^^^Thanks for the PM - I've only completed this tweak once on a local forum colleague's car - but this is how I remember it:
In the , enter the magic number () first then make the following changes:
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig - Set to
Active
IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI - Set to
Active
The "slider" bar on the in your video has 10 x different colors from which to select. These colors are basic RGB values and they are set by the Adaptation channels in the table below (you will find these in the ). If the channels below don't have the default RGB values on your car - you have to create your own colors for all 10 options (remember the German: Rotwert = Red, Gruenwert = Green, Blauwert = Blue).
To help with your selection of colors use something like
THIS (just click on a color on the webpage and the RGB numbers are returned (you need a decimal number in the range 0-255 for ALL the 30 x channels in my table below)
[B]Parent ID Child ID Adaptation Channel Name[/B]
IDE11714 ENG126825 Ambient light color list-Rotwert Farbe 1
IDE11714 ENG126826 Ambient light color list-Gruenwert Farbe 1
IDE11714 ENG126827 Ambient light color list-Blauwert Farbe 1
IDE11714 ENG126828 Ambient light color list-Rotwert Farbe 2
IDE11714 ENG126829 Ambient light color list-Gruenwert Farbe 2
IDE11714 ENG126830 Ambient light color list-Blauwert Farbe 2
IDE11714 ENG126831 Ambient light color list-Rotwert Farbe 3
IDE11714 ENG126832 Ambient light color list-Gruenwert Farbe 3
IDE11714 ENG126833 Ambient light color list-Blauwert Farbe 3
IDE11714 ENG133412 Ambient light color list-Rotwert Farbe 4
IDE11714 ENG133413 Ambient light color list-Gruenwert Farbe 4
IDE11714 ENG133414 Ambient light color list-Blauwert Farbe 4
IDE11714 ENG133415 Ambient light color list-Rotwert Farbe 5
IDE11714 ENG133416 Ambient light color list-Gruenwert Farbe 5
IDE11714 ENG133417 Ambient light color list-Blauwert Farbe 5
IDE11714 ENG133418 Ambient light color list-Rotwert Farbe 6
IDE11714 ENG133419 Ambient light color list-Gruenwert Farbe 6
IDE11714 ENG133420 Ambient light color list-Blauwert Farbe 6
IDE11714 ENG133421 Ambient light color list-Rotwert Farbe 7
IDE11714 ENG133422 Ambient light color list-Gruenwert Farbe 7
IDE11714 ENG133423 Ambient light color list-Blauwert Farbe 7
IDE11714 ENG133424 Ambient light color list-Rotwert Farbe 8
IDE11714 ENG133425 Ambient light color list-Gruenwert Farbe 8
IDE11714 ENG133426 Ambient light color list-Blauwert Farbe 8
IDE11714 ENG133427 Ambient light color list-Rotwert Farbe 9
IDE11714 ENG133428 Ambient light color list-Gruenwert Farbe 9
IDE11714 ENG133429 Ambient light color list-Blauwert Farbe 9
IDE11714 ENG133430 Ambient light color list-Rotwert Farbe 10
IDE11714 ENG133431 Ambient light color list-Gruenwert Farbe 10
IDE11714 ENG133432 Ambient light color list-Blauwert Farbe 10
Note: on the car on which I completed this tweak, the adaptation channel names were in English (as per the table), but I have a few s in my database that have the German name -
Ambientelicht Farbliste - not sure which will be in your .
After the changes above were completed, I recall that I re-set the unit (with the unit switched-on, press and keep holding down the ON/OFF knob until the turns-off and then turns-on again). Then select
Car - Settings - Background Lighting and switch from
Brightness to
Color Setting. This should bring-up the "slider" in your video - which should be populated with the RGB colors that you programmed into the table above. Of course, if you find any of the colors offensive - simply re-code the relevant RGB values!
