Audi R8 steering wheel retrofit to 2015 S3 8V
cilitkas
LT
Just done the steering swap, changed 2 pin locations on yellow plug but nothing works so far.
Anyone know correct wiring and coding for it?
Il include a full scan later.
Thanks.
South Molton, UK
We'll need the full Auto-Scan...
cilitkas
LT
Wednesday,20,December,2017,18:08:57:52461
VCDS Version: 17.8.0.1 (x64)
VIN: WAUFFGFF0F1070868   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 47 52 55 5F
          6C A9 BB BC
VIN: WAUFFGFF0F1070868   Mileage: 5520km-3429miles
BB-Door Rear Drv -- Status: Malfunction 0010
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 E    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 0A1D00322426000E3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259E 001002
   ROD: EV_ECM20TFS0208V0906259E.rod
   VCID: 428CC68CD5433C56DC-8016
17178 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:29
                    Engine speed: 0.00 /min
                    Coolant temperature: 88 °C
                    Intake air temperature: 46 °C
                    Voltage terminal 30: 12.304 V
                    Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
                    Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping speed
                    Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
                    Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after DTC-induced shutdown
                    Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
                    Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
                    Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
                    Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
                    Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer. braking
                    Drivetrain coordinator: brake fault status-ESP: no error
                    Drivetrain coordinator: brake fault status-Deceleration controller: Available
                    Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
                    Drivetrain coordinator: brake fault status-Bit 1: no error
                    Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
                    Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message consistency error
                    Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
                    Drivetrain coordinator: brake fault status: 5
                    Drivetrain coordinator: brake function status-Parking Brake: not active
                    Drivetrain coordinator: brake function status-ACC: Not braking
                    Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
                    Drivetrain coordinator: brake function status-Driver: Not braking
                    Drivetrain coordinator: brake function status-Hill descent control: passive
                    Drivetrain coordinator: brake function status-ASR: no intervention
                    Drivetrain coordinator: brake function status-MSR: no intervention
                    Drivetrain coordinator: brake function status-ADS: no intervention
                    Drivetrain coordinator: brake function status-ABS: no intervention
                    Drivetrain coordinator: brake function status-EDL: no intervention
                    Drivetrain coordinator: brake function status-ASP: no intervention
                    Drivetrain coordinator: brake function status-AWV2: No warning pressure
                    Drivetrain coordinator: brake function status-Bit 4: no intervention
                    Drivetrain coordinator: brake function status-Bit 11: not passively cycled
                    Drivetrain coordinator: brake function status-Bit 12: not passively cycled
                    Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
Readiness: 1010 0101
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4521
   Revision: 03253104    Serial number: TFK01409211795
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 1F4A6FF8067131BE93-804A
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
   Component: ESC           H31 0471
   Revision: 00000000    Serial number: 62804000001796
   Coding: 31FF6B9254270A6C017F030641CB698CD62A5080C08296B6024100588608
   Shop #: WSC 48663 001 1048576
   ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
   VCID: 4586DD90C46D0B6EF9-8010
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 63
                    Date: 2016.07.14
                    Time: 06:46:30
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 63
                    Date: 2016.07.14
                    Time: 06:46:30
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 63
                    Date: 2016.07.14
                    Time: 06:46:30
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 63
                    Date: 2016.07.14
                    Time: 06:46:30
          C1146 02 [137] - Signal Failure
                    Reset counter: 63
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:39
33000 - Longitudinal Acceleration
