Hi ll need help with vales and what to look for with starting problem
paulmaca
HC826742 (Improbable)
Have audi a4 avant 1.9tdi 130 on an 2002 plate which runs great and problem is starting .It is struggling to start hot and cold ,disconnecting coolant sensor because was originally a cold start problem but no difference and original audi replacement sensor (should fan come on when dissconected even when cold,seems wrong) Changed egr audi part because past its time ,changed thermostat and fitted new MAF original part but still no change to values, have added some values and would be gratefully for any input ie why would air pressure be so low and maf values way out, what to start checking first with multi metre or vcds also attached some engine values, also don't seem to get dash warning when maf or sensor disconnected but maf will give limp mode when disconected .Also tried checking for vacum leak using butane gas around egr fitting and air intake hoses to see if change in idle but nothing
18:41:13
250.0 mg/str MAF (specified) 230-310
475.3 mg/str MAF (actual) 210-350
0.0°KW Synchro. angle -3..+3°Ck.
1.0 Start synchro.
62.1°C Fuel Temp ~Amb.Temp.*C
0.0 % Fuel cooling state On:100%-Off:0%
36.0°C Intake Air Temp ~Amb.Temp.*C
27.7 mg/str IQ via MAF 47-60
465.5 mg/str MAF 900-1250
1041.3 Intake air press. 2100-2600
1041.3 Actual intake press. 2100-2600
19.9 % D.cycle MAP 35-80%
Please post an Auto-Scan people can see what this car is made of. "Plate" info is meaningless.
paulmaca
Thams Uwe
Saturday,06,September,2014,11:52:17:10405
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAUZZZ8E22A263750   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8E22A263750   Mileage: 258590km/160680miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 JL
   Component: 1,9l R4 EDC 0000SG  1519
   Coding: 00003
   Shop #: WSC 63351
   VCID: 6ADBDCDE16574C4E253-4B00
   WAUZZZ8E22A263750     AUZ6Z0B0014572    ELECTRIC                      ENGINE MOUNTING FRONT
17994 - Engine Mount Solenoid Valves (N144/N145)
            P1586 - 35-10 - Short to Plus - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      1726
   Coding: 04255
   Shop #: WSC 06435
   VCID: 2643E8EEC2CFA82EC1B-5140
   Part No: 8E0 820 043 BJ
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6ADBDCDE16574C4E253-5106
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00001
   Shop #: WSC 63351
   VCID: 346702A60413CABE4FF-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655
   Component: Airbag 8.4E         5001
   Coding: 0010602
   Shop #: WSC 63351 000 00000
   VCID: F4E742A694930ABE0FF-5140
   Part No: 8E0 953 549 F
   Component: Lenksáulenmodul     0308
   Coding: 00012
   Shop #: WSC 63351
   VCID: 366338AE126FD8AE71B-4B00
No Faults Found
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 FX
   Component: KOMBI+WEGFAHRS. RB4 D28
   Coding: 01400
   Shop #: WSC 01545
   VCID: 8407126694333A3E3FF-5140
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   VCID: EBD559DA99ADD546DE5-515E
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 AH
   Component: Komfortgerát T1B    0619
   Coding: 07115
   Shop #: WSC 63351
   VCID: 77FDF5AA55E5E1A6AAD-4AE8
   Subsystem 1 - Part No: 8E2959802B
   Component: Tõrsteuer.FS BRM 0002
   Subsystem 2 - Part No: 8E2959801B
   Component: Tõrsteuer.BF BRM 0002
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0002
No Faults Found
   Part No: 4B0 035 186 S
   Component: concert II  GRO    0001
   Coding: 02001
   Shop #: WSC 02334
   VCID: 306F0EB6F00BF69E2B7-4B00
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum.
If you look at the Autoscan in Uwe's link its in in between code tags as it takes up less room. [CODE] Full AutoScan [/CODE]
Also there is a new version out. Release 12.12.3
TDI28
Stoke on Trent. UK
C?ID=14643
Check the engine mount and replace if u/s this has a big input on start quantity values.
paulmaca
Mind if i ask how hydro mounting effects starting quality values thanks
I was sort of wondering that myself. :confused:
paulmaca
Thanks Kiethuk will do new scan with update when have some time and post results like Uwe's link
paulmaca
67 69 75 76 77
VIN: WAUZZZ8E22A263750 Mileage: 258990km/160928miles
01 engine
18080 - Coolant Fan Control 1 P1672 - 35-10 - Open or Short to Ground - Intermittent
09: Cent. Elect.
52-10 - Supply Voltage Too High - Intermittent
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent 9
coolant sensor was changed with original part in morning after lyng all night sensor was reading 18.9c in vcds but in car was 9.8c (gives correct temp when warm ie 90c but should disconnecting make starting easier also what voltage should sensor be getting and how to check with multi metre and would this effect air pressure reading regards Paul
paulmaca
Well thanks for help guys
paulmaca
Td128
Hi you might have been on the correct path . Problem was damaged fuel hose to filter and vibration from faulty mounting wouldn't help matters so thanks for input ;-)
