2018 Audi A3 e-tron
   #21
Andy
Sector 7G
HC424490
44 - Steering Assist maps
;SW:5Q0-909-144-T   HW:5Q0-909-144-R ---  Steering Assist
;Component:EPS_MQB_ZFLS  128 1072, Coding:D106
;EV_SteerAssisMQB,013144,EV_SteerAssisMQB_013.rod
;Friday,08,December,2017,16:14:15:29905
;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
;VCID: 45CDD25FC4D53702B59-8010
IDE03724-Straight line running,active ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE09571-RPM monitoring,active ,1
Elapsed Time: 00:02
;Friday,08,December,2017,16:14:07:29905
Group,Description,Actual
IDE00018,Voltage terminal 15,13.14, V
IDE00019,Voltage terminal 30,13.06, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine speed,0, /min
IDE00102,Control Module temperature,15.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,08,
IDE00550-MAS01078,Identification of parameterization-Vehicle type,G0,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,21,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,07,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assistant-System status,Marginal conditions have not been met,
IDE02006-IDE04227,Lane assistant-Directional stab. asst w/ pwr steering asst: steering status,0.000, Nm
IDE02006-MAS03095,Lane assistant-Function status,activated,
IDE02006-MAS03368,Lane assistant-Steering wheel vibration,not active,
IDE02202,End stage temperature,7.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02955,System status,Waiting for start request,
IDE03682-IDE04457,Sensor for motor position-Electric motor speed,N/A---,
IDE03682-MAS02961,Sensor for motor position-Engine angle,N/A---,
IDE03682-MAS03083,Sensor for motor position-Cosine signal,N/A---,
IDE03682-MAS03211,Sensor for motor position-Sine signal,N/A---,
IDE03682-MAS05053,Sensor for motor position-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,0, %
IDE03725-MAS03001,Steering Assistance-Mode,Comfort,
IDE03725-MAS03095,Steering Assistance-Function status,not activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,5.9, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,0.0, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
IDE03735,Steering torque,N/A---,
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE03736,Steering torque 2,N/A---,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,0.5, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,0.5, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active reset-Restoring force: setpoint,0, N
IDE04183,Steering assistance: target engine torque,0.000, Nm
IDE04184,Steering assistance: engine output,0.000, %
IDE04185,Terminal 30 voltage filtered,13.14, V
IDE04187,Steering torque: raw value 1,-28.613, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-91.699, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,-28.613, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-91.699, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.40, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.39, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.39, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,0.0, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,0.0, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,0.0, A
IDE04194,Steering assistance: electromotor power,N/A---,
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,4.7, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,0.0, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.74, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical center,0.30, mm
IDE04460,Steering angle sensor: offset straight line running,N/A---,
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not recognized,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not recognized,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not recognized,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not recognized,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,1,
IDE04511,Steering angle sensor external via CAN: angle,Measured value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measured value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,operational,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine speed,No,
IDE04787,Hybrid status,active,
IDE04805-IDE02955,Driving profile selection-System status,operational,
IDE04805-MAS01447,Driving profile selection-Act.val.,1,
IDE04805-MAS01448,Driving profile selection-Specified value,1,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05155,Power steering current consumption,N/A---,
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,80.66, mm
IDE05162-MAS01850,Software end stop-Right,-80.07, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,1426,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,1278,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,130,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,437,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,1,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,101,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG120739,Engine specified torque load-above_10_kilo_newton,3,
IDE05994-ENG120718,Engine specified torque load-below_-10_kilo_newton,0,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,28656,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,352,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,11,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,194,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,286,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,65,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,85,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adapt. value,0.120, Nm
IDE06678-MAS03095,Pull compensation-Function status,not activated,
IDE07399,Engine type,0,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Regulation active,Condition not met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,8,
MAS00464-MAS00109,Standard - ambient data 1-Hours,1,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,15,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,78, km
MAS00976-IDE80003,Counter-Analysis 3,3680870732,
MAS00976-IDE80004,Counter-Analysis 4,0,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
Elapsed Time: 00:08
Andy
Sector 7G
HC424490
47- Sound System maps
;SW:81A-035-466-B   HW:81A-035-466 ---  Sound System
;Component:MIB2_amp_P_A3 H10 0440, Coding:0173030000AAAA2AAA0000010000
;EV_AMPMst16C9Gen2ALPI,001002,EV_AMPMst16C9Gen2ALPI.rod
;Friday,08,December,2017,16:14:40:29905
;VCID: 240B6FDB2FAF2E0A827-8070
IDE10493-MAS03001-Electrical test 2 of loudspeakers-Mode,automatic ,73
IDE10493-ENG117360-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,73
IDE10493-ENG117361-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,60 ,73
IDE10493-ENG117378-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,73
IDE10493-ENG117379-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,60 ,73
IDE10493-ENG117380-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,73
IDE10493-ENG117381-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,60 ,73
IDE10493-ENG117382-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,73
IDE10493-ENG117383-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,60 ,73
IDE10493-ENG117384-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,73
IDE10493-ENG117385-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,60 ,73
IDE10493-ENG117386-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,73
IDE10493-ENG117387-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,60 ,73
IDE10493-ENG117388-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,73
IDE10493-ENG117389-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,60 ,73
IDE10493-ENG117390-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,73
IDE10493-ENG117391-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,60 ,73
IDE10493-ENG126164-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,73
IDE10493-ENG126165-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,60 ,73
IDE10493-ENG126166-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,73
IDE10493-ENG126167-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,60 ,73
IDE10493-ENG126168-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,73
IDE10493-ENG126169-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,60 ,73
IDE10493-ENG117362-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,73
IDE10493-ENG117363-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,60 ,73
IDE10493-ENG126170-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,73
IDE10493-ENG126171-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,60 ,73
IDE10493-ENG126172-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,73
IDE10493-ENG126173-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,60 ,73
IDE10493-ENG126174-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,73
IDE10493-ENG126175-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,60 ,73
IDE10493-ENG126176-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,73
IDE10493-ENG126177-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,60 ,73
IDE10493-ENG126178-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,73
IDE10493-ENG126179-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,60 ,73
IDE10493-ENG117364-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,73
IDE10493-ENG117365-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,60 ,73
IDE10493-ENG117366-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,73
IDE10493-ENG117367-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,60 ,73
IDE10493-ENG117368-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,73
IDE10493-ENG117369-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,60 ,73
IDE10493-ENG117370-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,73
IDE10493-ENG117371-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,60 ,73
IDE10493-ENG117372-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,73
IDE10493-ENG117373-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,60 ,73
IDE10493-ENG117374-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,73
IDE10493-ENG117375-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,60 ,73
IDE10493-ENG117376-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,73
IDE10493-ENG117377-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,60 ,73
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
Elapsed Time: 00:02
;Friday,08,December,2017,16:14:21:29905
IDE00019,Voltage terminal 30,13.1, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0.00, /min
IDE00668-MAS03231,Microphone current consumption-Microphone 1,2.80, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,0, counts
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,On,
IDE01716,Terminal 50 status,OFF,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,No,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,Yes,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,47,
IDE03880-MAS03425,MOST address-Physical address,04 02,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,13, min
IDE04317-MAS00108,Total system run time-Day,0, d
IDE04317-MAS00109,Total system run time-Hours,5, H
IDE04317-MAS00110,Total system run time-Minutes,48, min
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,No,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,Yes,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04649-MAS01968,Activation for housing fan-Fan,OFF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,Mute,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,Mute,
IDE05704-MAS02646,Digital Transmission Content Protection (DTCP) key-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,0,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,0,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE06055,Invalid authentication (DTCP),5F,
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,47, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-1, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Current,19, °C
IDE09935-MAS01424,Temperature of inductor-max.value,56, °C
IDE09935-MAS01425,Temperature of inductor-min.value,-1, °C
IDE09935-MAS02238,Temperature of inductor-Current,16, °C
IDE10545-IDE03744,Speaker status-Left effects speaker,OK,
IDE10545-IDE03745,Speaker status-Right effects speaker,OK,
IDE10545-IDE03747,Speaker status-Left Front Midrange Speaker,OK,
IDE10545-IDE03748,Speaker status-Right Front Midrange Speaker,OK,
IDE10545-MAS01188,Speaker status-Left front bass speaker,OK,
IDE10545-MAS01190,Speaker status-Left front treble speaker,OK,
IDE10545-MAS01191,Speaker status-Right front bass speaker,OK,
IDE10545-MAS01193,Speaker status-Right front treble speaker,OK,
IDE10545-MAS01194,Speaker status-Left rear bass speaker,OK,
IDE10545-MAS01195,Speaker status-Left rear treble speaker,OK,
IDE10545-MAS01196,Speaker status-Right rear bass speaker,OK,
IDE10545-MAS01197,Speaker status-Right rear treble speaker,OK,
IDE10545-MAS01198,Speaker status-Center speaker,OK,
IDE10545-MAS04506,Speaker status-Double subwoofer speaker 1,OK,
IDE10545-MAS04507,Speaker status-Double subwoofer speaker 2,OK,
IDE10545-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE10545-ENG126180,Speaker status-loudspeaker_channel_17,Measured value not available,
IDE10545-ENG126181,Speaker status-loudspeaker_channel_18,Measured value not available,
IDE10545-ENG126182,Speaker status-loudspeaker_channel_19,Measured value not available,
IDE10545-ENG126183,Speaker status-loudspeaker_channel_20,Measured value not available,
IDE10545-ENG126184,Speaker status-loudspeaker_channel_21,Measured value not available,
IDE10545-ENG126185,Speaker status-loudspeaker_channel_22,Measured value not available,
IDE10545-ENG126186,Speaker status-loudspeaker_channel_23,Measured value not available,
IDE10545-ENG126187,Speaker status-loudspeaker_channel_24,Measured value not available,
IDE10657-MAS01424,Temperature switching power supply-max.value,58, °C
IDE10657-MAS01425,Temperature switching power supply-min.value,-1, °C
IDE10657-MAS02238,Temperature switching power supply-Current,18, °C
IDE10659-MAS01424,Temperature switching power supply 2-max.value,54, °C
IDE10659-MAS01425,Temperature switching power supply 2-min.value,5, °C
IDE10659-MAS02238,Temperature switching power supply 2-Current,30, °C
MAS00464-MAS00111,Standard - ambient data 1-Seconds,39,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,4, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,17, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,12, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,8, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,16, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,0, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,42, s
Elapsed Time: 00:19
Andy
Sector 7G
HC424490
4B - Multifunc. Module maps
;SW:3Q0-907-338   HW:3Q0-907-338 ---  Multifunc. Module
;Component:FCM MQB Low   002 0286, Coding:000000050100142A00112300040000000000000000000000000000000000
;EV_MultiModulContiVW48X,001010,EV_MultiModulContiVW48X.rod
;Friday,08,December,2017,16:14:51:29905
;VCID: 72A75983A5DBF0BAC0B-8026
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection,Yes ,1
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,Yes ,1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,Yes ,1
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Yes ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE08418-Matrix light: total dimming,63 %,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,6
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,6
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,6
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,6
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,6
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,6
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,6
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,6
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,6
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,6
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,6
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,6
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,6
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,6
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,6
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,6
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,6
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,6
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,6
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,6
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,6
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,6
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,6
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,6
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,6
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,6
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,6
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,6
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,6
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,6
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,6
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,6
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,6
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,6
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,6
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,6
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,6
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,6
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,6
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,6
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,6
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,6
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,6
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,6
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,6
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,6
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,6
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,6
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,6
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,6
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,6
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,6
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,6
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,6
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,6
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,6
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,6
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,6
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,6
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,6
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,6
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,6
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,6
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,6
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,6
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,6
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,6
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,6
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,6
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,6
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,6
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,6
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,6
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,6
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,6
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,6
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,6
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,6
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,6
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,6
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,6
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,6
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,6
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,6
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,6
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,6
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,6
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,6
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,6
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,6
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest,30 %,12
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion,30 %,12
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest,30 %,12
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion,30 %,12
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest,50 %,12
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion,50 %,12
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest,50 %,12
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion,50 %,12
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest,75 %,12
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion,75 %,12
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest,80 %,12
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion,80 %,12
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG124607-Reference_Run_Activation_Effect,Activation effect disabled ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:07
;Friday,08,December,2017,16:14:45:29905
IDE00075,Vehicle speed,0.0, km/h
IDE00326,Steering wheel angle,4.70, °
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE01714,Status reverse gear,OFF,
IDE01717-ENG30211,Processor load-Software_component_AFS_MXB,9, %
IDE01717-ENG30223,Processor load-Total_system_FCM,22, %
IDE01943,Turn signal,not activated,
IDE01946,ESP intervention,not active,
IDE02389,Ambient brightness,0, lx
IDE02515,Low beam,OFF,
IDE02743,High Beam,OFF,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,-0.01, %
IDE03604,Left rear level control system sensor,42.80, %
IDE03616,Motor status,OFF,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,-23.3, mm
IDE03622,Left headlight beam adjusting motor: status,no error,
IDE03623,Right headlight beam adjusting motor: status,no error,
IDE03624,Left dynamic AFS light motor: specified value,32.000000, °
IDE03625,Right dynamic AFS light motor: specified value,32.000000, °
IDE03626,Left dynamic AFS light motor: status,no error,
IDE03627,Right dynamic AFS light motor: status,no error,
IDE03628,Adjusting motor for variable left front lighting: status,no error,
IDE03629,Adjusting motor for variable right front lighting: status,no error,
IDE03630,Left headlight beam adjusting motor: specified value,1024.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,1024.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,static AFS light-Dim static left AFS light,102.0, %
IDE03638-IDE03718,static AFS light-Dim static right AFS light,102.0, %
IDE03640,Dynamic AFS light,OFF,
IDE03669,Light distribution status,not activated,
IDE03727,Variable left front lighting specified position,204.70, %
IDE03728,Variable right front lighting specified position,204.70, %
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),-0.01, %
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),47.20, %
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE08447,Driving axis angle,-120.0, '
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS06932,Actual angle of ref. segments-Horizontal angle reference segment left,-500.0, '
IDE08706-MAS06933,Actual angle of ref. segments-Horizontal angle reference segment right,-500.0, '
IDE08706-MAS06934,Actual angle of ref. segments-Vertical angle reference segment left,-120.0, '
IDE08706-MAS06935,Actual angle of ref. segments-Vertical angle reference segment right,-120.0, '
IDE08713-MAS06936,Matrix light: calculated offset values-Horizontal offset: light left,-300.0, '
IDE08713-MAS06937,Matrix light: calculated offset values-Horizontal offset: light right,-300.0, '
IDE08713-MAS06938,Matrix light: calculated offset values-Vertical offset: light left,-300.0, '
IDE08713-MAS06939,Matrix light: calculated offset values-Vertical offset: light right,-300.0, '
IDE08714-MAS06929,Axle offsets-Axle offset front,-400.0, mm
IDE08714-MAS06930,Axle offsets-Axle offset rear,-400.0, mm
IDE08715,Func. status matrix high beam,not active,
ENG101323,Headlight leveling control state,static,
ENG107365,Left dynamic cornering light value,9.000000, °
ENG26446-ENG30212,Multifunction_Module_Application_Software_Version-Software_Version_AFS/MXB,0065,
ENG26446-ENG30225,Multifunction_Module_Application_Software_Version-Version_Routing_FCM,7160,
ENG124613,Predictive_Route_Data_Intown_Flag,Not available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,Not available,
ENG124612,Predictive_Route_Data_Placename_Sign,Not available,
ENG124611,Predictive_Route_Data_Speed_Limit,Not available,
ENG124609,Predictive_Route_Data_Street_Class,Not available,
ENG108468,Right dynamic cornering light value,ERROR,
Elapsed Time: 00:05
Andy
Sector 7G
HC424490
51 -Electric Drive maps
;SW:5G0-907-080-E   HW:5G0-907-080-E ---  Electric Drive
;Component:LE Gen 3.3H15 1032, Coding:40020000000000000000
;EV_DMCM08530115G0907080E,001008,EV_DMCM08530115G0907080E.rod
;Friday,08,December,2017,16:15:11:29905
;VCID: 29157EEF488DF362B11-807C
Elapsed Time: 00:00
;Friday,08,December,2017,16:15:01:29905
IDE00018,Voltage terminal 15,1,
IDE00019,Voltage terminal 30,13.044, V
IDE00613,Phase current phase U,1.31, A
IDE00614,Phase current phase V,2.19, A
IDE00615,Phase current phase W,3.81, A
IDE00619,RPM of electric machine,0, /min
IDE00626,Temperature of electric machine,17.03, °C
IDE00628,Specified value of intermediate circuit voltage,0.00, V
IDE00635,Intermediate circuit current,0.00, A
IDE00637,Intermediate circuit voltage,355.59, V
IDE00643,Minimum torque of electric machine,-0.25, Nm
IDE00644,Maximum torque of electric machine,-0.19, Nm
IDE00645,Specified torque of electric machine,0.00, Nm
IDE00651,Specified RPM of electric machine,0, /min
IDE00796,Offset angle of rotor positions,275.488, °el
IDE00938,Calculated actual torque of electric machine,-0.31, Nm
IDE00952,Availability of high voltage,1,
IDE04222,Test voltage for insulation measurement for power electronics,500.00, V
IDE04223,Test voltage for insulation measurement for e-machine,500.00, V
IDE05246,Power electronics heat sink temperature,28.09, °C
IDE05248,E-machine speed: actual value,0, /min
IDE05249,Regulation due to excessive temperature,0,
IDE05250,Drive control condition,Standby,
IDE05250-ENG14691,Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE,2,
IDE05419,Intermediate circuit current maximum limit,288.94, A
IDE05420,Intermediate circuit current minimum threshold,-119.00, A
IDE05421,Torque: current value,-0.19, Nm
IDE05425,Output current of DCDC converter,19.75, A
IDE05426,Buck converter operation due to current limit being exceeded,0,
IDE05427,Boost converter operation due to current limit being exceeded,0,
IDE05428,Buck converter operation due to voltage limit being exceeded,0,
IDE05429,Boost converter operation due to voltage limit being exceeded,0,
IDE05578,DCDC converter intermediate circuit voltage,355.59, V
IDE06501,Adaptation of magnetic flow: status,0,
IDE06502,Offset angle adaptation: status,OfsAccurate_E,
IDE06502-ENG14694,Offset angle adaptation: status-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb St Ag Rtr Offs UBYTE,2,
IDE06805,Status of voltage freedom,2,
IDE09094,CAN signal: battery manag system: traction network current,1.75, A
IDE09095,CAN signal: battery management system: traction network voltage,355.50, V
IDE09096,CAN signal: battery management sys.:hi. voltage protect.:status,MaiClsd,
IDE09096-ENG14700,CAN signal: battery management sys.:hi. voltage protect.:status-Test_Program_Rbe Asw Cif Enum rbe Cmn Glb Hvb Cntct UBYTE,2,
IDE09097,Electric motor: electric rotor frequency,0.0, Hz
IDE09098,Electric motor: electric power,0, W
IDE09099,Electric motor: mechanical power,96, W
IDE09100,Electric motor: idle status,WithoutStatorCurrent,
IDE09100-ENG14698,Electric motor: idle status-Test_Program_Rbe Asw Invr MCT enum Frwhl UBYTE,0,
IDE09101,Electric motor: magnetic flux reference value,0.000000, Wb
IDE09102,Electric motor: RMS current,0.44, A
IDE09103,E-machine: stator temperature,17.03, °C
IDE09104,E-machine: stator temperature char. curve range,1,
IDE09105,Power electronics: intermediate circuit current,0.00, A
IDE09107,Power electronics: internal power supply 2,0.443, V
IDE09108,Power electronics: internal power supply IGBT,29.787, V
IDE09111,Power electronics: gate driver status,ShortCircuitBot,
IDE09111-ENG14696,Power electronics: gate driver status-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Gate Drv UBYTE,0,
IDE09113,Power electronics: IGBT module temp: phase U,27.88, °C
IDE09114,Power electronics: IGBT module temp: phase V,27.97, °C
IDE09115,Power electronics: IGBT module temp: phase W,27.70, °C
IDE09117,Position offset calibration: stay,0.00, s
IDE09118,Magnetic flow calibration: status,0,
IDE09119,Position offset calibration: diagnostic status,NotTested__E,
IDE09119-ENG14697,Position offset calibration: diagnostic status-Test_Program_Rbe Asw Invr ISC enum St Diag Al Rtr Ofs Clb UBYTE,0,
IDE09123,D/C-D/C converter: power section temp,27.88, °C
IDE09124,DC/DC converter: traction network current,-0.789, A
IDE09126,Vehicle switch-off time,136, min
IDE09127,Status: switch-off time,Abstellzeit_berechnet,
IDE09127-ENG14695,Status: switch-off time-Test_Program_Rbe Asw Cif Enum rbe Cmn Glb Dwn Ti UBYTE,1,
IDE09128,DC/DC converter: status,rbe_AswDcdc_BuckReq_e,
IDE09128-ENG14699,DC/DC converter: status-Test_Program_Rbe Asw Dcdc Enum rbe Cmn Glb Dcdc Mod Cust Des UBYTE,4,
IDE09129,DC/DC converter: output current term 30,19.75, A
IDE09130,DC/DC converter: regulated output current term 30,13.203, V
IDE09210,Phase current phase U unrestricted,2.00, A
IDE09211,Phase current phase V unrestricted,1.50, A
IDE09212,Phase current phase W unrestricted,2.44, A
MAS06713,Supply voltage Terminal 30 - internal,12.500, V
MAS09947,Condition interm. circuit discharge circuit,DchaNotActv,
MAS09947-ENG14701,Condition interm. circuit discharge circuit-Test_Program_Rbe Asw Invr SYM enum St Dcha UBYTE,0,
MAS12577,Rotor position sensor 2 sine offset,0.000, V
MAS12578,Rotor position sensor 2 Cosine offset,0.000, V
MAS12772,DC/DC changer: high voltage current restriction,14.00, A
MAS12773,DC/DC changer: spec. operating mode,1,
MAS12774,DC/DC changer: spec. output voltage terminal 30,13.199, V
MAS13360,Discharge current HV intermediate circuit power electronics,0.00, A
MAS13361,PCB temperature power electronics,46.86, °C
MAS13362,Calculated coolant temperature DCDC converter,27.52, °C
MAS13363,Redundant intermediate circuit voltage power electronics,355.59, V
MAS13431,Low-voltage fuse: current,1.055, A
MAS13432,Low-voltage fuse: voltage,13.014, V
MAS13802,Rotor position sensor 2: cosine amplitude,0.000, V
MAS13803,Rotor position sensor 2: sine amplitude,0.000, V
MAS13804,Rotor position sensor 2: exciter amplitude,8.826, V
ENG105721,Current_DC_Link_power,0, W
ENG105722,Current_in_d-direction,-0.13, A
ENG105723,Current_in_q-direction,-0.19, A
ENG105770,DCDC_derating_due_to_overtemperature,0,
ENG105797,Desired_current_in_d-direction,0.00, A
ENG105798,Desired_current_in_q-direction,-0.44, A
ENG105799,Desired_torque,0.00, Nm
ENG106053,Effective_value_stator_current,1.00, A
ENG106109,Electric_drive_cooling_activated,option_not_available,
ENG106109-ENG14693,Electric_drive_cooling_activated-Test_Program_Rbe Asw Cif Enum rbe Asw Cif Sttr Coolt Circ UBYTE,3,
ENG106482,Failure_emergency_shut_off,0,
ENG106483,Failure_free_wheeling,0,
ENG106484,Failure_inverter_limited_performance,0,
ENG106485,Failure_inverter_shut_off,0,
ENG106555,Fieldweakening_active,0,
ENG13207,HV-circuit_operation_mode,rbe_CddHvMcu_NormMod_e,
ENG13207-ENG14703,HV-circuit_operation_mode-Test_Program_Rbe Cdd Hv Mcu Enum rbe Cdd Hv Mcu St Mod UBYTE,0,
ENG13208,IGBT_temperature_characteristic_curve_state,1,
ENG13209,Internal_sum_error_itemization,0,
ENG13205,Internal_supply_voltage_15_inverter_IGBT,15.322, V
ENG107077,Inverter_state,0,
ENG26312,ISC t Dbc Invr Snsr Max,27.97, °C
ENG107397,Load_moment_auxiliaries,-5.13, Nm
ENG107584,Maximal_DC-Link_voltage,400.00, V
ENG107585,Maximal_torque_hybrid_controller,2047.94, Nm
ENG107589,Maximum_power_limit,95008, W
ENG107590,Maximum_torque_derating_reason,inactive,
ENG107590-ENG14692,Maximum_torque_derating_reason-Test_Program_Rbe Asw Invr TQL enum Der UBYTE,1,
ENG26321,MCT Temp Rtr,23.11, °C
ENG107604,Mechanical_angular_speed,0.00, rad/s
ENG107623,Minimal_torque_hybrid_controller,-2047.94, Nm
ENG107624,Minimum_DC-Link_voltage,250.00, V
ENG107625,Minimum_power_limit,-95008, W
ENG107626,Minimum_torque_derating_reason,inactive,
ENG107626-ENG14692,Minimum_torque_derating_reason-Test_Program_Rbe Asw Invr TQL enum Der UBYTE,1,
ENG107742,Necessary_generator_torque,-0.19, Nm
ENG13206,Operation_mode_DCDC_actual_state,rbe_AswDcdc_Buck_e,
ENG13206-ENG14702,Operation_mode_DCDC_actual_state-Test_Program_Rbe Com Dcdc Can Enum rbe Cmn Glb Dcdc Oper Mod UBYTE,1,
ENG13204,Periodic_time_gate_driver,100.00, µs
ENG26341,Rbe Asw Invr Isc t Lnk Cap,31.92, °C
ENG26343,Rec rbe Com Drv Can 10ms t Oil Gbx Smp,22, °C
ENG109097,Stator_frequency,0.0, Hz
ENG99035,Voltage terminal 30,13.043, V
Elapsed Time: 00:10
Andy
Sector 7G
HC424490
52 - Door Elect, Pass. maps
;SW:5Q0-959-592-E   HW:5Q0-959-592-B ---  Door Elect, Pass.
