Abs coding following key,engine engine ecu,speedo and central electric module swap
mrqcars
C?ID=307137
Hi,I have purchased a hex v2 from gendan and registered it tonight,I am a car dealer not a mechanic
Ok,long story short,2013 damaged repairable a3 8v without keys chassis no wauzzz8v6ea039885.
Also a cat b breaker chassis no wauzzz8vxfa071465 ,both cars are 1.2tfsi
I have fitted the engine and gearbox,engine ecu ,speedo cluster,key,and central electronic module (no9)
Had svm performed to remove component protection,mm I,airbag module ,cluster ect.
The abs module would not take a code and shows all 00s in the coding,I have tried copying other codings from similar abs modules but get error 31 when trying to change coding.
I have copied and changed the coding of the instruments from the original speedo and also done the same with engine ecu.
The car runs and drives but I don’t know original coding for the abs module,can you assist?
Ps the breaker was a better spec than the car it’s ecu are being used in,please see, scan,rsvp,thanks,michael
Tuesday,12,December,2017,16:35:20:34356
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4401.4
Data version: 20171130 DS276.6
VIN: WAUZZZ8VXFA071465   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8VXFA071465   Mileage: 33400km-20753miles
Address 01: Engine (J623-CYVB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 CJ    HW: 04E 907 309 AF
   Component: 1.2l R4 TSI   H21 7798
   Revision: R5H21---
   Coding: 02190012230401082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM12TFS01104E906027CJ 001005
   ROD: EV_ECM12TFS01104E906027CJ.rod
   VCID: 6E86C718D01F6637B8D-803A
   CAN Converter 01:
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [032] - -
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:26:47
                    Engine speed: 711.00 /min
                    Normed load value: 21.6 %
                    Coolant temperature: 67 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 14.866 V
                    Mass flow through throttle valve: 6.3 kg/h
                    Median injection timing: 0.745 ms
                    Engine operating condition: Idling
                    A/C compressor: load current: act. value: 376.50 A
          U0428 00 [047] - -
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:26:46
                    Engine speed: 699.00 /min
                    Normed load value: 20.8 %
                    Coolant temperature: 68 °C
                    Voltage terminal 30: 14.889 V
                    CAN status - engine control module-Bit 0: 0
                    selected gear-Bit 0: 0
4714 - Steering Column Control Module
          U0212 00 [032] - No Communications
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:26:46
                    Engine speed: 696.50 /min
                    Voltage terminal 30: 14.795 V
4716 - No Communications with Parking Brake Control Module
          U0128 00 [047] - -
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:26:46
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 S    HW: 5Q0 907 379 G
   Component: ESC           H31 0456
   Revision: 00000000    Serial number: 61973000000620
   ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
   VCID: 4CC26D9086437427F69-8018
14 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 16:13:02
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 16:13:02
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 16:13:02
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 16:13:02
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 16:13:02
0398 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:00:24
4161 - Coding invalid
          U10DA 00 [009] - -
                    Reset counter: 180
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 16:12:00
8278 - Control Module Incorrectly Coded
          U1014 00 [137] - -
                    Reset counter: 179
                    Date: 2017.12.12
                    Time: 15:00:21
8290 - Coding Not Possible
          U10BC 00 [137] - -
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:00:27
8291 - Databus
                    Reset counter: 220
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:35:59
8306 - Databus
          U1122 00 [137] - Implausible Message
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:00:27
8308 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 179
                    Date: 2017.12.12
                    Time: 15:00:21
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [137] - Switches/Motors Detected
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 16:13:02
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 180
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 16:13:02
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
   Part No SW: 8V0 820 047 B    HW: 8V0 820 047 B
   Component: AC Manuell el H11 0031
   Revision: 20019000    Serial number: 00000000023158
   Coding: 00100004000000001000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008016
