Wednesday,20,December,2017,18:08:57:52461
VCDS Version: 17.8.0.1 (x64)
VIN: WAUFFGFF0F1070868 License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 47 52 55 5F
6C A9 BB BC
VIN: WAUFFGFF0F1070868 Mileage: 5520km-3429miles
BB-Door Rear Drv -- Status: Malfunction 0010
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 E HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 0A1D00322426000E3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259E 001002
ROD: EV_ECM20TFS0208V0906259E.rod
VCID: 428CC68CD5433C56DC-8016
17178 - Databus
U1123 00 [047] - Received Error Message
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:29
Engine speed: 0.00 /min
Coolant temperature: 88 °C
Intake air temperature: 46 °C
Voltage terminal 30: 12.304 V
Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping speed
Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after DTC-induced shutdown
Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer. braking
Drivetrain coordinator: brake fault status-ESP: no error
Drivetrain coordinator: brake fault status-Deceleration controller: Available
Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
Drivetrain coordinator: brake fault status-Bit 1: no error
Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message consistency error
Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
Drivetrain coordinator: brake fault status: 5
Drivetrain coordinator: brake function status-Parking Brake: not active
Drivetrain coordinator: brake function status-ACC: Not braking
Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
Drivetrain coordinator: brake function status-Driver: Not braking
Drivetrain coordinator: brake function status-Hill descent control: passive
Drivetrain coordinator: brake function status-ASR: no intervention
Drivetrain coordinator: brake function status-MSR: no intervention
Drivetrain coordinator: brake function status-ADS: no intervention
Drivetrain coordinator: brake function status-ABS: no intervention
Drivetrain coordinator: brake function status-EDL: no intervention
Drivetrain coordinator: brake function status-ASP: no intervention
Drivetrain coordinator: brake function status-AWV2: No warning pressure
Drivetrain coordinator: brake function status-Bit 4: no intervention
Drivetrain coordinator: brake function status-Bit 11: not passively cycled
Drivetrain coordinator: brake function status-Bit 12: not passively cycled
Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
Readiness: 1010 0101
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4521
Revision: 03253104 Serial number: TFK01409211795
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_VW37.rod
VCID: 1F4A6FF8067131BE93-804A
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62804000001796
Coding: 31FF6B9254270A6C017F030641CB698CD62A5080C08296B6024100588608
Shop #: WSC 48663 001 1048576
ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
VCID: 4586DD90C46D0B6EF9-8010
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 63
Date: 2016.07.14
Time: 06:46:30
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 63
Date: 2016.07.14
Time: 06:46:30
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 63
Date: 2016.07.14
Time: 06:46:30
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 63
Date: 2016.07.14
Time: 06:46:30
C1146 02 [137] - Signal Failure
Reset counter: 63
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:39
33000 - Longitudinal Acceleration
C10B1 29 [137] - Signal Implausible
Reset counter: 63
Date: 2016.07.14
Time: 06:46:30
Revision: 00021000 Serial number: 0347604164
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3A7CBE6CBD93749684-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000451410
Coding: 03000014010000000000000000001400
VCID: 336293489AF985DE47-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: C6B84057000000000001
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 64
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:29
Outside air temperature: 8.5 °C
Temperature after evaporator: 26.0 °C
Refrigerant pressure: 1.0 bar
Part No SW: 5Q0 937 085 AC HW: 5Q0 937 085 AC
Component: BCM MQBAB HNA H18 0134
Serial number: 01011426500482
Coding: 04151C46404106FD41C04004511807A00800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7AFC7E6CFD13B496C4-802E
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 140912 042 0585
Serial number: 140924215426
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23250614
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Serial number: 23 07 2014 00000046
Serial number: 00000000000060677680
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO32929111