;Component:TSG BFS       020 0041, Coding:005D17205E00048000000003
;EV_DCUPasseSideEWMAXKLO,006003,EV_DCUPasseSideEWMAXCONT.rod
;Friday,08,December,2017,16:15:57:29905
;VCID: 42C7C943D5FB003A90B-8016
IDE00001-Production mode,00000000 00000000 00000000  ,3
IDE02332-Deactivate production mode,00000000 00000000 00000000  ,3
Elapsed Time: 00:12
;Friday,08,December,2017,16:15:14:29905
IDE00310,Outside air temperature,5.0, °C
IDE01766-MAS02248,Distance impulses-Signal state,OK,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,13.1, V
IDE04216-MAS01458,Mirror heater-Operating condition,not_active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not activated,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,60, %
IDE04539-MAS02229,Mirror memory-Y coordinate,51, %
IDE04539-MAS02476,Mirror memory-install,installed,
IDE04540,Mirror adjustment (X/Y-direction),Position center,
IDE04580,Dimming of inside door handle lighting,92, %
IDE04581,Dimming for interior ambient lighting,255, %
IDE04586,Mirror fold-in activation,not active,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,15, %
IDE05727-IDE04213,Front passenger side door status-Central locking button,not activated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.0, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,0, %
IDE06872,Front passenger power window button,not activated,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,33.0, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.5, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.5, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.5, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.5, %
IDE07110-MAS01632,Recognition of motor variant for window regul.-Status,not recognized,
IDE07110-MAS04606,Recognition of motor variant for window regul.-Parameter set,15,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,4, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07543,Vehicle speed,0.0, km/h
IDE09335,Mirror fold-in: current consumption,0.0, A
MAS00464-MAS00106,Standard - ambient data 1-Year,2017,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,4,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,1248, km
MAS06010,Ambient light,255, %
Elapsed Time: 00:42
Andy
Sector 7G
HC424490
5F - Information Electr. maps
;SW:8V1-035-880-B   HW:8V1-035-880 ---  Information Electr.
;Component:MU-P-LNS-US   054 1110, Coding:017393020000000011220002041A00102F0029E5017001047E
;EV_MUHig6C3Gen2HBAS,001115,EV_MUHig6C3Gen2HBAS_AU37.rod
;Friday,08,December,2017,16:16:57:29905
;VCID: 3935AEAFB82D43E2C11-806C
IDE00346-Summertime-automatic,automatic ,1
IDE00759-Base volume of speech output,50 %,1
IDE00768-Country identification: country of sale,US ,2
IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1
IDE00845-Wheel circ.,0 mm,2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,No ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,Yes ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit,No ,3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,No ,3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
IDE02121-CD eject button,Enabled ,1
IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic ,49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,28 ,49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,85 ,49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,85 ,49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,85 ,49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,85 ,49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,85 ,49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,85 ,49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,85 ,49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,16 ,49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,16 ,49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,28 ,49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,85 ,49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,85 ,49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,85 ,49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,85 ,49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,85 ,49
IDE02502-Confirmation of installation change,57 3B ,2
IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,On ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,On ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,On ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,On ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present ,30
IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,On ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,On ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,Deactivated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_NAR ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,On ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE03580-Country code for mobile network,0 ,2
IDE03902-Automatic ring break diagnostic,No automatic start ,1
IDE04292-Roadside assistance mode,Corresponding setting in MMI ,1
IDE04294-Number attempted dialing attempts for roadside assistance,3 ,1
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,1 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,1 ,2
IDE04521-Sporadic ring break detection,Visual ,1
IDE04522-Awakening ability on optical databus,OFF ,1
IDE04549-Telephone data services,On ,1
IDE05111-Fee-based traffic information (TMC),65533 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE07399-ENG142045-Engine type-Engine_type_adaption_1,Value_from_BAP_protocol ,1
IDE07399-ENG142046-Engine type-Engine_type_adaption_2,Value_from_BAP_protocol ,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0 ,16
IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0 ,16
IDE10082-MAS09813-Telephone functions configuration-Entering Access Point Name,On ,1
IDE10082-MAS09814-Telephone functions configuration-Call Center Function,On ,1
IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi,Available ,1
IDE10082-MAS13847-Telephone functions configuration-Call center function on MIB: roadside assistance call,On ,1
IDE10082-MAS13848-Telephone functions configuration-Call center function on MIB: POI call,On ,1
IDE10082-MAS16726-Telephone functions configuration-Call center function on MIB: POI call regions,OFF ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,17 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128 ,40
IDE10668-Internal SIM card: use,Always ,1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,20 dBµV,3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,50 dB,3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,0.1 s,3
IDE11105-Brand-specific display of connect application,de.audi.mmiconnect ,19
IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength,4294967295 ,330
IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle,65535 ,330
IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle,65535 ,330
IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos,32767 ,330
IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle,65535 ,330
IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos,32767 ,330
IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos,32767 ,330
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,blocked ,21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,blocked ,21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,21
IDE11503-Satellite radio tuner: pre-activated subscription,05 ,1
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,Comfort data bus ,192
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,Comfort data bus ,192
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
IDE11638-Bluetooth Audio Codec,FF ,1
IDE12266-Follow on time for telephone,activated ,1
IDE12353-Configuration of traffic light online functions,On ,1
IDE12434-ENG152495-Vehicle menu operation: second generation: extension-menu_connection_manager,not activated ,60
IDE12434-ENG152499-Vehicle menu operation: second generation: extension-menu_connection_manager_after_disclaimer,not activated ,60
IDE12434-ENG152496-Vehicle menu operation: second generation: extension-menu_connection_manager_clamp_15_off,not activated ,60
IDE12434-ENG152497-Vehicle menu operation: second generation: extension-menu_connection_manager_over_threshold_high,not activated ,60
IDE12434-ENG152498-Vehicle menu operation: second generation: extension-menu_connection_manager_standstill,not activated ,60
IDE12434-ENG152548-Vehicle menu operation: second generation: extension-menu_daf_profile,not activated ,60
IDE12434-ENG152549-Vehicle menu operation: second generation: extension-menu_daf_profile_after_disclaimer,not activated ,60
IDE12434-ENG152550-Vehicle menu operation: second generation: extension-menu_daf_profile_clamp_15_off,not activated ,60
IDE12434-ENG152551-Vehicle menu operation: second generation: extension-menu_daf_profile_over_threshold_high,not activated ,60
IDE12434-ENG152552-Vehicle menu operation: second generation: extension-menu_daf_profile_stillstand,not activated ,60
IDE12434-ENG185793-Vehicle menu operation: second generation: extension-menu_engine_functions,not activated ,60
IDE12434-ENG185794-Vehicle menu operation: second generation: extension-menu_engine_functions_after_disclaimer,not activated ,60
IDE12434-ENG185795-Vehicle menu operation: second generation: extension-menu_engine_functions_clamp_15_off,not activated ,60
IDE12434-ENG185796-Vehicle menu operation: second generation: extension-menu_engine_functions_over_threshold_high,not activated ,60
IDE12434-ENG185797-Vehicle menu operation: second generation: extension-menu_engine_functions_stillstand,not activated ,60
IDE12434-ENG152515-Vehicle menu operation: second generation: extension-menu_fas_profile,not activated ,60
IDE12434-ENG152519-Vehicle menu operation: second generation: extension-menu_fas_profile_after_disclaimer,not activated ,60
IDE12434-ENG152516-Vehicle menu operation: second generation: extension-menu_fas_profile_clamp_15_off,not activated ,60
IDE12434-ENG152517-Vehicle menu operation: second generation: extension-menu_fas_profile_over_threshold_high,not activated ,60
IDE12434-ENG152518-Vehicle menu operation: second generation: extension-menu_fas_profile_standstill,not activated ,60
IDE12434-ENG185798-Vehicle menu operation: second generation: extension-menu_fod,not activated ,60
IDE12434-ENG185799-Vehicle menu operation: second generation: extension-menu_fod_after_disclaimer,not activated ,60
IDE12434-ENG185800-Vehicle menu operation: second generation: extension-menu_fod_clamp_15_off,not activated ,60
IDE12434-ENG185801-Vehicle menu operation: second generation: extension-menu_fod_over_threshold_high,not activated ,60
IDE12434-ENG185802-Vehicle menu operation: second generation: extension-menu_fod_stillstand,not activated ,60
IDE12434-ENG184478-Vehicle menu operation: second generation: extension-menu_mascot,not activated ,60
IDE12434-ENG184479-Vehicle menu operation: second generation: extension-menu_mascot_after_disclaimer,not activated ,60
IDE12434-ENG184480-Vehicle menu operation: second generation: extension-menu_mascot_clamp_15_off,not activated ,60
IDE12434-ENG184481-Vehicle menu operation: second generation: extension-menu_mascot_over_threshold_high,not activated ,60
IDE12434-ENG184482-Vehicle menu operation: second generation: extension-menu_mascot_stillstand,not activated ,60
IDE12434-ENG152562-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile,not activated ,60
IDE12434-ENG152563-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_after_disclaimer,not activated ,60
IDE12434-ENG152564-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_clamp_15_off,not activated ,60
IDE12434-ENG152565-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_over_threshold_high,not activated ,60
IDE12434-ENG152566-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_stillstand,not activated ,60
IDE12434-ENG152505-Vehicle menu operation: second generation: extension-menu_statistic,not activated ,60
IDE12434-ENG152509-Vehicle menu operation: second generation: extension-menu_statistic_after_disclaimer,not activated ,60
IDE12434-ENG152506-Vehicle menu operation: second generation: extension-menu_statistic_clamp_15_off,not activated ,60
IDE12434-ENG152507-Vehicle menu operation: second generation: extension-menu_statistic_over_threshold_high,not activated ,60
IDE12434-ENG152508-Vehicle menu operation: second generation: extension-menu_statistic_standstill,not activated ,60
IDE12434-ENG152510-Vehicle menu operation: second generation: extension-menu_sunroof,not activated ,60
IDE12434-ENG152514-Vehicle menu operation: second generation: extension-menu_sunroof_after_disclaimer,not activated ,60
IDE12434-ENG152511-Vehicle menu operation: second generation: extension-menu_sunroof_clamp_15_off,not activated ,60
IDE12434-ENG152512-Vehicle menu operation: second generation: extension-menu_sunroof_over_threshold_high,not activated ,60
IDE12434-ENG152513-Vehicle menu operation: second generation: extension-menu_sunroof_standstill,not activated ,60
IDE12434-ENG185803-Vehicle menu operation: second generation: extension-menu_vas,not activated ,60
IDE12434-ENG185804-Vehicle menu operation: second generation: extension-menu_vas_after_disclaimer,not activated ,60
IDE12434-ENG185805-Vehicle menu operation: second generation: extension-menu_vas_clamp_15_off,not activated ,60
IDE12434-ENG185806-Vehicle menu operation: second generation: extension-menu_vas_over_threshold_high,not activated ,60
IDE12434-ENG185807-Vehicle menu operation: second generation: extension-menu_vas_stillstand,not activated ,60
IDE12434-ENG152500-Vehicle menu operation: second generation: extension-menu_wireless_charging,not activated ,60
IDE12434-ENG152504-Vehicle menu operation: second generation: extension-menu_wireless_charging_after_disclaimer,not activated ,60
IDE12434-ENG152501-Vehicle menu operation: second generation: extension-menu_wireless_charging_clamp_15_off,not activated ,60
IDE12434-ENG152502-Vehicle menu operation: second generation: extension-menu_wireless_charging_over_threshold_high,not activated ,60
IDE12434-ENG152503-Vehicle menu operation: second generation: extension-menu_wireless_charging_standstill,not activated ,60
MAS00951-Bluetooth,On ,1
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
MAS03690-Telephone,Data & language service active ,1
MAS03782-WLAN,On ,1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,On ,12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,150.00 ms,12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,On ,12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,150.00 ms,12
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,activated ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,activated ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Terminal 15 ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Terminal 15 ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15 ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Terminal 15 ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Terminal 15 ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Databus Infotainment ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15 ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Terminal 15 ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Terminal 15 ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Terminal 15 ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15 ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Terminal 15 ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15 ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Terminal 15 ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15 ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15 ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15 ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Terminal 15 ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Terminal 15 ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Terminal 15 ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On ,10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,RLE ,10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1 ,10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,LVDS_map_FPK ,10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,0 ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,On ,10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1 ,10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,LVDS_map_FPK ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,On ,10
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,4 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,11 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,30 %,12
ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,10 %,1
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 00:44
;SW:8V1-035-880-B   HW:8V1-035-880 ---  Information Electr.