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 35342874F5C915EFB97-8060
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:00:20
                    Outside air temperature: 4 °C
                    Engine speed: 694.00 /min
                    Temperature after evaporator: 27.0 °C
                    Refrigerant pressure: 1.0 bar
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0134
   Serial number: 01011427302781
   Coding: 07040842C20102FD03044004B31407880000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DA4F0548D790DAF317-8028
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130705  041 0580
   Serial number:         130712062925
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0002
   Serial number: 20118716
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
   Serial number: 18 05 2013  00000351
   Serial number: 000000000ZY131751BJL
267012 - No Communications with Anti-Theft Siren / Alarm Horn
          U10F3 00 [009] - -
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:00:20
267032 - Alarm Horn / Siren for Anti-Theft System
          B131D 29 [009] - Signal Implausible
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:00:20
939524 - No Communications with Humidity Sensor
          U10F5 00 [009] - -
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:00:20
   Part No SW: 5Q0 959 655 L    HW: 5Q0 959 655 L
   Component: AirbagVW20    009 0349
   Serial number: 003GER0168WL
   Coding: 98CCC0000C0000005C5400CA00C800000065
   VCID: 49CC54848931610FCDF-801C
   Subsystem 1 - Part No SW: -----------    HW: 480 001 207 13
   Serial number: 357670000005A0DCFC09
   Subsystem 2 - Part No SW: -----------    HW: 480 001 207 13
   Serial number: 358670000005C0DCFC0C
   Subsystem 3 - Part No SW: -----------    HW: 480 401 307 13
   Serial number: 3516502BD1142C758369
   Subsystem 4 - Part No SW: -----------    HW: 480 401 307 13
   Serial number: 3526502C3107DB50E1EI
   Subsystem 5 - Part No SW: -----------    HW: 480 402 208 14
   Serial number: 3556502A316C6CE272DS
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 909 14
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502C5175A8D2C33K
   Subsystem 7 - Part No SW: -----------    HW: 480 400 909 14
   Component: PedP_Sensor_P  001 6149
   Serial number: 22965029D176A6C5D15S
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 809 14
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C3176A6C43073
1050117 - Databus
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:00:20
   Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
   Revision: --------    Serial number: 12071304401185
   Coding: 8418
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 77A8E27CAF4527FF6BB-8022
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 971 C    HW: 8V0 920 971 C
   Component: KOMBI         H02 4291
   Coding: 27840200228046000100A8001000000000000000
   ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
   VCID: 3D243054CDF9CDAF717-8068
16776967 - Databus
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:00:20
   Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1144
   Revision: --------    Serial number: 0000805725
   Coding: 030100042B0864005B000248000B00000001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 3A2E3B48DCD7FA97545-806E
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 18 07 2013  B1195410
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051760393
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 05071306070244
   Coding: 00100E204001040100001002
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DC4CA4B101A94F15F-8014
15873 - Steering angle sensor
                    Reset counter: 179
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:01:12
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 14.75 V
                    Temperature: 20.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 14.81 V
                    uAdSensI_SwitchedKl30_xdu16: 14.81 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19204 - Databus
                    Reset counter: 180
                    Mileage: 33400 km
                    Date: 2017.12.12
                    Time: 15:01:12
                    Motor status: 01
                    Temperature: 19.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 14.91 V
                    uAdSensI_SwitchedKl30_xdu16: 14.91 V
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serial number: 24061303110499
   Coding: 001006204001040100001002
   VCID: 3C223D50D6E3C4A7469-8068
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    041 0420
   Serial number: A7F00310141983
   Coding: 01730001FF00000021111101000A00002F0001460100010006
   Shop #: WSC 19279 003 1048576
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 3B203E4CD3EDC39F4F3-806E
   Subsystem 1 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H48 0013
   Serial number: AUZ8Z9DG601KZC
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000027061300020642
End----------(Elapsed Time: 01:14, VBatt start/end: 14.7V/14.6V)-----------
mrqcars[at]aol[dot]com
