Finding Security Access Codes in Factory Repair Manuals
thedave42
C?ID=321841
Hello all, I'm new to the Ross-Tech forums. Just received my HEX-V2 interface and have been having a look around. I noticed many of the modules require a Security Access code. I know I can find some of those already discovered out there, but it says on Ross-Tech's website that "Valid Login codes can be found in the Factory Repair Manual for your car".
http://www.ross-tech.com/vcds/tour/securityaccess.php
I have a 2017 Audi S3 and I've downloaded the factory repair manuals from erWin, but I cannot find those codes anywhere in the manuals. I have them all as PDFs so I can search for the terms, but I haven't found them yet searching for things like "security", "code", "login". What should I be looking for in the manual so that I can find these codes?
FWIW here's an Auto-Scan from my car:
Thursday,16,November,2017,12:58:52:54079
VCDS Version: 17.8.0.1  HEX-V2 CB: 0.4407.4
VIN: WAUF1GFF2H1024900   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          55 5F 6C A5 A9 BB BC CF
VIN: WAUF1GFF2H1024900   Mileage: 9115km-5663miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 0A1D00122466010E3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
   ROD: EV_ECM20TFS0208V0906259K_AU37.rod
   VCID: 48C9A6C0B23EC8B7D3A-801C
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4939
   Revision: 06354004    Serial number: TFK01608301919
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 53F381AC7B787B6FB68-8006
   Part No SW: 8V0 907 379 B    HW: 8V0 907 379 B
   Component: ESC           H25 0610
   Revision: 00000000    Serial number: 62196000000078
   Coding: 31AA6B7D549B13AD899A0B644191698CD62AC891D0829676184150D482A812
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   ROD: EV_Brake1UDSContiMK100IPB_035_AU37.rod
   VCID: 43D3B1EC8B18EBEF068-8016
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0415639588
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B23C90CF3E8932F4E8-806E
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001039180
   Coding: 03000014010000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 40D9BEE09A0EF0F71BA-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 99880A4800PAG0MUFU03
   Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H34 0236
   Serial number: 02001624000706
   ROD: EV_BCMBOSCH_017_VW27.rod
   VCID: 7EA50018A07A4607296-802A
   Component: WWS371 160625  043 0585
   Serial number:         160706063013
   Coding: 0A47F7
   Serial number: 62220658
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Serial number: 27 06 2016  00001188
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000036269984
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0015O28400000
   Coding: 101F00
   Part No SW: 5QA 919 294     HW: 5QA 919 294
   Component: PDC 8 KanalH07 0031
   Serial number: 000308418616249
   Coding: 0470155811
   ASAM Dataset: EV_EPHVA18AU3700000 009027
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 094F63C4E9B471BF0C4-805C
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: B50087C219FFC42474988055000026
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       010816012
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide_002_AU37.rod
   Serial number: 003GCR0617M8
   Shop #: WSC 46101 001 1048576
   VCID: 47CBA5FCBF20C7CFDA0-8012
   Belt Pretensioner left:
   Serial number: 34230167A15091651290
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A15091651527
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001J2UD+
   Coding: 303334
   Subsystem 4 - Part No SW: -----------    HW: 480 001 009 16
   Serial number: 3570000000011A685D1H
   Subsystem 5 - Part No SW: -----------    HW: 480 001 009 16
   Serial number: 3580000000080A685D1O
   Subsystem 6 - Part No SW: -----------    HW: 480 401 409 16
   Serial number: 3510001BB225A8C48535
   Subsystem 7 - Part No SW: -----------    HW: 480 401 409 16
   Serial number: 3520001B5225A8C462F7
   Subsystem 8 - Part No SW: -----------    HW: 480 400 408 16
   Serial number: 3550002A72095062A2F/
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 408 16
   Serial number: 3560002A52095064E29$
   Part No SW: 8V0 953 521 KT    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 27071604400332
   Coding: E818
   VCID: 167538B8A80AAE47916-8042
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 890     HW: 8V0 920 890
   Component: FBenUSA       H13 0045
   Coding: 08CD18537F98CF050281E8001800000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 7AAD0C08BC526A2715E-802E
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 12091610520857
   Coding: 030100043F085A005B00827CB80B00000001010000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CA10A10B6665417072-8028
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20160909204358 22280
   Serial number: 75410803001609081421
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7755
   Serial number: HA1-00012.08.16
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 45D7AFF4852CD5DF28C-8010
   Revision: 00000000    Serial number: 16000154592001