;Component:MU-P-LNS-US   054 1110, Coding:017393020000000011220002041A00102F0029E5017001047E
;EV_MUHig6C3Gen2HBAS,001115,EV_MUHig6C3Gen2HBAS_AU37.rod
;Friday,08,December,2017,16:16:15:29905
;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
;VCID: 3935AEAFB82D43E2C11-806C
Group,Description,Actual
IDE00019,Voltage terminal 30,13.4, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,66, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,5, °C
IDE00655-MAS02238,Temperature of processor circuit board-Current,43, °C
IDE00668-MAS03231,Microphone current consumption-Microphone 1,5.60, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,0, counts
IDE00916-IDE02127,Speaker status-Left front speaker,Measured value not available,
IDE00916-IDE02128,Speaker status-Right front speaker,Measured value not available,
IDE00916-IDE02129,Speaker status-Left rear speaker,Measured value not available,
IDE00916-IDE02130,Speaker status-Right rear speaker,Measured value not available,
IDE00916-MAS01198,Speaker status-Center speaker,Measured value not available,
IDE00916-MAS01201,Speaker status-Subwoofer speaker,Measured value not available,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,On,
IDE01442-MAS06123,Pressing a button-Eject button,not activated,
IDE01712-MAS01779,GPS Position-Length,75 18'17.4"W,
IDE01712-MAS01780,GPS Position-Width,40 13'26.3"N,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,12,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,10,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,63, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,35, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,48, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,41, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,Electrical OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,255, mA
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,Not available,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,not installed,
IDE01992-ENG20557,Installation list: current installations-ECU present Bit 0 Main_Unit,installed,
IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,not installed,
IDE01992-ENG20556,Installation list: current installations-ECU present Bit 1 reserved,not installed,
IDE01992-ENG20933,Installation list: current installations-ECU present Bit 10 SmartControlCarrier2,not installed,
IDE01992-ENG20932,Installation list: current installations-ECU present Bit 11 WirelessCharger1,not installed,
IDE01992-ENG20931,Installation list: current installations-ECU present Bit 12 WirelessCharger2,not installed,
IDE01992-ENG20930,Installation list: current installations-ECU present Bit 13 Multimedia Operating Unit,not installed,
IDE01992-ENG20929,Installation list: current installations-ECU present Bit 14 Head-up Display,not installed,
IDE01992-ENG20950,Installation list: current installations-ECU present Bit 15,not installed,
IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,not installed,
IDE01992-ENG20555,Installation list: current installations-ECU present Bit 2 Sound_System,installed,
IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,not installed,
IDE01992-ENG20554,Installation list: current installations-ECU present Bit 3 TV_Tuner,not installed,
IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,not installed,
IDE01992-ENG20553,Installation list: current installations-ECU present Bit 4 DVD_Changer,not installed,
IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,not installed,
IDE01992-ENG20552,Installation list: current installations-ECU present Bit 5 RearSeatEntertainment,not installed,
IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,not installed,
IDE01992-ENG20919,Installation list: current installations-ECU present Bit 6 MOST Kombi-Display,installed,
IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,not installed,
IDE01992-ENG20918,Installation list: current installations-ECU present Bit 7 SmartDisplayCarrier1,not installed,
IDE01992-ENG20935,Installation list: current installations-ECU present Bit 8 SmartDisplayCarrier2,not installed,
IDE01992-ENG20934,Installation list: current installations-ECU present Bit 9 SmartControlCarrier1,not installed,
IDE01995-ENG16990,Control module protocol information-Ethernet,No,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,255, mA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,48.4, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,31,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,32,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,25,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,10,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,48, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,48, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,46, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,44, dBµV
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG20563,Status of event memory-ECU Dtc Bit 0 Main_Unit,OK,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG20562,Status of event memory-ECU Dtc Bit 1 reserved,OK,
IDE02384-ENG20924,Status of event memory-ECU Dtc Bit 10 SmartControlCarrier2,OK,
IDE02384-ENG20923,Status of event memory-ECU Dtc Bit 11 WirelessCharger1,OK,
IDE02384-ENG20922,Status of event memory-ECU Dtc Bit 12 WirelessCharger2,OK,
IDE02384-ENG20921,Status of event memory-ECU Dtc Bit 13 Multimedia Operating Unit,OK,
IDE02384-ENG20920,Status of event memory-ECU Dtc Bit 14 Head-up Display,OK,
IDE02384-ENG20949,Status of event memory-ECU Dtc Bit 15,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG20561,Status of event memory-ECU Dtc Bit 2 Sound_System,OK,
IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG20560,Status of event memory-ECU Dtc Bit 3 TV_Tuner,OK,
IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG20559,Status of event memory-ECU Dtc Bit 4 DVD_Changer,OK,
IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG20558,Status of event memory-ECU Dtc Bit 5 Rear_Seat_Entertainment,OK,
IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG20945,Status of event memory-ECU Dtc Bit 6 MOST Kombi-Display,OK,
IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
IDE02384-ENG20944,Status of event memory-ECU Dtc Bit 7 SmartDisplayCarrier1,OK,
IDE02384-ENG20926,Status of event memory-ECU Dtc Bit 8 SmartDisplayCarrier2,OK,
IDE02384-ENG20925,Status of event memory-ECU Dtc Bit 9 SmartControlCarrier1,OK,
IDE02452-IDE02451,Satellite radio tuner status-Satellite radio antenna status,Electrical OK,
IDE02452-IDE02453,Satellite radio tuner status-Channel selection for satellite radio,1,
IDE02452-MAS01765,Satellite radio tuner status-Audio Signal,Available,
IDE02452-MAS01808,Satellite radio tuner status-Antenna current,139, mA
IDE02452-MAS02573,Satellite radio tuner status-Reception quality,optimum_signal,
IDE02452-MAS13343,Satellite radio tuner status-Satellite radio tuner: pre-activation status,05,
IDE02452-MAS13344,Satellite radio tuner status-Satellite radio tuner: pre-activation value,05,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE02766,Malfunction status,FF FB,
IDE03150-ENG16256,Readiness for bus sleep mode-Sleep Bit 0,Sleep mode,
IDE03150-ENG20569,Readiness for bus sleep mode-Sleep Bit 0 Main_Unit,End busstat,
IDE03150-ENG45492,Readiness for bus sleep mode-Sleep Bit 1,Sleep mode,
IDE03150-ENG20568,Readiness for bus sleep mode-Sleep Bit 1 reserved,Sleep mode,
IDE03150-ENG20941,Readiness for bus sleep mode-Sleep Bit 10 SmartControlCarrier2,Sleep mode,
IDE03150-ENG20940,Readiness for bus sleep mode-Sleep Bit 11 WirelessCharger1,Sleep mode,
IDE03150-ENG20939,Readiness for bus sleep mode-Sleep Bit 12 WirelessCharger2,Sleep mode,
IDE03150-ENG20938,Readiness for bus sleep mode-Sleep Bit 13 Bedienteil vorne,Sleep mode,
IDE03150-ENG20937,Readiness for bus sleep mode-Sleep Bit 14 Head-up Display,Sleep mode,
IDE03150-ENG20936,Readiness for bus sleep mode-Sleep Bit 15,Sleep mode,
IDE03150-ENG45491,Readiness for bus sleep mode-Sleep Bit 2,Sleep mode,
IDE03150-ENG20567,Readiness for bus sleep mode-Sleep Bit 2 Sound_System,End busstat,
IDE03150-ENG45490,Readiness for bus sleep mode-Sleep Bit 3,Sleep mode,
IDE03150-ENG20566,Readiness for bus sleep mode-Sleep Bit 3 TV_Tuner,Sleep mode,
IDE03150-ENG45489,Readiness for bus sleep mode-Sleep Bit 4,Sleep mode,
IDE03150-ENG20565,Readiness for bus sleep mode-Sleep Bit 4 DVD_Changer,Sleep mode,
IDE03150-ENG45488,Readiness for bus sleep mode-Sleep Bit 5,Sleep mode,
IDE03150-ENG20564,Readiness for bus sleep mode-Sleep Bit 5 RearSeatEntertainment,Sleep mode,
IDE03150-ENG21675,Readiness for bus sleep mode-Sleep Bit 6,Sleep mode,
IDE03150-ENG20928,Readiness for bus sleep mode-Sleep Bit 6 MOST Kombi-Display,End busstat,
IDE03150-ENG16255,Readiness for bus sleep mode-Sleep Bit 7,Sleep mode,
IDE03150-ENG20927,Readiness for bus sleep mode-Sleep Bit 7 SmartDisplayCarrier1,Sleep mode,
IDE03150-ENG20943,Readiness for bus sleep mode-Sleep Bit 8 SmartDisplayCarrier2,Sleep mode,
IDE03150-ENG20942,Readiness for bus sleep mode-Sleep Bit 9 SmartControlCarrier1,Sleep mode,
IDE03477-MAS00106,GPS time-Year,2017,
IDE03477-MAS00107,GPS time-Month,12,
IDE03477-MAS00108,GPS time-Day,8,
IDE03477-MAS00109,GPS time-Hours,21,
IDE03477-MAS00110,GPS time-Minutes,16,
IDE03477-MAS00111,GPS time-Seconds,25,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,16776960,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,5F,
IDE03880-MAS03425,MOST address-Physical address,04 00,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,15, min
IDE04317-MAS00108,Total system run time-Day,0, d
IDE04317-MAS00109,Total system run time-Hours,8, H
IDE04317-MAS00110,Total system run time-Minutes,40, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 06 09 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04334-MAS02643,Public key for SWaP function-Key,9A 49 9B 04 8B AE BF AC 83 3F DE 81 BA 80 30 93 05 B6 6F ED 54 59 C3 8F 60 F6 10 A9 AA 5A 19 10 05 17 05 8F EA 49 D3 75 E3 F9 E1 54 4E 17 EE C9 C3 C1 DD 7D 30 16 DE B1 55 45 FD 9E 18 00 51 22 D6 A1 33 10 95 C0 DD CF 43 A1 C2 FE C0 BC AA 1C FE 48 49 25 89 9E DD 71 B0 D4 08 CF 16 BF 10 E2 E1 BC 70 A3 52 F2 E6 54 0B 60 05 5A A7 52 EC 4A 83 65 F7 68 19 66 F4 D5 46 C7 38 B1 6B 5A 1F 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-ENG20542,Bus identification-Bus Identifier,Busmaster,
IDE04484,Regional codes,01 00 FF FE FF,
IDE04484,Regional codes,Not available,
IDE04484-MAS01632,Regional codes-Status,not active,
IDE04484-MAS03230,Regional codes-Optical drive,0,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Connection for external audio sources 2 (AUX-IN),
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04542-MAS03621,Status of active media source at output 2-Video codec,--------------------,
IDE04542-MAS03622,Status of active media source at output 2-Horizontal video resolution,65535,
IDE04542-MAS03623,Status of active media source at output 2-Vertical video resolution,65535,
IDE04542-MAS03778,Status of active media source at output 2-Active media source,Not available,
IDE04542-MAS03783,Status of active media source at output 2-Video Bitrate,65535, kbps
IDE04542-MAS03784,Status of active media source at output 2-Audio Bitrate,Not available,
IDE04542-MAS03785,Status of active media source at output 2-Digital rights management (DRM),Not available,
IDE04542-MAS03786,Status of active media source at output 2-Audio Codec,--------------------,
IDE04542-MAS03787,Status of active media source at output 2-Image format,--------------------,
IDE04542-MAS03788,Status of active media source at output 2-Horizontal image resolution,65535,
IDE04542-MAS03789,Status of active media source at output 2-Vertical image resolution,65535,
IDE04542-MAS03793,Status of active media source at output 2-Color depth,65535, bit
IDE04543-MAS00866,Authorization level for protection of minors-system origin,0,
IDE04543-MAS03778,Authorization level for protection of minors-Active media source,255,
IDE04544,Media type in optical drive,Not available,
IDE04545-IDE01588,Vehicle state-Driving direction,Measured value not available,
IDE04545-IDE01714,Vehicle state-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle state-Distance impulses,0,
IDE04545-IDE03684,Vehicle state-Vehicle stopped,Yes,
IDE04546-IDE00301,Navigation calibration-Distance,0.000, mm
IDE04546-MAS03647,Navigation calibration-Calibration condition,complete,
IDE04547,Traffic information,OFF,
IDE04605-MAS01779,Navigation: Corrected position-Length,075°18'18,9"W ,
IDE04605-MAS01780,Navigation: Corrected position-Width,040°13'26,6"N ,
IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,0.4, °/s
IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,20.08, m/s²
IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,20.08, m/s²
IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,20.08, m/s²
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04649-MAS01968,Activation for housing fan-Fan,OFF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,Mute,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04750-MAS03876,SIM cards-active SIM card,internal SIM-card,
IDE04750-MAS03877,SIM cards-SIM ID,890117022720704,
IDE04750-MAS03878,SIM cards-SIM IMSI,310170207041466,
IDE04750-MAS13882,SIM cards-SIM card in main unit: status,Not available,
IDE04750-MAS13883,SIM cards-SIM card in handset1 for telephone: status,Not available,
IDE04750-MAS13884,SIM cards-SIM card in handset 2 for telephone: status,Not available,
IDE04750-MAS13885,SIM cards-SIM card in mobile telephone: status,Not available,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth device address,2C DC AD 03 81 CD,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05277-MAS04210,Available changes in regional codes-Available changes DVD,4,
IDE05277-MAS04211,Available changes in regional codes-Available changes Blue-Ray,4,
IDE05277-MAS04285,Available changes in regional codes-Regional codes DVD,1,
IDE05277-MAS04286,Available changes in regional codes-Regional codes Blue-Ray,1,
IDE05430,Telephone serial number,354128064153282,
IDE05432-IDE07365,Mechanics of display unit 1 for multimedia system-Limit switch for display open,operated,
IDE05432-IDE07366,Mechanics of display unit 1 for multimedia system-Limit switch for display close,not activated,
IDE05432-MAS01458,Mechanics of display unit 1 for multimedia system-Operating condition,Open,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2127,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,15,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,0,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,31,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,63,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,63,
IDE05596-MAS00106,Last time GPS position outside map-Year,2127,
IDE05596-MAS00107,Last time GPS position outside map-Month,15,
IDE05596-MAS00108,Last time GPS position outside map-Day,0,
IDE05596-MAS00109,Last time GPS position outside map-Hours,31,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,63,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,63,
IDE05597-IDE03615,Bluetooth: Paired device 1-Version,3æ}ÒAndys6Splus"Apple Inc."	iPhone8,2Version 11.2 (Build ÿÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,40 33 1A E6 7D D2,
IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,3æ}ÒAndys6Splus"Apple Inc."	iPhone8,2Version 11.2 (Build ÿÿÿ
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),40 33,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),40 33,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,3æ}ÒAndys6Splus"Apple Inc."	iPhone8,2Version 11.2 (Build ÿÿÿ
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,Andys6Splus
"Apple Inc."
iPhone8,2
Version 11.2 (Build
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,40 33,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,40 33,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,40 33,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,40 33,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,40 33,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,40 33,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,40 33,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,40 33,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,40 33,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,40 33,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,40 33,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,40 33,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,40 33,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,40 33,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,40 33,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,40 33,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,40 33,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,00 00 00 00 00 00,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,--
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),00 00,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),00 00,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,--
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,--
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,00 00,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,00 00,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,00 00,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,00 00,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,00 00,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,00 00,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,00 00,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,00 00,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,00 00,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,00 00,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,00 00,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,00 00,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,00 00,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,00 00,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,00 00,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,00 00,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,00 00,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,--
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,00 00 00 00 00 00,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,--
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,65280,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,65280,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,65280,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,65280,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,65280,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05704-MAS02646,Digital Transmission Content Protection (DTCP) key-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,0,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,0,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,37.53, %
IDE05814,Individualization characteristic,C1 1E D5 D5 38,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06516-MAS01424,Temperature: optical drive-max.value,44, °C
IDE06516-MAS01425,Temperature: optical drive-min.value,0, °C
IDE06516-MAS02238,Temperature: optical drive-Current,31, °C
IDE06517-MAS01424,Temperature: audio amplifier-max.value,70, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,4, °C
IDE06517-MAS02238,Temperature: audio amplifier-Current,27, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,60, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-1, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Current,37, °C
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,60, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,13, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Current,47, °C
IDE06522-MAS01424,Temperature of phone unit-max.value,43, °C
IDE06522-MAS01425,Temperature of phone unit-min.value,5, °C
IDE06522-MAS02238,Temperature of phone unit-Current,32, °C
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07364,GPS receiver status,GPS data available,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE08530-MAS00106,Connection status online basic services-Year,2017.0, yr
IDE08530-MAS00107,Connection status online basic services-Month,12, mon
IDE08530-MAS00108,Connection status online basic services-Day,8, d
IDE08530-MAS00109,Connection status online basic services-Hours,21, H
IDE08530-MAS00110,Connection status online basic services-Minutes,14, min
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,40,
IDE08530-ENG20907,Connection status online basic services-Server_HTTP_Status_Code_Textual,Backend request running,
IDE08531-MAS00106,Connection status online license services-Year,2017.0, yr
IDE08531-MAS00107,Connection status online license services-Month,12, mon
IDE08531-MAS00108,Connection status online license services-Day,8, d
IDE08531-MAS00109,Connection status online license services-Hours,21, H
IDE08531-MAS00110,Connection status online license services-Minutes,1, min
IDE08531-MAS07132,Connection status online license services-Code status,8200,
IDE08531-MAS07134,Connection status online license services-ID services,86,
IDE08531-MAS07135,Connection status online license services-Activation status,Not available,
IDE08531-MAS07136,Connection status online license services-Exp. year,0, yr
IDE08531-MAS07137,Connection status online license services-Exp. month,0, mon
IDE08531-MAS07138,Connection status online license services-Exp. day,0, d
IDE08531-ENG20907,Connection status online license services-Server_HTTP_Status_Code_Textual,not defined,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,Electrical OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,255, mA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,48.4, %
IDE10200-MAS01482,Identification of volume control-Hardwareversion,---,
IDE10200-MAS01483,Identification of volume control-Softwareversion,----,
IDE10200-MAS09952,Identification of volume control-Part Number,-----------,
IDE10201-MAS01482,Identification of control unit for driving and comfort funct.-Hardwareversion,---,
IDE10201-MAS01483,Identification of control unit for driving and comfort funct.-Softwareversion,----,
IDE10201-MAS09952,Identification of control unit for driving and comfort funct.-Part Number,-----------,
IDE10412,Media status in optical drive,Empty,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10600-MAS01159,Status of the navigation database-Version number,00 1A,
IDE10600-MAS01632,Status of the navigation database-Status,valid,
IDE10600-MAS10892,Status of the navigation database-Country Code,00 01,
IDE10600-MAS10893,Status of the navigation database-Region Code,F0,
IDE10669-MAS11003,Internal SIM card: identification-ICCID,89011702272070414666,
IDE10669-MAS11004,Internal SIM card: identification-UICCID,74000022754042121109178F4A30C8--,
IDE10843-MAS01482,Function module: identification-Hardwareversion,10,
IDE10843-MAS04326,Function module: identification-Device name,AMP16cAPN                        ,
IDE10843-MAS11354,Function module: identification-Bootloader version,440,
IDE10843-MAS11355,Function module: identification-Application version,440,
IDE10843-MAS11356,Function module: identification-Module Name,AMP16cAPPL                       ,
IDE10857-MAS02476,Touchless loading of mobile phone: status-install,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-charge,No,
IDE10926-MAS00318,Function module: status-activated,Yes,
IDE10926-MAS00791,Function module: status-installed,Yes,
IDE10926-MAS11356,Function module: status-Module Name,Navigation,
IDE10926-MAS11749,Function module: status-Function and diagnosis readiness,Yes,
IDE11034-MAS01482,Satellite radio: module information-Hardwareversion,x01-00-01,
IDE11034-MAS11961,Satellite radio: module information-Serial number,48ZYHA4M,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 0D 00 34 38 5A 59 48 41 34 4D 00 02 98 05 8A 38 64 68 F5 31 71 89 CD BF 18 05 F7 F8 4B 3B 70 FD 99 3A BE 39 03 41 00 66 03 41 00 07 00 66 00 07,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,x0b-24-00,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,x01-22-13,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,x03-04-02,
IDE11034-MAS11966,Satellite radio: module information-Database Version,C0a00-F0400,
IDE11504-ENG127677,Satellite radio tuner: pre-activated subscription-SDARS_preactivation_coding status,Yes,
IDE13417-MAS02646,Key (DTCP): MMX-Key type,none,
IDE13516-MAS01159,Device certificate (DTCP): MMX-Version number,0,
IDE13516-MAS01779,Device certificate (DTCP): MMX-Length,0,
IDE13516-MAS06742,Device certificate (DTCP): MMX-Certificate type,0,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,8,
MAS00464-MAS00109,Standard - ambient data 1-Hours,1,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,50,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,78, km
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia display unit 1-System status,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,6, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,4, min
MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,13.3, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,61, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,22, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,15, %
MAS00837-MAS01632,Telephone Transceiver-Status,Not blocked,
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,1,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,93.3, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,35, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,40, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,2,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,0,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,1,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,19, dBµV
MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
MAS01991-IDE01001,Card reader-Application,--,
MAS01991-MAS01632,Card reader-Status,not connected,
MAS01991-MAS03159,Card reader-Manufacturer,FF,
MAS01991-MAS03375,Card reader-Major version,15,
MAS01991-MAS03376,Card reader-Minor version,15,
MAS01991-MAS03959,Card reader-Write-protection,Not available,
MAS01991-MAS04388,Card reader-Card type,-----,
MAS01991-MAS13476,Card reader-Manufacturing date: month,15, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
MAS03121,Ring break diagnostic line status,Supply voltage,
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, mon
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS03782-ENG117422,WLAN-IP_Address,010.173.189.001                        ,
MAS03782-ENG117423,WLAN-IP_Subnetmask,255.255.255.000                        ,
MAS03782-ENG117421,WLAN-MAC_Address,2C DC AD 03 81 CD,
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,0,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,SDAP,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,10,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,10,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,4, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,17, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,12, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,8, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,14, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,46, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,17, s
ENG127486-ENG117422,mac_adress_wlan_tethering-IP_Address,---------------------------------------,
ENG127486-ENG117423,mac_adress_wlan_tethering-IP_Subnetmask,---------------------------------------,
ENG127486-ENG117421,mac_adress_wlan_tethering-MAC_Address,2C DC AD 03 81 CC,
ENG129160,MMX mNAND Flash Version,Product = mmx2
Branch = rel/CLU8
Up to CL = 10604585
FirstTierSupplier = HARMAN
Project = project_mmx2_audi_nar_g21.cfg
OEM = AU
Region = NAR
Variant = G21
Media-Stack = EVO
Framework = 5.49.12.SR3 MIB2MAIN I199 CI68
JavaVM = j9_1.16+ObjectSwapper_1.02+XIPLoader_1.10+MCFObjectReader_1.01C+JavaCrypto_1.05+Socks5Support_1.00
DS$OptionDrawerVersion = 8.50
devp-iso-mmx-mib2 = 2014/08/15_05-51-30_UTC
putl = 1.0.0
uaputl = 2016/08/03-11:44:10-EDT
BlueSDK = 4.3.1 + A,
ENG129161,MMX NOR Flash Version,Product = mmx2
Branch = rel/CLU8
Up to CL = 10604585
OEM = AU
Region = NAR
Variant = G21
Media-Stack = EVO
DS"OptionDrawerVersion = 8.50
putl = 1.0.0
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,304, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG122217-ENG122284,SDARS_service-audio_service,subscribed,
ENG122217-ENG122285,SDARS_service-traffic_service,not_subscribed,
ENG122217-ENG122286,SDARS_service-travel_link_service,not_subscribed,
ENG122216-MAS00106,SDARS_subscription_status-Year,2000,
ENG122216-MAS00107,SDARS_subscription_status-Month,2,
ENG122216-MAS00108,SDARS_subscription_status-Day,1,
ENG122216-MAS00109,SDARS_subscription_status-Hours,4,
ENG122216-MAS00110,SDARS_subscription_status-Minutes,0,
ENG122216-MAS00111,SDARS_subscription_status-Seconds,0,
ENG122216-ENG122279,SDARS_subscription_status-SDARS_subscription,subscribed,
ENG122216-ENG125804,SDARS_subscription_status-SDARS_suspend_alert,no_alert,
ENG122216-ENG122280,SDARS_subscription_status-SDARS_suspension,not_suspended,
ENG117855-ENG117392,System_Character_Recognition-touchpanel_information,,
Elapsed Time: 00:41
Andy
Sector 7G
HC424490
6C - Back-up Cam. maps
;SW:5Q0-980-556-B   HW:5Q0-980-556-B ---  Back-up Cam.
