Monday,18,December,2017,14:17:43:40917
VCDS Version: 17.8.1.0 HEX-NET CB: 0.4401.4
Data version: 20171130 DS276.6
VIN: XXXXXXXXXXXXXXXX License Plate:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 47 52 55 5F 65 A5
A9
VIN: XXXXXXXXXXXXXX
Address 01: Engine (J623-CHHC) Labels: None
Part No SW: 8S0 906 259 K HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 0A1D00324424050B3002
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208S0906259K 001002
ROD: EV_ECM20TFS0208S0906259K.rod
VCID: 45C2B30AC43E336EE2-8010
Readiness: 1110 0001
Part No SW: 0D9 300 042 R HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5002
Revision: 06454104 Serial number: TFK01612132253
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_VW37.rod
VCID: 281C1ABE536CCE06F9-807C
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 8S0 907 379 F HW: 8S0 907 379 F
Component: ESC H42 0530
Revision: 00000000 Serial number: 60057000000361
Coding: 32AA208D1A9A15AF41920067C2959706334C0458A8820043E960CC
ASAM Dataset: EV_Brake1UDSContiMK100IPB 060017
ROD: EV_Brake1UDSContiMK100IPB_060.rod
VCID: 44C4AE0ECF040A66F5-8010
Part No SW: 3Q0 959 435 D HW: 3Q0 959 435 D
Component: VWKESSYMQB 026 0811
Revision: 00026000 Serial number: 0426656919
Coding: 000F0F1720
ASAM Dataset: EV_KessyHellaMQBAB 004039
VCID: 3B36D5F2B2FA759E84-806E
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0040
Revision: 20010000 Serial number: 16200000009000
Coding: 410040000011101000
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: 6C9426AE871422265D-8038
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 16D8456800PAG0MUFU03
Operating and display unit 2 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number: 00000000000000020589
Operating and display unit 3 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Operating and display unit 4 for air conditioning:
Subsystem 4 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001700901825
ROD: EV_BCMBOSCH_017_VW27.rod
VCID: 7EB01CE6E168A0B6E3-802A
Subsystem 1 - Part No SW: 8S2 955 119 B HW: 8S2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: 43x RL 161122 038 0371
Serial number: 00000001611210425212
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 62544143
Coding: 03005D
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 28 09 2016 00001993
Subsystem 4 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY163482RJ0
Serial number: 00000000000068104329
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39261635702926
Coding: 0000050011
ROD: EV_EPHVA14AU3700000_002_AU37.rod
VCID: 3C34D6EEB7F472A68D-8068
Part No SW: 5Q0 959 655 P HW: 5Q0 959 655 P
Component: AirbagVW20 010 0870
Serial number: 003M7R01VD9R
Coding: 88CCF0C00C8000005C5000CFC0C800000065
VCID: 4DD28B2A1C4ECB2E2A-8018
Subsystem 1 - Part No SW: ----------- HW: 480 001 701 17
Serial number: 35700000000144D8FF1X
Subsystem 2 - Part No SW: ----------- HW: 480 001 701 17
Serial number: 35800000000C24D8FF10
Subsystem 3 - Part No SW: ----------- HW: 480 011 701 17
Component: SideSensor_Dr 005 0108
Serial number: 351001A05D397A037D26
Subsystem 4 - Part No SW: ----------- HW: 480 402 810 16
Serial number: 3550002BD22C8ED0F19T
Front Sensor Passenger:
Subsystem 5 - Part No SW: ----------- HW: 480 402 810 16
Component: FrontSensor_P 001 6149
Serial number: 3560002B7234FA3111E2
Pedestrian Protection Center:
Subsystem 6 - Part No SW: ----------- HW: 480 401 512 16
Component: PedP_Sensor_C 001 6149
Serial number: 2300002BB23C4E51B0A5
Subsystem 7 - Part No SW: ----------- HW: 480 000 812 16
Serial number: I0M000000008A518002V
Subsystem 8 - Part No SW: ----------- HW: 480 000 812 16
Serial number: I0N00000000D0AB0002Y
Part No SW: 8S0 907 129 AL HW: 8S0 907 129 AL
Component: Lenks. Modul H07 0150
Revision: -------- Serial number: 91335QAE02647
Coding: 281C
ASAM Dataset: EV_SMLSKLOMQB 050001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 04446E0E8F84CA66B5-8050
Address 17: Instruments (J285) Labels:* Redir Fail!
