A4 B9 ALLROAD - SUNROOF CALIBRATION / BASIC SETTINGS
Klaus Ludwig
C?ID=227092
I seem to have lost the calibration / basic settings for my sunroof and sunroof blind and would be grateful if anyone could advise how to get the remaining two Sunroof controller system faults cleared.
When the issue originally occurred, there were 3 Sunroof controller faults.
The Sunroof coding changed for some reason that I am uncertain around the time I was doing an Autoscan with Debug set to 2. The Sunroof controller coding changed from 508000049202 to 508000000000.
Immediately after this change, the sunroof and sunroof blind did not work properly – only moving part of normal travel. I returned the Sunroof controller coding to original and the sunroof and sunroof blind now operate normally, however I still get two faults on the Sunroof controller indicating “Missing Calibration / Basic Setting” for both the sunroof and sunroof blind.
AUTOSCAN BEFORE FAULT OCURRED
Saturday,28,October,2017,16:30:03:27553
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN: WAUZZZF47HA152503   License Plate:
Mileage: 6142km-3816mi   Repair Order:
Chassis Type: F4-AU49 (4M2)
Scan: 01 02 03 08 09 13 15 16 17 19 22 29 2B 39 42 44 46 47 52 5F
          69 6C 6D 74 81 8B A5 BB BC CA D6 D7
VIN: WAUZZZF47HA152503   Mileage: 6142km-3816miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYRB)       Labels: None
   Part No SW: 8W0 906 259 D    HW: 06L 907 425
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 326500322376050B34180000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0208W0906259D 001004
   ROD: EV_ECM20TFS0208W0906259.rod
   VCID: 42DE43B2E4096B070DE-8016
Readiness: 1010 0001
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 155 G    HW: 0CJ 927 156
   Component: 0CJ 20TFSIRdW H03 0003
   Revision: --H03---    Serial number: 0000002276
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_VW51.rod
   VCID: 2D04000E4D97847FC0C-8078
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071170056001135
   Part No SW: 8W0 907 379 H    HW: 8W0 907 379 D
   Component: ESP9 Premium  H09 0719
   Coding: 14AA409928A72A9891A34891208052A2E6A592280214548912044A4567A549
   Shop #: WSC 06334 790 00001
   ASAM Dataset: EV_ESP9BOSCHCMP 001001
   ROD: EV_ESP9BOSCHCMP_001.rod
   VCID: 4ACE6B92DC39B347C5E-801E
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
   Component: Klima Zone 3  H32 0090
   Coding: 240808095544440D02000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 37282266BFCB3EAFAA0-8062
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001365114
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: D0788B9880PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501143C13900CD051587155B3F00B9130B31080000000000000000600016810A4502AB22B60A
   ROD: EV_BCM1BOSCHAU736_018.rod
   VCID: 025E83B2A489AB074DE-8056
   Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 170120  043 0813
   Serial number: 89425300301702003822
   Coding: 5BC7F7
   Serial number: 20314225X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 05 07 2016  00728608
   Serial number: GX1CE111011723310757
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 AT    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00298144
   Subsystem 6 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2616000199543002
   Part No SW: 8W0 907 561 B    HW: 8W0 907 561
   Component: LRR4          H10 0220
   Coding: 3473FFEB58FFEC0A949880A0
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 3D24304E9DF714FF70C-8068
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0106
   Serial number: 003UP003D6JD
   Coding: AACCF0C00C800000985400F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006015
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 4CC26D8AD64DAD77F72-8018
   Subsystem 1 - Part No SW: -----------    HW: 442 060 903 17
   Serial number: 3577Y00C721922F351E0
   Subsystem 2 - Part No SW: -----------    HW: 442 060 903 17
   Serial number: 3587Y00C721922F4635$
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 302 17
   Serial number: 35177000C2A58D2A878M
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 302 17
   Serial number: 3527700022A55168376-
   Subsystem 5 - Part No SW: -----------    HW: 442 0C0 803 17
   Serial number: 3557500BD21FBF14A1AX
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C0 803 17
   Serial number: 3567500BD21FBF1531AS
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C1 203 17
   Serial number: 2307500A521FBF13041%
   Subsystem 8 - Part No SW: -----------    HW: 442 431 003 17