Coding: 101F00
558100 - Databus
Reset counter: 64
Mileage: 5520 km
Date: 2016.08.22
Time: 05:03:57
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39331426305299
Coding: 0030150011
13637426 - Databus
Reset counter: 63
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:29
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR00T9BL
VCID: 479AD798FE61197E0B-8012
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34178311B07101440487
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34178312B07101470723
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y1400017NV00Y
Coding: 303230
Subsystem 4 - Part No SW: ----------- HW: 480 002 909 14
Serial number: 35700000000F7A34F01R
Subsystem 5 - Part No SW: ----------- HW: 480 002 909 14
Serial number: 358000000007AA34F01N
Subsystem 6 - Part No SW: ----------- HW: 480 402 909 14
Serial number: 3510002BB175A90091B0
Subsystem 7 - Part No SW: ----------- HW: 480 401 909 14
Serial number: 3520002A9176A6C17230
Subsystem 8 - Part No SW: ----------- HW: 480 400 808 14
Serial number: 35500029916FC22340B3
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 311 12
Component: FrontSensor_P 001 6149
Serial number: 3560002B30CC5BF032AE
9445973 - Seat occupied recognition control module
B1022 55 [137] - Not configured
Reset counter: 64
Mileage: 5520 km
Date: 2016.07.26
Time: 11:22:56
1050117 - Databus
Reset counter: 64
Mileage: 5520 km
Date: 2016.07.26
Time: 09:34:10
1049094 - Databus
Reset counter: 64
Mileage: 5520 km
Date: 2016.07.26
Time: 09:34:10
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 03101408490168
Coding: A018
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 0A1C2EACADF3A416D4-805E
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 8V0 920 871 L HW: 8V0 920 871 L
Component: KOMBI H02 6423
Coding: 03AD181A2B8800080204EE001800000000000000
Shop #: WSC 62170 001 104857
ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 03101410800018
Coding: 0101000820085A005B00022C180B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
66568 - Local data bus 2
U1076 00 [008] - Electrical malfunction
Reset counter: 104
Mileage: 5520 km
Date: 2016.08.22
Time: 04:55:32
Supply voltage: Terminal 30: 14.8 V
Terminal 15: On
197169 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Fault Frequency: 22
Reset counter: 65
Mileage: 5520 km
Date: 2016.08.22
Time: 04:41:06
Supply voltage: Terminal 30: 11.6 V
Terminal 15: On
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00009.08.14
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
VCID: 4684DA9CF96B0076F0-8012
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000270884002
Coding: 5D00000000000000
VCID: 346090549FF782E65E-8060
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0346835485
Coding: 030211
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3878A464839F668672-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0346892700
Coding: 030211
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 19091406070881
Coding: 005D1F205C00048000000002
VCID: 4088CC84DB4F2E46CA-8014
65604 - Door Warning Lamp
B1326 01 [008] - Electrical Failure
Reset counter: 104
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:29
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
ROD: EV_SteerAssisMQB_010.rod
VCID: 3566AD50948D9BEE69-8060
15873 - Steering angle sensor
Reset counter: 63
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:29
Motor status: 00
Supply voltage: 12.25 V
Temperature: 25.0 °C
KFC: 3E
KFA: 00 01
Environmental conditions: 5B
uioUdNotFilt_xdu16: 12.23 V
uAdSensI_SwitchedKl30_xdu16: 12.24 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19204 - Databus
Reset counter: 66
Mileage: 5520 km
Date: 2016.07.16
Time: 09:25:45
Motor status: 01
System status: Driving mode
Supply voltage: 11.75 V
Temperature: 7.0 °C
KFC: 4B
KFA: 00 04
Environmental conditions: 7F
uioUdNotFilt_xdu16: 11.84 V
uAdSensI_SwitchedKl30_xdu16: 11.84 V
Part No SW: 8V0 035 465 C HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0410
Serial number: AUZ8ZAEN900QK6B
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
1564 - Microphone for Vehicle/Ambient Noise
B13BB 13 [008] - Open Circuit
Reset counter: 104
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:31
Voltage terminal 30: 12.3 V
0527 - Front Right Treble Speaker
B1064 13 [008] - Open Circuit
Reset counter: 104
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:34
0522 - Front Left Treble Speaker
B1061 13 [008] - Open Circuit
Reset counter: 104
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:34
0537 - Rear Right Treble Speaker
