Saturday,20,November,2021,14:43:01:02428
VCDS Version: 21.9.0.2 (x64) HEX-NET CB: 0.4555.4
Data version: 20210903 DS330.0
Dealer/Shop Name: madelecrto
Workshop Code: 123 11144 011144
VIN: WAUZZZ4G0CN087525 License Plate: A6
Mileage: 279048km-173392mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 18 19 28 36 3B 3C 42 44
46 47 52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90
VIN: WAUZZZ4G0CN087525 Mileage: 279048km-173392miles
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0005
Revision: 53H37--- CVN: A0113789
Coding: 0A25401A046601020000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907401F 001005
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 260008C259EE71B91B-8072
VINID: 9D196AAAA11701378020714214FA1C386E
4531 - Fan 1 Control Circuit
P0691 00 [047] - Short to GND
Mileage: 279028 km
Date: 2021.11.08
Time: 18:24:56
Engine RPM: 0.00 /min
Coolant temperature: 89 °C
Intake air temperature: 34 °C
Voltage terminal 30: 12.000 V
Air mass: specified value: 603.8 mg/stroke
Coolant temperature at radiator outlet: actual value: 73.6 °C
Heat delivery temperature in cooling system: -273.1 °C
Outside temperature: 12.0 °C
Coolant fan 2: activation: 0.00 %
Coolant fan 1: activation: 10.00 %
Fuel temperature: 40.8 °C
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [032] - -
[Transmission control moduleplease read DTC]
Fault Frequency: 20
Mileage: 279028 km
Date: 2021.11.08
Time: 18:26:17
Engine RPM: 771.00 /min
Normed load value: 37.6 %
Coolant temperature: 88 °C
Intake air temperature: 33 °C
Voltage terminal 30: 13.560 V
Accelerator pedal: sensor voltage 1: 757.4 mV
Accelerator pedal: sensor voltage 2: 381.0 mV
Accelerator pedal: switch positions-Bits 0-7: 72
Starter control: Interlock- or P/N-signal-Bits 0-7: 161
Limitation: torque: 176.7 Nm
Control Module temperature: 34.4 °C
Part No SW: 4G1 927 156 B HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0001
Revision: --H10--- Serial number: 0000001204 CVN: 0000FA13
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 2C14FAEA47024BE9CD-8078
7 Faults Found:
8961 - Valve 3 in Transmission Part 2
P17D5 00 [040] - Mechanical Malfunction
Reset counter: 40
Mileage: 279028 km
Date: 2021.11.08
Time: 18:28:13
Engine RPM: 701 /min
Transmission input speed: 701 /min
Engine torque: -8 Nm
ATF temperature: 80 °C
Accelerator pedal position: 0.0 %
Clutch status: Beide Kupplungen offen
8962 - Clutch 2
P17D7 00 [104] - Pressure too High
Reset counter: 40
Mileage: 279028 km
Date: 2021.11.08
Time: 18:25:54
Engine RPM: 714 /min
Transmission input speed: 714 /min
Engine torque: 0 Nm
ATF temperature: 78 °C
10048 - Hydraulic Pressure Sensor 2 (G194)
P1765 00 [096] - Adaptation Limit Reached
Reset counter: 40
Mileage: 279029 km
Date: 2021.11.08
Time: 18:29:35
Engine RPM: 1942 /min
Transmission input speed: 1942 /min
Transmission output speed: 129 /min
Engine torque: 0 Nm
ATF temperature: 83 °C
Accelerator pedal position: 7.6 %
Clutch status: Kupplung 1 kann Moment übertragen
8125 - Internal Control Module
P060A 00 [109] - Processor Performance Monitoring
Reset counter: 40
Mileage: 279028 km
Time: 00:00:00
Engine RPM: 796 /min
Transmission input speed: 796 /min
Transmission output speed: 2000 /min
Engine torque: 0 Nm
ATF temperature: 0 °C
8345 - Internal Control Module
Reset counter: 40
Mileage: 279028 km
Time: 00:00:00
Engine RPM: 697 /min
Transmission input speed: 697 /min
Engine torque: -4 Nm
8128 - Internal Control Module
Reset counter: 40
Mileage: 279028 km
Time: 00:00:00
Engine RPM: 793 /min
Transmission input speed: 793 /min
Engine torque: -12 Nm
8349 - Internal Control Module
Reset counter: 40
Mileage: 279028 km
Time: 00:00:00
Engine RPM: 713 /min
Transmission input speed: 713 /min
Engine torque: 4 Nm
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Coding: 27A68701E465E180DB00
Shop #: WSC 02391 785 00200
VCID: 383CD6BA835AF749B9-806C
Part No SW: 4H0 907 064 BP HW: 4H0 907 064 BP
Component: BCM2 2.0 H31 0333
Coding: 05A82F06000000000000
VCID: 78BC16BACBDA374979-802C
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H12 0062
Serial number: 17111100040590
Coding: 361100B824
ASAM Dataset: EV_AirCondiComfoUDS 002033
VCID: 271E05C65EE468B120-8072
Part No SW: 4H0 907 063 BF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0100
Revision: 20012002 Serial number: 00000001298021
Coding: 2600201040349FE28181008380001D0CCF9CC30826090101000008602101
VCID: 6D9237EEB49882E19A-8038
Component: WWS57X 111013 H35 0051
Serial number: 111024153345
Coding: 0045F7
Component: RLS H04 0003
Serial number: 11776830
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 16 11 2011 00000996
Component: AQ_Hum_Sensor H02 0002
Serial number: AF38CAD5000000000001
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000008
VCID: 2D12F7EE741842E1DA-8078
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Revision: 11001001 Serial number: 55901131901205
Coding: 282B05
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3B36C9B6B26CDC5154-806E
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Coding: 7E04010202
VCID: 281C06FA53FA67C929-807C
154624 - Door Contact Switch
C1076 29 [009] - Signal Implausible
Reset counter: 171
Mileage: 279028 km
Date: 2021.11.08
Time: 18:24:54
Control Module temperature: 30 °C
Voltage terminal 15: 12.075 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
82688 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_TSK_FAIL]