Part No SW: 8S0 920 790 B HW: 8S0 920 790 B
Component: FBenRDW H39 0296
Coding: 24AD01D0688406000102FE849000C01008000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001023
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: 383CCAFE83CC5E8669-806C
U1014 00 [009] - -
Reset counter: 70
Mileage: 3445 km
Date: 2017.12.18
Time: 14:09:32
16777014 - Tire Pressure Monitoring Module
U0127 00 [009] - No Communications
Reset counter: 70
Mileage: 3445 km
Date: 2017.12.18
Time: 14:11:00
Part No SW: 8S0 907 468 E HW: 8S0 907 468 E
Component: GW MQB TT3 021 0286
Serial number: 03011710520135
Coding: 030100042F025A004B0002681C0B00000000000000000000000000000001
ASAM Dataset: EV_GatewContiAU33X 013005
ROD: EV_GatewContiAU33X.rod
VCID: 42C8A816D5100456C7-8016
Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
Component: J453 MFL H07 0002
Serial number: 20161215144538 00730
Subsystem 3 - Part No SW: 8W0 915 181 HW: 8W0 915 181
Serial number: 6382652504
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000347247017
Coding: 0900000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71AA37DAA036CFCE6E-8024
Component: TSG FS 020 0041
Serial number: 061216EL615103
Coding: 001342225001040100001402
VCID: 43C6AD12CA0A0D5ECC-8016
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9107
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 3A38D0F6BDC04C969F-806E
Part No SW: 8S0 035 466 A HW: 8S0 035 466
Component: MIB2_amp_P_TT H10 0440
Revision: 00000001 Serial number: AUZ8ZAGJB0059DT
Coding: 0133040000AA2A2AAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
VCID: 3424FECE9FA4BAE645-8060
Component: TSG BFS 020 0041
Serial number: 121216ELC00299
Coding: 001342225C01040100001402
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 03DE00102B200200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
VCID: 3620C4C689D8A8F67B-8062
Coding: E01800
Coding: E01800
Subsystem 3 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 S002
Coding: E01800
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01800
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8S0 035 020 G HW: 8S0 035 020 E
Component: MU-H-ND-EU 053 0892
Serial number: A712A0HB003360
Coding: 013304010000000011111102008A00102F0000E200F000007E
VCID: 2C14E6AE4794E2261D-8078
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8S0 919 614 M HW: 8S0 919 614 M
Component: ControlUnit_H H30 0206
Serial number: APVAK106121600010042
Compact Disc Database:
Component: Gracenote2 --- 1015
U1014 00 [009] - -
Reset counter: 63
Mileage: 3418 km
Date: 2017.12.16
Time: 15:46:38
Voltage terminal 30: 11.9 V
2571 - Navigation system
B126C F2 [009] - Navigation database not enabled
Reset counter: 63
Mileage: 3418 km
Date: 2017.12.16
Time: 15:46:38
U1111 00 [008] - -
Reset counter: 110
Mileage: 3443 km
Date: 2017.12.18
Time: 13:06:04
Voltage terminal 30: 12.1 V
BAP-BAP_Function_ID: 01
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 4M0 907 273 HW: 4M0 907 273
Component: RDKHUFAU736 H03 0008
Serial number: 00000000000684
ASAM Dataset: EV_RDKHUFAU736 002006
ROD: EV_RDKHUFAU736_AU37.rod
VCID: 6D922BAABC0E2B2E4A-8038
8390147 - Tire Pressure Monitoring
C10DC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 70
Mileage: 3445 km
Date: 2017.12.18
Time: 14:08:55
Expanded ambient data 1-Left front tire pressure sensor: identification: 648351928
Expanded ambient data 1-Right front tire pressure sensor: identification: 648889468
Expanded ambient data 1-Left rear tire pressure sensor: identification: 648893161
Expanded ambient data 1-Right rear tire pressure sensor: identification: 648503237
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H07 0060
Serial number: 10000625010
Coding: 0101020101010303000501000000010100
ROD: EV_MFKBoschAU370.rod
Part No SW: 8S0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0008
Serial number: 161206202215
End----(Elapsed Time: 01:27, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