;Component:RVC Compact   H12 0231, Coding:0273100102002001400040
;EV_CamSysRVRVCPANAMQBAB,006009,EV_CamSysRVRVCPANAMQBAB.rod
;Friday,08,December,2017,16:17:46:29905
IDE02709-Actuator: PWM signal,100 %,1
IDE03531-Wheel/tire description,1950 mm,2
MAS02209-Image contrast,50 %,1
MAS02851-Brightness,50 %,1
ENG119212-camera_off,35.00 km/h,2
ENG119211-camera_on,30.00 km/h,2
ENG119200-color,50 %,1
ENG119218-debounce_time_for_reverse_gear,0 ms,2
ENG119215-display_position,0 px,1
ENG119216-engine_restart_timer,0 ms,2
ENG119209-Frequency_Swinging_Logo,100 Hz,2
ENG119221-FSG_control_state,On ,1
ENG119220-ENG119101-grafic_element_setting-setting_1_color_value,FF FF ,128
ENG119220-ENG119099-grafic_element_setting-setting_1_HMI_mode,FF ,128
ENG119220-ENG119100-grafic_element_setting-setting_1_pallet_ID,255 ,128
ENG119220-ENG119128-grafic_element_setting-setting_10_color_value,FF FF ,128
ENG119220-ENG119126-grafic_element_setting-setting_10_HMI_mode,FF ,128
ENG119220-ENG119127-grafic_element_setting-setting_10_pallet_ID,255 ,128
ENG119220-ENG119131-grafic_element_setting-setting_11_color_value,FF FF ,128
ENG119220-ENG119129-grafic_element_setting-setting_11_HMI_mode,FF ,128
ENG119220-ENG119130-grafic_element_setting-setting_11_pallet_ID,255 ,128
ENG119220-ENG119134-grafic_element_setting-setting_12_color_value,FF FF ,128
ENG119220-ENG119132-grafic_element_setting-setting_12_HMI_mode,FF ,128
ENG119220-ENG119133-grafic_element_setting-setting_12_pallet_ID,255 ,128
ENG119220-ENG119137-grafic_element_setting-setting_13_color_value,FF FF ,128
ENG119220-ENG119135-grafic_element_setting-setting_13_HMI_mode,FF ,128
ENG119220-ENG119136-grafic_element_setting-setting_13_pallet_ID,255 ,128
ENG119220-ENG119140-grafic_element_setting-setting_14_color_value,FF FF ,128
ENG119220-ENG119138-grafic_element_setting-setting_14_HMI_mode,FF ,128
ENG119220-ENG119139-grafic_element_setting-setting_14_pallet_ID,255 ,128
ENG119220-ENG119143-grafic_element_setting-setting_15_color_value,FF FF ,128
ENG119220-ENG119141-grafic_element_setting-setting_15_HMI_mode,FF ,128
ENG119220-ENG119142-grafic_element_setting-setting_15_pallet_ID,255 ,128
ENG119220-ENG119146-grafic_element_setting-setting_16_color_value,FF FF ,128
ENG119220-ENG119144-grafic_element_setting-setting_16_HMI_mode,FF ,128
ENG119220-ENG119145-grafic_element_setting-setting_16_pallet_ID,255 ,128
ENG119220-ENG119149-grafic_element_setting-setting_17_color_value,FF FF ,128
ENG119220-ENG119147-grafic_element_setting-setting_17_HMI_mode,FF ,128
ENG119220-ENG119148-grafic_element_setting-setting_17_pallet_ID,255 ,128
ENG119220-ENG119152-grafic_element_setting-setting_18_color_value,FF FF ,128
ENG119220-ENG119150-grafic_element_setting-setting_18_HMI_mode,FF ,128
ENG119220-ENG119151-grafic_element_setting-setting_18_pallet_ID,255 ,128
ENG119220-ENG119155-grafic_element_setting-setting_19_color_value,FF FF ,128
ENG119220-ENG119153-grafic_element_setting-setting_19_HMI_mode,FF ,128
ENG119220-ENG119154-grafic_element_setting-setting_19_pallet_ID,255 ,128
ENG119220-ENG119104-grafic_element_setting-setting_2_color_value,FF FF ,128
ENG119220-ENG119102-grafic_element_setting-setting_2_HMI_mode,FF ,128
ENG119220-ENG119103-grafic_element_setting-setting_2_pallet_ID,255 ,128
ENG119220-ENG119158-grafic_element_setting-setting_20_color_value,FF FF ,128
ENG119220-ENG119156-grafic_element_setting-setting_20_HMI_mode,FF ,128
ENG119220-ENG119157-grafic_element_setting-setting_20_pallet_ID,255 ,128
ENG119220-ENG119161-grafic_element_setting-setting_21_color_value,FF FF ,128
ENG119220-ENG119159-grafic_element_setting-setting_21_HMI_mode,FF ,128
ENG119220-ENG119160-grafic_element_setting-setting_21_pallet_ID,255 ,128
ENG119220-ENG119164-grafic_element_setting-setting_22_color_value,FF FF ,128
ENG119220-ENG119162-grafic_element_setting-setting_22_HMI_mode,FF ,128
ENG119220-ENG119163-grafic_element_setting-setting_22_pallet_ID,255 ,128
ENG119220-ENG119167-grafic_element_setting-setting_23_color_value,FF FF ,128
ENG119220-ENG119165-grafic_element_setting-setting_23_HMI_mode,FF ,128
ENG119220-ENG119166-grafic_element_setting-setting_23_pallet_ID,255 ,128
ENG119220-ENG119170-grafic_element_setting-setting_24_color_value,FF FF ,128
ENG119220-ENG119168-grafic_element_setting-setting_24_HMI_mode,FF ,128
ENG119220-ENG119169-grafic_element_setting-setting_24_pallet_ID,255 ,128
ENG119220-ENG119173-grafic_element_setting-setting_25_color_value,FF FF ,128
ENG119220-ENG119171-grafic_element_setting-setting_25_HMI_mode,FF ,128
ENG119220-ENG119172-grafic_element_setting-setting_25_pallet_ID,255 ,128
ENG119220-ENG119176-grafic_element_setting-setting_26_color_value,FF FF ,128
ENG119220-ENG119174-grafic_element_setting-setting_26_HMI_mode,FF ,128
ENG119220-ENG119175-grafic_element_setting-setting_26_pallet_ID,255 ,128
ENG119220-ENG119179-grafic_element_setting-setting_27_color_value,FF FF ,128
ENG119220-ENG119177-grafic_element_setting-setting_27_HMI_mode,FF ,128
ENG119220-ENG119178-grafic_element_setting-setting_27_pallet_ID,255 ,128
ENG119220-ENG119182-grafic_element_setting-setting_28_color_value,FF FF ,128
ENG119220-ENG119180-grafic_element_setting-setting_28_HMI_mode,FF ,128
ENG119220-ENG119181-grafic_element_setting-setting_28_pallet_ID,255 ,128
ENG119220-ENG119185-grafic_element_setting-setting_29_color_value,FF FF ,128
ENG119220-ENG119183-grafic_element_setting-setting_29_HMI_mode,FF ,128
ENG119220-ENG119184-grafic_element_setting-setting_29_pallet_ID,255 ,128
ENG119220-ENG119107-grafic_element_setting-setting_3_color_value,FF FF ,128
ENG119220-ENG119105-grafic_element_setting-setting_3_HMI_mode,FF ,128
ENG119220-ENG119106-grafic_element_setting-setting_3_pallet_ID,255 ,128
ENG119220-ENG119188-grafic_element_setting-setting_30_color_value,FF FF ,128
ENG119220-ENG119186-grafic_element_setting-setting_30_HMI_mode,FF ,128
ENG119220-ENG119187-grafic_element_setting-setting_30_pallet_ID,255 ,128
ENG119220-ENG119191-grafic_element_setting-setting_31_color_value,FF FF ,128
ENG119220-ENG119189-grafic_element_setting-setting_31_HMI_mode,FF ,128
ENG119220-ENG119190-grafic_element_setting-setting_31_pallet_ID,255 ,128
ENG119220-ENG119194-grafic_element_setting-setting_32_color_value,FF FF ,128
ENG119220-ENG119192-grafic_element_setting-setting_32_HMI_mode,FF ,128
ENG119220-ENG119193-grafic_element_setting-setting_32_pallet_ID,255 ,128
ENG119220-ENG119110-grafic_element_setting-setting_4_color_value,FF FF ,128
ENG119220-ENG119108-grafic_element_setting-setting_4_HMI_mode,FF ,128
ENG119220-ENG119109-grafic_element_setting-setting_4_pallet_ID,255 ,128
ENG119220-ENG119113-grafic_element_setting-setting_5_color_value,FF FF ,128
ENG119220-ENG119111-grafic_element_setting-setting_5_HMI_mode,FF ,128
ENG119220-ENG119112-grafic_element_setting-setting_5_pallet_ID,255 ,128
ENG119220-ENG119116-grafic_element_setting-setting_6_color_value,FF FF ,128
ENG119220-ENG119114-grafic_element_setting-setting_6_HMI_mode,FF ,128
ENG119220-ENG119115-grafic_element_setting-setting_6_pallet_ID,255 ,128
ENG119220-ENG119119-grafic_element_setting-setting_7_color_value,FF FF ,128
ENG119220-ENG119117-grafic_element_setting-setting_7_HMI_mode,FF ,128
ENG119220-ENG119118-grafic_element_setting-setting_7_pallet_ID,255 ,128
ENG119220-ENG119122-grafic_element_setting-setting_8_color_value,FF FF ,128
ENG119220-ENG119120-grafic_element_setting-setting_8_HMI_mode,FF ,128
ENG119220-ENG119121-grafic_element_setting-setting_8_pallet_ID,255 ,128
ENG119220-ENG119125-grafic_element_setting-setting_9_color_value,FF FF ,128
ENG119220-ENG119123-grafic_element_setting-setting_9_HMI_mode,FF ,128
ENG119220-ENG119124-grafic_element_setting-setting_9_pallet_ID,255 ,128
ENG119201-image_delay_timer,0.0 s,1
ENG119219-Minimal_time_to_stay_in_bus_sleep_before_ECU_off,20000 ms,2
ENG119214-rv_dark_off,10.00 km/h,2
ENG119213-rv_dark_on,15.00 km/h,2
ENG119203-RV_Last_Mode,90° parking spot ,1
ENG102898-RV_Start_Mode,90° parking spot ,1
ENG119205-Time_to_open_Swinging_Logo,1000 ms,2
Elapsed Time: 00:06
;Friday,08,December,2017,16:17:43:29905
IDE00019,Voltage terminal 30,13.13, V
IDE00303-MAS00222,Status of doors/lids 1-Rear lid,closed,
IDE00303-MAS00223,Status of doors/lids 1-Hood,Measured value not available,
IDE00303-MAS01374,Status of doors/lids 1-Trailer,detected,
IDE00924-IDE08941,Steering angle-Rack position,0.000, mm
IDE00924-MAS02471,Steering angle-Sign,Positive,
IDE00924-MAS02983,Steering angle-Steering wheel angle,4.700, °
IDE00924,Steering angle,0.300, °
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,0.000, °
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE01714,Status reverse gear,not selected,
IDE03619,System status,passive,
IDE06449-MAS05746,Calibration of camera system-Rearview camera calibration status,Calibration ended,
IDE06449-MAS05748,Calibration of camera system-Rearview camera calibration progress,100, %
IDE06449-MAS05750,Calibration of camera system-Rearview camera calibration repeat attempts,0,
IDE06449-MAS05753,Calibration of camera system-Cause of rearview camera calibration error,no error,
IDE06449-MAS05803,Calibration of camera system-Rearview camera calibration resumption,No resumption,
IDE07402,External activation,Not available,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,45,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6, counts
ENG119197-ENG128717,camera_calibration_parameters-Cam0 Calibration binary threshold,00,
ENG119197-ENG119070,camera_calibration_parameters-Cam0 Calibration Result judgment,00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 20 41,
ENG119197-ENG119060,camera_calibration_parameters-Cam0 Changing default data - Ground to Camera Z,0, mm
ENG119197-ENG119061,camera_calibration_parameters-Cam0 Changing default data - Ground to wheel arch Z,0, mm
ENG119197-ENG119068,camera_calibration_parameters-Cam0 division counts horizontal,1,
ENG119197-ENG119069,camera_calibration_parameters-Cam0 division counts vertical,0,
ENG119197-ENG119062,camera_calibration_parameters-Cam0 Fixed value input - Ground to Camera Z,0, mm
ENG119197-ENG119063,camera_calibration_parameters-Cam0 Fixed value input - Ground to wheel arch Z,1143564698, mm
ENG119197-ENG119067,camera_calibration_parameters-Cam0 height of marker,0, mm
ENG119197-ENG119064,camera_calibration_parameters-Cam0 Marker size Full-size or Half-size,half size,
ENG119197-ENG119058,camera_calibration_parameters-Cam0 Transversal position front axle,1065353216, mm
ENG119197-ENG119059,camera_calibration_parameters-Cam0 Transversal position rear axle,0, mm
ENG119197-ENG119065,camera_calibration_parameters-Cam0 X direction of marker red ribbon,1166331904, mm
ENG119197-ENG119066,camera_calibration_parameters-Cam0 Y direction of marker,0, mm
ENG119196-ENG119090,camera_calibration_tolerance-RV_Calibration_Result,1043207291, px
ENG119196-ENG119084,camera_calibration_tolerance-RV_Calibration_Tolerance_alpha,3217198940, °
ENG119196-ENG119085,camera_calibration_tolerance-RV_Calibration_Tolerance_beta,3212165775, °
ENG119196-ENG119086,camera_calibration_tolerance-RV_Calibration_Tolerance_gamma,1047233823, °
ENG119196-ENG119087,camera_calibration_tolerance-RV_Calibration_Tolerance_x,0, mm
ENG119196-ENG119088,camera_calibration_tolerance-RV_Calibration_Tolerance_y,0, mm
ENG119196-ENG119089,camera_calibration_tolerance-RV_Calibration_Tolerance_z,3242563904, mm
Elapsed Time: 00:02
Andy
Sector 7G
HC424490
75- Telematics maps
;SW:5QE-035-285-A   HW:5QE-035-285-A ---  Telematics
;Component:OCULowMQBUS   009 0570, Coding:017393011082BA0100F800000000
;EV_OCULowMQB,001006,EV_OCULowMQB.rod
;Friday,08,December,2017,16:18:17:29905
;VCID: 43C9CC47CAE109329BD-8016
IDE00759-Base volume of speech output,0 dB,1
IDE00760-Microphone sensitivity,0 dB,1
IDE00761-MAS08397-After-run time-Long term energy budget,3600 mAh,14
IDE00761-MAS08398-After-run time-Short term energy budget,1000 mAh,14
IDE00761-MAS08399-After-run time-Waiting period from sleep to standby mode,0 min,14
IDE00761-MAS08400-After-run time-Waiting period from standby to stop mode,336 H,14
IDE00761-MAS08950-After-run time-Time period for cyclic stop mode in operating mode,0 min,14
IDE00761-MAS08951-After-run time-Time period for cyclic standby mode in operating mode,0 min,14
IDE00761-MAS08952-After-run time-Time period for operating mode,0 d,14
IDE00761-MAS08953-After-run time-Cyclic time after the operating mode,0 H,14
IDE00761-MAS08954-After-run time-Connection after T. 15 on,No ,14
IDE00761-MAS08955-After-run time-Time period for connection after T. 15 on,15 min,14
IDE00766-Reference channel delay,0 ms,1
IDE00769-Number 1 for Info call,8774193655 ,10
IDE00770-Number 1 for roadside assistance,8774193654 ,10
IDE02067-Antenna for telephone status,automatic ,1
IDE02330-Number 2 for Info call,8882915686 ,10
IDE02331-Number 2 for roadside assistance,8882449811 ,10
IDE02699-Number 1 for roadside assistance,8774193653 ,10
IDE02700-Number 2 for roadside assistance,8882449108 ,10
IDE03481-Emergency telephone number,112 ,3
IDE04307-MAS00688-Vehicle function list BAP-Multifunction indicator,activated ,1
IDE04307-MAS02957-Vehicle function list BAP-Time,activated ,1
IDE04307-MAS06654-Vehicle function list BAP-Charge manager,not activated ,1
IDE04478-SMS number 1 for call for help,60000004 ,8
IDE07699-Mobile network operator,aprd3.hughestelematics.com.attz ,31
IDE07899-Status of GPS antenna,external ,1
IDE09244-Fuel tank volume,70 l,1
MAS07461-Vehicle shut-down: maximum speed,5 km/h,2
MAS07464-Waiting period for activation vehicle shutdown,30 s,2
MAS07465-Safety mode for activation vehicle shutdown,activated ,1
MAS07466-Safety mode for deactivation vehicle shutdown,not activated ,1
MAS07467-Speed warning maximum speed,0 km/h,2
MAS08170-User profile name,none ,4
MAS08171-User profile password,none ,4
MAS08172-Mobile Online services: first host name,vw.us.p.tos.hughestelematics.net ,32
MAS08173-Mobile Online services: second host name,vw.us.p.tos.hughestelematics.net ,32
MAS08174-Fallback DNS Server,0.0.0.0 ,7
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,5 km,3
MAS08176-Test tel. number for roadside assistance,0 ,1
MAS08177-Acoustic warning for vehicle shut-down,activated ,1
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
MAS08983-Dimming coefficient of red function illumination,50 %,1
MAS08984-Dimming coefficient of green function illumination,50 %,1
MAS09650-Threshold for vehicle movement recognition,5 km/h,2
MAS13730-Radio mode,activated ,1
ENG123201-ENG123295-Cycle_Data_Log_Level-Automatic_Crash_Notification,ERROR ,9
ENG123201-ENG123362-Cycle_Data_Log_Level-Core_Service_Management,ERROR ,9
ENG123201-ENG123286-Cycle_Data_Log_Level-Geofencing,ERROR ,9
ENG123201-ENG123294-Cycle_Data_Log_Level-Information_Call,ERROR ,9
ENG123201-ENG123186-Cycle_Data_Log_Level-Manual_Emergency_Call,ERROR ,9
ENG123201-ENG123288-Cycle_Data_Log_Level-POI_Address_Import,ERROR ,9
ENG123201-ENG123215-Cycle_Data_Log_Level-Remote_Battery_Charging_Management,ERROR ,9
ENG123201-ENG123293-Cycle_Data_Log_Level-Remote_Departure_Time_Programming,ERROR ,9
ENG123201-ENG123287-Cycle_Data_Log_Level-Remote_Door_Unlock,ERROR ,9
ENG123201-ENG123216-Cycle_Data_Log_Level-Remote_Honking_and_Flashing,ERROR ,9
ENG123201-ENG123214-Cycle_Data_Log_Level-Remote_Pre_Trip_Climatisation,ERROR ,9
ENG123201-ENG123289-Cycle_Data_Log_Level-Remote_Speed_Alert,ERROR ,9
ENG123201-ENG123292-Cycle_Data_Log_Level-Remote_Trip_Statistics,ERROR ,9
ENG123201-ENG123290-Cycle_Data_Log_Level-Remote_Vehicle_Disabling,ERROR ,9
ENG123201-ENG123183-Cycle_Data_Log_Level-Remote_Vehicle_Status,ERROR ,9
ENG123201-ENG123291-Cycle_Data_Log_Level-Remote_Vehicle_Tracking,ERROR ,9
ENG123201-ENG123371-Cycle_Data_Log_Level-Roadside_Assistance_Dealer_Maintenance_Scheduling,ERROR ,9
ENG123201-ENG123193-Cycle_Data_Log_Level-Vehicle_Health_Report,ERROR ,9
ENG123200-Driving_Follow_Up_Time,5 min,1
ENG123199-Emergency_Call_Trigger_Condition,crash_intensity_2 ,1
ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
ENG123190-MAS01424-Geofencing_Area_Highth-max.value,4294967294 m,8
ENG123190-MAS01425-Geofencing_Area_Highth-min.value,1 m,8
ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,+2.147.483.647 ,28
ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2.147.483.648 ,28
ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,+2.147.483.647 ,28
ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2.147.483.648 ,28
ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
ENG123186-ENG123304-Manual_Emergency_Call-Radio_On_Trigger,On ,1
ENG123186-ENG123305-Manual_Emergency_Call-Vehicle_Termination,On ,1
ENG125481-Number_Of_Navigation_Destinations,20 ,1
ENG123194-ENG123349-Online_Services_Communication_Protocol-APN_Auth_Type,PAP_CHAP ,10
ENG123194-ENG123350-Online_Services_Communication_Protocol-GSM_Automatic_Operator,manual ,10
ENG123194-ENG123354-Online_Services_Communication_Protocol-Keep_Connection_Alive_If_Event_Expected_Within,10 min,10
ENG123194-ENG123356-Online_Services_Communication_Protocol-PDP_Grace_Time,120 s,10
ENG123194-ENG123351-Online_Services_Communication_Protocol-PDP_Type,IPv4 ,10
ENG123194-ENG123352-Online_Services_Communication_Protocol-TCP_Max_Receive_Window,65535 B,10
ENG123194-ENG123353-Online_Services_Communication_Protocol-TCP_Max_Transmit_Window,65535 B,10
ENG123194-ENG123355-Online_Services_Communication_Protocol-TCPMS,532 B,10
ENG123196-ENG123362-Online_Services_Data_Roaming-Core_Service_Management,activated ,3
ENG123196-ENG125484-Online_Services_Data_Roaming-Core_Service_Telephony,activated ,3
ENG123196-ENG123286-Online_Services_Data_Roaming-Geofencing,activated ,3
ENG123196-ENG125485-Online_Services_Data_Roaming-JobMechanism,activated ,3
ENG123196-ENG123288-Online_Services_Data_Roaming-POI_Address_Import,activated ,3
ENG123196-ENG123215-Online_Services_Data_Roaming-Remote_Battery_Charging_Management,activated ,3
ENG123196-ENG123293-Online_Services_Data_Roaming-Remote_Departure_Time_Programming,activated ,3
ENG123196-ENG123287-Online_Services_Data_Roaming-Remote_Door_Unlock,activated ,3
ENG123196-ENG123216-Online_Services_Data_Roaming-Remote_Honking_and_Flashing,activated ,3
ENG123196-ENG123214-Online_Services_Data_Roaming-Remote_Pre_Trip_Climatisation,activated ,3
ENG123196-ENG123289-Online_Services_Data_Roaming-Remote_Speed_Alert,activated ,3
ENG123196-ENG123292-Online_Services_Data_Roaming-Remote_Trip_Statistics,activated ,3
ENG123196-ENG123290-Online_Services_Data_Roaming-Remote_Vehicle_Disabling,activated ,3
ENG123196-ENG123183-Online_Services_Data_Roaming-Remote_Vehicle_Status,activated ,3
ENG123196-ENG123291-Online_Services_Data_Roaming-Remote_Vehicle_Tracking,activated ,3
ENG123196-ENG123363-Online_Services_Data_Roaming-Roadside_Assistance,activated ,3
ENG123196-ENG123193-Online_Services_Data_Roaming-Vehicle_Health_Report,activated ,3
ENG123195-ENG123358-Online_Services_Timeouts-HTTP_Timeout,125 s,9
ENG123195-ENG123361-Online_Services_Timeouts-Network_Timeout,120 s,9
ENG123195-ENG123360-Online_Services_Timeouts-PDP_Timeout,120 s,9
ENG123195-ENG123359-Online_Services_Timeouts-Secure_Connection_Timeout,120 s,9
ENG123195-ENG123357-Online_Services_Timeouts-Transport_Protocol_Timeout,120 s,9
ENG123197-Online_Services_Voice_Roaming,activated ,1
ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance,500 m,12
ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Driving direction,30 °,12
ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
ENG123183-ENG123302-Remote_Vehicle_Status-Remote_Vehicle_Status_Clamp_15_Off_Delay,60 s,2
ENG123183-ENG123301-Remote_Vehicle_Status-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,2
ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
ENG123184-Roof_Crash_Detection_Speed_Limit,30 km/h,1
ENG129162-Serial_Tracing, ,6
ENG123193-Vehicle_Health_Report,15000 km,1
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,10 s,6
ENG123198-ENG123368-Voice_Connection_Timeouts-Redial_ACN_MEC_If_Failed,Yes ,6
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,6 ,6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,15 s,6
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
Elapsed Time: 00:21
;Friday,08,December,2017,16:17:55:29905
;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