B1068 13 [008] - Open Circuit
Reset counter: 104
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:34
0532 - Rear Left Treble Speaker
B1066 13 [008] - Open Circuit
Reset counter: 104
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:34
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 21091401100625
Coding: 005D17205E00048000000002
VCID: 3F8ACF78A6B151BEB3-806A
Reset counter: 104
Mileage: 5520 km
Date: 2016.07.16
Time: 09:26:51
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 012A000123200400
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
13705992 - Databus
Reset counter: 63
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:29
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 038 A HW: 8V0 035 038
Component: MU-H-LNS-US H42 0289
Serial number: A302I0EB004416
Coding: 017301020000000021211102041A00102F000365010001047E
ROD: EV_MUHig6C3HBAS_AU37.rod
VCID: 326C964C65E38CD64C-8066
Subsystem 1 - Part No SW: V03 959 800 SR HW: -----------
Component: NAR 2014/2015 --- 0032
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY201S6F
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000005081400040002
Compact Disc Database:
Component: Gracenote --- 3005
U1014 00 [009] - -
Reset counter: 64
Mileage: 5520 km
Date: 2016.08.22
Time: 05:08:08
Voltage terminal 30: 11.5 V
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ROD: EV_CamSysRearPANAVW428.rod
VCID: 30689C446BEFBEC63A-8064
9529428 - Steering angle sensor
Reset counter: 63
Mileage: 5520 km
Date: 2016.07.14
Time: 06:46:29
passive
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140910201221
VCID: 7DF67570EC3D83AEE1-8028
Part No SW: 5Q0 959 395 B HW: 5Q0 959 395 B
Component: TSG HFS 020 0025
Serial number: 01101402090316
Coding: 004D17204000048000000002
ROD: EV_DCURearDriveMAXCONT_VW37.rod
65548 - Supply voltage
Reset counter: 96
Mileage: 41434 km
Date: 2017.08.03
Time: 00:04:11
Reset counter: 104
Mileage: 41434 km
Date: 2017.08.03
Time: 00:32:53
Component: TSG HBFS 020 0025
Serial number: 01101401100323
ROD: EV_DCURearPasseMAXCONT_VW37.rod
B1326 01 [009] - Electrical Failure
Reset counter: 64
Mileage: 5520 km
Date: 2016.07.17
Time: 07:09:36
End-------------------------(Elapsed Time: 05:20)--------------------------
This is gonna be one of those retrofits that people are not going to give away too much information due to the potential value.great when you know what to do.
I got main buttons working, now sorting start-stop.
We'll need you to post a full Auto-Scan of your S8 plus the part number of the R8 steering wheel to be able to answer that question.does anybody knows what i need to do that?
Friday,18,May,2018,17:01:28:18831
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ4H2DN****** License Plate:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 18 19 1B 20 22 28 30
34 36 3B 3C 42 46 47 52 53 56 5F 62 69 6C 6D 6F 72 81 84 85
88 89 8B 8E 8F 90 A9 BA
VIN: WAUZZZ4H2DN030091 Mileage: 56345km-35011miles
Address 01: Engine (------CGTA) Labels: None
Part No SW: 4H0 907 557 HW: 4H0 906 014
Component: 4.0l V8TFSI / X62 0010
Revision: NCX62---
Coding: 022A003A6556010A1800
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM40TFS0114H0907557 001012
ROD: EV_ECM40TFS0114H0907557.rod
VCID: 6DD7F290BCD8712CC3-8038
Readiness: 1110 1100
Part No SW: 4H1 927 158 BL HW: 0BK 927 156 AG
Component: 0BK 40TFSIRdW H16 1005
Revision: --H16---
ASAM Dataset: EV_TCMALX51011 002020
ROD: EV_TCMALX51011.rod
VCID: 7BF3CCC8F2ACEF9C4D-802E
Address 03: ABS Brakes (J104) Labels:. 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Coding: C6FDA30063BFC500E700
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 346127F49F72E0E4CC-8060
Part No SW: 4H0 907 064 FB HW: 4H0 907 064 CB
Component: BCM2 2.0 H33 0560
Coding: 05A72F46000000000000
Shop #: WSC 54086 001 1048576
VCID: 6ED5F59CB9DE8A34FA-803A
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000056249220
Coding: C018320085047201010001010101112131313333283333
VCID: 35671AF09C08F9ECFB-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 L HW: 4H0 820 043 L
Component: Klima 4 Zonen H20 0130
Coding: 68D108BE3C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 295FC68048B0AD0C6F-807C
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001536691
Coding: 0907201009749FF3BB810044A0001800009CE30A0E000101800108546F21
VCID: 6FEBE898BED4833CF1-803A
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 130218 H35 0080
Serial number: 130301171755
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10319169
Coding: 035D5B
Subsystem 3 - Part No SW: 4H0 941 531 C HW: 4H0 941 531 C
Component: E1 - LDS H07 0044
