Auto start-stop behavior?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I have a 2018 Atlas SEL Premium, with the 3.6L FSI V6. It comes with auto start-stop, like many cars these days. I seem to be part of a minority that actually likes the feature. Even though I know how to permanently disable it, I keep it on. But sometimes, start-stop doesn't kick in at a stop, and I don't clearly understand why, based on the reason given in the instrument cluster.
So my questions here are sort of the opposite of normal: how can I find out more about things that prevent start-stop from working?
  • "System/power needs": See this frequently. Sometimes it's obvious why (high electrical consumption, accessory demand, trailer hooked up, etc). Sometimes it's not. HVAC has its own category and it's clear when it's a HVAC demand.
  • "Traffic situation": See this every once in a while. Sometimes it's in stop-and-go traffic, but occasionally not. I can't figure out the criteria or inputs for this one. I feel like there has to be more than just too many back-to-back stops. Is there feedback from the forward camera for traffic, or traffic lights, or nav system intersection type feedback, or data from the nav's XM traffic data feed, or...?
I don't think my Atlas is misbehaving, I just want to better understand the system. I haven't yet found a good SSP or other reference that goes into deep detail.
Obligatory Auto-Scan:
Thursday,07,December,2017,19:37:07:43302
VCDS Version: 17.11.0.0 (x64)  HEX-V2 CB: 0.4409.4
Data version: 20171026 DS285.1
Dealer/Shop Name: Southwest Ohio Luxobarge Rescue
Workshop Code: 444 08607 000001
VIN: 1V2NR2CA0JC502209   License Plate: 2018ATLAS
Mileage: 17064km-10603mi   Repair Order: BETA17110
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 47 4B
          52 5F 69 6C 6D 75 A5 CA D6 D7
VIN: 1V2NR2CA0JC502209   Mileage: 17064km-10603miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (0-32-CDVC)       Labels: None
   Part No SW: 03H 906 026 J    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H20 4748
   Revision: 52H20000
   Coding: 012A003244740108B0000000000000000000000000000000
   Shop #: WSC 07645 128 28888
   ASAM Dataset: EV_ECM36FSI01103H906026J 001003
   ROD: EV_ECM36FSI01103H906026J.rod
   VCID: 2C020EDA7681A50113E7-8078
   CAN Converter 01:
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 A    HW: 09G 927 158
   Component: AISIN AQ8     206 3387
   Coding: 0000000100000000000000000000000000000000
   Shop #: WSC 09003 957 00200
   ROD: EV_TCMAQ450031_VW27.rod
   VCID: 313C1FAE51A3C8E920B1-8064
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Revision: 00000000    Serial number: 50697000000109
   Coding: 44FC6B8D84201A6EC5790300A2CC6922D62158A3C045967E38415058C2AA4200002F641C12141A118DDB45506CC8CF
   ROD: EV_Brake1UDSContiMK100IPB_036.rod
   VCID: 77A8E1B6FF47D6D9AEF5-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0430197433
   Coding: 0F2000070F
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3C223E9A86E135818307-8068
   Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58006600
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to temp low voltage]
                    Reset counter: 4
                    Mileage: 16725 km
                    Date: 2017.12.02
                    Time: 15:13:43
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: On
                    Terminal_50_Kessy_actual_value: On
                    ZAT_pressed: On
                    Park selector lever position: Not engaged and not locked
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 8.472 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
14222592 - Databus
          [Message ELV_01 missing]
                    Reset counter: 8
                    Mileage: 16833 km
                    Date: 2017.12.05
                    Time: 00:11:57
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: Timeout
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: Timeout
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.319 V
                    Actuation to the inside: active
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3CN 907 044 F    HW: 3CN 907 044 F
   Component: Climatronic   H05 1802
   Revision: 00001K01
   Coding: 1602062620001400110411101210150C
   Shop #: WSC 08607 444 00001
   ASAM Dataset: EV_ACClimaBHBVW416 002007
   ROD: EV_ACClimaBHBVW416.rod
