RCD330 Plus install - composite rear view camera
tony.young4650
Australia
C?ID=316617
I have installed my new RCD330 Plus.
Everything seems to work fine, including the park assist view.
I am trying to get my composite rear view camera working now.
I know the camera is fine, as immediately before installing the new radio I removed the existing standalone rear view camera screen from the vehicle.
I swapped out the blue plug socket for the composite video one supplied with the radio.
I enabled "back-up camera installed" in the radio module. The enabled the icon on the park pilot screen when I select reverse, but nothing happens when I press that then. With this enable it also seems to disable the on/off button, and the only way was to disable, then unplugged the radio to reset things.
I tried the camera setting in the Park/Steer Assist module, but that seemed to have no affect either.
I also had some trouble with the antenna adaptor. I had to trim some plastic off the plugs to make them match the sockets, and even then they don't really fit. I ended up just plugging one in. FM seems to work fine like that.
pictures here --> https://imgur.com/a/ujlb2
Chassis Type: 5N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 52 53 56 61
          62 72 77
VIN: WVGZZZ5NZEW039739   Mileage: 44470km-27632miles
   Part No SW: 03L 906 018 FQ    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H28 4573
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00250032042701080000
   ASAM Dataset: EV_ECM20TDI01103L906018FQ 003011
   ROD: EV_ECM20TDI01103L906018FQ.rod
   VCID: 7EA6F611E0784847296-802A
   Part No SW: 0BH 300 012 A    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H08 2236
   Revision: 00H08V01
   VCID: 211CED6D3146D7BF744-8074
   Part No SW: 5N0 614 109 BC    HW: 5N0 614 109 BC
   Component: J104   C6 450M V4F2 0011
   Revision: --H07---    Serial number: 00000007420963
   Coding: 0052545
   VCID: 6D84C15DB19EC3DF80C-8038
   Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010002003
   VCID: 79ACE50DF9566F7F1C4-802C
   Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
   Component: BCM PQ35 M    122 0173
   Revision: BC122001
   Coding: 40180A3B802518C0408800C0340081644B51AA88436D81606480C7000041
   VCID: 42DE42E1D480ECA70DE-8016
   Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 14091  013 0204
   Serial number: N2955119   °204!
   Coding: 009795
   Component: RLS 130913 05  54  0403
   Coding: 02304D
                    Reset counter: 2
                    Mileage: 44098 km
                    Date: 2017.10.22
                    Time: 08:41:29
                    Voltage: 11.00 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56231326101200
   Coding: 049303
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000.rod
   VCID: 44D244F9CE14E2973F2-8010
   Component: J234__20B VW10 HI   2118
   Revision: 26019000    Serial number: 003L7PK12EFM
   Coding: 0012354
   VCID: 7CA2FC19FAE45A57072-8028
   Subsystem 1 - Serial number: 6332MTS601772393
   Subsystem 2 - Serial number: 6342MTS618962383
   Subsystem 3 - Serial number: 6351HTS6AAR98CKJ
   Subsystem 4 - Serial number: 6361HTS6HDNB8CKJ
   Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Revision: FF010042    Serial number: 20130917200809
   Coding: 1882140000
   ROD: EV_SMLSNGVOLWS.rod
   Coding: 820000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 5N0 920 873 C    HW: 5N0 920 873 C
   Coding: 111F00
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
   VCID: 333017259BBA552F968-8066
   Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1642
   Revision:   H58       Serial number: 130913F1000153
   Coding: 356003
   VCID: 7AAEFA01FCD0646715E-802E
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: 4DC461DD11DE23DFE0C-8018
   VCID: 6A8ECA418CF0D4E7E5E-803E
Address 2E: Media Player 3
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0504
   Revision: 13110009    Serial number: 0007459135
   Coding: 0202BC
   VCID: 382A200982DCB677A3A-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1504
   Serial number: 00000008199985
   Coding: 000090
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 202    3501
   Revision: 00H22000
   Shop #: WSC 01324 785 00200
   VCID: 40DA48E9D68CFEB71BA-8014
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0504
   Revision: 15110009    Serial number: 0007455888
   Coding: 0202BC
   VCID: 392C250DB9D6AF7F5C4-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1504
   Serial number: 00000008209798
   Coding: 000090
   Revision:   H19       Serial number: 00000001416766
   Coding: 0026167
   VCID: 36362E3184484007B16-8062
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         534 5314
   Revision: --------    Serial number: VWZZZ4H6245739
   Coding: 16000400040005
   Shop #: WSC 00078 790 00185
   VCID: 46D65EF1F8A8D087216-8012
   Component: Batt.regelung H58 1642
   Coding: 330F1859
   VCID: 71BCDD2DA1A6273FA44-8024
   Component: J367-BDM  H07 0180
   Serial number: 40252945221491040234
   Part No SW: 5N0 035 729     HW: 5N0 035 729
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007665234274
   Coding: 0A01000080010101
   ROD: EV_UHVUMI.rod
   VCID: 6D84C15DBD1EC3DF80C-8038
End----(Elapsed Time: 01:21, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
tony.young4650
Australia
C?ID=316617
update
I was fiddling was the settings in Park Assist using the long code feature and i changed the rear camera setting to "japanese camera". VCDS kind of locked up, and now I seem to be getting lots of errors :-( how do I go about resetting the code to start with?
new scan as follows -->
          62 72 77
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine
Address 15: Airbags
   Coding: 111F00
   Coding: 356003
01304 - Radio
                    Fault Status: 00110100
                    Reset counter: 26
                    Mileage: 44470 km
                    Date: 2017.11.04
                    Time: 10:24:17
Address 22: AWD
   Coding: 0202BC
   Slave Driver:
   Coding: 000090
Address 46: Central Conv.
