Reductant tank heater fault
racerfiftynine
C?ID=301708
Just scanned a 2011 VW Sharan 2.0 TDI with a MIL light on. Fault with reductant heater. Thought I'd post to see if a common fault and see if I could post a full scan correct?
Any ideas? (I haven't looked myself yet)
Wednesday,08,November,2017,09:35:55:60494
VCDS Version: 17.8.0.1  HEX-NET CB: 0.4401.4
VIN: WVWZZZ7NZBV022449   License Plate: GD11 AEZ
Mileage: 91160km-56644mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 52 53 56 61
          62 69 72 77
VIN: WVWZZZ7NZBV022449   Mileage: 91160km-56644miles
18-Aux. Heat -- Status: Malfunction 1010
   Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
   Component: R4 2,0L EDC   H24 8257
   Revision: 44H24---    Serial number:
   Coding: 001D001A042501080000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HJ 003006
   ROD: EV_ECM20TDI01103L906018HJ.rod
   VCID: 79BA3082F8351C8ECD-802C
9655 - Control Circuit for Reductant Tank Heating
          P202A 00 [237] - Open Circuit
                    Mileage: 90731 km
                    Date: 2017.10.28
                    Time: 07:30:03
                    Engine speed: 1556.00 /min
                    Normed load value: 78.0 %
                    Vehicle speed: 74 km/h
                    Coolant temperature: 45 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 14.760 V
                    Outside air temperature: 11.5 °C
                    Pressure sensor for reducing agent: measured pressure: 5001 hPa
                    Sensor for reducing agent fill level: fill level: 80.36 %
                    Sensor for reducing agent tank temperature: temperature: 14.6 °C
                    Reducing agent pump: activation: 12.53 %
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 054 Q    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2602
   Revision: 05351112    Serial number: 00001011140789
   Shop #: WSC 00020 790 00000
   VCID: 240431F6E737B166CE-8070
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 L    HW: 7N0 614 109 L
   Component: J104   C3 450M VD7B 0008
   Revision: --H07---    Serial number: 00000003311122
   Coding: 0028186
   VCID: 3620FBBE41AB33F660-8062
   Part No SW: 5K0 907 044 F    HW: 5K0 907 044 F
   Component: Clima-Sharan  H11 0104
   Coding: 0000000009
   VCID: 2E10D3DE71FB0B3628-807A
   Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
   Component: BCM PQ35 B    011 0046
   Revision: BA011001
   Coding: 40180A3B8125F1C0400800C0140000E443511308426D21626480870000C1
   VCID: 3522FCB29CAD38EE69-8060
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110704  31  0032
   Serial number:         110723024450
   Coding: 000D9D
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y10M12D13h08m31s02S1
   Coding: 0380BB
   Subsystem 3 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
   Component: LIN BACKUP HO  H11 9004
02382 - Sensor for Light Detection (G399)
                    Reset counter: 152
                    Mileage: 90572 km
                    Date: 2012.03.18
                    Time: 17:27:43
                    Voltage: 14.00 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0010
   Revision: --------    Serial number: 80231034802853
   Coding: 118101
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 78BC3586C33F0586B2-802C
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag01K H07 0013
   Serial number: 003GFPQM2LMN
   Coding: 00314B
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E30E39EA19BFBB6B8-806A
   Serial number: 3493ETS60795F29139D/
   Serial number: 3503ETS60229123139D4
   Serial number: 3513ETS60BB741A13DDY
   Serial number: 3523ETS60DBA423139DU
   Serial number: 35540TS608B195E139DP
   Part No SW: 5K0 953 521 BD    HW: 5K0 953 569 B
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101214200704
   Coding: 1882240000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 6FAE0EDAB671423E63-803A
   Coding: E20000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 7N0 920 970 A    HW: 7N0 920 970 A
   Coding: 440B00
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
   VCID: 312AC8A260C514CE35-8064
   Part No: 7N0 963 271 A
   Component: Zuheizer        051 2630
