2007 Eos Top inop
Robert U'Ren
C?ID=9138
Hello
This is my first time posting. Customer stated top will not open. Found cracked third brake light. Water destroyed pump, latch, latch assist module and blew 40 amp fuse to roof module. Replace pump, latch, latch assist module and wire ends to to latches and even replaced roof module. After normalizing windows and doing a capacity discharge 3 time, sunroof rolls back and you can hear pump running and unlocking C segment but C Segment does not lift. Close roof to make light on dash go out. Check faults. Has 02805 fault. System interference. Check Roof Binary Data in Closed Position, all are correct. One problem I see is the trunk assist module is not working and pull the trunk down at all. Factory wiring diagram shows power and ground, which are all OK, and three signal wires going to roof module. There is no faults for latch assist module. Has anyone seen this problem with the latch assist module before and will this cause a problem with the roof not opening? I also saw previous blog on Eos roof problems. I tried basic setting to make roof open and did not find a value block to initiate this process. Any ideas or help would be greatly appreciated.
Welcome to the forum.
Would you be so kind as to post an Auto-Scan from this car for context, please?
Robert U'Ren
C?ID=9138
Monday,13,November,2017,09:02:56:61823
VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4401.4
VIN: WVWFA71F07V006316   License Plate:
Chassis Type: 1F (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 26 42 44 46 47 52 56 62
          63 65 72 73
VIN: WVWFA71F07V006316   Mileage: 194310km-120738miles
26-Auto Roof -- Status: Malfunction 0010
63-Entry Assist,D -- Status: OK 0000
73-Entry Assist, P -- Status: OK 0000
   Part No SW: 1Q0 907 115 E    HW: 1Q0 907 115 B
   Revision: --H14---    Serial number: VWX7Z0F53NK9MK
   Coding: 041C010A1C070160
   Shop #: WSC 22600 444 53940
   VCID: AE1044C339E6BA36A8-80FA
Readiness: 0010 0101
   Part No SW: 02E 300 043 F    HW: 02E 927 770 AE
   Component: GSG DSG         070 1157
   Revision: 04507000    Serial number: 00000605180645
   Shop #: WSC 44551 111 44551
   VCID: 977E8127A67C5BFEDB-80C2
   Revision: 00H11001
   Coding: 0021218
   Shop #: WSC 00020 000 00000
   VCID: F3A695B79244D7DE07-80A6
   Part No SW: 1Q0 907 044 A    HW: 1Q0 907 044 A
   Component: ClimatronicPQ35 093 0101
   Revision: 00093002    Serial number: 00000000000000
   VCID: AB164DD70AF4CF1E8F-80FE
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000005709453
   Coding: F58C8F0340041500470000000F00000000285D035C0000
   VCID: B73E61A7C6BC7BFEFB-80E2
   Component: Wischer 300606 020  0501
   Coding: 00038805
   Shop #: WSC 00020
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     100606 014  1201
   Coding: 00208933
   Shop #: WSC 00020
   Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
   Component: SDAR SIRIUS     H03 0120
   Revision: 00000000    Serial number: AUZ4Z7F3029964
   VCID: AC144ECB0FFAC82686-80F8
            000 -  -
                    Reset counter: 28
                    Mileage: 194315 km
                    Time: 09:45:44
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 13 Airbag VW8C      0180
   Revision: 92009018    Serial number: 003B3000FN9L
   Coding: 0012595
   VCID: BA387893F5AE669604-80EE
   Subsystem 1 - Part No: 1Q0 959 339
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 37T2B
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332SRB403610A96Xÿ†63
   Subsystem 5 - Serial number: 10A96Xÿ†6342SRB4036BCA211ÿ†63
   Subsystem 6 - Serial number: BCA211ÿ†6372URB40147CF8FNÿ†63
   Subsystem 7 - Serial number: 7CF8FNÿ†6382URB40147D01E2ÿ
   Subsystem 8 - Serial number: 7D01E2ÿ
   Part No SW: 1K0 953 549 AS    HW: 1K0 953 549 AS
   Component: J0527           035 0070
   Coding: 0012021
   VCID: 8346C577C2E4E75E17-80D6
   Part No SW: 1Q0 920 973 B    HW: 1Q0 920 973 B
   Revision: V0003000    Serial number: VWX7Z0F53NK9MK
   Coding: 0023203
   VCID: B22850B32DDE9ED6CC-80E6
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 3100106606879E
   Coding: 3FBF23620F065000
   Part No SW: 1Q0 919 965     HW: 1Q0 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1350208TK3KZ02
   VCID: F9BAA79FB028AD8E4D-80AC
   Component: IMMO            VDD 1610
   Shop #: WSC 64973 001 1048576
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 G    HW: 1Q0 959 255 G
   Component: Verdecksteuergeraet 0860
   Revision: 0033100R    Serial number: 151890154
   Coding: 0655360
   VCID: BC347E8BFF9A58A616-80E8
02805 - System Interference
            000 -  -
                    Reset counter: 28
                    Mileage: 194315 km
                    Time: 09:48:00
                    Voltage: 13.30 V
                    Voltage: 13.40 V
                    Voltage: 4.90 V
                    Error Code: 12
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1Q0 959 701 C
   Component: Tuer-SG         024 2737
   Coding: 0001207
   Shop #: WSC 22578 444 13900
   VCID: B42456ABD7CA90E6DE-80E0
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
            000 -  -
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 93908A800186281B0804040FB0080E04888C00
   VCID: F4A496AB974AD0E61E-80A0
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 1Q0 035 456 B    HW: 1Q0 035 456 B
   Component: DSP 10 Kanal        0013
   Revision: 00010000    Serial number: 00000000002465
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1Q0 959 702 B
   Coding: 0001206
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio PM6       017 0019
   Revision: 00017000    Serial number: VWZ5Z7F2086550
   Coding: 0010011
   VCID: A404A6EB672A00664E-80F0
   Part No: 1Q0 959 703
   Component: Tuer-SG         021 2705
   Coding: 0000128
Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
   Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
   Component: J572  EASYENTRY FS  0603
   Revision: 00H01000    Serial number: 5DS008646-01--
   Coding: 0000002
   Component:    RDK              0420
   Coding: 0000000
                    Fault Status: 01110101
                    Mileage: 194315 km
                    Time: 09:45:33
   Part No: 1Q0 959 704
   Coding: 0000128
Address 73: Entry Assist, P        Labels: 1Q0-959-790.lbl
   Component: J573  EASYENTRY BFS 0603
   Coding: 0000002
End----------(Elapsed Time: 01:42, VBatt start/end: 14.1V/14.0V)-----------
Robert U'Ren
C?ID=9138
HS1: 1 1 1 1 0 1 1 0 0 1 1 0 - :HS13 Hall Sensor Status In closed position.
Robert U'Ren
C?ID=9138
Update.
Found problem with new latch. Replaced latch again. Now trunk assist module now shows roof module unlocked. Roof now operates correctly.