          C10B1 29 [137] - Signal Implausible
                    Reset counter: 63
                    Date: 2016.07.14
                    Time: 06:46:30
   Revision: 00021000    Serial number: 0347604164
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A7CBE6CBD93749684-806E
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000451410
   Coding: 03000014010000000000000000001400
   VCID: 336293489AF985DE47-8066
   Serial number: C6B84057000000000001
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 64
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:29
                    Outside air temperature: 8.5 °C
                    Temperature after evaporator: 26.0 °C
                    Refrigerant pressure: 1.0 bar
   Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
   Component: BCM MQBAB HNA H18 0134
   Serial number: 01011426500482
   Coding: 04151C46404106FD41C04004511807A00800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7AFC7E6CFD13B496C4-802E
   Component: WWS371 140912  042 0585
   Serial number:         140924215426
   Coding: 0A47F7
   Serial number: 23250614
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Serial number: 23 07 2014  00000046
   Serial number: 00000000000060677680
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO32929111
   Coding: 101F00
558100 - Databus
                    Reset counter: 64
                    Mileage: 5520 km
                    Date: 2016.08.22
                    Time: 05:03:57
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331426305299
   Coding: 0030150011
13637426 - Databus
                    Reset counter: 63
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:29
   Serial number: 003GCR00T9BL
   VCID: 479AD798FE61197E0B-8012
   Belt Pretensioner left:
   Serial number: 34178311B07101440487
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34178312B07101470723
   Coding: 333135
   Occupant Detection:
   Serial number: 6940000Y1400017NV00Y
   Coding: 303230
   Subsystem 4 - Part No SW: -----------    HW: 480 002 909 14
   Serial number: 35700000000F7A34F01R
   Subsystem 5 - Part No SW: -----------    HW: 480 002 909 14
   Serial number: 358000000007AA34F01N
   Subsystem 6 - Part No SW: -----------    HW: 480 402 909 14
   Serial number: 3510002BB175A90091B0
   Subsystem 7 - Part No SW: -----------    HW: 480 401 909 14
   Serial number: 3520002A9176A6C17230
   Subsystem 8 - Part No SW: -----------    HW: 480 400 808 14
   Serial number: 35500029916FC22340B3
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 311 12
   Serial number: 3560002B30CC5BF032AE
9445973 - Seat occupied recognition control module
          B1022 55 [137] - Not configured
                    Reset counter: 64
                    Mileage: 5520 km
                    Date: 2016.07.26
                    Time: 11:22:56
1050117 - Databus
                    Reset counter: 64
                    Mileage: 5520 km
                    Date: 2016.07.26
                    Time: 09:34:10
1049094 - Databus
                    Reset counter: 64
                    Mileage: 5520 km
                    Date: 2016.07.26
                    Time: 09:34:10
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 03101408490168
   Coding: A018
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 0A1C2EACADF3A416D4-805E
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 871 L    HW: 8V0 920 871 L
   Component: KOMBI         H02 6423
   Coding: 03AD181A2B8800080204EE001800000000000000
   Shop #: WSC 62170 001 104857
   ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 03101410800018
   Coding: 0101000820085A005B00022C180B00000001010000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_011.rod
66568 - Local data bus 2
          U1076 00 [008] - Electrical malfunction
                    Reset counter: 104
                    Mileage: 5520 km
                    Date: 2016.08.22
                    Time: 04:55:32
                    Supply voltage: Terminal 30: 14.8 V
                    Terminal 15: On
197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Fault Frequency: 22
                    Reset counter: 65
                    Mileage: 5520 km
                    Date: 2016.08.22
                    Time: 04:41:06
                    Supply voltage: Terminal 30: 11.6 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00009.08.14
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 4684DA9CF96B0076F0-8012
   Revision: 00000000    Serial number: 14000270884002
   Coding: 5D00000000000000
   VCID: 346090549FF782E65E-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0346835485
   Coding: 030211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3878A464839F668672-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0346892700
   Coding: 030211
   Serial number: 19091406070881
   Coding: 005D1F205C00048000000002
   VCID: 4088CC84DB4F2E46CA-8014
65604 - Door Warning Lamp
          B1326 01 [008] - Electrical Failure
                    Reset counter: 104
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:29
