2012 Audi A6 ACC and Audi braking guard: Unavailable Error
AudiThisWorld
C?ID=206654
I have owned a Vag-Com cable for roughly five years now, but this is my first post.
On Monday morning, I started my car and received the "ACC and Audi braking guard: Unavailable" error on my dash. Typically, I restart my car, and it clears out the issue. This time that did not work. After returning home from work, I connected my cable to the car and pulled the following fault code:
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H17 0400
   Coding: 3601010202
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 285FFEFD53F4C906F9-807D
154624 - Door Contact Switch
          C1076 29 [009] - Signal Implausible
                    Reset counter: 104
                    Mileage: 142773 km
                    Date: 2017.12.06
                    Time: 17:19:52
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.658 V
The car has never been in an accident, nor have the front bumper sensors been removed. I did have a new windshield installed about four weeks ago, but I don't think that is related, as the adaptive cruise control worked fine up until Monday. I am puzzled as to what the issue is, and I don't want to fork over a ton of money for the stealership to diagnose the problem. I do see in the fault that part number "4G0 907 561 A" is listed. That is one of the bumper mounted radar sensors, and they are ~$1,200. Not sure if this fault is due to a faulty radar sensor or not, so I thought I would post here. Any help would be much appreciated.
Thanks in advance.
South Molton, UK
Please post the full Auto-Scan not just an edited section.
AudiThisWorld
C?ID=206654
Sorry, I am a noob. I would have added the whole .txt file, as I have seen others do the same but I could figure out how to do that. That is why I only posted the relevant fault.
Just copy & paste the whole contents of the .txt file.
AudiThisWorld
C?ID=206654
Thursday,07,December,2017,16:27:25:02002
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 17.8.1.0 (x64)
Data version: 20171130 DS276.6
VIN: WAUHGAFC8CN105007   License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
          52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90
VIN: WAUHGAFC8CN105007   Mileage: 142828km-88749miles
Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0010
   Revision: --H07---
   Coding: 0A2A0034056600060000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
   ROD: EV_ECM30TFS0214G0907551A_003.rod
   VCID: 275DFDC15EEAC67EF0-8073
6140 - Fan 1 Control Circuit
          P0691 00 [047] - Short to GND
                    Mileage: 142773 km
                    Date: 2017.12.06
                    Time: 17:23:38
                    Engine speed: 735.00 /min
                    Normed load value: 8.6 %
                    Coolant temperature: 101 °C
                    Intake air temperature: 61 °C
                    Ambient air pressure: 860 mbar
                    Voltage terminal 30: 13.710 V
                    Engine speed: actual: 1376 /min
                    MAF_ENVD: 168.85882 mg/stroke
                    Coolant temperature (unfiltered): 21.00 °C
                    Engine: operating status: IS
                    Engine load: 14.062500 %
                    Vehicle speed: actual: 0 km/h
Readiness: 0000 0100
   Part No SW: 4G0 927 158 P    HW: 0BK 927 156 AJ
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 3B7531B1B262729E84-806F
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 44A70F0122E5F0804B00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 387F2EBD8354598669-806D
   Part No SW: 4H0 907 064 BR    HW: 4H0 907 064 BR
   Component: BCM2 2.0      H31 0333
   Coding: 0D882006000000000000
   VCID: 7AFBF4B5F5D88B96DF-802F
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000263712004
   Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Component: KLIMA 4 ZONEN H12 0063
   Serial number: 10121100040887
   Coding: 6601207A4C
   ASAM Dataset: EV_AirCondiComfoUDS 002035
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001335158
   Coding: 09072091073C9FE281000084A0003800CF9CD208A20801258001085C3B00
   VCID: 6ED3C8E5B990D73673-803B
   Component: WWS57X 111119  H35 0051
   Serial number:         111208002402
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11830020
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 06 12 2011  00000498
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R105K02
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0018829219
   Coding: 853000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000003121100010454
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000009111100010671
   Coding: 110000
   Subsystem 8 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA102472000000633838
   Coding: 020300
   Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: D47802E5000000000001
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901134301405
   Coding: 280906
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3D713FA9AC767CAEBA-8069
   Coding: 3601010202
                    Reset counter: 104
                    Mileage: 142773 km
                    Date: 2017.12.06
                    Time: 17:19:52
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H31 0032
   Revision: --------    Serial number: 003D8001F7AE
   Coding: 303234373131303030324A55304C34473053
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 336519919A32BADE5C-8067
   Serial number: 6940000Y160001GF870L
