B9 Video In Motion. Any progress?
TJEli
C?ID=219101
Has anyone figured out how to enable V.I.M. in the B9 4G cars yet?
-Eli
Zenerdiode
Newcastle, England
C?ID=24330
I don't have a solution for you; but I'm genuinely intrigued by why you would want it enabled?
murmeltier
Switzerland
C?ID=260972
Does somebody know if it's possible with OBDEleven?
hadez16
C?ID=289891
Audi MIB2 MY 2018 is completely not possible yet.
rlarsen
Copenhagen, Denmark
C?ID=78998
VCDS can not be used - unless someone do a change to the VCDS SW like it was done with the developer menu coding :)
TJEli
C?ID=219101
OBD11 can do it. I do not wish to buy or use OBD11.
-Eli
rlarsen
Copenhagen, Denmark
C?ID=78998
Agree - but I don’t think Ross Tech want to do this change to VCDS - sadly
TJEli
C?ID=219101
I can understand why Ross Tech would not want to implement this as an "easy to do" option. Has anyone been able to find out how to get the security code for module 5F? I purchased the factory service manual thinking it would be in there but its not. :(
-Eli
DJAlix
London, United Kingdom
C?ID=238277
-Eli
20103 and S12345. If you are still looking to activate VIM save yourself some time as its not possible via VCDS or via the MIB/MMI green menu.
TJEli
C?ID=219101
The channel is there. I cannot update the value. It gives me an "out of range" error. I assume this is a security code issue.
-Eli
DJAlix
C?ID=238277
-Eli
Whats the name / text label of the channel in question?
TJEli
C?ID=219101
Module 5F, channel 3B. Bottom of the list in my car.
-Eli
TJEli
C?ID=219101
Unfortunately this will not give you VIM.
Why not with the correct security code? This is the same parameter from years past that turns off the screen at anything above 0 KPH.
-Eli
rlarsen
Copenhagen, Denmark
C?ID=78998
-Eli
It is not coded in a channel in the newest models anymore.
DJAlix
C?ID=238277
-Eli
The new MIB units, especially MIB2, are very different to the MMI of old.
SpeedRacerAZ
C?ID=312337
Any luck with this one? I see there's a way to do it through a script that a few online companies are offering for a steep fee.