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3566AD50948D9BEE69-8060
15873 - Steering angle sensor
                    Reset counter: 63
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:29
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 25.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5B
                    uioUdNotFilt_xdu16: 12.23 V
                    uAdSensI_SwitchedKl30_xdu16: 12.24 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19204 - Databus
                    Reset counter: 66
                    Mileage: 5520 km
                    Date: 2016.07.16
                    Time: 09:25:45
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 11.75 V
                    Temperature: 7.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 11.84 V
                    uAdSensI_SwitchedKl30_xdu16: 11.84 V
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN900QK6B
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
1564 - Microphone for Vehicle/Ambient Noise
          B13BB 13 [008] - Open Circuit
                    Reset counter: 104
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:31
                    Voltage terminal 30: 12.3 V
0527 - Front Right Treble Speaker
          B1064 13 [008] - Open Circuit
                    Reset counter: 104
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:34
0522 - Front Left Treble Speaker
          B1061 13 [008] - Open Circuit
                    Reset counter: 104
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:34
0537 - Rear Right Treble Speaker
          B1068 13 [008] - Open Circuit
                    Reset counter: 104
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:34
0532 - Rear Left Treble Speaker
          B1066 13 [008] - Open Circuit
                    Reset counter: 104
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:34
   Serial number: 21091401100625
   Coding: 005D17205E00048000000002
   VCID: 3F8ACF78A6B151BEB3-806A
                    Reset counter: 104
                    Mileage: 5520 km
                    Date: 2016.07.16
                    Time: 09:26:51
   Component: AFS-ECU       H01 0091
   Coding: 012A000123200400
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
13705992 - Databus
                    Reset counter: 63
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:29
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 038 A    HW: 8V0 035 038
   Component: MU-H-LNS-US   H42 0289
   Serial number: A302I0EB004416
   Coding: 017301020000000021211102041A00102F000365010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   VCID: 326C964C65E38CD64C-8066
   Subsystem 1 - Part No SW: V03 959 800 SR    HW: -----------
   Component: NAR 2014/2015  --- 0032
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY201S6F
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000005081400040002
   Compact Disc Database:
   Component: Gracenote  --- 3005
          U1014 00 [009] - -
                    Reset counter: 64
                    Mileage: 5520 km
                    Date: 2016.08.22
                    Time: 05:08:08
                    Voltage terminal 30: 11.5 V
   Coding: 027300010201000300
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 30689C446BEFBEC63A-8064
9529428 - Steering angle sensor
                    Reset counter: 63
                    Mileage: 5520 km
                    Date: 2016.07.14
                    Time: 06:46:29
                    passive
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140910201221
   VCID: 7DF67570EC3D83AEE1-8028
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 01101402090316
   Coding: 004D17204000048000000002
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
65548 - Supply voltage
                    Reset counter: 96
                    Mileage: 41434 km
                    Date: 2017.08.03
                    Time: 00:04:11
                    Reset counter: 104
                    Mileage: 41434 km
                    Date: 2017.08.03
                    Time: 00:32:53
   Component: TSG HBFS      020 0025
   Serial number: 01101401100323
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
          B1326 01 [009] - Electrical Failure
                    Reset counter: 64
                    Mileage: 5520 km
                    Date: 2016.07.17
                    Time: 07:09:36
End-------------------------(Elapsed Time: 05:20)--------------------------
hadez16
C?ID=289891
Is this retrofit project based on other successful retrofits from other persons?
DJAlix
London, United Kingdom
C?ID=238277
No coding needed or indeed possible. Getting this to work is all about the wiring, which involves re-pinning and running in new additional wires.
cilitkas
LT
great when you know what to do.
United States
I agree, this VIN has PR-Code 2PK Leather-wrapped multi-function sports steering wheel with tiptronic so the CAN GW should already be configured for that LIN wheel. Providing the R8 wheel is from the same time frame and uses the same LIN version it should simply communicate.
