Saturday,19,October,2019,00:41:50:13712
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 19.6.2.0 (x64) HEX-V2 : 0.4508.4
VIN: WAUGF78K49A192023 License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
52 53 55 56 62 65 67 6C 72 77
VIN: WAUGF78K49A192023 Mileage: 173810km-108000miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0001
Revision: E1H14---
Coding: 010C010A190F0160
Shop #: 22145 444 84529
Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79AFEEE6D95A0BCF8E9-802C
14 Faults Found:
7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 00 [104] - Too Lean
Mileage: 173022 km
Date: 2019.10.10
Time: 00:43:10
Engine speed: 1557.00 /min
Normed load value: 19.2 %
Vehicle speed: 11 km/h
Coolant temperature: 84 °C
Intake air temperature: 34 °C
Voltage terminal 30: 13.617 V
Unlearning counter according OBD: 28
2859 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [096] - Malfunction / Open Circuit
Mileage: 173456 km
Date: 2019.10.14
Time: 17:59:43
Engine speed: 758.00 /min
Normed load value: 11.4 %
Intake air temperature: 30 °C
Voltage terminal 30: 13.523 V
Unlearning counter according OBD: 31
2875 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 00 [096] - Malfunction / Open Circuit
Mileage: 173456 km
Date: 2019.10.14
Time: 17:53:50
Engine speed: 159.50 /min
Normed load value: 29.4 %
Coolant temperature: 54 °C
Voltage terminal 30: 11.732 V
2865 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
P3255 00 [232] - Regulation at Upper Limit
Fault Frequency: 24
Mileage: 172950 km
Date: 2019.10.09
Time: 18:03:32
Engine speed: 891.50 /min
Vehicle speed: 12 km/h
Coolant temperature: 105 °C
Intake air temperature: 53 °C
Voltage terminal 30: 13.381 V
2868 - Oxygen (Lambda) Sensor B1 S1
P3266 00 [237] - Internal Resistance Implausible
Fault Frequency: 24
Mileage: 172950 km
Date: 2019.10.09
Time: 18:02:34
Engine speed: 1674.50 /min
Normed load value: 31.8 %
Vehicle speed: 7 km/h
Coolant temperature: 100 °C
Intake air temperature: 54 °C
Voltage terminal 30: 13.334 V
10434 - Catalyst System; Bank 1
P0420 00 [237] - Efficiency Below Threshold
Mileage: 172487 km
Date: 2019.10.04
Time: 21:19:23
Engine speed: 1765.50 /min
Normed load value: 37.3 %
Vehicle speed: 39 km/h
Coolant temperature: 77 °C
Intake air temperature: 32 °C
Voltage terminal 30: 13.499 V
7679 - Oxygen (Lambda) Sensor B1 S1
P0132 00 [104] - Signal too High
Fault Frequency: 157
Mileage: 172845 km
Date: 2019.10.08
Time: 14:56:32
Engine speed: 1043.00 /min
Normed load value: 7.1 %
Vehicle speed: 15 km/h
Coolant temperature: 89 °C
Intake air temperature: 39 °C
Voltage terminal 30: 13.452 V
Unlearning counter according OBD: 26
7680 - Oxygen (Lambda) Sensor B1 S1
P0131 00 [104] - Signal too Low
Mileage: 172936 km
Date: 2019.10.09
Time: 12:50:22
Engine speed: 825.50 /min
Normed load value: 19.6 %
Coolant temperature: 81 °C
Intake air temperature: 37 °C
7670 - Oxygen (Lambda) Sensor B1 S1
P0130 00 [237] - Malfunction in Circuit
Fault Frequency: 60
Mileage: 172831 km
Date: 2019.10.08
Time: 12:56:27
Engine speed: 2557.50 /min
Vehicle speed: 37 km/h
Coolant temperature: 92 °C
Intake air temperature: 35 °C
Voltage terminal 30: 13.782 V
4060 - Cylinder 3
P0303 00 [236] - Misfire Detected
Mileage: 173354 km
Date: 2019.10.13
Time: 13:34:47
Engine speed: 3198.50 /min
Normed load value: 88.2 %
Vehicle speed: 44 km/h
Coolant temperature: 101 °C
Intake air temperature: 45 °C
4063 - Cylinder 4
P0304 00 [236] - Misfire Detected
Mileage: 173354 km
Date: 2019.10.13
Time: 13:35:14
Engine speed: 751.50 /min
Normed load value: 13.3 %
Coolant temperature: 104 °C
4057 - Cylinder 2
P0302 00 [236] - Misfire Detected
Mileage: 172512 km