Serial number: 22 03 2013 00000930
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000022031300010433
Coding: 100000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000025031300010765
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA104975000003108381
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 18788D96000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 2343D4A8229C775C25-8076
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061308501884
Coding: AA0B23
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71EFEEE0A0E095CCE7-8024
Part No SW: 4H0 907 561 B HW: 4H0 907 561
Component: ACC3 H19 0410
Coding: 7F04010101
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A5D398C4DB6A61466-807E
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00CG6G2
Coding: 30314246323430303031554A304C34483053
VCID: 36651DFC890EF2F4F2-8062
Serial number: 3575HRB400U50CQ0G0D9
Serial number: 3585HRB404P1SJR069J3
Serial number: 3515JRB400M50GBONH0L
Serial number: 3525JRB400O50GBOH8MV
Serial number: 3554VRB400650EA2DPJC
Serial number: 3564VRB400S50EGO69CX
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815MCF0000B
Coding: 0004BC
VCID: 387913C48B1A0484E0-806C
Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L
Component: E221 - MFL H09 0010
Serial number: 15 09 2012 33291689
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4H0 920 830 N HW: 4H0 920 830 N
Component: TBenRDWACCNV- H51 0515
Revision: 34081076 Serial number: 658040313592012
Coding: 138F0802F7440008030100
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 30692BE46B6ADCC4A8-8064
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 K HW: 4H0 919 204 K
Component: Analoguhr D4 H05 0225
Serial number: 2130306002622
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 D HW: 4H0 265 105 D
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20130208203931
Coding: 4D1D01
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4H0 907 468 AC HW: 4H0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000876170
Coding: 00ED074800
ASAM Dataset: EV_GatewPkoUDS 001018
VCID: 72EDE1ECA5E6AED41E-8026
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 60079F57341910314368
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 13077002697021200410
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4H0 907 144 C HW: 4H0 907 144 C
Component: DYNAMIKLENK. H06 0100
Revision: 51001005 Serial number: --------------
Coding: 090100
VCID: 2859C3845BBA940470-807C
Part No SW: 8K0 857 511 F HW: 8K0 857 511 A
Component: FLA H04 0020
Revision: AA001002
Coding: 04018B646E6E645A5A253D3E00
VCID: 346127F49772E0E4CC-8060
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0013
Serial number: 001803130001173
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 275BC0B85EA49B7C79-8072
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 4H0 919 158 K HW: 4H0 919 158 K
Component: Klima Fond H16 0121
Coding: 2100000000
ASAM Dataset: EV_AirCondiHeck 001039
ROD: EV_AirCondiHeck_AU64.rod
VCID: 387913C4831A0484E0-806C
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000040376
Coding: 01010101000000000001000102
VCID: 64C197B4671230649C-8030
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008007
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E55359C715ECA34BA-807A
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000056249219
Coding: C0183B0085057201010001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 L HW: 4H0 907 637 G
Component: SARA 6D red H02 0056
Revision: -------- Serial number: EJ1BPA71006F4R
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4H0 907 566 A HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-07
Coding: 0010103
VCID: 2E55359CB95ECA34BA-807A
Subsystem 1 - Part No: 4H0 907 568 A
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-27
Subsystem 3 - Serial number: 5F27.03.1300H02000AMS14389ÿ
Subsystem 4 - Serial number: S14389ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0273
Revision: -------- Serial number: 0000055809966
Coding: 011F1E015E00628202083013
VCID: 48996304FBFA740490-801C
Revision: 00002001 Serial number: 0303076806
Coding: 011A0E2000B93C85BB30C7C42E03010F0000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.030 H08 0006
Serial number: WOO20690876
Coding: 901F00
Subsystem 4 - Part No SW: 4H0 907 133 A HW: 4H0 907 133 A
Component: J505-FSH H06 0046
Serial number: 00000000000000006716
Subsystem 5 - Part No SW: 4H0 947 135 K HW: 4H0 947 135 K
Component: Dachelektroni H11 0080
Serial number: A2011000000000477430
Subsystem 6 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS010 H06 0005
Serial number: WOO1000WT1.