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00B91FD7521E1BW
   Subsystem 9 - Part No SW: -----------    HW: 442 431 003 17
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00B91FD7523051F
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 015C8CBEA18FB01F544-8054
Address 17: Instruments (J285)       Labels:* 8W5-920-xxx-17.clb
   Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
   Component: FBenRDW       H17 0313
   Coding: 248481D2FC90060001A3E9601000600000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736.rod
   Part No SW: 4M2 907 468 D    HW: 4M2 907 468 A
   Component: Gateway       H16 0108
   Revision: 4W020004    Serial number: 0444W031017303
   Coding: 0301000100008640290700000059003258B20007100000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002.rod
   VCID: 392C245E89DF28DF5C4-806C
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20170306092341 01094
   Serial number: 7667883204
Address 22: AWD (J492)       Labels:* None
   Part No SW: 8W9 927 755     HW: 0CJ 927 749
   Component: B9_DL3_H_SD5  H01 0004
   Serial number: 1627218093
   Coding: 11040000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 0B40AE9693C3EA4F3E8-805E
   Part No SW: 4M0 907 397 AD    HW: 4M0 907 397 D
   Component: LCM_MLBevoH05 0024
   VCID: 79ACE45EC95FE8DF1C4-802C
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000057571014
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 323E137254A9DB879DE-8066
   Part No SW: 8W0 959 593 E    HW: 8W0 959 593
   Component: TSG FS        005 0057
   Serial number: 0000246992342
   Coding: 005F9A215001000000001082
   Part No SW: 8W0 909 144 G    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0409
   Coding: 0D888380008080
   ASAM Dataset: EV_EPSZFAU49X 003018
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 41DC4CBEE10F701F144-8014
   Part No SW: 8W0 907 064 CC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   018 0344
   Coding: 013500002F110040630980006E00480033004010004702502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012.rod
   VCID: 7F580A46D77BC6EF220-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY170523FQR
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000068824057
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0904
   Serial number: >1057819
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAHJA01DJYQ
   Coding: 0194420800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
   VCID: 76B6EF62F84187A7716-8022
   Part No SW: 8W0 959 592 E    HW: 8W0 959 592
   Component: TSG BFS       005 0057
   Serial number: 0000247202345
   Coding: 005F9A215C01000000001080
   VCID: 4BC06E96D343AA4FFE8-801E
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 035     HW: 8W5 035 035
   Component: MU-P-LND-EU   033 0917
   Serial number: A829C0HB015766
   Coding: 019442010000000013111102000A00332F0003E7017001009E
   VCID: 74B2D56AEE3D95B74F2-8020
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 8W2 919 605     HW: 8W2 919 605
   Component: AU49x_DU_HIGH  H40 0008
   Serial number: AUZ8Z9GBK00ERZ
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK111021700040012
   Compact Disc Database:
   Component: Gracenote2  --- 1015
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anheanger     H21 0203
   Serial number: 00006789,)-''.
   Coding: 0100000202000000
   Shop #: WSC 12345 102 209715
   VCID: 3B203E5683E31ACF4E8-806E
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG014213
   Coding: 02940201BF0FA10008404080
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   VCID: 3432156AAEBDD5B78F2-8060
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 31246258600000
   Coding: 0570
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 8W0 907 777 H    HW: 8W0 907 777 C
   Component: Fahrwerk-SG   H35 1214
   Serial number: 1603170515
   Coding: 9051486158
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426_VW53.rod
   Part No SW: 8W2 713 041 L    HW: 8W2 713 041 J
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170313001402
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736_AU49.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 B    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   Part No SW: 8W0 907 217 B    HW: 8W0 907 217
   Component: BVS           H15 0042
   Coding: 0404090200000402024023A5CD0000FCB0F0C020E280
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   Part No SW: 8W0 959 595 E    HW: 8W0 959 595
   Component: TSG HFS       005 0057