Have you compared the factory wiring diagrams from the R8 to the ones from this car yet?
cilitkas
LT
i will be checking everything again tomorrow, i got no communication with steering module now...
cilitkas
LT
This is gonna be one of those retrofits that people are not going to give away too much information due to the potential value.
but there will be people that will get nothing out of knowing this and post "how to" here, and it will be me, once its sorted.
ghost
C?ID=139898
For buttons to work you need 3 wires - Negative, Positive and LIN. Check on your existing loom where you have the power coming into MF module, 3rd one will be your LIN wire.
^^^ hmm......... notwithstanding the issue of the LIN wire - is it really possible to use a steering wheel from a R8 (MLB platform?) on a MQB platform car?
As I understand, on MQB vehicles the the multi-function steering wheel is included into the CAN network (rather than being a slave of the steering column module) - it is a LIN slave to the CAN Gateway.
ghost
C?ID=139898
Same steering wheel is fitted in TTRS MK3 @Don which is MQB platform. So there must be the way of making it working in 8V
martinlop
Argentina
C?ID=303160
HINT:
If you find the R8 steering wheel´s circuit in the "cyberspace" you might be able to compare (as DjAlix said) 1-1 with the one you have currently installed.
hope this helps.
PS. UWE, you are the one!
Please don't post links to copyrighted materials in the open forum. I understand you're trying to be helpful here. If you want to share something like that with someone, please do it via PM. That way RT isn't an "accessory" to your infringement. :thanks:
cilitkas
LT
I got main buttons working, now sorting start-stop.
lclerc69
France
C?ID=169317
hi
i try to install Audi R8 steering wheels on my 2013 Audi S8
does anybody knows what i need to do that ?
thank you
best regards
South Molton, UK
does anybody knows what i need to do that?
We'll need you to post a full Auto-Scan of your S8 plus the part number of the R8 steering wheel to be able to answer that question.
lclerc69
France
C?ID=169317
hi here is my log :
Friday,18,May,2018,17:01:28:18831
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ4H2DN******   License Plate:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 18 19 1B 20 22 28 30
          34 36 3B 3C 42 46 47 52 53 56 5F 62 69 6C 6D 6F 72 81 84 85
          88 89 8B 8E 8F 90 A9 BA
VIN: WAUZZZ4H2DN030091   Mileage: 56345km-35011miles
Address 01: Engine (------CGTA)       Labels: None
   Part No SW: 4H0 907 557     HW: 4H0 906 014
   Component: 4.0l V8TFSI / X62 0010
   Revision: NCX62---
   Coding: 022A003A6556010A1800
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM40TFS0114H0907557 001012
   ROD: EV_ECM40TFS0114H0907557.rod
   VCID: 6DD7F290BCD8712CC3-8038
Readiness: 1110 1100
   Part No SW: 4H1 927 158 BL    HW: 0BK 927 156 AG
   Component: 0BK 40TFSIRdW H16 1005
   Revision: --H16---
   ASAM Dataset: EV_TCMALX51011 002020
   ROD: EV_TCMALX51011.rod
   VCID: 7BF3CCC8F2ACEF9C4D-802E
Address 03: ABS Brakes (J104)       Labels:. 4H0-907-379.clb
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: C6FDA30063BFC500E700
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 346127F49F72E0E4CC-8060
   Part No SW: 4H0 907 064 FB    HW: 4H0 907 064 CB
   Component: BCM2 2.0      H33 0560
   Coding: 05A72F46000000000000
   Shop #: WSC 54086 001 1048576
   VCID: 6ED5F59CB9DE8A34FA-803A
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000056249220
   Coding: C018320085047201010001010101112131313333283333
   VCID: 35671AF09C08F9ECFB-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 L    HW: 4H0 820 043 L
   Component: Klima 4 Zonen H20 0130
   Coding: 68D108BE3C
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 295FC68048B0AD0C6F-807C
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001536691
   Coding: 0907201009749FF3BB810044A0001800009CE30A0E000101800108546F21
   VCID: 6FEBE898BED4833CF1-803A
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 130218  H35 0080
   Serial number:         130301171755
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10319169
   Coding: 035D5B
   Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
   Component: E1 - LDS  H07 0044
   Serial number: 22 03 2013  00000930
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000022031300010433
   Coding: 100000
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000025031300010765