Group,Description,Actual
IDE00019,Voltage terminal 30,12.7, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,31, °C
IDE00608,Type of fuel,Petrol,
IDE00667,Microphone status,Not available,
IDE00668,Microphone current consumption,0.0, mA
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button,Not available,
IDE00767,No. of unscheduled ECU resets,0,
IDE01215,Terminal 58d dimmer,Measured value not available,
IDE01625,Muting of radio/radio navigation system via control wire,Measured value not available,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,W75°18'18.986",
IDE01712-MAS01780,GPS Position-Width,N40°13'26.382",
IDE01712-MAS02230,GPS Position-Height,182, m
IDE01713-MAS01632,Status GPS reception-Status,No GPS reception,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,12,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,10,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,0, mA
IDE01971,Lowest recorded control module temperature,4, °C
IDE01972,Highest recorded control module temperature,45, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,1, mA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,100.0, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,0,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,0,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,0,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,0,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02486,Data logger triggering,Measured value not available,
IDE03348-MAS01586,Speed warning-Alarm,0,
IDE03348,Speed warning,655.33, km/h
IDE03348-MAS08775,Speed warning-Calculation frequency,5, s
IDE03348-MAS08776,Speed warning-tolerance,5, m
IDE03348-MAS08777,Speed warning-Contact bounce suppression,5, s
IDE03477-MAS00106,GPS time-Year,2000,
IDE03477-MAS00107,GPS time-Month,1,
IDE03477-MAS00109,GPS time-Hours,1,
IDE03477-MAS00110,GPS time-Minutes,1,
IDE03477-MAS00111,GPS time-Seconds,0,
IDE04605-IDE01712,Navigation: Corrected position-GPS Position,Not available,
IDE04605-MAS01779,Navigation: Corrected position-Length,75305274,
IDE04605-MAS01780,Navigation: Corrected position-Width,40223995,
IDE04605-ENG123297,Navigation: Corrected position-error_value,0, m
IDE04750-MAS03876,SIM cards-active SIM card,internal,
IDE04750-MAS03877,SIM cards-SIM ID,89011702258131432490,
IDE04750-MAS03878,SIM cards-SIM IMSI,310170813143249,
IDE04750-MAS04226,SIM cards-Telephone number,                              ,
IDE04750-MAS08401,SIM cards-SIM intern,Available,
IDE04750-MAS08402,SIM cards-SIM extern,Not available,
IDE04790,Call for help button,Not available,
IDE05430,Telephone serial number,358895053435435,
IDE06644,Vehicle positioning system,Measured value not available,
IDE07007-IDE00983,A/C heater function via remote control-Interior temperature,25, °C
IDE07007-IDE04927,A/C heater function via remote control-Window heater,On,
IDE07007-MAS01118,A/C heater function via remote control-Climate control,OFF,
IDE07007-MAS02289,A/C heater function via remote control-Outside air temperature,5, °C
IDE07007-MAS05945,A/C heater function via remote control-Specified temperature,26.1, °C
IDE07007-MAS08947,A/C heater function via remote control-After-run time for power supply,30, min
IDE07007-MAS08948,A/C heater function via remote control-After-run time for battery,15, min
IDE07007-MAS08949,A/C heater function via remote control-Climate control without power supply,On,
IDE07007-MAS08957,A/C heater function via remote control-A/C window heater,On,
IDE07007-MAS08958,A/C heater function via remote control-reason for last climate control,Measured value not available,
IDE07543,Vehicle speed,0.00, km/h
IDE07940-IDE07007,Status of enabling for online services-A/C heater function via remote control,activated,
IDE07940-IDE07909,Status of enabling for online services-Remote control for vehicle locking,not activated,
IDE07940,Status of enabling for online services,activated,
IDE07940-IDE07974,Status of enabling for online services-Transmission of navigation targets,not activated,
IDE07940-IDE07975,Status of enabling for online services-Remote control for charge function of H-V battery,activated,
IDE07940-IDE07976,Status of enabling for online services-Info call,not activated,
IDE07940-IDE08155,Status of enabling for online services-Vehicle state report,not activated,
IDE07940-IDE08158,Status of enabling for online services-Roadside assistance / schedule agreement for service,not activated,
IDE07940-MAS08370,Status of enabling for online services-Position monitoring (Geofencing),not activated,
IDE07940-MAS08371,Status of enabling for online services-Remote control for speed warning,not activated,
IDE07940-MAS08372,Status of enabling for online services-Remote control for vehicle shutdown,not activated,
IDE07940-MAS08373,Status of enabling for online services-Remote control for vehicle location,not activated,
IDE07940-MAS08374,Status of enabling for online services-Remote control for lights and horn,not activated,
IDE07940-MAS08375,Status of enabling for online services-Distance statistics display,activated,
IDE07940-MAS08376,Status of enabling for online services-Display vehicle state,activated,
IDE07940-MAS08377,Status of enabling for online services-Remote control for departure time programming,activated,
IDE07940-MAS08448,Status of enabling for online services-Manual roadside assistance,not activated,
IDE07940-MAS08449,Status of enabling for online services-Automatic roadside assistance,not activated,
IDE07975-IDE00704,Remote control for charge function of H-V battery-Charge level,active,
IDE07975-IDE01839,Remote control for charge function of H-V battery-Battery charge condition,14, %
IDE07975-IDE05431,Remote control for charge function of H-V battery-Locking for H-V charge plug,locked,
IDE07975-IDE06986,Remote control for charge function of H-V battery-H-V battery charge current: maximum value,32, A
IDE07975-MAS01002,Remote control for charge function of H-V battery-Remaining operating range,3, km
IDE07975-MAS01118,Remote control for charge function of H-V battery-Climate control,Cooling,
IDE07975-MAS05682,Remote control for charge function of H-V battery-External Charging,Available,
IDE07975-MAS08781,Remote control for charge function of H-V battery-Connection state of charging plug,connected,
IDE07975-MAS08782,Remote control for charge function of H-V battery-Remaining charge time,159, min
IDE07975-MAS08783,Remote control for charge function of H-V battery-Reason for last battery charge,Measured value not available,
IDE07975-MAS08784,Remote control for charge function of H-V battery-Charging current type,AC,
IDE08077-MAS01240,Timer 1 for programming of departure time-Programming status,not programmed,
IDE08077-MAS01635,Timer 1 for programming of departure time-Monday,not programmed,
IDE08077-MAS01636,Timer 1 for programming of departure time-Tuesday,not programmed,
IDE08077-MAS01637,Timer 1 for programming of departure time-Wednesday,not programmed,
IDE08077-MAS01638,Timer 1 for programming of departure time-Thursday,not programmed,
IDE08077-MAS01639,Timer 1 for programming of departure time-Friday,not programmed,
IDE08077-MAS01640,Timer 1 for programming of departure time-Saturday,not programmed,
IDE08077-MAS01641,Timer 1 for programming of departure time-Sunday,not programmed,
IDE08077-MAS08963,Timer 1 for programming of departure time-Condition of timer,active,
IDE08077-ENG123310,Timer 1 for programming of departure time-Timer_Mode,HV charging,
IDE08077-ENG123309,Timer 1 for programming of departure time-Timer_Type,one time,
IDE08078-MAS01240,Timer 2 for programming of departure time-Programming status,Measured value not available,
IDE08078-MAS01635,Timer 2 for programming of departure time-Monday,not programmed,
IDE08078-MAS01636,Timer 2 for programming of departure time-Tuesday,not programmed,
IDE08078-MAS01637,Timer 2 for programming of departure time-Wednesday,not programmed,
IDE08078-MAS01638,Timer 2 for programming of departure time-Thursday,not programmed,
IDE08078-MAS01639,Timer 2 for programming of departure time-Friday,not programmed,
IDE08078-MAS01640,Timer 2 for programming of departure time-Saturday,not programmed,
IDE08078-MAS01641,Timer 2 for programming of departure time-Sunday,not programmed,
IDE08078-MAS08963,Timer 2 for programming of departure time-Condition of timer,Measured value not available,
IDE08078-ENG123310,Timer 2 for programming of departure time-Timer_Mode,Measured value not available,
IDE08078-ENG123309,Timer 2 for programming of departure time-Timer_Type,Measured value not available,
IDE08079-MAS01240,Timer 3 for programming of departure time-Programming status,Measured value not available,
IDE08079-MAS01635,Timer 3 for programming of departure time-Monday,not programmed,
IDE08079-MAS01636,Timer 3 for programming of departure time-Tuesday,not programmed,
IDE08079-MAS01637,Timer 3 for programming of departure time-Wednesday,not programmed,
IDE08079-MAS01638,Timer 3 for programming of departure time-Thursday,not programmed,
IDE08079-MAS01639,Timer 3 for programming of departure time-Friday,not programmed,
IDE08079-MAS01640,Timer 3 for programming of departure time-Saturday,not programmed,
IDE08079-MAS01641,Timer 3 for programming of departure time-Sunday,not programmed,
IDE08079-MAS08963,Timer 3 for programming of departure time-Condition of timer,Measured value not available,
IDE08079-ENG123310,Timer 3 for programming of departure time-Timer_Mode,Measured value not available,
IDE08079-ENG123309,Timer 3 for programming of departure time-Timer_Type,Measured value not available,
IDE08159-IDE07007,Status of online services-A/C heater function via remote control,not active,
IDE08159-IDE07975,Status of online services-Remote control for charge function of H-V battery,active,
IDE08159-IDE08158,Status of online services-Roadside assistance / schedule agreement for service,not active,
IDE08159-MAS08370,Status of online services-Position monitoring (Geofencing),not active,
IDE08159-MAS08371,Status of online services-Remote control for speed warning,not active,
IDE08159-MAS08372,Status of online services-Remote control for vehicle shutdown,not active,
IDE08159-MAS08373,Status of online services-Remote control for vehicle location,not active,
IDE08159-MAS08374,Status of online services-Remote control for lights and horn,not active,
IDE08159-MAS08377,Status of online services-Remote control for departure time programming,not active,
IDE08159-MAS08448,Status of online services-Manual roadside assistance,not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,00,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,04,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status GSG,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ELV,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,4,
MAS01490-MAS08403,Energy management-Remaining short term energy budget,802, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,5,
MAS04394-IDE03580,Connection status-Country code for mobile network,310,
MAS04394-IDE07699,Connection status-Mobile network operator,410,
MAS04394-MAS03991,Connection status-Reception level antenna 1,100.0, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,HSPA,
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-MAS08408,Connection status-Number of hours to next event,21,
MAS04394-MAS08409,Connection status-Number of minutes to next event,17,
MAS04394-MAS08410,Connection status-Number of seconds to next event,5,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,142366764,
MAS04394-ENG123308,Connection status-TCP_Connection_State,not active,
MAS06193-IDE06986,Profile 1-H-V battery charge current: maximum value,0, A
MAS06193-MAS04721,Profile 1-Minimum charge level,0, %
MAS06193-MAS04722,Profile 1-Maximum charge level,0, %
MAS06193-MAS08967,Profile 1-Start high voltage charging:Hour,0,
MAS06193-MAS08968,Profile 1-Start high voltage charging:Minute,0,
MAS06193-MAS08969,Profile 1-End of high voltage charging:Hour,0,
MAS06193-MAS08970,Profile 1-End of high voltage charging:Minute,0,
MAS06194-IDE06986,Profile 2-H-V battery charge current: maximum value,0, A
MAS06194-MAS04721,Profile 2-Minimum charge level,0, %
MAS06194-MAS04722,Profile 2-Maximum charge level,0, %
MAS06194-MAS08967,Profile 2-Start high voltage charging:Hour,0,
MAS06194-MAS08968,Profile 2-Start high voltage charging:Minute,0,
MAS06194-MAS08969,Profile 2-End of high voltage charging:Hour,0,
MAS06194-MAS08970,Profile 2-End of high voltage charging:Minute,0,
MAS06195-IDE06986,Profile 3-H-V battery charge current: maximum value,0, A
MAS06195-MAS04721,Profile 3-Minimum charge level,0, %
MAS06195-MAS04722,Profile 3-Maximum charge level,0, %
MAS06195-MAS08967,Profile 3-Start high voltage charging:Hour,0,
MAS06195-MAS08968,Profile 3-Start high voltage charging:Minute,0,
MAS06195-MAS08969,Profile 3-End of high voltage charging:Hour,0,
MAS06195-MAS08970,Profile 3-End of high voltage charging:Minute,0,
MAS06413,Audio signal output,Not available,
MAS08178-IDE02493,Crash information-Automatic door unlocking,No,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08178-MAS08956,Crash information-Automatic emergency call activated:Fuel shut-off,No,
MAS08179,List of last telephone numbers,,
MAS08180,Remote-controlled horn and lights,0, s
MAS08181-MAS01779,Area restriction configuration-Length,0, m
MAS08181-MAS01780,Area restriction configuration-Width,0, m
MAS08181-MAS08775,Area restriction configuration-Calculation frequency,65535, s
MAS08181-MAS08776,Area restriction configuration-tolerance,65535, m
MAS08181-MAS08777,Area restriction configuration-Contact bounce suppression,65535, s
MAS08181-MAS08778,Area restriction configuration-Rotation angle,65535, °
MAS08181-MAS08779,Area restriction configuration-Zone type,Not available,
MAS08181-MAS08780,Area restriction configuration-Area type,rectangle,
MAS08183-IDE02068,Event list: horn and lights (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08183-MAS08552,Event list: horn and lights (ring memory)-Event generated,Unknown,
MAS08184-IDE02068,Event list: emergency call(ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08184-MAS08552,Event list: emergency call(ring memory)-Event generated,Unknown,
MAS08185-IDE02068,Event list: vehicle shut-down (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08185-MAS08552,Event list: vehicle shut-down (ring memory)-Event generated,Unknown,
MAS08186-IDE02068,Event list: vehicle location (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08186-MAS08552,Event list: vehicle location (ring memory)-Event generated,Unknown,
MAS08187-IDE02068,Event list area restriction (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08187-MAS08552,Event list area restriction (ring memory)-Event generated,Unknown,
MAS08188-IDE02068,Event list: Mobile Online services (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08188-MAS08552,Event list: Mobile Online services (ring memory)-Event generated,Unknown,
MAS08189-IDE02068,Event list: speed warning (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08189-MAS08552,Event list: speed warning (ring memory)-Event generated,Unknown,
MAS08190-IDE02068,Event list: distance statistics (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08190-MAS08552,Event list: distance statistics (ring memory)-Event generated,Unknown,
MAS08191-IDE02068,Event list: vehicle state (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08191-MAS08552,Event list: vehicle state (ring memory)-Event generated,Unknown,
MAS08192-IDE02068,Event list: info call (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08192-MAS08552,Event list: info call (ring memory)-Event generated,Unknown,
MAS08193-IDE02068,Event list: battery charge management (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08193-MAS08552,Event list: battery charge management (ring memory)-Event generated,Unknown,
MAS08194-IDE02068,Event list: A/C (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08194-MAS08552,Event list: A/C (ring memory)-Event generated,Unknown,
MAS08195-IDE02068,Event list: departure time (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08195-MAS08552,Event list: departure time (ring memory)-Event generated,Unknown,
MAS08196-IDE02068,Event list: vehicle status report (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08196-MAS08552,Event list: vehicle status report (ring memory)-Event generated,Unknown,
MAS08197-IDE02068,Event list:roadside assist and maint. schedule(ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08197-MAS08552,Event list:roadside assist and maint. schedule(ring memory)-Event generated,Unknown,
MAS08198-IDE02068,Event lists: imported navigation destinations (bring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08198-MAS08552,Event lists: imported navigation destinations (bring memory)-Event generated,Unknown,
MAS08199-IDE02068,Event list: vehicle locking (ring memory)-Time stamp,00 00 00 00 00 00 00,
MAS08199-MAS08552,Event list: vehicle locking (ring memory)-Event generated,Unknown,
ENG123206-ENG123337,Antenna_Switch-GPS_Antenna_Switch,external,
ENG123206-ENG123336,Antenna_Switch-GSM_Antenna_Switch,external,
ENG123207-IDE01588,Calculated_Position_And_Direction_Areal_Update-Driving direction,0, °
ENG123207-MAS01632,Calculated_Position_And_Direction_Areal_Update-Status,Not available,
ENG123207-MAS01779,Calculated_Position_And_Direction_Areal_Update-Length,,
ENG123207-MAS01780,Calculated_Position_And_Direction_Areal_Update-Width,,
ENG123207-ENG123297,Calculated_Position_And_Direction_Areal_Update-error_value,0, m
ENG123208-MAS00106,Geofencing_schedule_start_time-Year,2000,
ENG123208-MAS00107,Geofencing_schedule_start_time-Month,0,
ENG123208-MAS00108,Geofencing_schedule_start_time-Day,0,
ENG123208-MAS00109,Geofencing_schedule_start_time-Hours,0,
ENG123208-MAS00110,Geofencing_schedule_start_time-Minutes,0,
ENG123208-MAS00111,Geofencing_schedule_start_time-Seconds,0,
ENG123209-MAS00106,Geofencing_schedule_stop_time-Year,2000,
ENG123209-MAS00107,Geofencing_schedule_stop_time-Month,0,
ENG123209-MAS00108,Geofencing_schedule_stop_time-Day,0,
ENG123209-MAS00109,Geofencing_schedule_stop_time-Hours,0,
ENG123209-MAS00110,Geofencing_schedule_stop_time-Minutes,0,
ENG123209-MAS00111,Geofencing_schedule_stop_time-Seconds,0,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,255,
ENG123212-ENG123347,GPS_Dilution_of_precision-geometric_dilution_of_precision,130,
ENG123212-ENG123346,GPS_Dilution_of_precision-horizontal_dilution_of_precision,8,
ENG123212-ENG123296,GPS_Dilution_of_precision-Initiation,initialized,
ENG123212-ENG123348,GPS_Dilution_of_precision-positional_dilution_of_precision,643,
ENG123212-ENG123345,GPS_Dilution_of_precision-time_dilution_of_precision,640,
ENG123212-ENG123344,GPS_Dilution_of_precision-vertical_dilution_of_precision,232,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,255,
ENG125913,Hybrid_Type,PlugIn_Hybrid,
ENG117422,IP_Address,10.101.125.233,
ENG117869-IDE01588,Nav._Calculated_Direction-Driving direction,0, °
ENG117869-MAS01632,Nav._Calculated_Direction-Status,Available,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,0,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,737,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,no error,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,0, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,273,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,no error,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,0,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,no error,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,458,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,0,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,0,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,0,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,0,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,0,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,6,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,0,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,12,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,0,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,no error,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,0,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,1, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,no error,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,13476, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,0,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,1705839, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,no error,