Subsystem 7 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84365074
Part No SW: 4H1 035 465 B HW: 4H1 035 465
Component: BO G3 D4 ANC H03 0150
Revision: 09000000 Serial number: 0012231
Coding: 020101
VCID: 2645CDBC51AE827442-8072
Subsystem 1 - Part No SW: 4H0 035 466 HW: 4H0 035 466
Component: BO D4 SLAVE H51 0180
Serial number: 00703130023180
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0273
Revision: -------- Serial number: 0000055818161
Coding: 011F1E015E00628202083003
VCID: 3C710FD4BF2228A404-8068
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000635223
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B533C88424CBF1C9D-807E
Part No SW: 4H0 035 053 J HW: 4H0 035 053
Component: Radio U Basic H60 0133
Revision: AB001007 Serial number: 228C.0D7519056
Coding: 010003010000000001
Part No SW: 4H0 035 654 B HW: 4H0 035 670 N
Component: H-BNT-EU H45 1034
Revision: -------- Serial number: 179C%0D7508733
Coding: 030100000201FBEF7DB4AB1E00000003080001000000000000
VCID: 2547CAB02CA8896C4B-8070
Subsystem 1 - Part No: 8R0 060 884 FC
Component: EUR 2018 2601
Subsystem 2 - Part No SW: 4H0 919 604 G HW: 4H0 919 604 G
Component: DU8 D4 SV NB H48 0021
Serial number: AUZ8ZDDC90081TV
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000109074
Component: CD-Database 4949
Reset counter: 80
Mileage: 56345 km
Date: 2018.05.18
Time: 16:53:06
Text: DU902A,Front,M,0,0,6
03623 - Invalid Secruity/Release Code
Reset counter: 80
Mileage: 56345 km
Date: 2018.05.18
Time: 16:53:05
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0273
Revision: -------- Serial number: 0000055497215
Coding: 010F1E014000628202083003
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 4H0 907 383 C HW: 4H0 907 383 C
Component: Anhaenger H11 0100
Revision: 5H001001 Serial number: 00000192827461
Coding: 0104010000000000
VCID: 2D5732907458B12C83-8078
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0150
Revision: 11001001 Serial number: 82330JF0079802
Coding: 0209000101010000010102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
ROD: EV_CamerSysteTopViewAUDI_005.rod
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 AB HW: 4H0 959 107 M
Component: HDSG-Modul H11 0043
Revision: 10011001 Serial number: 062300296
Coding: 0210044001
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6ED5F59CB1DE8A34FA-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000102905
Coding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63C394A86A1C375C65-8036
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H06 0273
Revision: -------- Serial number: 0000055497212
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5015 Serial number: SN130212 0109
ROD: EV_GSM2x3Mono.rod
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 F HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0042
Serial number: 0K84AE40093239
Coding: 1100
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 326D21EC6566EED4DE-8066
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H09 0008
Serial number: 00000000001305800313
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Coding: E9060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2645CDBC59AE827442-8072
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00010538224001
Coding: 766FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F6B28987654C33CB1-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00010645139702
Coding: 366FF2
Part No SW: 4H0 907 541 B HW: 4H0 907 541
Component: ACC3 H19 0400
Coding: 7F04010101
ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
ROD: EV_AdaptCruisContr2AU64X_002.rod
VCID: 2859C38453BA940470-807C
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H31 0041
Serial number: 005000122203137
Coding: 01A0BB071111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Component: RGS-VL H13 0080
Coding: 0066F609031F0376070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 316F2EE06060D5CCA7-8064
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4H0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0003
Serial number: 130319200681
VCID: 2C513F944742B82494-8078
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001 Serial number: 97804001664804
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: 66C58DBC992E427482-8032
End-------------------------(Elapsed Time: 08:12)--------------------------