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA104975000003108381
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 18788D96000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2343D4A8229C775C25-8076
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061308501884
   Coding: AA0B23
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71EFEEE0A0E095CCE7-8024
   Part No SW: 4H0 907 561 B    HW: 4H0 907 561
   Component: ACC3          H19 0410
   Coding: 7F04010101
   ASAM Dataset: EV_AdaptCruisContrAU64X 002021
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2A5D398C4DB6A61466-807E
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00CG6G2
   Coding: 30314246323430303031554A304C34483053
   VCID: 36651DFC890EF2F4F2-8062
   Serial number: 3575HRB400U50CQ0G0D9
   Serial number: 3585HRB404P1SJR069J3
   Serial number: 3515JRB400M50GBONH0L
   Serial number: 3525JRB400O50GBOH8MV
   Serial number: 3554VRB400650EA2DPJC
   Serial number: 3564VRB400S50EGO69CX
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90815MCF0000B
   Coding: 0004BC
   VCID: 387913C48B1A0484E0-806C
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H09 0010
   Serial number: 15 09 2012  33291689
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4H0 920 830 N    HW: 4H0 920 830 N
   Component: TBenRDWACCNV- H51 0515
   Revision: 34081076    Serial number: 658040313592012
   Coding: 138F0802F7440008030100
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K.rod
   VCID: 30692BE46B6ADCC4A8-8064
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 K    HW: 4H0 919 204 K
   Component: Analoguhr D4  H05 0225
   Serial number: 2130306002622
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 D    HW: 4H0 265 105 D
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20130208203931
   Coding: 4D1D01
   Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000876170
   Coding: 00ED074800
   ASAM Dataset: EV_GatewPkoUDS 001018
   VCID: 72EDE1ECA5E6AED41E-8026
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 60079F57341910314368
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 13077002697021200410
   Part No SW: 4H0 907 144 C    HW: 4H0 907 144 C
   Component: DYNAMIKLENK.  H06 0100
   Revision: 51001005    Serial number: --------------
   Coding: 090100
   VCID: 2859C3845BBA940470-807C
   Part No SW: 8K0 857 511 F    HW: 8K0 857 511 A
   Component: FLA           H04 0020
   Revision: AA001002
   Coding: 04018B646E6E645A5A253D3E00
   VCID: 346127F49772E0E4CC-8060
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0013
   Serial number: 001803130001173
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   VCID: 275BC0B85EA49B7C79-8072
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H16 0121
   Coding: 2100000000
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 387913C4831A0484E0-806C
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000040376
   Coding: 01010101000000000001000102
   VCID: 64C197B4671230649C-8030
   Part No SW: 4H0 907 553 E    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0099
   Coding: 008007
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E55359C715ECA34BA-807A
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000056249219
   Coding: C0183B0085057201010001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 L    HW: 4H0 907 637 G
   Component: SARA 6D red   H02 0056
   Revision: --------    Serial number: EJ1BPA71006F4R
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   Coding: 0010103
   VCID: 2E55359CB95ECA34BA-807A
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F27.03.1300H02000AMS14389ÿ
   Subsystem 4 - Serial number: S14389ÿ
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H06 0273
   Revision: --------    Serial number: 0000055809966
   Coding: 011F1E015E00628202083013
   VCID: 48996304FBFA740490-801C
   Revision: 00002001    Serial number: 0303076806
   Coding: 011A0E2000B93C85BB30C7C42E03010F0000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.030  H08 0006
   Serial number:     WOO20690876
   Coding: 901F00
   Subsystem 4 - Part No SW: 4H0 907 133 A    HW: 4H0 907 133 A
   Component: J505-FSH  H06 0046
   Serial number: 00000000000000006716
   Subsystem 5 - Part No SW: 4H0 947 135 K    HW: 4H0 947 135 K
   Component: Dachelektroni  H11 0080
   Serial number: A2011000000000477430
   Subsystem 6 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS010  H06 0005
   Serial number:     WOO1000WT1.
