Audi S4; Misfire, Cylinder disabling
Dukedesmo
C?ID=288946
2014 Audi S4 Avant, driving normally then suddenly develops a misfire and loss of power, EPC light comes on. Fortunately just a few miles out so 'limped' home.
Ran auto scan and got the following;
Tuesday,14,November,2017,15:06:35:24986
VCDS Version: 17.8.0.1 (x64)
VIN: WAUZZZ8K7EA150192   License Plate:
Mileage: 36420km-22630mi   Repair Order: misfire
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 30 36 42 44 46 47 52 53 56 5F
          62 6D 72 A9
VIN: WAUZZZ8K7EA150192   Mileage: 36420km-22630miles
Address 01: Engine (J623-CGWC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 D    HW: 4H0 907 551
   Component: 3.0l V6 TFSIX07 0004
   Revision: --X07---
   Coding: 12250034052701020800
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551D 001004
   ROD: EV_ECM30TFS0218K5907551D.rod
   VCID: 377CA0AB8E2C1EFE7B-8062
6354 - Cylinder 5
          P0305 00 [101] - Misfire Detected
                    Mileage: 36418 km
                    Date: 2017.11.14
                    Time: 14:53:26
                    Engine speed: 4950.00 /min
                    Normed load value: 91.0 %
                    Vehicle speed: 109 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 14.218 V
                    Engine speed: actual: 4928 /min
                    MAF_ENVD: 1024.04703 mg/stroke
                    Coolant temperature (unfiltered): 95.25 °C
                    Engine: operating status: PL
                    T_AST_ENVD: 642.50 s
                    Vehicle speed: actual: 109 km/h
7948 - Cylinder Disabling
          P130A 00 [101] - -
                    Mileage: 36418 km
                    Date: 2017.11.14
                    Time: 14:53:26
                    Engine speed: 5008.00 /min
                    Normed load value: 74.5 %
                    Vehicle speed: 111 km/h
                    Voltage terminal 30: 14.319 V
                    Engine speed: actual: 5088 /min
                    MAF_ENVD: 1029.49409 mg/stroke
                    Vehicle speed: actual: 111 km/h
   Part No SW: 8K5 927 156 B    HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H03 0003
   Revision: --H03---
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 387EA3978332118672-806C
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 291DCC01
   Shop #: WSC 06335 000 00000
   VCID: 09181653A058D80EDD-805C
   Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
   Component: BCM2 2.0      H14 0650
   Coding: 01B24040000000000000
   VCID: 7EF2758FE996EFB6F8-802A
   Subsystem 1 - Part No SW: 8K0 959 754 BH    HW: 8K0 959 754 BH
   Serial number: 0514000046830011
   Serial number: 0214000068278002
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01100420140302
   Coding: 6624028000
   VCID: 78FE6397CBB2D186B2-802C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000789946701
   Coding: 260000108034AFC00081404300001D0D0F1D470A27090201000008004400030100000024000000
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 010414  H06 0080
   Serial number: SWF14044015610
   Coding: 00FD11
   Serial number: 22487512
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000104144832
   Serial number: FA780227000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC0WUTP
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 60782 001 1048576
   VCID: 489ED357F3D2610602-801C
   Serial number: 6334MSME443A333AD
   Serial number: 6344MSME443C6E75T
   Serial number: 6352QSME1E400648E
   Serial number: 6362QSME1A401B6EP
   Serial number: 63732SME40404A66X
   Serial number: 63832SME4F400F689
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NDE001IC
   Coding: 000037
   VCID: 489ED357FBD2610602-801C
   Part No SW: 8K0 920 982 T    HW: 8K0 920 982 T
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZAE62M34F
   Coding: 33A7110003012600010000
   VCID: 4580DA63CCC07C6EF9-8010
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y143310158
   Coding: 80CF07FF00
   VCID: 4A9AE95FE5DE931614-801E
   Serial number: 9802233103
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 14099003849011200410
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000084090
   Coding: 01010101000000000001000102
   VCID: 2D5082C37470A42E11-8078
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000097259421
   Coding: 01781300000000000000
   VCID: 3B74BC9BBA043A9E9F-806E
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000098884238
   Coding: 011C02205E21410001
   VCID: 4FACF84B1EBCB63E43-801A
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0003457337
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3560AAA39420ECEE69-8060
   Revision: 00002001    Serial number: 0332027708
   Coding: 013B0622A0B938948330023680000047
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS151  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
   Revision: 00005001    Serial number: 94813028507104
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000098720192
   VCID: 4E92E54F19B6BF3648-801A
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 20000000431915
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3A7AB99FBD3E039684-806E
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109D20E7915856
   Coding: 010103010000000001
   VCID: 285E73D75B928106E2-807C
   Part No SW: 8R2 035 666 E    HW: 8R2 035 666 C
   Component: H-BN-EU       H47 0793
   Revision: --------    Serial number: 206DZ0E7560780
   Coding: 110101010206A1ED41808B5E00000403E40100020000000000
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Component: DU7 High  H42 0104
   Serial number: A130DI0E3000809
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001824649
   Component: CD-Database  5571
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000098922402
   Coding: 010C02204021210001
   VCID: 4682DD6FF1C67776F0-8012
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E72B58FA9162FB6B8-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
   Serial number: 8K9827852C
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000098919842
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 140301200807
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72EA51BFA5CEBBD68C-8026
End-------------------------(Elapsed Time: 04:09)--------------------------
Not had any previous problem, so I reset all DTCs and it is all OK again. went for a test drive and everything seems fine.
So, anyone got any ideas - spark plug, coil pack? also when looking at the engine from the front, which is cylinder 5?
Thanks in advance for any help.
Gone But Not Forgotten
Dukedesmo
C?ID=288946
Thanks for the reply, can you elaborate what the firmware update is?
Dukedesmo
C?ID=288946
OK, might be a bit above what I'm trying to do here. It has been OK for 3 years so not sure a firmware update is going to make any difference.
I'm thinking along the lines of a possible coil or sparkplug fault although it seems OK now it must have detected something? Just a bit worrying that it shut down the cylinder - don't know if it would have restarted with a simple off/on ignition as I reset the DTCs first - I'm not sure I'd want to drive it any distance with a cylinder shut down?
Dukedesmo
C?ID=288946
Following up on this; I had the same fault again about a week later under exactly the same conditions, only this time it also reported "16903 - Vapor Bubble Formation in Low-Pressure Fuel Circuit" along with the cylinder 5 misfire and consequent cylinder shutdown? Don't know this is related to the misfire? (consequence, cause etc.) but again it was OK after a restart.
Not wanting to get too deep into investigations in a cold garage, I had already bought a new coil so fitted this to cylinder 5 that day and it has been fine since.
On the advice of another member I also logged misfires on all cylinders from engine start to engine stop on a run with plenty of hard acceleration and whilst there were a few randomly distributed recorded misfires, there was nothing serious enough to shut anything down (how many are too many?). Now in hindsight I should have done this before swapping the coil, or even swapped the coil to another cylinder? But I didn't and (for now at least) it's running fine so I'm not planning to swap it back.
I also pulled out the spark plug whilst there and it looked fine, maybe I should change them but as it's running OK I'll wait, at least, until the next service although the schedule doesn't call for plug replacement for a good few miles anyway? and I'll enquire about the Firmware update the next time I'm at the dealer.
Hopefully any carbon buildup issues are a good few thousand miles away yet...
Eric
HC800000
Mostly out of curiosity:
   Revision: --X07---
Is the engine chipped?
Dukedesmo
C?ID=288946
Yes, stage 1 Revo map, switchable between stock and performance modes.
