U1121 Missing Message -- Yes but from what?
jeroenveer
C?ID=299782
I am working on a Haldex control module on the bench.
When i do a read out i get fault codes but they all give the same message U1121 00 [009] - Missing Message.
It is not showing what the message its missing like the older modules it would say missing Message from ECU or ABS etc.
is there any way to get some more information from this i tried to look for the number in front of the fault ( 16653, 16655 ) but i can't find any links on those.
Wednesday,15,November,2017,17:45:25:06109
VCDS Version: 17.10.0.2 (x64)  HEX-NET CB: 0.4407.4
Data version: 20171026 DS283.3
                Address 22: AWD       Labels: 0CQ-907-554.clb
Control Module Part Number: 0CQ 907 554 C    HW: 0CQ 525 130
  Component and/or Version: Haldex4Motion H52 7753
           Software Coding: 0101
            Work Shop Code: WSC 51344 001 104857
              ASAM Dataset: EV_AllWheelContrHA1VW37X 002015 ()
                      VCID: C5C205AC5CB6BB024FF-8090
10 Faults Found:
16653 - Databus
16655 - Databus
17468 - Databus
17495 - Databus
17471 - Databus
17469 - Databus
17470 - Databus
16657 - Databus
17474 - Databus
16727 - Databus
NostraJackAss
Dude missing messages for controllers due to talking on bench..........RTFB WD and install termination or pull up resistor's or install needed modules on bench while observing 125> block data.
jeroenveer
C?ID=299782
Yes i know its missing the other modules, i am going to simulate those modules but since the fault codes are all the same i don;t know which module simulation is giving problems.
measuring block are not available grayed out, i can open adv meas values but it does not have the blocks that tell if a module is found.
jeroenveer
C?ID=299782
WD won't help with this it's in the CANBUS communication.
Can't find the codes from the readouts in any books and not sure if they are fault codes like the P codes
jeroenveer
C?ID=299782
I have a CAN analyzer and know how to simulate CAN ecu's that's not the problem.
The question was about the fault codes i get with VCDS what they mean.
I have 10 VCDS fault codes but all have the same description missing message that i understand. but what i would like to know if there is a way to know what message it is missing.
like the older modules it would give:
NostraJackAss
Already answered and if you have a good CAN analyzer it will tell you what you ask.
What other modules from this car do you have on your test bench?
You have 10 of these faults. I would guess it's one for each of the modules that this Haldex expects to receive data from. Engine, Trans, ABS, Instruments, etc, etc.
Right, that's because those are arbitrarily assigned by the control module manufacturer and get translated to something meaningful (in this case U1121) based on the ASAM data.
Simulate the modules? Where are you getting the specs for the messages that the other modules broadcast?
Right, since this module uses UDS, it does not support the old-school Measuring Blocks. I've had a look at what's available in Advances Measuring Values for this module and don't see anything that looks to be an equivalent of the stuff older modules traditionally had in 125-128.
golfi_vend
Tartu, Estonia
C?ID=195131
I know VCP and ODIS is able to tell which module. Why can't this be implented in vcds,?
jeroenveer
C?ID=299782
Thank you for the reply Uwe makes things clearer now.
right now it's just this single module on the test bench.
Yes it will be multiple modules like ECU ABS etc.
I have CAN matrix documentation for all the messages so i know all the details of the messages, that combined with a trace from a car enables me to simulate the module like the ECU and ABS.
It would make it easier to know what module i am not simulating correctly if VCDS log tells me from which module the missing or implausible message is.
Have to do more reading on UDS haven't done much with it yet.
Is it possible that the Advances Measuring Values that are available in VCDS going to be expanded in updates?
That's a very good question! Unfortunately, I don't have enough familiarity with the intricacies of the source data to be able to give you a meaningful answer.
I certainly won't say that it's impossible. But it all depends on what's available in the source data. Almost everything in a UDS module is "driven" by the data available for that module.
16653 - Databus
This one should be for the steering angle sensor.
Still looking for the rest.
Here ya go:
16653 - Databus
Lenkwinkelsensor -TO -- LWL_01
16655 - Databus
Bremsensteuergerät - TO -- ESP_02
17468 - Databus
Bremsensteuergerät - TO -- ESP_05
17495 - Databus
Bremsensteuergerät - TO -- ESP_07
17471 - Databus
Bremsensteuergerät - TO -- ESP_14
17469 - Databus
Bremsensteuergerät - TO -- ESP_19
17470 - Databus
Bremsensteuergerät - TO -- ESP_21
16657 - Databus
Motorsteuergerät - TO -- Mot_12
17474 - Databus
Motorsteuergerät - TO -- Mot_14
16727 - Databus
Motorsteuergerät - TO -- Mot_20
Hat tip to Yanping for finding these, and yes, we are looking at putting this data in VCDS in a future version.
jeroenveer
C?ID=299782
Thank you Uwe for looking into it!
very curious how you found it!?
currently trying the simulation still no luck with any off the fault.
jeroenveer
C?ID=299782
you posted just before i wrote my message.
awesome very big thanks to both of you!
jeroenveer
C?ID=299782
VCDS only shows max of 10 fault codes is this correct?
Can confirm the codes below:
16653 - Databus
16655 - Databus
17468 - Databus
17495 - Databus
Managed to clear the above with simulation and some new faults appear:
17501 - Databus
17502 - Databus
17472 - Databus
17473 - Databus
Eric
HC800000
Incorrect.
Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 070 F    HW: 06K 907 425
   Component: Simos12.2     H09 6865
   Revision: --H09---    Serial number: 00000000000000
   Coding: 001A0012242400170000
   Shop #: WSC 00066 790 00012
   ASAM Dataset: EV_ECM18TFS02006K906070F 001010
   ROD: EV_ECM18TFS02006K906070F.rod
   VCID: 2D07F73BFD945999033F-8078
49 Faults Found:
19795 - EVAP System Leak Detection Pump Heater Control Circuit
          P240A 00 [035] - Open Circuit
19798 - Control Circuit for EVAP Vent Control
          P0447 00 [035] - Open Circuit
19791 - EVAP Leak Detection Pump Control Circuit
          P2400 00 [035] - Malfunction
14964 - Coolant Fan Control Circuit 1
          P0480 00 [035] - Electrical Malfunction
23096 - Intake Air Temp. Sensor (G42)
          P0113 00 [035] - Signal too High
15313 - Engine Coolant Temp. Sensor (G62)
          P0118 00 [035] - Signal too High
16837 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
          P2185 00 [035] - Signal too High
21352 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
          P2432 00 [039] - Short to Ground
                    Mileage: 48447 km
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: -39 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 11.992 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 0 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.065 V
                    FAC_TPS_1_SAE: 0.000000 %
                    FUP_H_SAE: 28000.0 kPa
15219 - Accelerator Position Sensor (G79)
          P2122 00 [167] - Signal too Low
                    Mileage: 48447 km
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 255 kPa
15221 - Accelerator Position Sensor 2 (G185)
          P2127 00 [167] - Signal too Low
                    Mileage: 48447 km
                    T_AST_SAE: 0 s
17791 - Coolant Pump Control Circuit
          P2600 00 [035] - Open
23176 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [035] - Malfunction
14995 - Fuel Pump Control Module
          P025A 00 [035] - Electrical Fault
15034 - Fuel Pressure Sensor (G247)
          P0190 00 [035] - Circuit Malfunction
15376 - Fuel Pressure Regulator Valve (N276)
          P2294 00 [167] - Open Circuit
                    Mileage: 48447 km
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 0 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.061 V
15211 - Oile Pressure Regulating Valve
          P164E 00 [035] - Electrical Malfunction
15289 - Output for Starter Relay
          P0615 00 [035] - Open Circuit
15293 - Control Circuit for Starter Relay 2
          P3049 00 [035] - Open Circuit
14923 - Crash Shut-Down Activated
          P1609 00 [168] - -
                    Mileage: 48446 km
                    Date: 2024.14.11
                    Time: 23:15:26
14969 - Radiator Fan (V7)
          P1950 00 [096] - Movement Restricted / Jammed
15131 - Cylinder 3
          P0303 00 [096] - Misfire Detected
15128 - Cylinder 2
          P0302 00 [096] - Misfire Detected
15137 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
15187 - Park/Neutral Switch Input Circuit
          P0850 00 [035] - Open or Short to Plus
15197 - Intake Manifold Flap Position Sensor (Bank 1)
          P2014 00 [039] - Electrical Malfunction
                    Mileage: 48447 km
                    Voltage terminal 30: 12.031 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 0 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 3.013 V
19802 - EVAP System
          P0457 00 [096] - Leak Detected  (Check Fuel Cap!)
17753 - Implausible Data Received from HVAC Control Module (J301)
          U0424 00 [035] - -
14875 - No Communications with Airbag Control Module
          U0151 00 [035] - -
16499 - Steering Column Control Module
          U0212 00 [035] - No Communications
16790 - Implausible Data Received from Transmission Control Module
          U0402 00 [035] - -
16791 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [035] - -
16795 - Implausible Data Received from Transmission Control Module
          U0402 00 [035] - -
14898 - No Communications with Steering Angle Sender (G85)
          U0126 00 [035] - -
14906 - No Communication with ABS Brake Control Module
          U0121 00 [035] - -
16990 - Body Control Module (Central Electric)
          U0140 00 [035] - No Communications
15015 - Turbocharger Bypass Valve Control Circuit
          P0033 00 [035] - Malfunction / Open Circuit
16469 - Throttle Actuator Control Circuit
          P2100 00 [167] - Open Circuit
                    Mileage: 48447 km
                    T_AST_SAE: 0 s
17758 - Implausible Data Received from Transmission Control Module
          U0402 00 [035] - -
15113 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [035] - Malfunction / Open Circuit
15116 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
          P0030 00 [035] - Malfunction / Open Circuit
15120 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0108 00 [035] - Signal too High
15212 - Manifold Pressure / Boost Sensor (G31)
          P0238 00 [035] - Signal too High
15270 - Camshaft Timing Adj. Bank1 (N205)
          P1528 00 [035] - Open Circuit
17759 - Implausible Data Received from Transmission Control Module
          U0402 00 [035] - -
24558 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [035] - -
16807 - Implausible Data Received from Transmission Control Module
          U0402 00 [035] - -
15423 - Turbocharger Boost Control Position Sensor Circuit
          P2565 00 [167] - Signal too High
                    Mileage: 48447 km
                    Charge air pressure control valve uncond voltage sensor: 4.9902 V
                    Charge air pressure control valve voltage: position closed: 3.6621 V
                    Charge air pressure control valve activation pulse duty factor: 0.00 %
                    Charge air pressure control valve position: actual value: 0.00 %
                    Charge air pressure control valve position: target value: 0.00 %
15338 - Throttle Position Sensor (G69)
          P0122 00 [167] - Signal too Low
                    Mileage: 48447 km
                    T_AST_SAE: 0 s
15340 - Angle Sensor 2 for Throttle (G188)
          P0222 00 [167] - Signal Too Low
                    Mileage: 48447 km
                    T_AST_SAE: 0 s
. Maybe the limitation is in the haldex module?
jeroenveer
C?ID=299782
Yes then the modules has memory for only 10
