Yes, thank you to everyone for all of your help!
So all of the warning lights have gone off as far as I can tell. I still get a ding when I start up the vehicle and I'm guessing it has to do with the "Failure to communicate with unit" or whichever code is left in the module. I have no idea what that issue is. I have the indirect so I'm not sure where the issue is.
Note: Airbag malfunction (failure to communicate with occupant sensor) went away after I completed the module function test or whatever it was where I had to turn the wheel between 90 and 180 degrees.
The airflow at idle is too low fault should hopefully go away after I complete a throttle body alignment which brings me to one final issue-
What's the deal with the "Check memory of steering wheel electronics" fault? My cruise control still works fine. I've searched all over with no solutions found. Is it because I recoded the voice command button to a mute button?
Anyways, thanks again to all of you. You all have been such a huge help and I'm glad to finally have and all the other features tied into it on my car.
Here's my latest auto-scan, Jack. Hopefully the information gained will help someone else code their module as well!
Sunday,05,November,2017,19:33:54:15250
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 17.8.0.1 (x64) HEX-V2 : 0.4407.4
VIN: 3VWDX7AJ1BM006318 License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56 77
VIN: 3VWDX7AJ1BM006318 Mileage: 211210km-131239miles
03- Brakes -- Status: Malfunction 0010
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 A HW: 07K 906 055
Component: 2,5l R5/4V G01 9214
Revision: T4H04--- Serial number:
Coding: 0000075
Shop #: 25016 444 13939
VCID: 2C01FA78BA088E47D72-8078
005784 - Please Check Memory of Steering Wheel Electronics
P1698 - 000 - - Intermittent
Fault Frequency: 132
Mileage: 211065 km
Date: 2012.03.27
Time: 18:23:18
Temperature: 93.0°C
Temperature: 66.0°C
Absolute Pres.: 1000.0 mbar
Fault Frequency: 14
Mileage: 211203 km
Date: 2012.03.28
Time: 16:43:19
RPM: 1220 /min
Load: 35.3 %
Speed: 11.0 km/h
Temperature: 90.0°C
Temperature: 63.0°C
012408 - Throttle Control
P3078 - 000 - Airflow at Idle too Low
Mileage: 211097 km
Date: 2012.03.28
Time: 13:47:06
RPM: 790 /min
Load: 34.1 %
Temperature: 89.0°C
Temperature: 54.0°C
Readiness: 0000 0100
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 1741
Revision: 00H90000 Serial number:
Coding: 0000840
Shop #: 00066 000 00000
VCID: 00597EC86600BA275BA-8054
Address 03: Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
Coding: B14B440C492208008D0E22E592211061A70000
Shop #: 00066 123 12345
VCID: 74B122182EB896874F2-8020
Reset counter: 202
Mileage: 211217 km
Date: 2012.03.28
Time: 19:24:30
Count: 2
Count: 12
Count: 28672
Count: 16390
Count: 45312
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 L HW: 5C0 820 047 L
Component: J301 Klimaanlage 0102
Revision: 2000908S Serial number: 00000000034037
VCID: 290F036CB5FA9B6F2C4-807C
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 C HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0226
Revision: B2066001 Serial number: 03311231100025
Coding: 73994BBE08A10B0008382000200A84C400C2502E60000000300000000000
Shop #: 25807 444 59326
VCID: 2D07F77C8D12874FC0C-8078
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3462
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3462
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.019 H08 0006
Serial number: WRH000061ZC
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0017246
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3462
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3462
Coding: 800000
00975 - Heated Rear Window (Z1)
006 - Short to Plus
Fault Status: 01100110
Reset counter: 202
Mileage: 211217 km
Date: 2012.03.28
Time: 19:24:32
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 012 0805
Serial number: 003END07B4B0
Coding: 00003232
Dataset: EV_AirbaVW10SMEVW360 A01017
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FBB2D74471EB55FB20-803A
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1000000FKL0O
Coding: 303143
Serial number: 3572MSME4A713552ZZZU
Serial number: 3582MSME13486553ZZZT
Component: S.Sens.Fahr.H H01 ----
Serial number: 3516KSME44526208ZZZK
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H01 ----
Serial number: 3526KSME34606208ZZZJ
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H01 ----
Serial number: 3556LSME111A0708ZZZM
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H01 ----
Serial number: 3566LSME6D0B0408ZZZ.
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5C6 920 950 D HW: 5C6 920 950 D
Component: KOMBI H07 0406
Coding: 170000
Shop #: 00066 123 00148
Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 2B03F964B386897FDE8-807E
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 0226
Coding: 102001
VCID: 70B92E085AA0AAA7ABA-8024
Mileage: 211217 km
Date: 2012.03.28
Time: 19:24:30
Component: IMMO H07 0406
Shop #: 00000 000 00000
Dataset: EV_Immo_UDS_VDD_RM09 A03008
VCID: 6A8D3C607CFC5077E5E-803E
Part No SW: 5ND 035 190 A HW: 5ND 035 190 A
Component: RCD510USBRVC 001 0003
Revision: -----001 Serial number: VWZ4Z3M8135616
Coding: 05000424040006
Shop #: 00081 790 00128
VCID: 3A2DCC204C5C20F755E-806E
00856 - Radio Antenna
Reset counter: 202
Mileage: 211217 km
Date: 2012.03.28
Time: 19:24:29
Reset counter: 202
Mileage: 211217 km
Date: 2012.03.28
Time: 19:31:09
00877 - Treble Speaker Rear Right (R16)
Reset counter: 202
Mileage: 211217 km
Date: 2012.03.28
Time: 19:31:09
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668295109
Coding: 0A00000000010100
Shop #: 01383 790 50316
Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 323DE40094ACD8B79DE-8066
9457425 - Left audio channel for speech/telephone
B104F 11 [001] - Short to GND
9457169 - Right audio channel for speech/telephone
B104E 11 [001] - Short to GND
End----------(Elapsed Time: 01:20, VBatt start/end: 12.6V/12.6V)-----------