   Serial number: 0000247086289
   Coding: 000F98200001000000001080
   VCID: 4EC6678220519F67996-801A
   Component: TSG HBFS      005 0057
   Serial number: 0000247421983
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address CA: Sunroof (J245)       Labels:* None
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     012 0003
   Coding: 508000049202
   ROD: EV_SunRoofCONTIAU736_004_VW37.rod
   VCID: 73B0D676EB33928F568-8026
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 7PP 941 571 BC    HW: 7PP 941 571 B
   ROD: EV_LEDModLeftMELCOAU736_AU49.rod
   VCID: 1768C2E6DF0B1EAF8A0-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: None
End----------(Elapsed Time: 02:09, VBatt start/end: 13.2V/13.2V)-----------
AUTOSCAN AFTER FAULT OCURRED
Saturday,28,October,2017,17:43:38:27553
   Revision: --H13---
   Coding: 5BC7F7
   Coding: 02005D
   Coding: 230000
   Coding: 11040000
   Coding: 0570
   Coding: 9051486158
   Coding: 508000000000
0264 - Sunroof
          B1543 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 68
                    Mileage: 6142 km
                    Date: 2017.10.28
                    Time: 16:48:05
                    Sunroof-Position: 0 %
                    Sunroof-Direction of movement: Not moving
                    Sunroof-Norming: not normed
                    Sunroof-Position: Slid.position
                    Sunroof-Excessive temperature protection: not active
                    Sunroof-Reversing: not active
                    Sunroof-Adaption depth: 100 %
0274 - Roof Shade
          B1544 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 68
                    Mileage: 6142 km
                    Date: 2017.10.28
                    Time: 16:48:05
                    Roof Blind-Position: not normed
                    Roof Blind-Direction of movement: Not moving
                    Roof Blind-Norming: not normed
                    Roof Blind-Excessive temperature protection: not active
                    Roof Blind-Reversing: not active
                    Roof Blind-Adaption depth: 100 %
0325 - No Vehicle Type Coded
          B1694 00 [009] -  -
                    Reset counter: 68
                    Mileage: 6142 km
                    Date: 2017.10.28
                    Time: 16:48:05
End------(Elapsed Time: 69:48, VBatt start/end: 13.2V/13.2V, Deb=2)--------
AUTOSCAN NOW (AFTER CHANGING SUNROOF CONTROLLER CODE BACK TO ORIGINAL)
Monday,13,November,2017,00:44:31:27553
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
Mileage: 6753km-4196mi   Repair Order:
VIN: WAUZZZF47HA152503   Mileage: 6753km-4196miles
CA-Sunroof -- Status: Malfunction 0010
   Revision: --H13---
Readiness: 1110 0001
   Coding: 5BC7F7
   Coding: 02005D
   Coding: 230000
   Coding: 11040000
   Coding: 013500006F110040630980006E00080033004010004702502F0400000504803F001F0001000000
   Coding: 0570
   Coding: 9051486158
0264 - Sunroof
                    Reset counter: 84
                    Mileage: 6753 km
                    Date: 2017.11.13
                    Time: 00:41:12
                    Sunroof-Position: Tilt out posi.
0274 - Roof Shade
                    Reset counter: 84
                    Mileage: 6753 km
                    Date: 2017.11.13
                    Time: 00:41:12
                    Roof Blind-Position: 0 %
                    Roof Blind-Norming: normed
End----------(Elapsed Time: 02:08, VBatt start/end: 13.3V/13.6V)-----------
Klaus Ludwig
C?ID=227092
Following for info:-
CA – SUNROOF – BASIC SETTINGS (FULL LIST OF OPTIONS)
IDE01475-Resetting of all adaptations
IDE09818-Sunroof: standardization
IDE09819-Roof roller blind: calibration
IDE09820-Sun roof: start up service position
IDE09821-Roof blind: start up service position
IDE09822-Sunroof: reset standardization
IDE09823-Roof roller blind; reset standardization
IDE09824-Reset counter: control unit
IDE09825-Reset counter: sunroof
IDE09826-Reset counter: roof blind
ENG146656-Normalisation
ENG146658-Roof_blind_adjusting_specified_position
ENG146657-Sliding_sunroof_adjusting_specified_position
Gone But Not Forgotten
Hello Klaus,
Try holding the buttons the entire time of the function from open to close and then cycle the key to see if it learns the ADP range.
Klaus Ludwig
C?ID=227092
Hi Jack,
I have two spring loaded buttons. One for the sunroof and one for the sunroof blind. Both buttons have five positions. The normal position plus the first position and finally the second position (for both opening and closing) if additional force is applied.