Reset counter: 211
Mileage: 279028 km
Date: 2021.11.08
Time: 18:26:18
Voltage terminal 15: 13.723 V
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG005FJLC
Coding: 30323436313330303437554A304C34473053
VCID: 3620D882894E0139AB-8062
Serial number: 3575HRB40510UJCI397B
Serial number: 3585HRB405B0U2UQ7P67
Serial number: 3515JRB40690R8AA911R
Serial number: 3525JRB405L0TO4MB87Z
Serial number: 3554VRB40550P4N0COCS
Serial number: 3564VRB405R0P4N0IG4+
Revision: -------- Serial number: 90372KK4000FR
Coding: 0000DC
VCID: 373ED5868644F831B0-8062
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0009
Serial number: 01 11 2011 B0081896
Part No SW: 4G8 920 931 R HW: 4G8 920 931 R
Component: TDieRdwAcc H79 0416
Revision: 25460175 Serial number: 658141111591026
Coding: 138609000F110008000000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K_AU57.rod
VCID: 3D32C7AEAC78D2616A-8068
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 E HW: 4H0 265 105 E
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20111018143953
Coding: 5D3B00
VCID: 240412CA27D283A905-8070
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000310488
Coding: 00CD077D00
GVL: FDEDF84CFEE3600D40
ROD: EV_GatewUDS_AU57.rod
VCID: 3424E28A9F32132995-8060
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790118464
Voltage stabilizer:
Serial number: 11319000662021200410
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0062
Serial number: 12111100040610
Coding: 01
ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
VCID: 302CEE9A6B2A2F09F1-8064
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000017963141
VCID: 77BE1586C6C4383170-8022
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4202S6JC0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D12F7EE7C1842E1DA-8078
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH02 0020
Revision: 00H02000 Serial number: 6PZ 010 287-03
Coding: 0000101
VCID: 302CEE9AA32A2F09F1-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H02 0020
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F11.11.1100H020003CF22486˙
Subsystem 4 - Serial number: F22486˙
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F16205E00628002080013
Shop #: WSC 02312 785 00200
VCID: 41CABB5ED880B6810E-8014
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0003219203
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 3228E49265261D1987-8066
Revision: 00002001 Serial number: 0162401274
Coding: 01000E2000B93481832008040C0303000000000000000000000000000000
Subsystem 1 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84182575
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 171
Mileage: 279036 km
Date: 2021.11.08
Time: 18:45:48
02616 - Fuel Tank Cap; Unlock
Reset counter: 171
Mileage: 279036 km
Date: 2021.11.08
Time: 19:18:31
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000007065
Coding: 030000
VCID: 1D72272E04B8B2614A-8048
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F16205E00628002080002
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000186107
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A18FCF24DF655D93F-807E
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 111115-0004-059
Coding: 1121A6101002A300
ROD: EV_HeadlRegulBasic_AU21.rod
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G1 035 053 E HW: 4G1 035 053
Component: Radio U Basic H41 0093
Revision: AB001007 Serial number: 227K30B7507279
Coding: 010003010000000001
VCID: 210A1BDE38C096816E-8074
Part No SW: 4G0 035 670 G HW: 4G0 035 670 A
Component: H-BNT-EU H47 0484
Revision: -------- Serial number: 428K%0B7530763
Coding: 050100000003EBEF7D10CB3E00000003000001000000000000
VCID: 271E05C656E468B120-8072
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB13023PNR
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Serial number: 90349KKE000H5
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14204000628002080002
VCID: 44C4B24AC792A3A925-8010
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Revision: --H04--- Serial number: 525 PA8J1YG0OB
Coding: 1080004
VCID: 260008C291EE71B91B-8072
Part No SW: 4G5 959 107 A HW: 4G5 959 107
Component: HDSG-Modul H01 0038
Revision: 13001001 Serial number: 306100456
Coding: 111104C000
ASAM Dataset: EV_HDSGAu571 001001
ROD: EV_HDSGAu571.rod
Component: TSG HR H04 0212
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H25 0036
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 65824FCE6468BAA1D2-8030
0001 - Front Heater for Lane-Holding Assist
C1101 15 [009] - Open or Short to Plus
Fault Frequency: 6
Reset counter: 172
Mileage: 279028 km
Date: 2021.11.08
Time: 18:25:56
Outside temperature: -44.0 °C
Voltage terminal 15: 13.1 V
Control Module temperature: 38.0 °C
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 7E04010202
Reset counter: 171
Mileage: 279028 km
Date: 2021.11.08
Time: 18:24:55
Control Module temperature: 23 °C
Voltage terminal 15: 12.048 V
Velocity_vehicle_reference: -0.00 m/s
U1113 00 [008] - -
Reset counter: 211
Mileage: 279028 km
Date: 2021.11.08
Time: 18:26:18
Control Module temperature: 24 °C
Voltage terminal 15: 13.670 V
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000051011117
Coding: 04C0B8181111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 312AEB9E60202601FE-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:19, VBatt start/end: 14.9V/14.8V)-----------