   Coding: 5D00000000000000
   VCID: 3431E230DEB65C578F2-8060
   Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0410
   Revision: --------
   Coding: 04C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   VCID: 392FD304F9D4A13F5C4-806C
   Serial number: 280716EGR2466A
   Coding: 005D1B205C00048000000003
   Coding: 9107
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 3A2DCC08FCD2AA2755E-806E
   Part No SW: 81A 035 466     HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0100
   Revision: 00000001    Serial number: AUZ8ZAGHX0092E4
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 629D546834C282E72DE-8036
   Serial number: 190716EGI13134
   Coding: 005D13205E00048000000003
   VCID: 42DDB4E89402E2E70DE-8016
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0EE2021123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E25C018E0FA8607696-806A
   Part No SW: 8V1 035 880     HW: 8V1 035 880
   Component: MU-P-LNS-US   052 0694
   Serial number: A702H0G7514053
   Coding: 017351020000000011220002041A00102F0027E5017001047E
   VCID: 77AB153C8F40774F6A0-8022
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY207MJS
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL119071600010617
   Compact Disc Database:
   Component: Gracenote2---  --- 3009
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 3
                    Mileage: 7334 km
                    Date: 2017.08.01
                    Time: 16:05:36
                    Voltage terminal 30: 14.1 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Coding: 0273010102002001400040
   Serial number: 29081612K20568
   Coding: 0403070100000201012223468048490080000E200020
   ROD: EV_MFKBoschMQBB_VW36.rod
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Serial number: 160825200167
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Revision: J388
   Coding: 000C13204000048000000002
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   Serial number: 020916DHV10819
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 3Q0 907 590 D    HW: 3Q0 907 590
   Revision: --------
   Coding: 04C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
   VCID: 3635D838C8CA4E47B16-8062
End----(Elapsed Time: 02:23, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
The suggestion that those are in factory repair manuals applies to older cars. For the newer cars, all those goodies are hidden away in the code and data for the factory scan tool.
Is there something specific you're trying to accomplish on this car that you believe requires a security access code?
Dave: if I can add to Uwe's sage advice, You will find reference to SA s on the web where the VCDS community is aware of these codes. I don't know how new SA s are found (they are as rare as rocking-horse sh#t) -I suspect that some are discovered using tools like VCP (less so these days), others might be disclosed by VAG boffins and divine revelation might also be involved!
In any event, your s3 (very nice! my bucket-list car) is fortunate to be built on a MQB platform. It therefore shares many features with other MQB platform vehicles - like my more pedestrian Golf mk7. This includes SA s.
In my preambles across the web, I've thieved many SA s and I've created a a central repository (suppository?) for these MQB codes HERE. Try these, but be aware that the control modules in your s3 (very nice! my bucket-list car) get very cranky if you input a wrong SA. In these instances, the modules spit-the-dummy and they refuse to accept a new SA for a period of time that is measured with the ignition turned-on!
PS: As a quid-pro-quo for access to my post, you are automatically obligated to contribute to the list if you are fortunate enough to find a new SA. Hope you take this responsibility seriously !!;)
thedave42
C?ID=321841
Thank you both for the info.
I was looking for the Security Access code for the 02-Auto Trans module to see if there was a way to turn on the gear display while the car was in drive, and I will definitely contribute to that great list if I find it (thanks for posting that)! The info I have found so far indicates that's the module I need access to, but if that's not the case I'd be happy for a nudge in the right direction.
Dave: I note that the code-string on your hex02 module is the venerable hex0014!! This is exactly the code-string on my hex02 module that does show the gear number on the MFD.
I'm aware that there is a gear number display tweak for newer hex02 modules with longer code-strings (i.e. hex010200000C000000000000000000000000000000 & hex00348), but AFAIK the fix for older modules lies in a firware change - alas something that is beyond the reach of even the brilliant HEX-V2!!
thedave42
C?ID=321841
Thanks, that's very helpful to know. I was curious about the much shorter code string, and that was part of why I was looking for the Security Access code. I didn't know if that was all it would let me see without security access. I had seen some information on how to do it through the 02 module for another model and wanted to poke around to see if I had the same setting. Sounds like I don't! :-)