Before carrying out the procedure suggested I had to keep my finger on the button continuously if I wanted the sunroof or sunroof blind to operate. Pulling the switches to the second position (both opening and closing) made no difference. As soon as I released the button the sunroof or sunroof blind stopped moving.
After carrying out the procedure suggested if I pull the switch to the first position the sunroof or sunroof blind stops as soon as I release the switch and if I pull the switch to the second position and release it the sunroof or sunroof blind continues to move until its end position for both opening and closing.
By the way, I was not 100% sure what you meant regarding cycling the key ( I have keyless ignition). I took it to mean using the manual key in the Driver’s door. I tried this after leaving the sunroof and blind closed and also after leaving both fully open and letting the door key-switch close them.
We have achieved something. However, I am still getting two Fault codes for the sunroof – as below:-
Tuesday,14,November,2017,23:48:26:27553
                Address CA: Sunroof       Labels: None
Control Module Part Number: 4M0 907 594     HW: 4M0 907 594
  Component and/or Version: SAD_STG_1     012 0003
           Software Coding: 508000049202
            Work Shop Code: WSC 06335 790 00001
              ASAM Dataset: EV_SunRoofCONTIAU736 004008 (AU49)
0264 - Sunroof
                    Reset counter: 85
                    Mileage: 6788 km
                    Date: 2017.11.14
                    Time: 23:47:32
0274 - Roof Shade
                    Reset counter: 85
                    Mileage: 6788 km
                    Date: 2017.11.14
                    Time: 23:47:32
AIB Wolfgang
Hallo Klaus,
just with a little help from my translator:rolleyes:
Adapt sunroof control unit -J245-
After a glass lid, a motor, the slide guide or the Sunroof roller blind has been replaced, an adaption-run for the appropriate drive must be performed.
For new spare parts motors, the standardization run starts immediately after the
switch operation without 10 seconds waiting time.
During the learning run, the closing force limitation is switched off.
Ignition is switched on.
The sunroof adjustment slider -E139- must be in the position "Sunroof closed" are located.
Pull the sunroof adjustment control -E139- down and hold it during the entire normalization process
(about 20 seconds) in this position.
- During standardization run, the glass lid closes first and moves then approx. 200 mm to the rear.
- After the lid has been closed again, standardization run has finished, please release the sunroof adjustment control -E139-.
Klaus Ludwig
C?ID=227092
Hi Wofgang,
Success :)
Thanks!!!
Despite your English translation not being 100% perfect I have managed to understand the method and now all perfect and I no longer have any sunroof fault codes.
With the ignition on and the sunroof closed I put the switch to the 2nd close position. This is what you would normally do if the sunroof was open and you wanted to close it except when activating the switch to the 2nd position you would not need to keep holding it for the sunroof to close.
I then held the switch continuously until something happened and after a number of seconds the sunroof opened and then closed. I waited for some more seconds until I was sure nothing else was happening and then released the switch. I did the same with the sunroof blind.
After the above procedure, all sunroof fault codes cleared and remained clear.
Vielen Dank!!!
Klaus Ludwig
C?ID=227092
This is a reminder to myself and anyone else for the future that the sunroof and sunroof-shade adaptation calibrations are carried out separately and do not require the use of VCDS, though obviously VCDS can be used to confirm success (faults will reset and remain clear).
Commencing with sunroof and sunshade in closed position:-
To calibrate sunroof pull down the sunroof switch and keep holding it down until after the sunroof opens and then closes again.
To calibrate the sunroof sun-shade push the sunshade button all the way forward and hold in this position until after the sunshade has opened and then closed.
Calibration is now complete and no other action is required. Be aware to keep hands and fingers clear of moving parts whilst calibration is taking place.
mikemod
C?ID=49161
Thanks for this post, my 2017 S5 did the same thing. I had been doing an autoscan previously but can't be sure exactly when it happened.
The sunroof was fine before, then lost all info from bottom five bytes the same as yours.
This was the same time that two errors, which I had mentioned in a previous thread, relating to the rear door closing status appeared, even though I have only a two-door car.
Putting the coding back and then going through the calibration fixed the sunroof and after clearing the other faults they never returned.
