1J Gold Cluster fault
HCAE
New Zealand
C?ID=213797
Hi All.
Got a interesting fault here.. Its easier to show you rather then explain it.
The fault is not present at idle, only at over 1000 rpm. Other then this, the car runs fine. When checking measuring blocks for voltage in Engine its about 13.8 then give it a few revs and we lose communication. The headlights, interior lights etc all work and don't flicker. I have check the battery voltage at the battery and ignition switch, I suspected the voltage would be low, but have a steady (on an scope) 13.9v at the battery and after all the fuses and at ignition switch. No dropping out.
Here is the before scan:
Tuesday,09,September,2014,08:27:32:55685
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
VIN:    License Plate: 5URFEE
Mileage: 207560km-128971mi   Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
          76
   Mileage: 207560km/128971miles
Address 01: Engine        Labels: 06A-906-018-AGU.lbl
   Part No: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR AT D02
   Coding: 04030
   Shop #: WSC 73380
   VCID: 69D9AFDF13A067562C3-4AE8
16500 - Engine Coolant Temp. Sensor (G62)
            P0116 - 35-10 - Implausible Signal - Intermittent
00528 - Barometric Pressure (Altitude) Sensor (F96)
            06-10 - Signal too High - Intermittent
00544 - Maximum Boost Pressure Exceeded
            35-10 - - - Intermittent
Readiness: N/A
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 GE
   Component: AG4 Getriebe 01M    4577
   Coding: 00000
   VCID: 79F9FF9F6300D7D6DC3-095E
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 Q
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 00028
   VCID: 3F8D51873DA439E6A27-4AE8
   Part No: 6Q0 909 605 A
   Component: 02 AIRBAG VW5       0003
   Coding: 12338
   Shop #: WSC 00028
   VCID: 356133AF0F98F3B678B-4AE8
Address 17: Instruments        Labels: 1J0-920-xx0-17.lbl
   Part No: 1J0 920 821 A
   Component: A4-KOMBIINSTR. VDO V22
   Coding: 07542
   Shop #: WSC 00012
   VCID: 224BF8F3AE16740EAD9-5124
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0X1936889
   IMMO-IDENTNR: VWZ7Z0X1936889
   Part No: 6N0 909 901
   Coding: 00007
   Shop #: WSC 00028
   VCID: F0EF42BBB07A169EEBD-5140
   Part No: 1J0 959 799 AJ
   Component: 4Y Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 00028
   VCID: 86030463A2FE282E211-4AE8
   Subsystem 1 - Part No: 1J0959802F
   Component: 4Y Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J0959801G
   Component: 4Y Tõrsteuerger. BF0002B
   Subsystem 3 - Part No: 1J4959811C
   Component: 4Y Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 4Y Tõrsteuerger. HR0002r
After erasing all codes and running engine and getting fault to occur:
Tuesday,09,September,2014,10:12:00:55685
          76
   Coding: 04030
   Shop #: WSC 73380
   VCID: 69D9AFDF13A067562C3-4B00
            06-00 - Signal too High
            P0116 - 35-00 - Implausible Signal
Readiness: N/A
   Coding: 00000
   Coding: 13504
   Shop #: WSC 00028
   VCID: 3F8D51873DA439E6A27-4B00
   Coding: 12338
   Shop #: WSC 00028
   Coding: 07542
   Shop #: WSC 00012
   VCID: 224BF8F3AE16740EAD9-5140
   Coding: 00007
   Shop #: WSC 00028
   Coding: 04097
   Shop #: WSC 00028
   Component: 4Y Tõrsteuerger. BF0002r
   Component: 4Y Tõrsteuerger. HL0002H
Any ideas?
Cheers
Nice post; a picture is worth 1000 words and a video is worth 30 pictures per second. :D
Diagnostic comms to the engine (and only the engine) go THROUGH the cluster, so I guess it's not a surprise that you lose comms to the engine when the cluster loses its mind.
As to why the cluster is losing its mind, well... If it were me, I'd start by pulling the cluster out of the dashboard far enough to probe the connectors on the back of it and verify power and ground at the there. A 'scope is an excellent tool for that.
HCAE
New Zealand
C?ID=213797
So I scoped the power supply to the cam sensor and injectors, had massive spikes in the pattern, eventually traced the fault to an earth for the coils that hadn't been put back on properly after someone had replaced a coil! Put that back on hey presto, we're done.
Cheers
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Nice work! I wouldn't have known where to even begin on that.
Jason
Blessed is the Auto-Electric guy who has an oscilloscope and knows how to use it. Far too many people these days think a scan-tool will do everything they need. They're wrong. Scan tools are obviously indispensable on modern cars, but they can only tell you what the car itself knows, and it simply doesn't know everything.
Gone But Not Forgotten
It is seriously recommended because the VC is pot metal aluminum........... a poor conductor by all standards through a cast iron block.
Run a ground directly to it for that lug for coils to the battery......
It will save your coils later and is most likely why someone needed a coil............enhance them all if you can.
That video is awesome and looks like a pinball machine hitting the jackpot.