Date: 2019.10.04
Time: 23:14:47
Engine speed: 4269.00 /min
Normed load value: 94.1 %
Vehicle speed: 94 km/h
Coolant temperature: 93 °C
Intake air temperature: 36 °C
Voltage terminal 30: 13.146 V
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [236] - -
Fault Frequency: 8
Mileage: 172512 km
Date: 2019.10.04
Time: 23:14:47
4201 - Fuel Level too Low
P1250 00 [096] - -
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 C HW: 0B6 927 156
Component: 0B6 20TFSIUSA H04 0051
Revision: --H04---
Coding: 001002
Shop #: 06335 123 12345
Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 363525DAA8C424B723B-8062
Address 03: Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AF HW: 8K0 907 379 AF
Component: ESP8 quattro H04 0210
Coding: 150500
VCID: 7DA7FAF6CDF237EFA21-8028
Address 05: /Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AG HW: 8K0 907 064 AG
Component: BCM2 1.1 H80 BCM2 1.1 H80 01450145
Coding: 090200
Shop #: 06335 000 00000
VCID: 75B7E2D6F5C26FAFEA1-8020
Subsystem 1 - Part No: 8T0 959 754 G
Component: FBSAUDIB8 IDG
Subsystem 2 - Part No: 8K0 905 852 D
Component: ELVAUDIB8
No Faults Found
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 M HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 340AJ097518153
Coding: 0001003
Shop #: 00000 000 08192
VCID: 43D34C0EE796811F945-8016
Subsystem 1 - Part No: 8T0 919 609 A
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000206757
Subsystem 3 - Serial number: 0102.12.080000000100010370ÿ
Subsystem 4 - Serial number: 010370ÿ
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0150
Revision: C1000000 Serial number: 01130120090307
Coding: 64002000
VCID: 72BDD9CA84AC7897CF3-8026
Fault Status: 00100001
Reset counter: 69
Mileage: 172639 km
Date: 2019.10.05
Time: 22:13:12
Voltage: 13.80 V
Temperature: 24.0°C
Temperature: 17.0°C
Count: 12027
Count: 13085
Bin. Bits: 01000000
Bin. Bits: 00001011
Time: 255.00 s
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000293598
Coding: 260810091023CB010001080300003D0D4F9C460800010161000000
Shop #: 12345 123 12345
VCID: 303913C24A200A87797-8064
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 130109 H06 0070
Serial number: SWF09010135573
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: H04 0003
Serial number: 10352847
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - H07 0080
Serial number: 00000000000901091646
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
01853 - Heated Seat; Left Front (Z45)
Fault Status: 01101100
Reset counter: 39
Mileage: 173136 km
Date: 2019.10.11
Time: 13:20:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043003 Serial number: AUZ5ZBI8722594
Shop #: 00000 000 00000
VCID: 2A0D01AA60FC7057B73-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7I0506078
Coding: 0000100
VCID: 313F16C64D2A038F769-8064
Reset counter: 36
Mileage: 172992 km
Date: 2019.10.09
Time: 20:23:46
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 F HW: 8K0 919 475
Component: PARKHILFE 4K H06 0040
Revision: 11001001 Serial number: 40140900804852
Coding: 200103
VCID: 3C2137F29668FEE7D5F-8068
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
Component: AirbagVW-AU10 H27 0410
Serial number: 0039KD14RLR$
Coding: 303836354230303030304A55304C384B3053
Dataset: EV_AirbaECUVWAUDI010 A02007
VCID: 40D94302FA009A07897-8014
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R08000039R4
Serial number: 6334MSME426570164
Serial number: 6344MSME447118122
Serial number: 6352QSME341A2518B
Serial number: 6362QSME3C172620B
Serial number: 63732SME3E17302C+
Serial number: 63832SME3E171604-
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90304IA800023
Coding: 000017
