2017 Passat SEL (NMS) ACC How to Enable Automatic Drive Away After Short Stop?
nhdoc
C?ID=98855
I have a 2017 SEL and would like to enable the "automatic drive away after short stop" and "automatic drive away by pre-trigger" (touching gas pedal) features but checking the boxes in the long coding section of controller 13 doesn't enable this feature on my car - it makes no difference. Have you got any ideas on what coding changes are necessary for this to get accomplished? My controller 13 is 7N0 907 572 C and the standard coding is 01001002FE0739. Anyone??
hadez16
C?ID=289891
This is only possible with the additional traffic jam assist which depends on parameters of your A5 camera which you cannot reach via VCDS.
nhdoc
C?ID=98855
Thank you for your reply. My understanding is that traffic jam assist combines the drive-away function with lane tracking but the North America version cars like the Golf don't have traffic jam assist enabled but still have the automatic drive away feature enabled so it seems like it should be something that would be codeable without the changes to the camera settings but maybe I am wrong. Plus, you say the changes cannot be reached with VCDS but wouldn't it just be a matter of knowing what byte/bit controls this and changing the coding?
hadez16
C?ID=289891
ACC stops working after 2 seconds of standstill.
Any automatic driveaway would make the "traffic jam assist" senseless as this feature gets sold especially with that feature advertised. You're right that traffic jam assist is ACC+LaneAssist at low speed.
And no, there exist bits and bytes beyond coding and adaptation which cannot be changed with VCDS but include functions to be enabled/disabled.
nhdoc
C?ID=98855
OK, you obviously know more than I do.
I do know there have been people who have succesfully enabled the drive away function on cars in which it was not turned on and they do not have traffic jam assist but this was on the Golf, not on the Passat. I had just hoped that there was a way to do that exact same thing (and yes, I do know that it has a 3 second limit but after that just a touch of the gas pedal resumes cruise). On my car it will disengage below about 15MPH and in order to resume I have to speed back up and press resume button. So all I wanted was these two features turned on, like what was described in this thread, just for the 2017 Passat instead of the Golf:
http://forums.vwvortex.com/showthre...ive-away-After-Short-Stop-quot-with-OBDEleven
nhdoc: I'm not familiar with 2017 Passat, but I find that many (all?) of the long coding descriptors that appear on VCP and OBD11 also now appear in the new "yellow" long coding helper screens on VCDS -which is an excellent facility!
Given that the 2017 Passat does have a MQB platform - like the Golf, have you actually scrolled through the "yellow" long coding helper screens on the module @ address hex13 for something similar looking to "Automatic_driveaway_after_short_stop" and "Automatic_driveaway_by_pretrigger".
The NMS Passat sold in the US isn't all that MQB-like. I'm pretty sure there are still some non-UDS modules in it.
Of course, it couldn't hurt if nhdoc would post an Auto-Scan from this car.
nhdoc
C?ID=98855
I did go into long coding helper for controller 13 and found the boxes with those labels unchecked. I checked them and saved the new coding but the functions did not enable. The car behaved exactly as it did before I had checked them, so I put them back to the original settings.
Tomorrow I will auto scan my car and post the results. Thanks to everyone who is trying to help!
nhdoc
C?ID=98855
Sunday,05,November,2017,09:31:20:28013
VCDS Version: 17.8.0.1
VIN: 1VWCT7A36HC083060   License Plate: PASSAT
Mileage: 660km-410mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 36 3C 42 44 46 47
          4F 52 5F 61 62 72 75 A5
VIN: 1VWCT7A36HC083060   Mileage: 660km-410miles
Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 BJ    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 3685
   Revision: --H13---
   Coding: 001A0092244400179000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_ECM18TFS02006K906071BJ 001006
   ROD: EV_ECM18TFS02006K906071BJ.rod
   VCID: 74E7FE2FDFD642E69E-8020
   Part No SW: 09G 927 158 BD    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3121
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 76E3C427C9AA50F6A0-8022
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F5492A00FDA30B03EA9219004100F1F01A
   VCID: 75E1C32BDCAC5BEEA9-8020
   Part No SW: 5K0 959 434 H    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1308
   Revision: 00093000    Serial number: 0437183118
   Coding: 132C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: 3A7B1017BD32F49684-806E
   Slave 1:
   Subsystem 1 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 66009<24
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 13 [008] - Open Circuit
                    Reset counter: 63
                    Mileage: 652 km
                    Date: 2017.11.03
                    Time: 08:04:59
   Part No SW: 561 907 044 BD    HW: 561 907 044 BD
   Component: Climatronic   H08 0910
   Revision: 00001K05
   Coding: 0050019012
   VCID: 5ABBB0975D721496A4-800E
   Part No SW: 5K0 937 087 AL    HW: 5K0 937 087 AL
   Component: BCM PQ35 H++  122 0184
   Revision: BN122001
   Coding: EF200E1B982B08D4098806013400854800F1000645A00DB0E4806200BC70
   VCID: 7F0D2103EE9011BEF3-802A
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 280317 04  42  0106
   Coding: 0038DD
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0480
   Revision: --------    Serial number: 39461709300391
   Coding: 0031165011
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00.rod
   VCID: 3B751513B208CD9E9F-806E
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 21021704394156
   Coding: 01001002FE0739
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 36630427892A10F660-8062
1024 - Databus
                    Reset counter: 64
                    Mileage: 661 km
                    Date: 2017.11.03
                    Time: 09:21:39
                    Control Module temperature: 36 °C