   Subsystem 7 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84365074
   Part No SW: 4H1 035 465 B    HW: 4H1 035 465
   Component: BO G3 D4 ANC  H03 0150
   Revision: 09000000    Serial number: 0012231
   Coding: 020101
   VCID: 2645CDBC51AE827442-8072
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 00703130023180
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0273
   Revision: --------    Serial number: 0000055818161
   Coding: 011F1E015E00628202083003
   VCID: 3C710FD4BF2228A404-8068
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000635223
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B533C88424CBF1C9D-807E
   Part No SW: 4H0 035 053 J    HW: 4H0 035 053
   Component: Radio U Basic H60 0133
   Revision: AB001007    Serial number: 228C.0D7519056
   Coding: 010003010000000001
   Part No SW: 4H0 035 654 B    HW: 4H0 035 670 N
   Component: H-BNT-EU      H45 1034
   Revision: --------    Serial number: 179C%0D7508733
   Coding: 030100000201FBEF7DB4AB1E00000003080001000000000000
   VCID: 2547CAB02CA8896C4B-8070
   Subsystem 1 - Part No: 8R0 060 884 FC
   Component: EUR 2018  2601
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDDC90081TV
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000109074
   Component: CD-Database  4949
            000 -  -
                    Reset counter: 80
                    Mileage: 56345 km
                    Date: 2018.05.18
                    Time: 16:53:06
                    Text: DU902A,Front,M,0,0,6
03623 - Invalid Secruity/Release Code
            000 -  -
                    Reset counter: 80
                    Mileage: 56345 km
                    Date: 2018.05.18
                    Time: 16:53:05
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0273
   Revision: --------    Serial number: 0000055497215
   Coding: 010F1E014000628202083003
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 4H0 907 383 C    HW: 4H0 907 383 C
   Component: Anhaenger     H11 0100
   Revision: 5H001001    Serial number: 00000192827461
   Coding: 0104010000000000
   VCID: 2D5732907458B12C83-8078
   Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
   Component: TopView       H05 0150
   Revision: 11001001    Serial number: 82330JF0079802
   Coding: 0209000101010000010102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
   ROD: EV_CamerSysteTopViewAUDI_005.rod
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0043
   Revision: 10011001    Serial number: 062300296
   Coding: 0210044001
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6ED5F59CB1DE8A34FA-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000102905
   Coding: 200000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63C394A86A1C375C65-8036
   Component: TSG HR        H06 0273
   Revision: --------    Serial number: 0000055497212
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5015    Serial number: SN130212  0109
   ROD: EV_GSM2x3Mono.rod
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0042
   Serial number: 0K84AE40093239
   Coding: 1100
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   VCID: 326D21EC6566EED4DE-8066
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H09 0008
   Serial number: 00000000001305800313
Address 85: On Board Cam. (J852)       Labels:* None
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2645CDBC59AE827442-8072
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00010538224001
   Coding: 766FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F6B28987654C33CB1-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00010645139702
   Coding: 366FF2
   Part No SW: 4H0 907 541 B    HW: 4H0 907 541
   Component: ACC3          H19 0400
   Coding: 7F04010101
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 2859C38453BA940470-807C
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H31 0041
   Serial number: 005000122203137
   Coding: 01A0BB071111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Coding: 0066F609031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 316F2EE06060D5CCA7-8064
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0003
   Serial number: 130319200681
   VCID: 2C513F944742B82494-8078
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804001664804
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X.rod
   VCID: 66C58DBC992E427482-8032
End-------------------------(Elapsed Time: 08:12)--------------------------
lclerc69
France
C?ID=169317
part number for the steering wheel :
4S0419091E