   VCID: 42DE4062E4054371C9CB-8016
   Fresh Air Blower Back:
   Part No SW: 5Q0 937 085 BG    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H34 0236
   Serial number: 7041011802ÿÿÿÿ
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F580996D777EE99E6A5-802A
   Subsystem 1 - Part No SW: 5Q0 955 555     HW: 5Q0 955 555
   Component: RLHSS  046 0120
   Serial number: S6Y17M01D31H15M40S26
   Coding: 00B86D
   Subsystem 2 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0050
   Serial number: 0000009600335Z363302
   Coding: 150000
   Garage Door Opener Operating Unit:
   Subsystem 3 - Part No SW: 3CN 959 719     HW: 3CN 959 719
   Component: GTO BF  H06 0007
   Serial number: 8MW00117011700010527
   Seat Backrest Fan 1 Front Left:
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0163999
   Seat Cushion Fan 1 Front Left:
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0164122
   Seat Backrest Fan 1 Front Right:
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0182946
   Seat Cushion Fan 1 Front Right:
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0246621
   Part No SW: 5QA 919 298 B    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0038
   Serial number: 000308417617023
   Coding: 0271667151
   ASAM Dataset: EV_EPHVA2CAU3700000 009032
   VCID: 4FF879562757BE195645-801A
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Coding: 320007C959FFC728949C810530401600000000000000000000
   ROD: EV_ACCBOSCHVW416.rod
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Fault Frequency: 66
                    Reset counter: 18
                    Mileage: 16662 km
                    Date: 2017.11.30
                    Time: 11:53:17
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 13.2 V
                    Velocity_vehicle_reference: 1.55 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.27 m/s²
   Part No SW: 3Q0 959 655 BC    HW: 3Q0 959 655 BC
   Component: Airbag VW21   004 0503
   Revision: --------    Serial number: 003SUM49OKEP
   Coding: 8CCCDC00000000005000001A420800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 005A8A6AAA8991619F5F-8054
   Occupant Detection:
   Component: Occ.Detection  H13 0022
   Serial number: IBH0000J170006OQEB0P
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 001 601 17
   Serial number: 35700000000E643DB12Q
   Subsystem 3 - Part No SW: -----------    HW: 454 001 601 17
   Serial number: 35800000000B843DB12Q
   Subsystem 4 - Part No SW: -----------    HW: 454 801 002 17
   Serial number: 35100BE8B0F0F000000/
   Subsystem 5 - Part No SW: -----------    HW: 454 802 301 17
   Serial number: 352009E26BE0E000000.
   Subsystem 6 - Part No SW: -----------    HW: 454 802 812 16
   Serial number: 35500DCF80E0E0000003
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 802 812 16
   Component: FrontSensor_P  304 0149
   Serial number: 35600FAFB0E0E0000007
   Part No SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
   Component: Lenks. Modul  004 0140
   Revision: --------    Serial number: 11011704400586
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 03508566BB9F8A79827D-8056
   Part No SW: 3CN 920 891 A    HW: 3CN 920 891 A
   Component: KOMBI         404 3192
   Coding: 03A50F1DEF88CF0502887F0B5001000320000000
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Fault Frequency: 8
                    Reset counter: 6
                    Mileage: 16644 km
                    Date: 2017.11.30
                    Time: 11:32:59
   Component: GW MQB High   515 5286
   Serial number: 20021700840033
   Coding: 0B0500347F087300FB0722581E0F00010000070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 2F3819D64797DE193685-807A
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29160001817810016366
   Coding: 36FFFF
   Serial number: 6858452904
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
   Component: U13DCAC  H23 0860
   Serial number: 0001255
   Serial number: HA1-00002.12.16
   Coding: 0301
   VCID: 4ACE6842DC359B3101BB-801E
   Serial number: 17000007942012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BCDFAE912388E96031-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0021
   Serial number: Y0006PL516752
   Coding: 0010000000000500018280808080000000008100000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_VW41.rod
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung --> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.]