VCID: 3D273AF68D72F7EFE21-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 980 A HW: 8K0 920 980 A
Component: KOMBIINSTR. H18 0224
Revision: 00000000 Serial number: 9E17670D8
Coding: 030511000300D705020201
Part No SW: 8T0 907 468 P HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0095
Revision: EB500046 Serial number: 4600E091078306
Coding: 000303
VCID: 4EC56D3A30D47C770BB-801A
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 1805B278041208
Reset counter: 84
Mileage: 173456 km
Date: 2019.10.14
Time: 17:31:00
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 020000
VCID: 2B0304AE6306695F4C5-807E
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 HW: 8K0 959 760
Component: MEM-FS H05 0043
Revision: AA000000 Serial number: 00001001158803
Coding: 00585300000000000000
VCID: 77ABE8DEEFCE1DBFF8D-8022
Mileage: 172807 km
Date: 2019.10.06
Time: 22:48:06
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H52 1100
Revision: 00000000 Serial number: 341AN097522836
VCID: 38292BE2AE50D2C7317-806C
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: FA H11 0250
Revision: Serial number: 0000008282729
Coding: 011F03200F00410001
VCID: 41DF4606F18A930F869-8014
Component: BCM2 1.1 H80 0145
Revision: 00002001 Serial number: 0116443622
Coding: 016216E220F24406033002
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Serial number: 00000000000000111055
Component: BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS130 H06 0037
02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
Fault Status: 00101100
Fault Frequency: 35
Reset counter: 94
Mileage: 172138 km
Date: 2019.10.02
Time: 12:33:25
Reset counter: 86
Mileage: 173467 km
Date: 2019.10.15
Time: 10:31:40
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 AD HW: 8T0 035 223 G
Component: DSP STD H08 0300
Revision: S2600000
Coding: 020201
VCID: 70B9D3C28AA04A87397-8024
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: BF H11 0250
Revision: Serial number: 0000008294094
VCID: 40D94302FA809A07897-8014
Fault Status: 01101000
Reset counter: 4
Mileage: 171695 km
Date: 2019.09.25
Time: 01:15:32
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 F HW: 8K0 907 801 F
Component: Audi B8 H06 0070
Revision: 00000003 Serial number: 00000000290993
VCID: 323D19CA442C38970F3-8066
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Coding: 0000004
Shop #: 06334 000 00000
VCID: 77ABE8DEE3CE1DBFF8D-8022
Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
Component: TUNER EU/US/ H42 0630
Revision: 00000000 Serial number: 357AT097517255
Coding: 0000002
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: HL H10 0251
Revision: Serial number: 0000008368026
Coding: 010F01200000220001
VCID: 44D14F12EE988627ADF-8010
Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502- H03 0250
Revision: 00001001 Serial number: 13140782266448
Coding: 0CD154
02214 - Tire Pressure Warning
Reset counter: 92
Mileage: 173630 km
Date: 2019.10.17
Time: 11:35:12
Bin. Bits: 00001000 00100011
Voltage: 13.90 V
Text: 17,0°C; -0,73bar;3444397030;00h; 16°C
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000812030072
Shop #: 12336 024 394758
VCID: 34311FD2B23836A71DF-8060
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
Component: J772__Rearview 0070
Revision: --H12--- Serial number: 525PA8-J8Y92OH
Coding: 1000007
Shop #: 06335 123 01234
VCID: 372B28DEA34EDDBF38D-8062
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: HR H10 0251
Revision: Serial number: 0000008368121
Coding: 010F01200040220001
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005076316
Coding: 0010900
VCID: 2809FBA27EF04247A17-807C
End----------(Elapsed Time: 02:54, VBatt start/end: 12.4V/12.4V)-----------