   Serial number: 3575HRB405H11FPI60MH
   Serial number: 3585HRB405H11FPI10TK
   Serial number: 3515JRB40650TGJIJGSG
   Serial number: 3525JRB405T0U2UUO90K
   Serial number: 3554VRB405B0TO4MDPCK
   Serial number: 3564VRB405B0TO4MF9C7
   Revision: --------    Serial number: 90372KL90015X
   Coding: 00003C
   VCID: 377D2D81864A56FE60-8063
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0009
   Serial number: 11 11 2011  D0039197
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 982 T    HW: 4G8 920 982 T
   Component: TBenUsaAcc    H79 0416
   Revision: 25460175    Serial number: 658261111592039
   Coding: 0BCF09040F01D705020000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   VCID: 45815749C4A6346EE2-8011
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000338815
   Coding: 00C1033000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 34671A8D9F3CBDE645-8061
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790409565
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0063
   Serial number: 11121100040331
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002017
   VCID: 2F6D15E1761A9E3E38-807B
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000019915523
   Coding: C0581B008F002001000001010101102030303232203232
   VCID: 387F2EBD8B54598669-806D
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA42034G8V0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D510FE97C16EC2E0A-8079
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0020
   Revision: 00H02000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 306F169DA32481C621-8065
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H02 0020
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F08.12.1100H020003CF21099ÿ
   Subsystem 4 - Serial number: F21099ÿ
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F17205E00628002000013
   Shop #: WSC 02312 785 00200
   VCID: 41894359D88E184EDE-8015
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0005256693
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326B1C956528B3D657-8067
   Revision: 00002001    Serial number: 0165306692
   Coding: 0106063A00FA448580B00880020500000000000000000000000000000000
   VCID: 7AFBF4B5F5D88B96DF-FFFF
   Component: GTO BF  H01 0070
   Serial number: 00000000000000063290
   Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
   Component: J245 PS40.033  H07 0006
   Serial number:     WOO14390797
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00000624936
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000034717
   Coding: 030000
   VCID: 1C37D22D1FAC15A66D-8049
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F17205E00628002000002
                    Fault Status: 01101100
                    Reset counter: 104
                    Mileage: 142779 km
                    Date: 2017.12.07
                    Time: 08:06:21
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000192317
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2A5B04F54DF8FB16EF-807F
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 111206-0004-027
   Coding: 1221A6601002A400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C5702ED470CE5261D-8079
   Part No SW: 4G0 035 082 C    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0101
   Revision: AB001007    Serial number: 236L$0B7501367
   Coding: 020007010000000001
   VCID: 204FE6DD33C43146B1-8075
   Part No SW: 4G0 035 746 C    HW: 4G0 035 746
   Component: H-BNT-NA      H48 0423
   Revision: --------    Serial number: 031LW0B7523606
   Coding: 050200000003E9EF75128B3E00000003100001000000000000
   Shop #: WSC 22803 444 183823
   VCID: 275DFDC156EAC67EF0-8073
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB94004V4M
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349KLD0009N
   Component: CD-Database  3371
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F17204000628002000002
   VCID: 44874A4DC79C0D66F5-8011
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J1YG4JT
   Coding: 1080004
   Shop #: WSC 60807 000 1048576
   VCID: 2643F0C591E0DF76CB-8073
   Component: TSG HR        H04 0212
Address 85: On Board Cam. (J852)       Labels:* None
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H25 0036
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 65C1B7C96466146E02-8031
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 3601010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   VCID: 2643F0C559E0DF76CB-8073
                    Reset counter: 106
                    Mileage: 142828 km
                    Date: 2017.12.07
                    Time: 16:13:46
                    Control Module temperature: 9 °C
                    Voltage terminal 15: 14.700 V
                    Velocity_vehicle_reference: -0.00 m/s
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000050912117
   Coding: 048198180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31691399602E88CE2E-8065
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 09:22)--------------------------
MasterTommy
Amsterdam
C?ID=295586
If the radar sensor has an obstructed view (heavy rain or snow during driving, or a layer of snow ice or dirt stuck on the sensor ehile parked) it will throw a similar code on the dash on VW’s. Obviously not related to the door contact switch though. Seeing as specifically the radar sensor is giving the door contact switch code, it must be something the radar sensor wants fully functional. Is central electrics throwing the same code?
