Diego, USA
C?ID=345556
Great information. Thank you. Luckily, the dealer performed the scan at no charge.
My friend and I both have 1993 Eurovans, and we get together once a year to scan them. I think he bought the 2x2 adapter to do that.
I'm still waiting for him to get back to me... but I guess it is time for me to pickup my own.
Just ordered from Ross Tech. Will report back once I can Autoscan and post results.
I will perform one with the original. Then I will install the CT version and perform another Autoscan.
Stay tuned.
   #25
Duck dive
San Diego, USA
C?ID=345556
Rcvd my HEX-V2 to scan this GTI (and a 2x2 for my 1993 Eurovan too)
Here are the Autoscan results with the original (Canadian) CCM
This is my first ever, so please bear with me.
I notice something about the ignition switch... it has hesitated when started sometimes (we already replaced original battery).
The headlight one... guess I need to research.
The cooling one is probably the thermostat (I have a cheap bluetooth OBD2). But $500 to swap (called two places). Not sure I want to try it myself. Why do they put a part that will fail so deep in there?
Then there is the 1330 no signal/intermittent with the CCM. Not sure about that???
Anyway, the goal is to swap the CCM to the USA version ending in -CT. Now that I have done the Autoscan, is there a way to copy the settings so they can be input in the the USA CCM?
Friday,31,August,2018,14:50:39:15635
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: WVWEV71K88W168445   License Plate:
Mileage: 111750km-69438mi   Repair Order:
Gateway Installation List:  1K0 907 530 L
46-Central Conv. -- Status: Malfunction 1010
Friday,31,August,2018,14:52:13:15635
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56
VIN: WVWEV71K88W168445   Mileage: 111750km-69438miles
   Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0GN3N67YR
   Coding: 0403010A18070160
   Shop #: WSC 01279 785 00200
   VCID: 363525885444AC879B8-8062
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -  - Intermittent - MIL ON
                    Fault Status: 10101000
                    Mileage: 106103 km
                    Time: 02:03:52
                    RPM: 3077 /min
                    Load: 31.4 %
                    Speed: 61.0 km/h
                    Temperature: 75.0°C
                    Temperature: 35.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
   Revision: 00H11001
   Coding: 0004738
   VCID: 73B3DC9C07B6F9AF7C6-8026
   Part No SW: 1K0 907 044 CQ    HW: 1K0 907 044 CQ
   Component: ClimatronicPQ35 130 1212
   Revision: 00130022    Serial number: 00000000000000
   VCID: 78A9EBB01ED09AF7494-802C
   Revision: 00H54000    Serial number: 01000007715840
   Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
   Shop #: WSC 91511 999 72883
   VCID: 71BFD6947DAACBBF8EA-8024
   Component: Wischer 071107 021  0501
   Coding: 00038805
   Shop #: WSC 91511
            010 - Open or Short to Plus
                    Fault Status: 01111010
                    Reset counter: 214
                    Mileage: 110630 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.30 V
                    Reset counter: 247
                    Mileage: 111563 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.30 V
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0179201
   VCID: 2E050DE8AC149447D38-807A
            000 -  -
                    Fault Frequency: 21
                    Reset counter: 190
                    Mileage: 111272 km
                    Time: 18:27:15
   Component: 6L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D09VZWB
   Coding: 0013900
   Shop #: WSC 01269 785 00200
   VCID: 6C81C7E05A882657BDC-8038
   Subsystem 1 - Serial number: 6332MSME315748627
   Subsystem 2 - Serial number: 6342MSME31530F087
   Subsystem 3 - Serial number: 6352QSME42232131
   Subsystem 4 - Serial number: 6362QSME446E0A0FV
   Subsystem 5 - Serial number: 63727SME107C4807%
   Subsystem 6 - Serial number: 63827SME0F1F2E61F
   Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
   Coding: 0002022
   VCID: 75B7E28409C2E79F522-8020
   Part No SW: 1K6 920 874 A    HW: 1K6 920 874 A
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0GN3N67YR
   Coding: 0007303
   Shop #: WSC 19410 444 98964
   VCID: 313F1694BD2A8BBFCEA-8064
                    Reset counter: 247
                    Mileage: 111563 km
                    Time: 13:22:22
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K07A27014F
   Coding: E9811F060013020000
   VCID: 30391390B62082B7C14-8064
                    Reset counter: 247
                    Mileage: 111563 km
                    Time: 13:22:23
            000 -  -  - Intermittent
                    Reset counter: 247
                    Mileage: 111563 km
                    Time: 13:26:04
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T28PM03
   VCID: 7DA7FAA431F2BFDF1A2-8028
   Component: IMMO            VDD 1216
01176 - Key
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 38292BB05E505AF7894-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 353722844942A79F922-8060
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 939006885103281B0904058FB0080A0488BC00
   Shop #: WSC 00000 785 00200
                    Fault Frequency: 13
                    Reset counter: 247
                    Mileage: 111563 km
                    Time: 18:03:16
   Coding: 0001076
   VCID: 392F2EB4655A43FF76A-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B1DF8002B8FE9765C-8020
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio PM6       130 0037
   Revision: 00130000    Serial number: VWZ5Z7I2297042
   Coding: 0040401
   Shop #: WSC 39612 828 149130
   VCID: 290FFEF495FAF37F06A-807C
                    Fault Status: 01111011
                    Reset counter: 141
                    Mileage: 107460 km
                    Time: 11:44:21
End----------(Elapsed Time: 01:06, VBatt start/end: 12.4V/12.4V)-----------
Rcvd my HEX-V2
Got you Verified. Moving this to Retrofits now.