                    Reset counter: 7
                    Mileage: 16793 km
                    Date: 2017.12.04
                    Time: 19:29:29
   Serial number: 0427420305
   Coding: 02012103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Serial number: 0427017983
   Coding: 020121
   Serial number: 27121606050HIT
   Coding: 003F1B205200020000000000
   VCID: 43D04566FB1F4A79C2FD-8016
   Serial number: 00000000000005469691
   Coding: 011000
   Revision: 00000000    Serial number: 0001417184
   Coding: 01010311004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
   VCID: 40DA4A6AEA095161DFDF-8014
   Revision: 00000001    Serial number: VWZ8Z1GBA02RF4C
   Coding: 2214060002A00A2A000000000000
   ASAM Dataset: EV_AMPMst12C3Gen2ALPI 001001
   ROD: EV_AMPMst12C3Gen2ALPI.rod
   VCID: 6D84C3DE8D1B6C094419-8038
   Component: FCM MQB Low   001 0286
   Serial number: 14021700840110
   Coding: 000000070100135200010000000000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X.rod
   VCID: 72BED0A29425B3F1992B-8026
   Serial number: 221216060500N8
   Coding: 003F13205E00020000000000
   Serial number: 00000000000005472451
   Coding: 091000
   Part No SW: 3QF 035 876     HW: 3QF 035 876
   Component: MU-S-NS-US    840 0755
   Coding: 021406020000000051220002001808001F0500E401200005CE
   Shop #: WSC 08607 444 00002
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 074891768FA7A659DE15-8052
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H40 8074
   Serial number: VWZ6ZDT0050741
   Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
          [USB - communication error]
                    Reset counter: 9
                    Mileage: 16833 km
                    Date: 2017.12.05
                    Time: 00:13:01
                    Voltage terminal 30: 11.8 V
                    Interface for external media: status-Status: Open circuit
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0430201804
   Coding: 0200000200000000
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG008159
   Coding: 01140604A30F20000000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   VCID: 382A228AB2D919A1676F-806C
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Coding: 0988
   VCID: 41DC4F6EE1035869D0D1-8014
   Coding: 02140602C2823A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Serial number: 15011712K20431
   Coding: 000401060001020100221355C050890084000E200020
   ROD: EV_MFKBoschMQBB_VW27.rod
   VCID: 3B203D8683EF32B98A0D-806E
Address CA: Sunroof (J245)       Labels:* None
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 00804074160C
   ROD: EV_SunRoofCONTIAU736.rod
   VCID: 3D24339E9DFB3C89B439-8068
   Part No SW: 7P5 941 591 AA    HW: 7P5 941 591 A
   Component: LED1L         H06 0003
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7BA0FD86C36FF2B9CA8D-802E
0800 - Bulb for Low-Beam Headlamp
          U4F5256 F6 [040] - Over-Temp Protection Active
                    Reset counter: 0
                    Mileage: 16602 km
                    Date: 2017.11.29
                    Time: 23:32:19
   Component: LED1R         H06 0003
   ROD: EV_LED_PLUS_R_KEBODAVW416.rod
                    Reset counter: 0
                    Mileage: 16602 km
                    Date: 2017.11.29
                    Time: 23:32:19
End----------(Elapsed Time: 02:21, VBatt start/end: 14.7V/14.7V)-----------
Eric
HC800000
Have you tried the history data function in 19, and then interpreting it with Niels' toolbox (Analyze button)?
NEtech
Denmark
C?ID=56995
There is some information if you search for "stop" in measvalues in [19].
There is an older SSP #426 (VW).
Often when start/stop does not work in my VW Up, it is because of battery charge level.
I also like start/stop ;)
From a history file, when your car brand new, there was "consumer current high".
^^^ I know absolutely nothing about the 2018 Atlas SEL Premium, with the 3.6L FSI V6. I had to google it- it looks like a very nice (big?) car. Anyhow, a couple of sites that I visited, mentioned that the Atlas was built on the MQB platform. This being the case, I wonder if the Atlas might have the same feature that exists on its smaller MQB cousin (mk7) that tells the driver exactly why SS isn't engaging. It's a screen that is accessible from the MIB and it looks like this:
So - each of the items on the list above is a reason why SS is not engaging -the list is updated each time that the car is stopped and SS is enabled. Notice the "human-head" symbol next to some entries - these are factors that are at the digression of the driver. Incidentally, the first entry in the list is the message that appears because of the coding tweak to disable SS - which as you will know, works by fooling the module into thinking that the temperature is too high (the temperature method), or that the voltage is too low to restart the car (voltager method).