United States
I had a caller with a ACC problem in a A6 or A7 at one point with that exact issue. It was a faulty LF door latch causing inop ACC.
The A6/A7 SSPs directed me to this one: Systems Self-Study Program 960103 named 2011 Audi A8 Running Gear and Suspension Systems I can't quote the entire thing but page 42 says:
Under the following conditions, the
ACC is automatically deactivated and the
Electromechanical Parking Brake (EPB)
activated while the vehicle is stationary:
–  Opening a door: The driver’s door is
monitored redundantly by the door contact
and microswitch in the door lock. All other
doors are monitored by the door contact
switch.
    The ACC receives information from the
corresponding door control modules and
redundantly from the ABS control module.
–  Opening the hood
–  Longer parking period: ESP enables the
pressure holding function by actuating the
valves. Since the valve coils heat up due to
the actuating current, the maximum vehicle
holding time that can be maintained by ESP
is limited. Once this period of time has been
exceeded, the function is transferred to the
EPB.
–  ESP  fault
–  Fault in another control module relevant to the
ACC function (except a fault in the EPB control
module)
–  Engine turned OFF
    The ACC is deactivated if the EPB is operated
while the ACC is active.
If a fault occurs in the EPB system, the ACC is
deactivated. Simultaneously, park position “P”
is activated automatically. “ACC: TAKE OVER!” is
shown in the instrument cluster.
That copy/paste job is unsightly but the logic makes sense.
I would check the door latch status in 42 and 46. Let us know if you need help locating those MVBs.
United States
I'm back. After realizing we don't have a lbl file for that #42 I checked into similar modules and came up with MVB 001.1:
001,1,Door Status
0 = inactive\1 = active
xxxxxxx? = Key Switch open
xxxxxx?x = Key Switch closed
xxxxx?xx = Central Locking (CL) Interior Switch locking
xxxx?xxx = Central Locking (CL) Interior Switch unlocking
xxx?xxxx = Lock Feedback "locked"
xx?xxxxx = Lock Feedback "safed" (not USA)
x?xxxxxx = Door Contact Switch
?xxxxxxx = Catch (for Closing Assistance)
I would observe the x?xxxxxx = Door Contact Switch position in address 42. Compare that to the live data in address 52 when opening and closing the right door to see if you can conclusively determine the latch microswitch is faulty on the left.
AudiThisWorld
C?ID=206654
001,1,Door Status
How do I do this? I see #42 and #53 for the driver and passenger door electronics. Where can I see the output of data?
Thanks so much for taking time out of your day to help me by the way.
How do I do this? I see #42 and #53 52 for the driver and passenger door electronics. Where can I see the output of data?
[Select]
[42-Driver's Door] -or- [52-Pass. Door]
[Measuring Blocks]
Put 001 in the first of the three fields labelled 'Group' and click [Go!]
AudiThisWorld
C?ID=206654
They both show as 00000000 when closed and 01000000 when open. I am testing opening the door slowly to trip the sensor and VagCom picks up both sensors as quickly as well as the dash display. I don't see any difference between the passenger and driver side. Also, the voltage for both sensors are basically the same.
AudiThisWorld
C?ID=206654
switch.
–  Opening the hood
EPB.
–  ESP  fault
module)
–  Engine turned OFF
Also, I noticed that this says that the parking brake would activate under this scenario. My parking brake is not active while in park, FYI.
Andy_sim
C?ID=15057
Hi there,
I have the same problem, id anyone find a solution?
Andy
autotech97
Serbia
C?ID=369769
Yes I had a simmilar problem yesterday the driver door lock mechanism was defective part no : 4G1837015 , but I managed to repair it , with soldering two wires from the switch directly to the door connector cable , or you can simply change complete door mechanism.