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000041
   VCID: 3228C7AEADC32FD64C-8066
01444 - Under-Voltage Shut-Off (Automatic)
            000 -  -  - Intermittent
                    Reset counter: 159
                    Mileage: 91119 km
                    Date: 2012.03.29
                    Time: 08:52:07
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 101210F1002971
   Coding: 468003
   VCID: 312AC8A268C514CE35-8064
                    Fault Status: 00110100
                    Reset counter: 153
                    Mileage: 89960 km
                    Date: 2012.03.14
                    Time: 15:13:39
   Component: IMMO          H20 0420
   VCID: 6A981FCE8D93A71634-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669036630
   VCID: 281C25C65B1F5506E2-807C
   Part No SW: 7N0 959 793 D    HW: 7N0 959 793
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000110543322
   Coding: 011006208001411011
   VCID: 43C6926AC279965ED7-8016
   Part No: 7N0 909 144 L
   Component: EPS_ZFLS Kl. 275    3102
   Revision: 00H17000
   VCID: 3C34E9967F87E9A696-8068
   Part No SW: 7N0 959 792 D    HW: 7N0 959 792
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000109830261
   VCID: 42C8976EDD639F56DC-8016
   Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
   Component: J540 EPB4  VW-53083 0006
   Revision:   H18       Serial number: 00000000130499
   Coding: 0024067
   Part No SW: 5M0 035 186 AB    HW: 5M0 035 186 AB
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2K7863568
   Coding: 0100040004
   VCID: 6C9419D68F67B92646-8038
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71AA08A2A84554CE75-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370225881
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000110848287
   Coding: 010004200001411001
   VCID: 45C28C72CC4DA86EF9-8010
   Component: ConWysTrailer H07 0100
   Revision: 3A001001    Serial number: 00000132425721
   Coding: 0100000100000000
   Shop #: WSC 00007 223 174336
   VCID: 302CCDA663CF1DC63A-8064
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000110848018
   Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007669025065
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:49, VBatt start/end: 12.0V/12.0V)-----------
racerfiftynine
C?ID=301708
I've just spoken to TPS (Volkswagen Trade Parts) and common replacement of reductant heater £516.12 +vat and / or module £290.31 +vat.
I will do some wiring checks later on today when I get time.
MIL light does clear and fault is intermittent.
My question is, can I code the module if required or does anyone know if it is plugs 'n' play?
Fault is an intermittent open circuit / under voltage to auxiliary heater element, which TPS think is more likely module fault. Depends really on if the under voltage code is created by an actual voltage test or the fact the temperature sensor in tank doesn't warm up as expected?
NostraJackAss
Change the heater and or check wiring to it if tests good..........and ultimately ECU in rare some cases as per the RTFB.
Should just plug in if just the element purchased......
Detlef Trapp
World
C?ID=56993
There is a heater repair kit for abt. 200 Euros, part # 7N0198970A, it is pretty easy to install, just take off the rear bumper and the inner fender liner, and unbolt and lower the tank, screw out the older heater and screw in the new one, plug it in and put everything back in place - done!
racerfiftynine
C?ID=301708
Wow, thanks guy. Shows forums are worth the time.
Heater repair kit good number, but currently on back order 5 - 10 days. Cleared codes and driven 10 miles, so going to let customer have it back and order repair kit. Got to be worth a go at £180.91+VAT. Slightly annoyed TPS weren't forth coming with repair kit when I phoned this morning.
Detlef Trapp
World
C?ID=56993
BTW, I just saw there is also a "B"-Version of this repair kit - 7N0198970B - but could not find much further information so you may want to ask your parts guy if this is the replacement part for the "A"-Version and if he got you the right part this time
racerfiftynine
C?ID=301708
Apologies been a while. Just to finish tread, fitted supplied repair kit form TPS and all sorted!
