- Sep 15, 2014
- 46
- 23
- Zagreb Cro
- C?ID=116509
I use for a long time VCDS, and I see on this forum has a lot of interesting topics, and decided to spend a little time on it ...
Welcome!Hmmm, maybe not, I click on my profile again, and now it says junior member... ok new question, how long does it take to be verified after you submit the form?
You should be a verified VCDS User now. If you encounter problems posting, please email support@ross-tech.comHmmm, maybe not, I click on my profile again, and now it says junior member... ok new question, how long does it take to be verified after you submit the form?
VCDS Version: Release 12.12.3 (x64)
Data version: 20140822
Monday,15,September,2014,17:57:09:22859
Chassis Type: AJ (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 65 72 77
VIN: 3VWRL7AJ6AM118886
Part No SW: 03L 906 019 CL HW: 03L 906 022 TS
Component: R4 2,0L EDC G000SG 7966
Revision: 12H03--- Serial number:
Coding: 0050072
Shop #: WSC 78391 667 394982
VCID: 77D3050D06940FA6AA7-8022
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - MIL ON
Fault Status: 11100000
Mileage: 137023 km
Date: 2050.14.27
Time: 12:28:02
Voltage: 12.84 V
Lambda: -12.6 %
Lambda: 11.0 %
Bin. Bits: 00011110
Voltage: 3.800 V
001025 - EGR System
P0401 - 000 - Insufficient Flow - Intermittent - MIL ON
Fault Status: 10100000
Mileage: 137036 km
Date: 2050.14.27
Time: 16:31:08
RPM: 2139 /min
Speed: 84.0 km/h
Voltage: 14.14 V
Load: 95.7 %
Load: 100.0 %
Mass Air / Rev.: 490.0 mg/str
Mass Air / Rev.: 510.0 mg/str
Readiness: 1 2 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B400C49230002881302EC921F0042300000
Shop #: WSC 00066 000 00000
VCID: 78D10631CB8A00DEA3D-802D
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00148
ROD: EV_ClimaBasis_SE36.rod
VCID: 75CF0F05D4987DB6B8B-8020
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 0129
Revision: BI111001
Coding: 2D200B1E902F3EE4800800854000000401000086510085605C8020000000
VCID: 3753C50D8614CFA66A7-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 08021 21 0512
Coding: 009795
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM02HB3H
Coding: 0012340
VCID: 6EFD206979CE4E6E791-803B
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME4F1404010
Subsystem 3 - Serial number: 6342MSME4F422744E
Subsystem 4 - Serial number: 6351HSME1F624B42C
Subsystem 5 - Serial number: 6361HSME1F624B75J
Subsystem 6 - Serial number: 63727SME1F7F23317
Subsystem 7 - Serial number: 63827SME20112456P
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0000731
VCID: 76CD0809019E76AEB11-8023
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Part No SW: 5M0 920 970 G HW: 5M0 920 970 G
Component: KOMBI H05 0305
Coding: 271F00
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 3449F2019F6224BE4F5-8061
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 010310F2001884
Coding: E9807F07001612001002
VCID: 69F753754020A9562C3-803C
Part No SW: 1K5 919 965 D HW: 1K5 919 965 D
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1293324T4TQT05
Coding: 0000004
VCID: 3C59DA217F32ECFE875-8069
Component: IMMO H05 0305
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EAF5AC790D26224EA59-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667799465
VCID: 266D184951BE462EC11-8073
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000591049
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_DCU42BroseDriveSide.rod
VCID: 2773154D5EB45F26FA7-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004738448
Coding: 000490
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 3147FB15A8701196243-8064
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7K3068658
Coding: 0100040004
VCID: 61E74B557810E116F43-8034
Reset counter: 29
Mileage: 44889 km
Date: 2019.14.25
Time: 12:25:08
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
02903 - Hard Warning 2
Mileage: 118994 km
Date: 2043.14.02
Time: 07:06:35
Text: 3392415416
Pressure: 1.90 bar
Pressure: 2.40 bar
Temperature: -16.0°C
Text: 80
02801 - Hard Warning
Mileage: 134888 km
Date: 2050.14.02
Time: 09:50:37
Text: 3392415413
Pressure: 0.10 bar
Pressure: 2.40 bar
Temperature: 22.0°C
Text: A0
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial number: 00000005225072
Coding: 0013077
VCID: 3A55DC397506D2CE959-806F
End ---------------------------------------------------------------------
wrapping. Please bare with me as I learn... Im a Ross Tech Baby.
I do that, today i got mail from ross tech...and I steel can not post topics on forum!?Welcome prako !
If you fill out this form, you will get your userid promoted to Verified VCDS User and can post in the other sections.
Hold tight... most of the R-T folks are in Frankfurt at automechanika, and it's a manual process to promote your user id.I do that, today i got mail from ross tech...and I steel can not post topics on forum!?
Thanks for registering. You should now be a "Verified VCDS User" with all the rights and privileges that it entails.I do that, today i got mail from ross tech...and I steel can not post topics on forum!?