Well, we have the coding there. But it's not entirely clear to me whether the coding will transfer directly.
The other thing I would do, just to have it, is to make an Adaptation Channel Map from your CCM.
[Applications]
[Controller Channel Map]
Controller Address = 46
Login or Security Access Code: leave blank
Function: Adaptation
Output: CSV File
[Go]
Once that's done, I would physically swap the modules and run another scan so we can see what you've got. Don't change anything in the new module yet.
Duck dive
San Diego, USA
C?ID=345556
Here is the Adaptation Channel Map from the original CCM -CA (Canada)
I will swap to -CT CCM and run Autoscan and Adaptation and post later today.
;SW:1K0-959-433-CA HW:1K0-959-433-CA --- Central Conv.
;Component: KSG PQ35 G2 020 0204, Coding:939006885103281B0904058FB0080A0488BC00
;Saturday,01,September,2018,09:45:59:15635
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.2
;VCID: 71BFD6947DAACBBF8EA-8024
Channel,,Field 1,Field 2,Field 3,Field 4,
01,1,Key,learn (adapt),1, - ,
02,,ERROR:,Channel 02,Not,Available,
03,1,OPEN,Single Door,ON, - ,
04,1,Auto Lock /, ,ON, - ,
05,0,Auto Unlock, ,OFF, - ,
06,,ERROR:,Channel 06,Not,Available,
07,1,Unlocked,Remote Ctrl.,Blink, - ,
08,1,Unlocked,Key,Blink, - ,
09,,ERROR:,Channel 09,Not,Available,
Duck dive
San Diego, USA
C?ID=345556
Is it recommended (or required) to disconnect battery for swapping CCM?
   #30
Duck dive
San Diego, USA
C?ID=345556
Here is the Autoscan and Adaptation Channel Map from the CCM -CT (USA)
Saturday,01,September,2018,14:53:21:15635
Mileage: 111750km-69438mi   Repair Order: CCM-CT
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
65-Tire Pressure -- Status: Not registered 0011
                    Mileage: 106103 km
                    Time: 02:03:52
                    RPM: 3077 /min
                    Load: 31.4 %
                    Speed: 61.0 km/h
                    Temperature: 75.0∞C
                    Temperature: 35.0∞C
                    Voltage: 14.224 V
   Revision: 00H11001
   Coding: 0004738
   Coding: 00038805
   Shop #: WSC 91511
                    Fault Status: 01101010
                    Reset counter: 214
                    Mileage: 110630 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.30 V
                    Reset counter: 254
                    Mileage: 111563 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.30 V
            000 -  -
                    Fault Frequency: 21
                    Reset counter: 190
                    Mileage: 111272 km
                    Time: 18:27:15
   Coding: 0013900
   Coding: 0002022
   Coding: 0007303
                    Reset counter: 254
                    Mileage: 111563 km
                    Time: 13:22:22
                    Reset counter: 254
                    Mileage: 111563 km
                    Time: 13:22:23
            000 -  -
                    Reset counter: 214
                    Mileage: 111563 km
                    Time: 13:26:04
01176 - Key
   Coding: 0001077
   Component:    KSG PQ35 RDK 052 0218
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   Shop #: WSC 00066 000 00000
   VCID: 04518F405218CE1755C-8050
                    Reset counter: 247
00830 - Convertible Top Control Module (J256)
                    Reset counter: 203
                    Fault Status: 00110100
                    Reset counter: 247
                    Reset counter: 203
                    Reset counter: 247
   Coding: 0001076
   Coding: 0000003
   Coding: 0040401
                    Reset counter: 141
                    Mileage: 107460 km
                    Time: 11:44:21
   Component:    RDK              0440
   Coding: 0100101
                    Reset counter: 254
                    Mileage: 111578 km
                    Time: 12:23:37
End----------(Elapsed Time: 01:09, VBatt start/end: 12.1V/12.2V)-----------
;SW:1K0-959-433-CT HW:1K0-959-433-CT --- Central Conv.