ENG123204,Outgoing_call_line_state,Idle,
ENG123202,Phone_Register_State,registerstate_registered,
ENG129162-ENG98933,Serial_Tracing-Status,not activated,
ENG123210-MAS00106,Speed_alert_schedule_start_time-Year,2000,
ENG123210-MAS00107,Speed_alert_schedule_start_time-Month,0,
ENG123210-MAS00108,Speed_alert_schedule_start_time-Day,0,
ENG123210-MAS00109,Speed_alert_schedule_start_time-Hours,0,
ENG123210-MAS00110,Speed_alert_schedule_start_time-Minutes,0,
ENG123210-MAS00111,Speed_alert_schedule_start_time-Seconds,0,
ENG123211-MAS00106,Speed_alert_schedule_stop_time-Year,2000,
ENG123211-MAS00107,Speed_alert_schedule_stop_time-Month,0,
ENG123211-MAS00108,Speed_alert_schedule_stop_time-Day,0,
ENG123211-MAS00109,Speed_alert_schedule_stop_time-Hours,0,
ENG123211-MAS00110,Speed_alert_schedule_stop_time-Minutes,0,
ENG123211-MAS00111,Speed_alert_schedule_stop_time-Seconds,0,
ENG123193-ENG123341,Vehicle_Health_Report-Collection_Period,Deactivated,
ENG123193-ENG123342,Vehicle_Health_Report-Day_at_month_for_report,0,
ENG123193-ENG123343,Vehicle_Health_Report-Day_at_week_for_report,Not available,
ENG123193-ENG123339,Vehicle_Health_Report-Distance_Based_Distance,0, km
ENG123193-ENG123338,Vehicle_Health_Report-Distance_Based_Start_Mileage,0, km
ENG123193-ENG123340,Vehicle_Health_Report-Maintenance_Based_Distance,0, km
Elapsed Time: 00:21
Andy
Sector 7G
HC424490
8C - Hybrid Battery maps
;SW:5Q0-915-182-D   HW:5Q0-915-182-C ---  Hybrid Battery
;Component:BECM          H05 0921, Coding:00000000
;EV_BECM09620115Q0915182,006041,EV_BECM09620115Q0915182.rod
;Friday,08,December,2017,16:19:19:29905
;VCID: 342B9F9B9F4FBE8A127-8060
IDE00010-Serial number,V6130090 ,20
IDE00011-Vehicle Identification Number (VIN),----------------- ,17
IDE05417-Serial number of H-V / hybrid battery,288 SYEDVQ0ABJ  ,15
IDE05963-ASSY part number, ,12
IDE11985-Expected OBD requirements,US OBD ,1
Elapsed Time: 00:01
;Friday,08,December,2017,16:18:46:29905
IDE00010,Serial number,V6130090,
IDE00019,Voltage terminal 30,13.05, V
IDE00056-ENG36045,History data 1-HVBHDM_1_4,00 00 00 00,
IDE00056-ENG125711,History data 1-HVBHDM01_1,6,
IDE00056-ENG125712,History data 1-HVBHDM01_2,8,
IDE00056-ENG125713,History data 1-HVBHDM01_3,48,
IDE00057-ENG36046,History data 2-HVBHDM_2_4,00 00 00 00,
IDE00057-ENG125714,History data 2-HVBHDM02_1,8,
IDE00057-ENG125715,History data 2-HVBHDM02_2,8,
IDE00057-ENG125716,History data 2-HVBHDM02_3,64,
IDE00058-ENG36047,History data 3-HVBHDM_3_4,00 00 00 00,
IDE00058-ENG125717,History data 3-HVBHDM03_1,8,
IDE00058-ENG125718,History data 3-HVBHDM03_2,8,
IDE00058-ENG125719,History data 3-HVBHDM03_3,64,
IDE00059-ENG36048,History data 4-HVBHDM_4_4,00 00 00 00,
IDE00059-ENG125720,History data 4-HVBHDM04_1,8,
IDE00059-ENG125721,History data 4-HVBHDM04_2,8,
IDE00059-ENG125722,History data 4-HVBHDM04_3,64,
IDE00060-ENG36049,History data 5-HVBHDM_5_2,00 00 00 00,
IDE00060-ENG125723,History data 5-HVBHDM05_3,6,
IDE00061-ENG36050,History data 6-HVBHDM_6_4,00 00 02 6F,
IDE00061-ENG125724,History data 6-HVBHDM06_1,10,
IDE00061-ENG125725,History data 6-HVBHDM06_2,2,
IDE00061-ENG125726,History data 6-HVBHDM06_3,20,
IDE00062-ENG36051,History data 7-HVBHDM_7_4,00 00,
IDE00062-ENG125727,History data 7-HVBHDM07_1,6,
IDE00062-ENG125728,History data 7-HVBHDM07_2,6,
IDE00062-ENG125729,History data 7-HVBHDM07_3,21,
IDE00063-ENG36052,History data 8-HVBHDM_8_4,00 00,
IDE00063-ENG125730,History data 8-HVBHDM08_1,6,
IDE00063-ENG125731,History data 8-HVBHDM08_2,6,
IDE00063-ENG125732,History data 8-HVBHDM08_3,21,
IDE00064-ENG36053,History data 9-HVBHDM_9_2,00 00 19 14,
IDE00064-ENG128710,History data 9-HVBHDM09_1,96,
IDE00065-ENG36054,History data 10-HVBHDM_10_2,00 00 01 02,
IDE00065-ENG128711,History data 10-HVBHDM10_1,10,
IDE00066-ENG36055,History data 11-HVBHDM_11_4,00 00,
IDE00066-ENG125733,History data 11-HVBHDM11_1,8,
IDE00066-ENG125734,History data 11-HVBHDM11_2,2,
IDE00066-ENG125735,History data 11-HVBHDM11_3,16,
IDE00067-ENG36056,History data 12-HVBHDM_12_4,00 00,
IDE00067-ENG125736,History data 12-HVBHDM12_1,08,
IDE00067-ENG125737,History data 12-HVBHDM12_2,02,
IDE00067-ENG125738,History data 12-HVBHDM12_3,10,
IDE00068-ENG36044,History data 13-HVBHDM_13_2,00 00 00 28,
IDE00068-ENG128712,History data 13-HVBHDM13_1,8,
IDE00069-ENG36057,History data 14-HVBHDM_14_3,7D,
IDE00069-ENG125739,History data 14-HVBHDM14_1,07 53,
IDE00069-ENG125740,History data 14-HVBHDM14_2,96,
IDE00070-ENG36058,History data 15-HVBHDM_15_4,7D,
IDE00070-ENG125741,History data 15-HVBHDM15_1,8,
IDE00070-ENG125742,History data 15-HVBHDM15_2,40,
IDE00070-ENG125743,History data 15-HVBHDM15_3,320,
IDE00071,History data 16,00 96,
IDE00071-ENG125744,History data 16-HVBHDM16_1,2C,
IDE00071-ENG125745,History data 16-HVBHDM16_2,00 02,
IDE00071-ENG125746,History data 16-HVBHDM16_3,58,
IDE00071-ENG125747,History data 16-HVBHDM16_4,FF FF,
IDE00071-ENG125748,History data 16-HVBHDM16_5,96,
IDE00097,OBD - requirements for which this vehicle is designed,OBD and OBD II,
IDE00637,Intermediate circuit voltage,356.3, V
IDE00773,Terminal 15 status via CAN,Measured value not available,
IDE00961-MAS05695,Malfunction Indicator Lamp-Start request,not active,
IDE01021,Current of H-V / hybrid battery,1.80, A
IDE01028-MAS01422,Air temperature of H-V / hybrid battery-Intake,19, °C
IDE01028-MAS01423,Air temperature of H-V / hybrid battery-Exhaust,19, °C
IDE01803-ENG36059,History data 17-HVBHDM_17_2,00 6A,
IDE01803-ENG125750,History data 17-HVBHDM17_1,6,
IDE01804-ENG36060,History data 18-HVBHDM_18_2,00 00 3A 06,
IDE01804-ENG125751,History data 18-HVBHDM18_1,8,
IDE01805-ENG36061,History data 19-HVBHDM_19_2,00 03 C5 A3,
IDE01805-ENG125752,History data 19-HVBHDM19_1,7,
IDE01806-ENG36062,History data 20-HVBHDM_20_2,00 25 FC 09,
IDE01806-ENG125753,History data 20-HVBHDM20_1,7,
IDE01838,Battery temperature,20, °C
IDE01839,Battery charge condition,50, %
IDE03410-MAS05695,Yellow warning lamp-Start request,not active,
IDE03411-MAS05695,Red warning lamp-Start request,not active,
IDE05416,H-V battery insulation measurement test voltage,500, V
IDE05417,Serial number of H-V / hybrid battery,288 SYEDVQ0ABJ ,
IDE05963,ASSY part number,,
IDE06302-MAS01422,Temperature of evaporator-Intake,19, °C
IDE06302-MAS01423,Temperature of evaporator-Exhaust,19, °C
IDE06346,H-V battery voltage,355.7, V
IDE06404,Pilot line,not active,
IDE06422-ENG106773,IUMPR_1-General_Denominator,3,
IDE06422-ENG106916,IUMPR_1-Ignition_Cycle_Counter,70,
IDE06422-ENG100120,IUMPR_1-Milage,70, km
IDE06422-ENG128699,IUMPR_1-Number_of_IUMPR_Records,53,
IDE06423-ENG128703,IUMPR_2-Denominator_to_DFCC_ID2_2,3,
IDE06423-ENG128701,IUMPR_2-DFCC_Value_to_Record_ID2_1,26653,
IDE06423-ENG128702,IUMPR_2-Numerator_to_DFCC_ID2_2,66,
IDE06423-ENG128700,IUMPR_2-Recordnumber_uneven,1,
IDE06424-ENG128707,IUMPR_3-Denominator_to_DFCC_ID3_2,3,
IDE06424-ENG128705,IUMPR_3-DFCC_value_of_record_ID_3_2,26652,
IDE06424-ENG128706,IUMPR_3-Numerator_to_DFCC_ID3_2,70,
IDE06424-ENG128704,IUMPR_3-Recordnumber_even,2,
IDE06673,Initialization status,not active,
IDE06805,Status of voltage freedom,High voltage power off not recognized,
IDE06948,High-volt. battery mode: spec. value,Extern. charging: AC voltage,
IDE06973,Power reduction status,not active,
IDE07044-MAS01420,Predictive limit for charge current-Limit for charge current,26, A
IDE07045-MAS01420,Dynamic limit for charge current-Limit for charge current,125, A
IDE07227-IDE01024,Voltage in H-V system-Voltage of hybrid battery after protection,356.3, V
IDE07227-MAS05684,Voltage in H-V system-Voltage at power electronics,355.7, V
IDE07227-MAS05685,Voltage in H-V system-Voltage at high-voltage charging device,351.0, V
IDE08217-MAS01234,maximum voltage for battery cells-Index 1,56,
IDE08217-MAS02985,maximum voltage for battery cells-Value,3.709, V
IDE08218-MAS01234,minimum voltage for battery cells-Index 1,41,
IDE08218-MAS02985,minimum voltage for battery cells-Value,3.703, V
IDE08230-MAS01421,Dynamic limit for discharge current-Limit for discharge current,301, A
IDE08231-MAS01421,Predictive limit for discharge current-Limit for discharge current,115, A
IDE08817,Charge state: cell 01,50, %
IDE08818,Charge state: cell 02,50, %
IDE08819,Charge state: cell 03,50, %
IDE08820,Charge state: cell 04,50, %
IDE08821,Charge state: cell 05,50, %
IDE08822,Charge state: cell 06,50, %
IDE08823,Charge state: cell 07,50, %
IDE08824,Charge state: cell 08,50, %
IDE08825,Charge state: cell 09,50, %
IDE08826,Charge state: cell 10,50, %
IDE08827,Charge state: cell 11,50, %
IDE08828,Charge state: cell 12,50, %
IDE08829,Charge state: cell 13,50, %
IDE08830,Charge state: cell 14,50, %
IDE08831,Charge state: cell 15,50, %
IDE08832,Charge state: cell 16,50, %
IDE08833,Charge state: cell 17,50, %
IDE08834,Charge state: cell 18,50, %
IDE08835,Charge state: cell 19,50, %
IDE08836,Charge state: cell 20,50, %
IDE08837,Charge state: cell 21,50, %
IDE08838,Charge state: cell 22,50, %
IDE08839,Charge state: cell 23,50, %
IDE08840,Charge state: cell 24,50, %
IDE08841,Charge state: cell 25,50, %
IDE08842,Charge state: cell 26,50, %
IDE08843,Charge state: cell 27,50, %
IDE08844,Charge state: cell 28,50, %
IDE08845,Charge state: cell 29,50, %
IDE08846,Charge state: cell 30,50, %
IDE08847,Charge state: cell 31,50, %
IDE08848,Charge state: cell 32,50, %
IDE08849,Charge state: cell 33,50, %
IDE08850,Charge state: cell 34,50, %
IDE08851,Charge state: cell 35,50, %
IDE08852,Charge state: cell 36,50, %
IDE08853,Charge state: cell 37,50, %
IDE08854,Charge state: cell 38,50, %
IDE08855,Charge state: cell 39,50, %
IDE08856,Charge state: cell 40,50, %
IDE08857,Charge state: cell 41,50, %
IDE08858,Charge state: cell 42,50, %
IDE08859,Charge state: cell 43,50, %
IDE08860,Charge state: cell 44,50, %
IDE08861,Charge state: cell 45,50, %
IDE08862,Charge state: cell 46,50, %
IDE08863,Charge state: cell 47,51, %
IDE08864,Charge state: cell 48,50, %
IDE08865,Charge state: cell 49,50, %
IDE08866,Charge state: cell 50,50, %
IDE08867,Charge state: cell 51,50, %
IDE08868,Charge state: cell 52,50, %
IDE08869,Charge state: cell 53,50, %
IDE08870,Charge state: cell 54,50, %
IDE08871,Charge state: cell 55,50, %
IDE08872,Charge state: cell 56,50, %
IDE08873,Charge state: cell 57,50, %
IDE08874,Charge state: cell 58,51, %
IDE08875,Charge state: cell 59,50, %
IDE08876,Charge state: cell 60,50, %
IDE08879,Charge state: cell 61,50, %
IDE08880,Charge state: cell 62,50, %
IDE08881,Charge state: cell 63,50, %
IDE08882,Charge state: cell 64,50, %
IDE08883,Charge state: cell 65,50, %
IDE08884,Charge state: cell 66,50, %
IDE08885,Charge state: cell 67,50, %
IDE08886,Charge state: cell 68,50, %
IDE08887,Charge state: cell 69,50, %
IDE08888,Charge state: cell 70,50, %
IDE08889,Charge state: cell 71,51, %
IDE08890,Charge state: cell 72,50, %
IDE08891,Charge state: cell 73,50, %
IDE08892,Charge state: cell 74,50, %
IDE08893,Charge state: cell 75,50, %
IDE08894,Charge state: cell 76,50, %
IDE08895,Charge state: cell 77,50, %
IDE08896,Charge state: cell 78,50, %
IDE08897,Charge state: cell 79,50, %
IDE08898,Charge state: cell 80,50, %
IDE08899,Charge state: cell 81,50, %
IDE08900,Charge state: cell 82,50, %
IDE08901,Charge state: cell 83,50, %
IDE08902,Charge state: cell 84,50, %
IDE08903,Charge state: cell 85,50, %
IDE08904,Charge state: cell 86,50, %
IDE08905,Charge state: cell 87,50, %
IDE08906,Charge state: cell 88,50, %
IDE08907,Charge state: cell 89,50, %
IDE08908,Charge state: cell 90,50, %
IDE08909,Charge state: cell 91,50, %
IDE08910,Charge state: cell 92,50, %
IDE08911,Charge state: cell 93,50, %
IDE08912,Charge state: cell 94,50, %
IDE08913,Charge state: cell 95,50, %
IDE08914,Charge state: cell 96,50, %
IDE10320-MAS01146,Workshop code and date of last reset of crash shutdown-Workshop code,00 00 00 00 00 00,
IDE10320-MAS01230,Workshop code and date of last reset of crash shutdown-Date,00 00 00,
IDE80253,Voltage terminal 30C,12.75, V
MAS00194-ENG128689,--no display---CMC_SEL_out,01,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000, yr
MAS00464-MAS00107,Standard - ambient data 1-Month,1, mon
MAS00464-MAS00108,Standard - ambient data 1-Day,8, d
MAS00464-MAS00109,Standard - ambient data 1-Hours,1, H
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0, min
MAS00464-MAS00111,Standard - ambient data 1-Seconds,9, s
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,255,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,78, km
MAS01302,Protection of posit. terminal of high voltage / hybrid battery,closed,
MAS01303,Protection of neg. terminal of high voltage / hybrid battery,closed,
MAS02199-MAS01966,Lowest measured temperature-Temperature sensor,36,
MAS02199-MAS02985,Lowest measured temperature-Value,18, °C
MAS02200-MAS01966,Highest measured temperature-Temperature sensor,72,
MAS02200-MAS02985,Highest measured temperature-Value,21, °C
MAS04266,Temperature sensor 1,20, °C
MAS04267,Temperature sensor 2,21, °C
MAS04268,Temperature sensor 3,19, °C
MAS04269,Temperature sensor 4,19, °C
MAS04270,Temperature sensor 5,18, °C
MAS04271,Temperature sensor 6,20, °C
MAS04272,Temperature sensor 7,20, °C
MAS04273,Temperature sensor 8,21, °C
MAS04291,Positive voltage of high volt battery after protection,356.1, V
MAS04292,Negative Voltage of high volt battery after protection,0.3, V
MAS04293-MAS01632,Entire HV system positive terminal insulation resistance-Status,valid,
MAS04293,Entire HV system positive terminal insulation resistance,3640, kOhm
MAS04294-MAS01632,HV battery positive terminal insulation resistance-Status,invalid,
MAS04294,HV battery positive terminal insulation resistance,10000, kOhm
MAS04295-MAS01632,Entire HV system minus terminal insulation resistance-Status,valid,
MAS04295,Entire HV system minus terminal insulation resistance,4670, kOhm
MAS04296-MAS01632,HV battery minus terminal insulation resistance-Status,invalid,
MAS04296,HV battery minus terminal insulation resistance,10000, kOhm
MAS04649,Cell 1,3.706, V
MAS04650,Cell 2,3.705, V
MAS04651,Cell 3,3.705, V
MAS04652,Cell 4,3.705, V
MAS04653,Cell 5,3.705, V
MAS04654,Cell 6,3.706, V
MAS04655,Cell 7,3.705, V
MAS04656,Cell 8,3.706, V
MAS04657,Cell 9,3.706, V
MAS04658,Cell 10,3.706, V
MAS04659,Cell 11,3.706, V
MAS04660,Cell 12,3.705, V
MAS04661,Cell 13,3.705, V
MAS04662,Cell 14,3.705, V
MAS04663,Cell 15,3.704, V
MAS04664,Cell 16,3.706, V
MAS04665,Cell 17,3.706, V
MAS04666,Cell 18,3.706, V
MAS04667,Cell 19,3.706, V
MAS04668,Cell 20,3.706, V
MAS04669,Cell 21,3.706, V
MAS04670,Cell 22,3.706, V
MAS04671,Cell 23,3.707, V
MAS04672,Cell 24,3.706, V
MAS04673,Cell 25,3.705, V
MAS04674,Cell 26,3.706, V
MAS04675,Cell 27,3.706, V
MAS04676,Cell 28,3.706, V
MAS04677,Cell 29,3.705, V
MAS04678,Cell 30,3.705, V
MAS04679,Cell 31,3.705, V
MAS04680,Cell 32,3.708, V
MAS04681,Cell 33,3.707, V
MAS04682,Cell 34,3.707, V
MAS04683,Cell 35,3.708, V
MAS04684,Cell 36,3.707, V
MAS04685,Cell 37,3.704, V
MAS04686,Cell 38,3.705, V
MAS04687,Cell 39,3.705, V
MAS04688,Cell 41,3.705, V
MAS04689,Cell 42,3.704, V
MAS04690,Cell 43,3.705, V
MAS04691,Cell 44,3.707, V
MAS04692,Cell 45,3.707, V
MAS04693,Cell 46,3.707, V
MAS04694,Cell 47,3.707, V
MAS04695,Cell 48,3.707, V
MAS04696,Cell 49,3.707, V
MAS04697,Cell 50,3.707, V
MAS04698,Cell 51,3.707, V
MAS04699,Cell 52,3.707, V
MAS04700,Cell 53,3.707, V
MAS04701,Cell 54,3.706, V
MAS04702,Cell 55,3.707, V
MAS04703,Cell 56,3.708, V
MAS04704,Cell 57,3.709, V
MAS04705,Cell 58,3.708, V
MAS04706,Cell 59,3.709, V
MAS04707,Cell 60,3.708, V
MAS04708,Cell 61,3.707, V
MAS04709,Cell 62,3.706, V
MAS04710,Cell 63,3.707, V
MAS04711,Cell 64,3.707, V
MAS04712,Cell 65,3.707, V
MAS04713,Cell 66,3.707, V
MAS04714,Cell 67,3.707, V
MAS04715,Cell 68,3.708, V
MAS04716,Cell 69,3.709, V
MAS04717,Cell 70,3.709, V
MAS04718,Cell 71,3.708, V
MAS04719,Cell 72,3.709, V
MAS04720,Cell 40,3.704, V
MAS04721-MAS01234,Minimum charge level-Index 1,11,
MAS04721-MAS02985,Minimum charge level-Value,50, %
MAS04722-MAS01234,Maximum charge level-Index 1,57,
MAS04722-MAS02985,Maximum charge level-Value,51, %
MAS06567-ENG36313,Frequency Counter-Counter SOC 0 to 10,0,
MAS06567-ENG36314,Frequency Counter-Counter SOC 10 to 20,0,
MAS06567-ENG36315,Frequency Counter-Counter SOC 20 to 30,0,
MAS06567-ENG36316,Frequency Counter-Counter SOC 30 to 40,0,
MAS06567-ENG36317,Frequency Counter-Counter SOC 40 to 50,0,
MAS06567-ENG36318,Frequency Counter-Counter SOC 50 to 60,0,
MAS06567-ENG36319,Frequency Counter-Counter SOC 60 to 70,0,
MAS06567-ENG36320,Frequency Counter-Counter SOC 70 to 80,0,
MAS06567-ENG36321,Frequency Counter-Counter SOC 80 to 90,0,
MAS06567-ENG36322,Frequency Counter-Counter SOC 90 to 100,0,
MAS06567-ENG36323,Frequency Counter-Main counter,0,
MAS06761,Sum of voltage of all battery cells,355.776, V
MAS07735,Cell 73,3.705, V
MAS07736,Cell 74,3.705, V
MAS07737,Cell 75,3.705, V
MAS07738,Cell 76,3.704, V
MAS07739,Cell 77,3.705, V
MAS07740,Cell 78,3.704, V
MAS07741,Cell 79,3.705, V
MAS07742,Cell 80,3.706, V
MAS07743,Cell 81,3.707, V
MAS07744,Cell 82,3.707, V
MAS07745,Cell 83,3.707, V
MAS07746,Cell 84,3.706, V
MAS07747,Cell 85,3.705, V
MAS07748,Cell 86,3.706, V
MAS07749,Cell 87,3.706, V
MAS07750,Cell 88,3.705, V
MAS07751,Cell 89,3.705, V
MAS07752,Cell 90,3.706, V
MAS07753,Cell 91,3.705, V
MAS07754,Cell 92,3.707, V
MAS07755,Cell 93,3.707, V
MAS07756,Cell 94,3.707, V
MAS07757,Cell 95,3.708, V
MAS07758,Cell 96,3.706, V
MAS07792,Expanded battery limits,not active,
MAS07798,Status pre-loader,Open,
MAS07799,Pump for HV battery coolant: status,no error,
MAS07804,Pump for HV battery coolant: specified power value,0.0, %
MAS07805,Pump for HV battery coolant: RPM list value,655340, /min
MAS07807-MAS07808,Valve 1 coolant HV battery: activation-Valve 1 coolant HV battery: spec. value,closed,
MAS07807-MAS07809,Valve 1 coolant HV battery: activation-Valve 1 coolant HV battery: act. value,not defined,
MAS07813,HV battery: cool. level requirement,no cooling request,
MAS07815,Cooling status BMS,OFF,
MAS07826,Reqmnt. emergency discharge HV interm. circ. condenser,not active,
MAS07827,Mode HV battery actual value,Extern. charging: AC voltage,
MAS12552,Coolant valve voltage,0.014, V
MAS12567,Activation signal for high voltage contactor,00,
MAS12568,Feedback signal for high voltage contactor,01,
Elapsed Time: 00:32
   #30
Andy
Sector 7G
HC424490
A5 - Frt Sens. Drv. Assist maps
;SW:3Q0-980-654-H   HW:3Q0-980-654-A ---  Frt Sens. Drv. Assist
;Component:MQB_B_MFK     H07 0272, Coding:040307030000020101222346814E490080000E200120
;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_VW36.rod
;Friday,08,December,2017,16:19:51:29905
;VCID: 3C3BB7BBB71F76CADA7-8068
IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated ,1
IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated ,1
IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated ,1
IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated ,1
IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated ,1
IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated ,1
IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated ,1
IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated ,1
IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h,2
IDE04733-Road sign detection fusion mode,Road sign fusion ,1
IDE07358-Distance to calibration field,1500 mm,2
IDE09375-IDE05717-Axle offset-Front axle transverse position,1.00001 mm,4
IDE09375-IDE05718-Axle offset-Rear axle transverse position,5.96046e-006 mm,4
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,678 mm,8
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,686.75 mm,8
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,673.25 mm,8
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,682 mm,8
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2350 mm,24
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,732.5 mm,24