Does the Atlas have a similar screen?
Zenerdiode
Newcastle, England
C?ID=24330
Sorry Don, I meant I wonder why not having the seatbelt fastened would be a plausible reason for Start/Stop to disengage?
hmm......... you certainly do ask the big questions!!! Good thinking - I'm not sure. Perhaps the logic is that if the car has been automatically stopped by SS and the driver subsequently unfastened her seat-belt to get out of the car, SS is prohibited from restarting the engine when the driver takes her foot off the brake pedal. But I'm guessing!!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I have not. I didn't realize that was part of the stored history. That seems like a good next step for understanding more detail behind the "system/power needs" catchall.
Battery charge level makes sense sometimes, but I've gone on relatively long drives where I notice it persistently. I'll even have highway drives where I come to a stop at the end of an offramp and still have "system/power needs" pop up. I suppose it's possible there's some alternator DF programming to lower output at cruise, to try to hit a fuel mileage goal. Anyway, I'll get a battery history dump tonight and post it here.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
... I wonder if the Atlas might have the same feature that exists on its smaller MQB cousin (mk7) that tells the driver exactly why SS isn't engaging. It's a screen that is accessible from the MIB and it looks like this:
I haven't seen any way to get that info from the MIB, but I do always see one reason (not multiple) shown in the instrument cluster. I can see things like seatbelt unbuckled, traffic situation, HVAC needs, and the ubiquitous system/power needs.
...works by fooling the module into thinking that the temperature is too high (the temperature method), or that the voltage is too low to restart the car (voltager method).
I've verified my Atlas responds to the well-known "voltage" tweak, if applied. I have it at the factory default.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
A couple days ago, when Googling this again using slightly different terms, I ran across an interesting Atlas "selling points" document that has a lot of detail.
https://www.vwwebsource.com/content...ing-Points-Final.pdf?pdf=Selling-Points-atlas
Pages 7 and 8 are highly informative. In particular, it led me to figure out the triggering condition for "traffic situation". It's what prevents auto-stop from kicking in repeatedly when very slowly creeping forward in traffic or other fine maneuvering. The vehicle has to exceed 2MPH since the last auto-stop in order to be eligible again. Over the weekend I verified that slow-creep does correlate with the "traffic situation" displayed reason, it's repeatable.
Side note: for being a dealer-only site, vwwebsource.com sure does leak a lot of open-linkable content to Google's index. Probably unintentional on their part. Interesting stuff. Be sure to go past the first page or two.
dr_torch
Ottawa, Canada
C?ID=442284
Good afternoon @DV52 .... do you know if this can be enabled though adaptations?
I changed the following:
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27 => activated
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus => Comfort Data Bus
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons => activated
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high => activated
But nothing on the VC and nothing on the MMI.
Where do you find that screen? :)
hmm.........not sure for a yanky Atlas - but on the version of Golf mk7 that we get down in the very deep south :), the screens are enabled by this (I think):
  • ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons > activated
  • ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high> activated
Here's a copy of the instruction-set that I thieved from an early post of mine ( on my local Aussie forum) - it was written for a Golf mk7:
  1. With the car running, press the Car button on the escutcheon plate around the MIB center screen.
  2. The following screen should come-up. If you get this screen, press the area of the screen circled
    . Mk7 Stop/Start System - Issues and Questions-stop_start_1-png .
    If the screen above does not appear when the "Car" button is pressed, then you will probably get something like the following screen
    Mk7 Stop/Start System - Issues and Questions-stop_start_2-png
    If this happens, press the "View" panel at the bottom LHS (you can just see it in the pic) and then press the "Vehicle Status" panel that I have circled (with a rectangle) . Then go to step 2 above.
  3. After Step 2, the following screen appears showing why stop/start is not working. What's great about this screen is that the entries update in real-time (well almost real time - it actually updates after a scanning period)!
    . Mk7 Stop/Start System - Issues and Questions-stop_start_3-png