;Component: KSG PQ35 RDK 052 0218, Coding:13900F880186281B0904058FB0880F0488DCA0
;Saturday,01,September,2018,14:53:56:15635
;VCID: 04518F405218CE1755C-8050
10,3,Locked,Remote Ctrl.,Beep + Blink, - ,
11,3,Locked,Key,Beep + Blink, - ,
12,2,safe, ,Beep, - ,
13,,ERROR:,Channel 13,Not,Available,
14,,ERROR:,Channel 14,Not,Available,
15,,ERROR:,Channel 15,Not,Available,
16,,ERROR:,Channel 16,Not,Available,
17,0,Comfort,Remote Ctrl.,OFF, - ,
18,1,Alarm delay,Driver,ON, - ,
19,0,Locked,Inactive,OFF, - ,
20,,ERROR:,Channel 20,Not,Available,
21,,ERROR:,Channel 21,Not,Available,
22,,ERROR:,Channel 22,Not,Available,
23,,ERROR:,Channel 23,Not,Available,
24,,ERROR:,Channel 24,Not,Available,
25,,ERROR:,Channel 25,Not,Available,
****** Continues
OK, the first thing to do is to register the TPMS module (which is really part of the CCM) in your Gateway.
[Select]
[19-CAN Gateway]
Scroll down to 65-TPMS and put a check-mark next to it.
[Save Coding]
The go though and clear all the fault codes from everything and see what comes back.
Have you got appropriate TPMS sensors installed in all the wheel/tire assemblies?
Duck dive
San Diego, USA
C?ID=345556
Here is the Autoscan (USA CCM -CT, cleared DTCs)
Note: I do not have the tire sensors yet. I want to ensure I can do this before I purchase and have installed at tire shop.
Sunday,02,September,2018,10:01:25:15635
Mileage: 111750km-69438mi   Repair Order: -ct-cleared
                    Mileage: 106103 km
                    Time: 02:03:52
                    RPM: 3077 /min
                    Load: 31.4 %
                    Speed: 61.0 km/h
                    Temperature: 75.0∞C
                    Temperature: 35.0∞C
                    Voltage: 14.224 V
   Revision: 00H11001
   Coding: 0004738
   Coding: 00038805
   Shop #: WSC 91511
            000 -  -
                    Fault Frequency: 21
                    Reset counter: 190
                    Mileage: 111272 km
                    Time: 18:27:15
   Coding: 0013900
   Coding: 0002022
   Coding: 0007303
   Coding: E9811F070013020000
   Coding: 0001077
   Coding: 0001076
   Coding: 0000003
   Coding: 0040401
                    Reset counter: 214
                    Mileage: 111753 km
                    Time: 10:02:58
   Component:    RDK              0440
   Coding: 0100101
End----------(Elapsed Time: 01:06, VBatt start/end: 12.1V/12.1V)-----------
Looks pretty good to me! (*)
I've forgotten what the deal is with the antenna(s) for this setup; i.e. whether it requires anything external.
(*) Aside from the P2181 Code in the ECU, which will of course cause you to fail smog in Kalifornia.
   #34
Duck dive
San Diego, USA
C?ID=345556
That is good news. So I'll locate some sensors and get installed.
What about the CCM Adaptation Channel Map? How can I import the values from the original CCM (-CA, Canada)?
   #35
I'm not sure you need to, but it's good to have them for posterity, just in case..
Duck dive
San Diego, USA
C?ID=345556
Well, right now, the trunk and fuel door buttons are swapped. So something is wrong. And looking at the ACM map from the original to the new look very different.
Since the new CCM didn't come from a GTI (it seems) then, I assume the ACM is wrong.
Wouldn't I need to adjust ACM, especially with this irregular behavior with the trunk/fuel door?
   #37
I don't see anything in those modules that would make this configurable.
Let's whether it's confused about the switch inputs or the actuator outputs.
Go to Output Tests and use Selective. There should be one for the Tank Flap and another for the Hatch/Trunk/Rear Lid. Hit them and let us know whether they're correct or bass-ackwards.
Duck dive
San Diego, USA
C?ID=345556
Definitely backwards. Same behavior in VCDS tests as with door buttons or key FOB buttons.
And when I use the logo truck handle, it opens the fuel door.
   #39
golfi_vend
Tartu, Estonia
C?ID=195131
Well....I see that many bytes are different to Your original "CA" coding. I would suggest trying coding: 939006885103281B0904058FB0080A04889C00 , it is same as Your original, but with TPMS enabled.
Many of the bytes are undocumented, so we have no idea what they are.
   #40
Hmm... Unless I'm missing something, it sounds like you might have to re-pin the connector to the CCM then.
If anyone else has any other ideas, please chime in.