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1494 mm,24
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2350 mm,24
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-732.5 mm,24
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1494 mm,24
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2350 mm,24
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,732.5 mm,24
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,906 mm,24
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2350 mm,24
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-732.5 mm,24
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,906 mm,24
IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
IDE10870-Switch-on condition: lane depart. warn.,off (setting via menu) ,1
IDE10872-Warning intensity: lane depart. warning,Medium ,1
IDE10873-BAP personalization,activated ,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,-0.243 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,0.105 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.027 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,1298 mm,8
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0 ,3
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0 ,3
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic ,3
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled ,3
ENG120319-Mask_error_reactions_for_development,not activated ,1
ENG107577-Masked_fault_classes-,255 ,4
ENG130777-standstill_mode,not activated ,1
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,12.8 ,5
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,0 ,5
ENG130779-Xcp_interface,not activated ,1
Elapsed Time: 00:07
;Friday,08,December,2017,16:19:25:29905
IDE00018,Voltage terminal 15,13.1, V
IDE00102,Control Module temperature,23, °C
IDE00326-MAS02471,Steering wheel angle-Sign,Positive,
IDE00326,Steering wheel angle,4.7, °
IDE00925-MAS02471,Yaw rate-Sign,Positive,
IDE00925,Yaw rate,0.00, °/s
IDE00973,Outside air temperature,5.0, °C
IDE01968,Dynamic calibration: yaw angle offset,0.182, °
IDE01969,Dynamic calibration: pitch angle offset,0.069, °
IDE01970,Dynamic calibration: roll angle offset,-0.379, °
IDE01971,Lowest recorded control module temperature,0, °C
IDE01972,Highest recorded control module temperature,40, °C
IDE02057,Dynamic calibration: status,Passive values stored,
IDE03222-MAS02534,Blindness detection-Clear view,No,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS11936,Blindness detection-Causes of blindness,Clear view,
IDE03222-MAS11937,Blindness detection-Pixel failure,0, %
IDE03222-MAS11949,Blindness detection-Windshield heater blindness,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,7, km
IDE04036,High beam assistant: status,not active,
IDE04037,High beam recommendation,OFF,
IDE04123,High beam: reason for shut-off,4,
IDE04125,Visibility,Not Used,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07214,Dynamic calibration: camera height offset,0, mm
IDE09424,Number of recognized lane markings,0,
IDE09433-MAS01632,Perception module for light assistant-Status,passive,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,unknown Object_1_distance,
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,unknown Object_2_distance,
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,unknown Object_1_horizontal_angle,
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,unknown Object_2_horizontal_angle,
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,unknown Object_1_vertical_angle,
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,unknown Object_2_vertical_angle,
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,0, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,0, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,0,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,0,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,0, °
IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,0, °
IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,0, °
IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,0, °
IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,0, °
IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,0, °
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,No object,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,No object,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Left hand driv.,
IDE10220,Initial online calibration active,not active,
IDE10398-MAS10691,Self-glare-Self-glare quality,0, %
IDE10398-MAS11502,Self-glare-Self-glare recognition,No,
IDE10398-MAS11503,Self-glare-Self-glare status,not active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,1.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,1.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,1.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,1.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.105, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,1.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.027, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,1.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,-0.243, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,1.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1298, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,1.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,Calibration not yet performed,
IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,Calibration not yet performed,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2017,
IDE10664-MAS00107,Current initial calibration: details-Month,11,
IDE10664-MAS00108,Current initial calibration: details-Day,10,
IDE10664-MAS00109,Current initial calibration: details-Hours,1,
IDE10664-MAS00110,Current initial calibration: details-Minutes,50,
IDE10664-MAS00111,Current initial calibration: details-Seconds,18,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,3,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,WAUSPBFF8JA063478,
IDE10664-MAS03010,Current initial calibration: details-Focal length,1379,
IDE10664-MAS03075,Current initial calibration: details-Calibration point X coordinates on imaging sensor,644,
IDE10664-MAS03076,Current initial calibration: details-Calibration point Y coordinates on imaging sensor,363,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE11956,Boot manager version,31 12 30 13,
MAS00464-MAS00106,Standard - ambient data 1-Year,2017,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,4,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,0,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6,
ENG130818-MAS01505,Windscreen_heater_camera-Engine off,Yes,
ENG130818-MAS02374,Windscreen_heater_camera-System malfunction,no error,
ENG130818-MAS03849,Windscreen_heater_camera-Crash signal,not active,
ENG130818-ENG120256,Windscreen_heater_camera-par_Actuator_test,not active,
ENG130818-ENG120266,Windscreen_heater_camera-par_Ambient_temperature_too_low,No,
ENG130818-ENG120257,Windscreen_heater_camera-par_Blindness_activation,no request,
ENG130818-ENG120260,Windscreen_heater_camera-par_camera_temperature_too_high,No,
ENG130818-ENG120258,Windscreen_heater_camera-par_condensation_danger_activation,no request,
ENG130818-ENG120268,Windscreen_heater_camera-par_current_windscreen_heater,0.0, A
ENG130818-ENG120265,Windscreen_heater_camera-par_Heating_time_exceeded,No,
ENG130818-ENG120259,Windscreen_heater_camera-par_initial_heating,not active,
ENG130818-ENG130881,Windscreen_heater_camera-par_preventive_heating,not active,
ENG130818-ENG120264,Windscreen_heater_camera-par_Windscreenheater_error,not active,
ENG130818-ENG101577,Windscreen_heater_camera-Windscreen_heater_state_of_activation,not active,
Elapsed Time: 00:26
Andy
Sector 7G
HC424490
BB - Door Rear Drv maps
;SW:5Q0-959-395-E   HW:5Q0-959-395-B ---  Door Rear Drv
;Component:TSG HFS       020 0041, Coding:000C17204000048000000002
;EV_DCURearDriveMINKLO,006003,EV_DCURearDriveMAXCONT.rod
;Friday,08,December,2017,16:20:14:29905
;VCID: 43C9CC47CAE109329BD-8016
IDE00001-Production mode,00000000 00000000 00000000  ,3
IDE02332-Deactivate production mode,00000000 00000000 00000000  ,3
Elapsed Time: 00:01
;Friday,08,December,2017,16:20:04:29905
IDE01766-MAS02248,Distance impulses-Signal state,OK,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,13.2, V
IDE04580,Dimming of inside door handle lighting,92, %
IDE04581,Dimming for interior ambient lighting,255, %
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not activated,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,7, %
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.0, %
IDE06208-MAS02098,Rear window regulator status: driver side-Power window control standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,0, A
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,255, %
IDE06621,Driver side rear power window button,not activated,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,127.5, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.5, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.5, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.5, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.5, %
IDE06940,Rear window regulator child lock: driver side,active,
IDE07110-MAS01632,Recognition of motor variant for window regul.-Status,not recognized,
IDE07110-MAS04606,Recognition of motor variant for window regul.-Parameter set,15,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,5, °C
IDE07415,Comfort function for rear window regulator: driver side,not active,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,1248, km
MAS06010,Ambient light,255, %
Elapsed Time: 00:09
Andy
Sector 7G
HC424490
BC - Door Rear Pass maps
;SW:5Q0-959-395-E   HW:5Q0-959-395-B ---  Door Rear Pass
;Component:TSG HBFS      020 0041, Coding:000C17204000048000000002
;EV_DCURearPasseMINKLO,006003,EV_DCURearPasseMAXCONT.rod
;Friday,08,December,2017,16:20:31:29905
Elapsed Time: 00:01
;Friday,08,December,2017,16:20:22:29905
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,13.2, V
IDE02266,Passenger side rear power window button,not activated,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not activated,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.0, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,0, A
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06941,Rear window regulator child lock: frt.pass. side,active,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,5, °C
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,127.5, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.5, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.5, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.5, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.5, %
Elapsed Time: 00:09
Andy
Sector 7G
HC424490
C0- Act. for Ext. Noise maps
;SW:5QE-035-335-L   HW:5QE-035-335-B ---  Act. for Ext. Noise
;Component:E_SOUND_SG    H09 0212, Coding:04
;EV_ENoiseS1NNVW3707,006013,EV_ENoiseS1NNVW3707_006.rod
;Friday,08,December,2017,16:20:36:29905
;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
;VCID: 4AD7E163EDCBD87A58B-801E
ENG141639-ENG123297-dimming_switch_led_yellow-error_value,80 %,13
ENG141639-ENG101574-dimming_switch_led_yellow-X1,0 ,13
ENG141639-ENG99557-dimming_switch_led_yellow-X2,10 ,13
ENG141639-ENG102140-dimming_switch_led_yellow-X3,50 ,13
ENG141639-ENG102936-dimming_switch_led_yellow-X4,100 ,13
ENG141639-ENG103548-dimming_switch_led_yellow-X5,220 ,13
ENG141639-ENG113992-dimming_switch_led_yellow-X6,253 ,13
ENG141639-ENG99777-dimming_switch_led_yellow-Y1,2 %,13
ENG141639-ENG100480-dimming_switch_led_yellow-Y2,2 %,13
ENG141639-ENG100773-dimming_switch_led_yellow-Y3,6 %,13
ENG141639-ENG100631-dimming_switch_led_yellow-Y4,10 %,13
ENG141639-ENG102174-dimming_switch_led_yellow-Y5,80 %,13
ENG141639-ENG113993-dimming_switch_led_yellow-Y6,100 %,13
ENG141640-IDE12022-dimming_switch_led_yellow_absorption-Dimming button: yellow LED damping reducing dimming,0.00 ,4
ENG141640-IDE12023-dimming_switch_led_yellow_absorption-Dimming button: yellow LED damping dimming,0.00 ,4
Elapsed Time: 00:01
;Friday,08,December,2017,16:20:35:29905
Group,Description,Actual
IDE00916-MAS09310,Speaker status-Channel 1,OK,
IDE00916-MAS09311,Speaker status-Channel 2,Not coded,
MAS00478-MAS01167,Reserved-Actuation time,Unknown,
MAS00478-MAS01168,Reserved-Start parameter,OFF,
MAS00478-ENG102225,Reserved-Input Output Control Parameter,--no display--,
MAS13192,Button for eSound,not coded/not installed,
MAS13193,LED button status,not coded/not installed,
MAS13196,Mute indicator for production,not active,
ENG127110,ecu_internal_temperature,32, °C
Elapsed Time: 00:00
Andy
Sector 7G
HC424490
C6 - Batt. Chrg. maps
;SW:5QE-915-682-AG   HW:5QE-915-682-AG ---  Batt. Chrg.
;Component:OBC KOSTAL    H40 4013, Coding:105168023000
;EV_OBCSinglPhaseKLOMQB12P,001001,EV_OBCSinglPhaseKLOMQB12P.rod
;Friday,08,December,2017,16:20:47:29905
;VCID: 12673903C51B50BA60B-8046
IDE00001-Production mode,OFF ,3
IDE08427-MAS07237-Statistics of power outlet A for battery charging-No. of connections,11 ,4
IDE08427-MAS07238-Statistics of power outlet A for battery charging-No. of lockings,0 ,4
IDE08428-MAS07237-Statistics of power outlet B for battery charging-No. of connections,0 ,4
IDE08428-MAS07238-Statistics of power outlet B for battery charging-No. of lockings,0 ,4
IDE08659-MAS07237-Statistic of DC charger for battery charging-No. of connections,0 ,6
IDE08659-MAS07238-Statistic of DC charger for battery charging-No. of lockings,0 ,6
IDE08659-MAS07239-Statistic of DC charger for battery charging-No. of charging process.,0 ,6
IDE08686-IDE01464-Base profile load management-Rear window defogger,OFF ,13
IDE08686-IDE01537-Base profile load management-Windshield defogger,OFF ,13
IDE08686-MAS04721-Base profile load management-Minimum charge level,1 %,13
IDE08686-MAS04722-Base profile load management-Maximum charge level,100 %,13
IDE08686-MAS05945-Base profile load management-Specified temperature,22.0 °C,13
IDE08686-MAS07289-Base profile load management-A/C requirement,On ,13
IDE08686-MAS07291-Base profile load management-Recharg.time: status,On ,13
IDE08686-MAS07292-Base profile load management-Recharge time start hour,23 H,13
IDE08686-MAS07293-Base profile load management-Recharge time start minute,0 min,13
IDE08686-MAS07294-Base profile load management-Recharge time end hour,23 H,13
IDE08686-MAS07295-Base profile load management-Recharge time end minute,0 min,13
IDE08686-MAS07605-Base profile load management-Charge request,OFF ,13
IDE08686-MAS08221-Base profile load management-A/C retention time,30 min,13
IDE08686-MAS08222-Base profile load management-Lead time: start of charging,5 min,13
IDE08686-MAS08223-Base profile load management-Automatic A/C,On ,13
IDE08686-MAS08224-Base profile load management-Time for automatic A/C,15 min,13
IDE08686-MAS08226-Base profile load management-Max charging current,16 A,13
IDE08686-MAS08227-Base profile load management-Quick charge: SOC upper limit,100 %,13
MAS12691-MAS12692-Activation times: plug locking device-Re-locking time plug,30 s,3
MAS12691-MAS12693-Activation times: plug locking device-Locking activation time,400 ms,3
MAS12691-MAS12694-Activation times: plug locking device-Unlocking activation time,400 ms,3
Elapsed Time: 00:03
;Friday,08,December,2017,16:20:40:29905
IDE00019,Voltage terminal 30,13.1, V
IDE00637,Intermediate circuit voltage,399.8, V
IDE00767,No. of unscheduled ECU resets,00,
IDE06954,HV charge current: act. value,3, A
IDE06955-ENG114223,HV charge current: spec. value-Charger_HV_current_commanded_value,2.8, A
IDE07975,Remote control for charge function of H-V battery,not activated,
IDE08421-IDE05431,Power outlet A for battery charging-Locking for H-V charge plug,locked,
IDE08421-MAS07220,Power outlet A for battery charging-Status connect. recognition,present,
IDE08421-MAS07221,Power outlet A for battery charging-Connector locking requirement,00000000 ,
IDE08421-MAS07222,Power outlet A for battery charging-Connector unlocking requirement,00000000 ,
IDE08421-MAS07223,Power outlet A for battery charging-Max. current of charge connector,63, A
IDE08421-MAS07565,Power outlet A for battery charging-Activation charge cover lock charge socket A,not requested,
IDE08421-MAS07567,Power outlet A for battery charging-Status charge cover lock charge socket A,not locked,
IDE08421-MAS10983,Power outlet A for battery charging-Activation charge cover unlock charge socket A,not requested,
IDE08421-MAS12565,Power outlet A for battery charging-Charge socket temperature sensor AC,8.8, °C
IDE08421-MAS12566,Power outlet A for battery charging-Charge sensor temperature sensor DC,0.0, °C
IDE08422-IDE05431,Power outlet B for battery charging-Locking for H-V charge plug,not locked,
IDE08422-MAS07220,Power outlet B for battery charging-Status connect. recognition,Not Present,
IDE08422-MAS07221,Power outlet B for battery charging-Connector locking requirement,00000000 ,
IDE08422-MAS07222,Power outlet B for battery charging-Connector unlocking requirement,00000000 ,
IDE08422-MAS07223,Power outlet B for battery charging-Max. current of charge connector,63, A
IDE08422-MAS07224,Power outlet B for battery charging-Temp. of charge socket,9.0, °C
IDE08422-MAS07566,Power outlet B for battery charging-Activation charge cover lock charge socket B,not requested,
IDE08422-MAS07568,Power outlet B for battery charging-Status: chg. cover lock. device: chg. socket B,not locked,
IDE08423-MAS02949,Control signal for power outlet A for battery charging-Frequency,1000, Hz
IDE08423-MAS02952,Control signal for power outlet A for battery charging-Control voltage,5687, mV
IDE08423-MAS03873,Control signal for power outlet A for battery charging-Duty cycle,16.6, %
IDE08423-MAS04136,Control signal for power outlet A for battery charging-Current,10.0, A
IDE08423-MAS07262,Control signal for power outlet A for battery charging-Signal recognized,00000001 ,
IDE08424-MAS02949,Control signal for power outlet B for battery charging-Frequency,0, Hz
IDE08424-MAS02952,Control signal for power outlet B for battery charging-Control voltage,0, mV
IDE08424-MAS03873,Control signal for power outlet B for battery charging-Duty cycle,0.0, %
IDE08424-MAS04136,Control signal for power outlet B for battery charging-Current,0.0, A
IDE08424-MAS07262,Control signal for power outlet B for battery charging-Signal recognized,00000000 ,
IDE08425-MAS07225,Indicator lamps for power outlet A for battery charging-Status: indicator light 1,OFF,
IDE08425-MAS07226,Indicator lamps for power outlet A for battery charging-Status: indicator light 2,Blinking,
IDE08425-MAS07227,Indicator lamps for power outlet A for battery charging-Status: indicator light 3,OFF,
IDE08425-MAS07228,Indicator lamps for power outlet A for battery charging-Intensity: indicator light 1,100, %
IDE08425-MAS07229,Indicator lamps for power outlet A for battery charging-Intensity: indicator light 2,100, %
IDE08425-MAS07230,Indicator lamps for power outlet A for battery charging-Intensity: indicator light 3,100, %
IDE08425-MAS07231,Indicator lamps for power outlet A for battery charging-Period duration: indicator light 1,2000, ms
IDE08425-MAS07232,Indicator lamps for power outlet A for battery charging-Period duration: indicator light 2,2000, ms
IDE08425-MAS07233,Indicator lamps for power outlet A for battery charging-Period duration: indicator light 3,2000, ms
IDE08425-MAS07582,Indicator lamps for power outlet A for battery charging-Intensity: activation 4,0, %
IDE08425-MAS07590,Indicator lamps for power outlet A for battery charging-Period duration: activation 4,0, ms
IDE08425-MAS13012,Indicator lamps for power outlet A for battery charging-Status: indicator light 4,OFF,
IDE08426-MAS07225,Indicator lamps for power outlet B for battery charging-Status: indicator light 1,OFF,
IDE08426-MAS07226,Indicator lamps for power outlet B for battery charging-Status: indicator light 2,OFF,
IDE08426-MAS07227,Indicator lamps for power outlet B for battery charging-Status: indicator light 3,OFF,
IDE08426-MAS07228,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 1,100, %
