The ABS couldnt see the j500 of power steering , is the code should be changed
Saturday,04,November,2017,06:34:19:11183
VCDS Version: 17.8.0.1
Dealer/Shop Name: Harisa car service
VIN: WVWZZZ1KZ6M716435 License Plate:
Mileage: 109870km-68270mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 76
VIN: WVWZZZ1KZ6M716435 Mileage: 109870km-68270miles
15-Airbags -- Status: Not registered 0011
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 J HW: 1K0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H10--- Serial number: VWZ7Z0E2932012
Coding: 040300031C070160
Shop #: WSC 61020 981 94077
VCID: 2D548BFBB43A912E11-8078
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Mileage: 109638 km
Time: 07:07:29
RPM: 765 /min
Load: 22.0 %
Temperature: 88.0°C
Temperature: 56.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
012599 - Intake Manifold Runner Control
P3137 - 001 - Basic Setting not Completed - Intermittent
Fault Status: 00100001
Mileage: 109642 km
Temperature: 75.0°C
Temperature: 52.0°C
Voltage: 12.573 V
001602 - Sensor Reference Voltage A: Circuit
P0642 - 002 - Low - Intermittent
Mileage: 109642 km
Temperature: 77.0°C
Temperature: 62.0°C
Voltage: 12.573 V
012600 - Intake Manifold Runner Control
P3138 - 008 - Regulation Deviation - Intermittent
Mileage: 109759 km
Time: 12:40:58
Temperature: 78.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Part No SW: 02E 300 042 Q HW: 02E 927 770 AE
Component: GSG DSG 070 0985
Revision: 04507000 Serial number: 00000509060075
Shop #: WSC 00066 000 00000
VCID: 214C67CBF8E2454EA5-8074
Address 03: ABS Brakes Labels: 1K0-614-517-MK60AT.clb
Part No SW: 1K0 614 517 R HW: 1K0 614 517 R
Component: ESP FRONT MK60-AT 0103
Revision: 00T12001
Coding: 0037506
VCID: 3666A497416CD2F660-8062
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BD
Component: ClimatronicPQ35 090 0808
VCID: 6ADE40E74554461634-803E
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000001073229
Coding: 83071E2700041500C70A00000F00000080095D035C000110000000000000
Shop #: WSC 00066 123 12345
VCID: 33609D83521EC7DE47-8066
Component: Wischer 260908 021 0501
Coding: 00038805
Shop #: WSC 00066
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 141
Mileage: 109876 km
Voltage: 14.00 V
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD18GXZD
Coding: 0020788
Shop #: WSC 73430 790 00000
VCID: 3D74BBBB645A01AEA1-8068
Subsystem 1 - Serial number: 6332MSME3D454B0EP
Subsystem 2 - Serial number: 6342MSME3830622C8
01638 - Crash-Sensor for Side Airbag; Rear Drivers Side (G256)
01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257)
01588 - Igniter for Head-Airbag; Drivers Side (N251)
002 - Lower Limit Exceeded - MIL ON
01589 - Igniter for Head-Airbag; Passenger Side (N252)
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 034 0070
Coding: 0012121
VCID: 77F8699306E6EBFEBB-8022
Component: E0221 002 0010
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
Part No: 1K0 920 862 A
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0019503
Shop #: WSC 00011 888 96745
VCID: 285A7AEF9BD8B406E2-807C
010 - Open or Short to Plus
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 120808F1001182
Coding: 6D817F0E0002021002
VCID: 3564A39B5C6AD9EE69-8060
Mileage: 109876 km
Time: 03:28:31
Component: IMMO 3HL 1212
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1519
Revision: 71009005 Serial number: 00000285188828
Coding: 0000180
VCID: 71EC578B6882B5CE75-8024
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 98900A0001060C7F2D0484056008CF03E0FC00
VCID: 03000D43423EB75E97-8056
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1519
Revision: 71009005 Serial number: 00000828888826
Coding: 0000436
VCID: 72EE58876D848ED68C-8026
01735 - Potentiometer for Mirror Adj. Horizontal; Pass. Side
Fault Status: 01101000
Reset counter: 141
Mileage: 109876 km
01737 - Potentiometer for Mirror Adj. Vertical; Pass. Side
Reset counter: 141
Mileage: 109876 km
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74E25E9F179080E69E-8020
Part No SW: 5ND 035 190 B HW: 5ND 035 190 B
Component: RCD510USBRVC 003 0003
Revision: -----001 Serial number: VWZ4Z3R8122891
Coding: 01000425030006
Shop #: WSC 79107 123 12345
VCID: 3B70B5A3BA4E0F9E9F-806E
Reset counter: 141
Mileage: 109876 km
Time: 03:28:29
Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003481160
Coding: 0000144
VCID: 75E4639B1CEA99EEA9-8020
Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003477054
Coding: 0000144
VCID: 76E6649701EC92F6A0-8022
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 12 Einparkhilfe 0101
End-------------------------(Elapsed Time: 02:27)--------------------------