   Coding: 0202BC
   Slave Passenger:
   Coding: 000090
   Coding: 1600040004000C
   Coding: 330F1859
End----(Elapsed Time: 00:53, VBatt start/end: 12.3V/12.2V. VIgn 0.0V)------
update
End----(Elapsed Time: 00:53, VBatt start/end: 12.3V/12.2V. [B][COLOR="#0000FF"]VIgn 0.0V[/COLOR][/B])------
Ignition looks to be off?
m87a
Bosnia and Herzegovina
C?ID=156900
for any camera to work on rcd330g there is a timer delay kit which can be bought on aliexpress for camera to work. Without this timer delay camera will work only once and after that it will just say not ready or something like that
also in Address 10: Park/Steer Assist (J791) look in adaptation channels ops display and from OPS switch to automatic or camera
tony.young4650
Australia
C?ID=316617
must have been something like.
Seems all ok again now, but still no idea how to get the camera working :-(
          62 72 77
VIN: WVGZZZ5NZEW039739   Mileage: 44590km-27706miles
   Revision: 00H08V01
   Component: J104   C6 450M V4FD 0011
   Coding: 0052545
   Revision: 00001004
   Coding: 0010002003
   Revision: BC122001
   Coding: 009795
   Coding: 02304D
                    Reset counter: 27
                    Mileage: 44098 km
                    Date: 2017.10.22
                    Time: 08:41:29
                    Voltage: 11.00 V
                    Fault Status: 00101010
                    Reset counter: 34
                    Mileage: 44563 km
                    Date: 2017.11.08
                    Time: 17:58:31
                    Voltage: 11.70 V
   Coding: 249303
   Coding: 0012354
   Coding: 1882140000
   Coding: 820000
   Coding: 111F00
   Coding: 356003
01304 - Radio
                    Reset counter: 26
                    Mileage: 44470 km
                    Date: 2017.11.04
                    Time: 10:24:17
   Coding: 0000005
   Coding: 0202BC
   Slave Driver:
   Coding: 000090
   Revision: 00H22000
   Coding: 0202BC
   Slave Passenger:
   Coding: 000090
   Coding: 0026167
   Coding: 330F1859
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:20, VBatt start/end: 12.1V/12.1V)-----------
downtime
Finland
C?ID=280813
From where are you getting power to the camera? Also did you get the +12v trigger signal from backup light or what?
tony.young4650
Australia
C?ID=316617
it was all wired in when i purchased the vehicle, but I did tidy up the mess of wires recently. It pulls power off a circuit at rear of the vehicle somewhere and it has a relay wired in with the backup light acting as the trigger for the relay. does that make sense?
I assume it has been done like that because the backup light circuit wouldn't like the current draw if connected directly.
it worked perfectly on the small standalone screen before I re-routed it to the RCD330
It doesn't have a delay relay in the circuit (yet). But I assume it should at least work initially without that, even if it then throws up some errors.
downtime
Finland
C?ID=280813
Double check that the composite connection is ok.
And as you have removed the blue plug, did you notice that there's 3 wires there? You should not remove the blue plug but instead you should get repair wire with correct connectors, insert them to the plug and the solder the composite wires to those. You can get repair wire with connectors on both ends quite cheap from official dealer.
You can also buy ready made adapter from Aliexpress like this :
https://ae01.alicdn.com/kf/HTB1bzST...t-b-View-b-font-font-b-Camera-b-font-font.jpg
And then just insert the three wires from the existing plug into that one.
tony.young4650
Australia
C?ID=316617
I have swapped out the old plug for the new one as per your picture, that came with the RCD330.
tony.young4650
Australia
C?ID=316617
ok. I am a complete newby to VCDS, so I will have another play and try and see what you mean by adaptation.
cheers
tony.young4650
Australia
C?ID=316617
I have got a bit further now thanks.
I changed the channel 10 adaptation to "rear camera" as suggested
And also long code 56-Radio, Byte 3, Bit 6 to "Back-up camera installed"
I now get the screen what I assume should be the camera vision, but then after a couple of seconds it changes to the screen that says
The "rear view" camera system is not currently available
pictures here --> https://imgur.com/a/7TLor
m87a
C?ID=156900
in adaptation change from rear camera to automatic, test this, it should change automatically either ops or camera, try to put in reverse then drive and again in reverse, from experience automatic is best, if you leave at rear camera, sometimes when you quickly go from reverse to drive and again reverse it just stays at OPS display, it won't change back automatically to camera
you're gonna need this adapter for camera to work not just once, this is timer delay voltage, meaning it will leave camera on for another 6-8 seconds on to work, so RCD will recognise that and there will be no more that rear view camera not available
https://www.aliexpress.com/item/Time-delay-device-Box-For-RCD330-AV-REAR-VIEW-CAMERA/32792452700.html?spm=2114.search0104.8.3.mj3dbf
you just get black image? check power to your camera, and signal wire
tony.young4650
Australia
C?ID=316617
m87a
C?ID=156900
i don't know about that smaller one, i have only used bigger one and i know it work 100%, but it could be that smaller one also works