IDE08426-MAS07229,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 2,100, %
IDE08426-MAS07230,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 3,100, %
IDE08426-MAS07231,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 1,2000, ms
IDE08426-MAS07232,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 2,2000, ms
IDE08426-MAS07233,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 3,2000, ms
IDE08426-MAS07582,Indicator lamps for power outlet B for battery charging-Intensity: activation 4,0, %
IDE08426-MAS07590,Indicator lamps for power outlet B for battery charging-Period duration: activation 4,0, ms
IDE08426-MAS13012,Indicator lamps for power outlet B for battery charging-Status: indicator light 4,OFF,
IDE08427-MAS07237,Statistics of power outlet A for battery charging-No. of connections,11,
IDE08427-MAS07238,Statistics of power outlet A for battery charging-No. of lockings,0,
IDE08428-MAS07237,Statistics of power outlet B for battery charging-No. of connections,0,
IDE08428-MAS07238,Statistics of power outlet B for battery charging-No. of lockings,0,
IDE08430,Cause of cancellation of charge procedure,not active,
IDE08431,Remaining time for charge procedure,325, min
IDE08432-MAS02158,Button for battery charging-Actuation condition,not activated,
IDE08432-MAS04737,Button for battery charging-Indicator lamp,On,
IDE08505-MAS07220,Power outlet for quick charging of HV battery-Status connect. recognition,present,
IDE08638-MAS04721,SOC limits: set by customer-Minimum charge level,1, %
IDE08638-MAS04722,SOC limits: set by customer-Maximum charge level,0, %
IDE08639,max. loading power,1000, W
IDE08640,Spec. mode: load mgmnt.,AC main charge,
IDE08649-IDE06971,Ready to charge-Operational readiness in H-V system,active,
IDE08649-MAS07214,Ready to charge-Status charge readiness: engine,ready for operation,
IDE08649-MAS07215,Ready to charge-Status charge readiness charge mngmt.,ready for operation,
IDE08657-MAS01424,Current at DC charg. stat.-max.value,0, A
IDE08657-MAS07236,Current at DC charg. stat.-Act.val.,0, A
IDE08658-MAS01424,Voltage at DC charg. stat.-max.value,0, V
IDE08658-MAS07236,Voltage at DC charg. stat.-Act.val.,0, V
IDE08659-MAS07237,Statistic of DC charger for battery charging-No. of connections,0,
IDE08659-MAS07238,Statistic of DC charger for battery charging-No. of lockings,0,
IDE08659-MAS07239,Statistic of DC charger for battery charging-No. of charging process.,0,
IDE08677-MAS07258,Load mode-Stat.: charge mode,AC main charge,
IDE08677-MAS07259,Load mode-Chg. type,Imm. charg.,
IDE08717,Status mains voltage,present,
IDE08718-MAS06699,Chademo version-Vehicle,0,
IDE08718-MAS07395,Chademo version-Chg. statn.,0,
IDE08719-IDE08720,Values from battery mgmt system-Current condition of battery mgmt. system,External Charging,
IDE08719-MAS01420,Values from battery mgmt system-Limit for charge current,N/A---,
IDE08719-MAS04059,Values from battery mgmt system-Battery temperature,20.0, °C
IDE08719-MAS07289,Values from battery mgmt system-A/C requirement,no request,
IDE08719-MAS07396,Values from battery mgmt system-Act. voltage HV battery,N/A---,
IDE08719-MAS07397,Values from battery mgmt system-Act. current HV battery,N/A---,
IDE08719-MAS07407,Values from battery mgmt system-Max. battery charging voltage,N/A---,
IDE08751-MAS02158,Load button-Actuation condition,not activated,
IDE08751-MAS04737,Load button-Indicator lamp,OFF,
IDE08751-MAS07596,Load button-Locating illum. charge button,OFF,
IDE08938,Chrgr cooling reqrmnt,Low cooling reqmnt.,
IDE08985,AC line current: actual val,9.4, A
IDE08986,AC line voltage: actual val,109, V
IDE09039,HV charger - current output voltage,351, V
IDE09057,HV battery charge state,36.0, %
IDE11570-ENG30068,Activation periods of charging cover locking-raw_value_in_develop_by_ODXauthor,00,
IDE11571-ENG30068,Voltage terminal 30 battery data module-raw_value_in_develop_by_ODXauthor,A4,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,44,
MAS06335-ENG30068,Voltage low voltage side DCDC - converter-raw_value_in_develop_by_ODXauthor,84,
MAS07392-MAS07393,Control signal DC charge-Control signal 1,00000000 ,
MAS07392-MAS07394,Control signal DC charge-Control signal 2,00000001 ,
MAS07396-ENG30068,Act. voltage HV battery-raw_value_in_develop_by_ODXauthor,05 8F,
MAS07407-ENG30068,Max. battery charging voltage-raw_value_in_develop_by_ODXauthor,01 90,
MAS07558,Spec. op. condition charge unit,AC main charge,
MAS07559,Act.. op. condition charge unit,AC main charge,
MAS07563,Function limitation charging due to temp. charge socket,not active,
MAS07564,Function limitation charging due to temp. charge unit,not active,
MAS12397-ENG30068,Number of lockings: charge cover A-raw_value_in_develop_by_ODXauthor,00 73,
ENG125865,AC_maximum_input_current_value,10.0, A
ENG125867,AC_network_frequency,60.0, Hz
ENG125873,charger_coolant_temperature,26, °C
ENG123145-ENG123175,Charging_Connector_Locking_Parameter-delocking_request_time_CAN,0, ms
ENG123145-ENG123173,Charging_Connector_Locking_Parameter-delocking_time_lag,0, ms
ENG123145-ENG123174,Charging_Connector_Locking_Parameter-locking_delay_time,0, ms
ENG123145-ENG123176,Charging_Connector_Locking_Parameter-locking_time_lag,0, ms
ENG123142,charging_process_request,AC_Charging_Request,
ENG123144,charging_status,Charging,
ENG125862,current_voltage_protection,not active,
ENG123148,ekk_air_condition_current,0.0, A
ENG125863,error_status_battery_charger,not active,
ENG126556,gate_driver_voltage_DCDC,15.9, V
ENG126555,gate_driver_voltage_PFC,15.8, V
ENG126544,high_voltage_activation_request,requested,
ENG123143,max_HV_DC_voltage_obc,395, V
ENG123146,permission_to_charge_lm,00000000 ,
ENG125870,power_efficiency,95.0, %
ENG125869,power_loss_battery_charger,40, W
ENG123147,ptc_heater_current,0.0, A
ENG07647,temperature_battery_charger_PFC_coil,34, °C
ENG125871,temperature_battery_charger_system_board,46, °C
ENG125872,temperature_DCDC_coil,31, °C
ENG125876,temperature_DCDC_powerline,36, °C
ENG125864,warning_status_battery_charger,no warning,
Elapsed Time: 00:07
   #35
Andy
Sector 7G
HC424490
CF - Lane Chge Asst 2 maps
;SW:3Q0-907-590-F   HW:3Q0-907-590 ---  Lane Chge Asst 2
;Component:MRR1Rear      H21 0610, Coding:04C002
;EV_RearRadarS2BoschVW48X,001007,EV_RearRadarS2BoschVW48X.rod
;Friday,08,December,2017,16:20:55:29905
;VCID: 3833ABAB83275AEA3EF-806C
Elapsed Time: 00:00
;Friday,08,December,2017,16:20:53:29905
IDE00018,Voltage terminal 15,12.90, V
IDE00019,Voltage terminal 30,Measured value not available,
IDE00020,Terminal 15 status,Measured value not available,
IDE00102,Control Module temperature,27, °C
IDE01352,Temperature unit,°C,
IDE01763,Dimming,0,
IDE09387,Dynamic angle offset lane change assist.,-0.13, °
ENG112308,ECU_Serial_Number,FF F3 2D 2D 2D 2D 2D 2D 20 20 20 20 20 32 42 6F,
Elapsed Time: 00:01
Andy
Sector 7G
HC424490
D7 - Light Ctrl Left 2 Maps
;SW:7PP-941-572-AC   HW:7PP-941-572-A ---  Light Ctrl Left 2
;Component:LED1L         H09 0008, Coding:
;EV_LEDModLeftMELCOAU736,001004,EV_LEDModLeftMELCOAU736_VW37.rod
;Friday,08,December,2017,16:21:03:29905
;VCID: 17714817EEF97592175-8042
Elapsed Time: 00:00
;SW:7PP-941-572-AC   HW:7PP-941-572-A ---  Light Ctrl Right 2
;Component:LED1R         H09 0008, Coding:
;EV_LEDModRightMELCOAU736,001004,EV_LEDModLeftMELCOAU736_VW37.rod
;Friday,08,December,2017,16:21:12:29905
Elapsed Time: 00:00
Andy
Sector 7G
HC424490
OBD Map
;33-OBD2
;Friday,08,December,2017,16:21:15:29905
03,Fuel system 1/2 status,Engine off,Engine off
04,Calculated load value,0.0 %,0.0 %
05,Engine coolant temperature,14 °C,14 °C
06,Short Term Trim - Bank 1,0.0 %
07,Long Term Trim - Bank 1,-0.8 %
0B,Intake Manifold Absolute Pressure,100 kPa abs
0C,Engine RPM,0 /min,0 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,0.0 Degrees
0F,Intake air temperature,15 °C
11,Throttle position sensor,17.3 %
12,Secondary Air Status,Atmosphere/off
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.455 V
1C,OBD Requirements Met,OBD + OBD II
1F,Time since engine start,0 s
21,Distance travelled with MIL on,0 km
2E,Commanded Evaporative Purge,0.0 %
2F,Fuel Level Input,98.0 %
30,Warm-ups since DTC cleared,6
31,Distance since DTC cleared,66 km
33,Barometric pressure,100 kPa abs
34,Bank 1 Sensor 1 Status,1.005 Lambda,-0.004 mA
3C,B1S1 Cat. Temp.,4.4 °C
42,Control module voltage,13.154 V,13.100 V
43,Absolute Load Value,0 %
49,Accelerator Pedal Position D,15 %,15 %
Even though my car was "running" I will do another one with the gasoline engine actually running.
Eric
HC800000
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
I'd be like, stay out of my car, NHTSA! :)
   #39
D-Dub
C?ID=272151
Wow almost 40 posts worth of info.
If new cars are going to have all this and more, might be time to think of a better way of exporting and managing/viewing uploaded data...
How awesome would it be if vcds could (by user choice of course) upload all of this data automatically to a member accessible and easily usable web database..
:popcorn:
   #40
Andy
Sector 7G
HC424490
;SW:5G0-907-080-E   HW:5G0-907-080-E ---  Electric Drive
;Component:LE Gen 3.3H15 1032, Coding:40020000000000000000
;EV_DMCM08530115G0907080E,001008,EV_DMCM08530115G0907080E.rod
;Friday,08,December,2017,16:15:11:29905
;VCID: 29157EEF488DF362B11-807C
Elapsed Time: 00:00
;Friday,08,December,2017,16:15:01:29905
IDE00018,Voltage terminal 15,1,
IDE00019,Voltage terminal 30,13.044, V
IDE00613,Phase current phase U,1.31, A
IDE00614,Phase current phase V,2.19, A
IDE00615,Phase current phase W,3.81, A
IDE00619,RPM of electric machine,0, /min
IDE00626,Temperature of electric machine,17.03, °C
IDE00628,Specified value of intermediate circuit voltage,0.00, V
IDE00635,Intermediate circuit current,0.00, A
IDE00637,Intermediate circuit voltage,355.59, V
IDE00643,Minimum torque of electric machine,-0.25, Nm
IDE00644,Maximum torque of electric machine,-0.19, Nm
IDE00645,Specified torque of electric machine,0.00, Nm
IDE00651,Specified RPM of electric machine,0, /min
IDE00796,Offset angle of rotor positions,275.488, °el
IDE00938,Calculated actual torque of electric machine,-0.31, Nm
IDE00952,Availability of high voltage,1,
IDE04222,Test voltage for insulation measurement for power electronics,500.00, V
IDE04223,Test voltage for insulation measurement for e-machine,500.00, V
IDE05246,Power electronics heat sink temperature,28.09, °C
IDE05248,E-machine speed: actual value,0, /min
IDE05249,Regulation due to excessive temperature,0,
IDE05250,Drive control condition,Standby,
IDE05250-ENG14691,Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE,2,
IDE05419,Intermediate circuit current maximum limit,288.94, A
IDE05420,Intermediate circuit current minimum threshold,-119.00, A
IDE05421,Torque: current value,-0.19, Nm
IDE05425,Output current of DCDC converter,19.75, A
IDE05426,Buck converter operation due to current limit being exceeded,0,
IDE05427,Boost converter operation due to current limit being exceeded,0,
IDE05428,Buck converter operation due to voltage limit being exceeded,0,
IDE05429,Boost converter operation due to voltage limit being exceeded,0,
IDE05578,DCDC converter intermediate circuit voltage,355.59, V
IDE06501,Adaptation of magnetic flow: status,0,
IDE06502,Offset angle adaptation: status,OfsAccurate_E,
IDE06502-ENG14694,Offset angle adaptation: status-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb St Ag Rtr Offs UBYTE,2,
IDE06805,Status of voltage freedom,2,
IDE09094,CAN signal: battery manag system: traction network current,1.75, A
IDE09095,CAN signal: battery management system: traction network voltage,355.50, V
IDE09096,CAN signal: battery management sys.:hi. voltage protect.:status,MaiClsd,
IDE09096-ENG14700,CAN signal: battery management sys.:hi. voltage protect.:status-Test_Program_Rbe Asw Cif Enum rbe Cmn Glb Hvb Cntct UBYTE,2,
IDE09097,Electric motor: electric rotor frequency,0.0, Hz
IDE09098,Electric motor: electric power,0, W
IDE09099,Electric motor: mechanical power,96, W
IDE09100,Electric motor: idle status,WithoutStatorCurrent,
IDE09100-ENG14698,Electric motor: idle status-Test_Program_Rbe Asw Invr MCT enum Frwhl UBYTE,0,
IDE09101,Electric motor: magnetic flux reference value,0.000000, Wb
IDE09102,Electric motor: RMS current,0.44, A
IDE09103,E-machine: stator temperature,17.03, °C
IDE09104,E-machine: stator temperature char. curve range,1,
IDE09105,Power electronics: intermediate circuit current,0.00, A
IDE09107,Power electronics: internal power supply 2,0.443, V
IDE09108,Power electronics: internal power supply IGBT,29.787, V
IDE09111,Power electronics: gate driver status,ShortCircuitBot,
IDE09111-ENG14696,Power electronics: gate driver status-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Gate Drv UBYTE,0,
IDE09113,Power electronics: IGBT module temp: phase U,27.88, °C
IDE09114,Power electronics: IGBT module temp: phase V,27.97, °C
IDE09115,Power electronics: IGBT module temp: phase W,27.70, °C
IDE09117,Position offset calibration: stay,0.00, s
IDE09118,Magnetic flow calibration: status,0,
IDE09119,Position offset calibration: diagnostic status,NotTested__E,
IDE09119-ENG14697,Position offset calibration: diagnostic status-Test_Program_Rbe Asw Invr ISC enum St Diag Al Rtr Ofs Clb UBYTE,0,
IDE09123,D/C-D/C converter: power section temp,27.88, °C
IDE09124,DC/DC converter: traction network current,-0.789, A
IDE09126,Vehicle switch-off time,136, min
IDE09127,Status: switch-off time,Abstellzeit_berechnet,
IDE09127-ENG14695,Status: switch-off time-Test_Program_Rbe Asw Cif Enum rbe Cmn Glb Dwn Ti UBYTE,1,
IDE09128,DC/DC converter: status,rbe_AswDcdc_BuckReq_e,
IDE09128-ENG14699,DC/DC converter: status-Test_Program_Rbe Asw Dcdc Enum rbe Cmn Glb Dcdc Mod Cust Des UBYTE,4,
IDE09129,DC/DC converter: output current term 30,19.75, A
IDE09130,DC/DC converter: regulated output current term 30,13.203, V
IDE09210,Phase current phase U unrestricted,2.00, A
IDE09211,Phase current phase V unrestricted,1.50, A
IDE09212,Phase current phase W unrestricted,2.44, A
MAS06713,Supply voltage Terminal 30 - internal,12.500, V
MAS09947,Condition interm. circuit discharge circuit,DchaNotActv,
MAS09947-ENG14701,Condition interm. circuit discharge circuit-Test_Program_Rbe Asw Invr SYM enum St Dcha UBYTE,0,
MAS12577,Rotor position sensor 2 sine offset,0.000, V
MAS12578,Rotor position sensor 2 Cosine offset,0.000, V
MAS12772,DC/DC changer: high voltage current restriction,14.00, A
MAS12773,DC/DC changer: spec. operating mode,1,
MAS12774,DC/DC changer: spec. output voltage terminal 30,13.199, V
MAS13360,Discharge current HV intermediate circuit power electronics,0.00, A
MAS13361,PCB temperature power electronics,46.86, °C
MAS13362,Calculated coolant temperature DCDC converter,27.52, °C
MAS13363,Redundant intermediate circuit voltage power electronics,355.59, V
MAS13431,Low-voltage fuse: current,1.055, A
MAS13432,Low-voltage fuse: voltage,13.014, V
MAS13802,Rotor position sensor 2: cosine amplitude,0.000, V
MAS13803,Rotor position sensor 2: sine amplitude,0.000, V
MAS13804,Rotor position sensor 2: exciter amplitude,8.826, V
ENG105721,Current_DC_Link_power,0, W
ENG105722,Current_in_d-direction,-0.13, A
ENG105723,Current_in_q-direction,-0.19, A
ENG105770,DCDC_derating_due_to_overtemperature,0,
ENG105797,Desired_current_in_d-direction,0.00, A
ENG105798,Desired_current_in_q-direction,-0.44, A
ENG105799,Desired_torque,0.00, Nm
ENG106053,Effective_value_stator_current,1.00, A
ENG106109,Electric_drive_cooling_activated,option_not_available,
ENG106109-ENG14693,Electric_drive_cooling_activated-Test_Program_Rbe Asw Cif Enum rbe Asw Cif Sttr Coolt Circ UBYTE,3,
ENG106482,Failure_emergency_shut_off,0,
ENG106483,Failure_free_wheeling,0,
ENG106484,Failure_inverter_limited_performance,0,
ENG106485,Failure_inverter_shut_off,0,
ENG106555,Fieldweakening_active,0,
ENG13207,HV-circuit_operation_mode,rbe_CddHvMcu_NormMod_e,
ENG13207-ENG14703,HV-circuit_operation_mode-Test_Program_Rbe Cdd Hv Mcu Enum rbe Cdd Hv Mcu St Mod UBYTE,0,
ENG13208,IGBT_temperature_characteristic_curve_state,1,
ENG13209,Internal_sum_error_itemization,0,
ENG13205,Internal_supply_voltage_15_inverter_IGBT,15.322, V
ENG107077,Inverter_state,0,
ENG26312,ISC t Dbc Invr Snsr Max,27.97, °C
ENG107397,Load_moment_auxiliaries,-5.13, Nm
ENG107584,Maximal_DC-Link_voltage,400.00, V
ENG107585,Maximal_torque_hybrid_controller,2047.94, Nm
ENG107589,Maximum_power_limit,95008, W
ENG107590,Maximum_torque_derating_reason,inactive,
ENG107590-ENG14692,Maximum_torque_derating_reason-Test_Program_Rbe Asw Invr TQL enum Der UBYTE,1,
ENG26321,MCT Temp Rtr,23.11, °C
ENG107604,Mechanical_angular_speed,0.00, rad/s
ENG107623,Minimal_torque_hybrid_controller,-2047.94, Nm
ENG107624,Minimum_DC-Link_voltage,250.00, V
ENG107625,Minimum_power_limit,-95008, W
ENG107626,Minimum_torque_derating_reason,inactive,
ENG107626-ENG14692,Minimum_torque_derating_reason-Test_Program_Rbe Asw Invr TQL enum Der UBYTE,1,
ENG107742,Necessary_generator_torque,-0.19, Nm
ENG13206,Operation_mode_DCDC_actual_state,rbe_AswDcdc_Buck_e,
ENG13206-ENG14702,Operation_mode_DCDC_actual_state-Test_Program_Rbe Com Dcdc Can Enum rbe Cmn Glb Dcdc Oper Mod UBYTE,1,
ENG13204,Periodic_time_gate_driver,100.00, µs
ENG26341,Rbe Asw Invr Isc t Lnk Cap,31.92, °C
ENG26343,Rec rbe Com Drv Can 10ms t Oil Gbx Smp,22, °C
ENG109097,Stator_frequency,0.0, Hz
ENG99035,Voltage terminal 30,13.043, V
Elapsed Time: 00:10
Here's a map of the same module with the battery depleted (range 0 miles, gas engine started shortly before pulling into the driveway:
;Monday,11,December,2017,18:39:20:29905
IDE00019,Voltage terminal 30,13.031, V
IDE00613,Phase current phase U,-1.44, A
IDE00614,Phase current phase V,-1.25, A
IDE00615,Phase current phase W,0.38, A
IDE00626,Temperature of electric machine,32.33, °C
IDE00637,Intermediate circuit voltage,343.81, V
IDE00643,Minimum torque of electric machine,0.50, Nm
IDE00644,Maximum torque of electric machine,0.50, Nm
IDE00938,Calculated actual torque of electric machine,0.50, Nm
IDE05246,Power electronics heat sink temperature,16.83, °C
IDE05419,Intermediate circuit current maximum limit,246.00, A
IDE05420,Intermediate circuit current minimum threshold,-120.44, A
IDE05421,Torque: current value,0.44, Nm
IDE05425,Output current of DCDC converter,28.75, A
IDE05578,DCDC converter intermediate circuit voltage,343.69, V
IDE09094,CAN signal: battery manag system: traction network current,-1.00, A
IDE09095,CAN signal: battery management system: traction network voltage,343.50, V
IDE09102,Electric motor: RMS current,0.75, A
IDE09103,E-machine: stator temperature,32.33, °C
IDE09107,Power electronics: internal power supply 2,0.451, V
IDE09108,Power electronics: internal power supply IGBT,29.795, V
IDE09113,Power electronics: IGBT module temp: phase U,16.56, °C
IDE09114,Power electronics: IGBT module temp: phase V,16.67, °C
IDE09115,Power electronics: IGBT module temp: phase W,16.45, °C
IDE09123,D/C-D/C converter: power section temp,16.78, °C
IDE09124,DC/DC converter: traction network current,-1.266, A
IDE09126,Vehicle switch-off time,0, min
IDE09129,DC/DC converter: output current term 30,32.25, A
IDE09210,Phase current phase U unrestricted,-1.44, A
IDE09211,Phase current phase V unrestricted,-3.31, A
IDE09212,Phase current phase W unrestricted,-1.69, A
MAS06713,Supply voltage Terminal 30 - internal,12.484, V
MAS13361,PCB temperature power electronics,41.19, °C
MAS13362,Calculated coolant temperature DCDC converter,16.28, °C
MAS13363,Redundant intermediate circuit voltage power electronics,344.00, V
MAS13431,Low-voltage fuse: current,1.031, A
MAS13432,Low-voltage fuse: voltage,13.000, V
MAS13804,Rotor position sensor 2: exciter amplitude,8.820, V
ENG105722,Current_in_d-direction,-0.50, A
ENG105723,Current_in_q-direction,0.75, A
ENG105798,Desired_current_in_q-direction,0.56, A
ENG106053,Effective_value_stator_current,0.75, A
ENG13205,Internal_supply_voltage_15_inverter_IGBT,15.326, V
ENG26312,ISC t Dbc Invr Snsr Max,16.69, °C
ENG107397,Load_moment_auxiliaries,-8.44, Nm
ENG26321,MCT Temp Rtr,35.31, °C
ENG107742,Necessary_generator_torque,0.44, Nm
ENG26341,Rbe Asw Invr Isc t Lnk Cap,30.56, °C
ENG26343,Rec rbe Com Drv Can 10ms t Oil Gbx Smp,37, °C
Elapsed Time: 00:10