                    Voltage terminal 15: 12.1 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
0275 - Databus
                    Reset counter: 64
                    Mileage: 661 km
                    Date: 2017.11.03
                    Time: 09:21:35
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM0D95A-
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 63C58D736A38D55EF7-8036
   Serial number: IBH0000000000079CAUS
   Coding: 30324A
   Subsystem 2 - Part No SW: -----------    HW: 480 001 204 17
   Serial number: 357000000005473CD22K
   Subsystem 3 - Part No SW: -----------    HW: 480 002 704 17
   Serial number: 35800000000A8AC0832Q
   Subsystem 4 - Part No SW: -----------    HW: 480 021 304 17
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001B924A8C52E55B
   Subsystem 5 - Part No SW: -----------    HW: 480 021 504 17
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001C124D8E62461+
   Subsystem 6 - Part No SW: -----------    HW: 480 021 403 17
   Component: FrontSensor_D  000 0189
   Serial number: 3550001992465B42367$
   Subsystem 7 - Part No SW: -----------    HW: 480 021 403 17
   Component: FrontSensor_P  000 0189
   Serial number: 3560001992465B45D221
   Part No SW: 1K5 953 521 CS    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20170411201829
   Coding: 2002C40008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 000FA2FF9B6E6E468A-8054
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 0931702543100288AF1B
   Coding: 2C0000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 561 920 981 B    HW: 561 920 981 B
   Coding: 221E010000
   VCID: 1B35F59312C8AD9E7F-804E
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 12051703010257
   Coding: 461010
   VCID: 7BF5D513FA880D9EDF-802E
   Component: IMMO          H03 1104
   Coding: 000007
   VCID: 6ADBE0578D12841634-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 17000101769001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3169373B604437CE35-8064
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0183
   Revision: AA000000    Serial number: 00000236222203
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 224BC8773DA29C56BC-8076
Address 3C: Lane Change (J1086)       Labels:* None
   Serial number: 0438953985
   Coding: 02011102
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C77160FB706CAA696-8068
   Lane Change Assistant 2:
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0010942159
   Coding: 3415FD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E33FC8701DAB8B698-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14202746170609145521
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 313    3501
   Revision: 00H22000
   Shop #: WSC 19460 666 12345
   VCID: 39790F1B7034FF8E8D-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0135070
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 285FDA5F539E7606E2-807C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1682
   Coding: 01030108
   VCID: 6FEDF143BEF0613E63-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011700300499
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  002 0003
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0010966041
   Coding: 3415FC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F4DC18306D0B1BE93-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14202747170609123846
   Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
   Component: MU-S-NS-US    H31 0359
   Serial number: VWZAZ2T1128520
   Coding: 02140102AA00000051220003001808009F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2447CE6F2FB69266CE-8070
   Subsystem 1 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
   Component: Batt.regelung H56 1682
   Coding: E1200859
   VCID: 71E9F73BA8C477CE75-8024
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0160
   Serial number: 000003554140563
   Coding: 02140102C24232107F1606000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 14279EAFFF16E2E63E-8040
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 10041711K20446
   Coding: 000401010001020100201346C080800080000E200000
   ROD: EV_MFKBoschMQBB_VW36.rod
End-------------------------(Elapsed Time: 04:53)--------------------------
nhdoc
C?ID=98855
I have posted the results of the auto scan above. The faults in the controller 13 from a couple of days ago are probably as a result of my trying a long code I found online for another model but when I tried it in my car I got an error message upon putting the car into drive, so I went back to the default code and no further issues have resulted from that. I also got a "key not found" error when I was scanning - might just have been interference from the laptop in the car though.
hadez16
C?ID=289891
This thread from VWVortex is quite interesting, I'll doublecheck that when I have some time.
dnoermann
C?ID=358118
I like to warm this UP again :)
So the Passat in discussion is still PQ based, using the BOSCH MRREVO ACC for the PQ.
And here is a quote from the VW Manual for VW Sharan 2019 which uses same ACC.
Stop-and-go traffic
ACC can brake vehicles with DSG® dual clutch gearbox to a standstill and hold them stationary. ACC remains active. As soon as you accelerate to at least 2 km/h, ACC control is resumed.
So we have a "light" Stop and Go function here, with 7N0 Radar in PQ Plattform.
In MQB the "ACC Stop & Go" is a special Swap Code in Radar, but that one is not available in PQ Version.
Now the question is, how to get it enabled in other PQ Cars than Sharan.
From my research:
- Precondition is EPB and Autohold, to let the Car stay still
This is probably possible with the Mk60EC ABS together with China EPB Controller (for all those PQ based Golf's)
- ABS is a crucial Factor (Sharan does have ABS with integrated EPB)
- ACC Dataset is probably important, too.
I myself am trying to get that working in my T5 (with retrofitted ACC from T6) and i have gathered some friends with T6 and Passat NMS who have same Goal :)
Anyone who like to share knowledge is very welcome.
dnoermann
C?ID=358118
I have to add, that VW Manual is refering to DSG as well as Automatic Gear box.
In both cases is Stop-and-go possible.
