VW 1k0959703K door module software
golfi_vend
Tartu, Estonia
C?ID=195131
Hello
I have MY2007 buggy software rear door module. Dana suggested that the EEPROM needs upgrading, but when i visited my dealer for other stuff and briefly asked, they said no software was available. Also when searching online, i didn't found any signs that corresponding .sgo file exist, not on 10.2013 VAS PC DVD anyway.
My question is, can someone confirm, there is a software for my buggy door module? Although no faults in operation are present, I'd like to have a fault free car.
Dana said:
2007 Golf:
2007 model year 4 door Golf/GTI and Eos models had a noted issue with the software in the rear door controllers. After low voltage conditions any number of faults, or serious functionality concerns such as the window going UP when DOWN was selected and DOWN when UP was selected, are not uncommon.
The US market TPI is 2015050 and the RoW should be 2015433/12 but the modifications are made directly to the EEPROM of the module with the factory scan tool to correct the buggy software. VCDS cannot perform this modification so you may want to try the VW local dealer before replacing the controller if it is causing any functionality concerns. However, if the vehicle does not have any functionality concerns .. you may consider leaving it alone and ignoring that fault code for now.
Best Regards,
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         005 0913
   Coding: 0000144
   Shop #: WSC 30198 264 1012551
   VCID: 387FDAA54B5509FA2B-806D
00102 - Rear Left Interior Locking Button (E310)
Thursday,04,September,2014,17:48:35:01666
VCDS Version: 14.8.0.0 (x64)
Data version: 20140822
Workshop Code: 257 66565 000032
VIN: WVWZZZ1KZ7Wxxxxxx   License Plate: MINU OMA ECU UUENDUS
Mileage: 184730km-114785mi   Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 62 72 76
          7D
VIN: WVWZZZ1KZ7Wxxxxxx  Mileage: 184730km-114785miles
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 JG    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  9967
   Revision: --H06---    Serial number: VWZBZ0F0503310
   Coding: 0000172
   Shop #: WSC 74565 000 00000
   VCID: 6DD13BF174977C5208-8038
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0006786
   Shop #: WSC 01279 785 00200
   VCID: 72EB288D6DA9A3AAD5-8027
   Part No SW: 1K0 907 044 BH    HW: 1K0 907 044 BH
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: 6ED33CFD7991874A31-803B
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000006142618
   Coding: EF0A0E07001E1500001400641400000080397F0D5C
   Shop #: WSC 66565 257 00032
   VCID: 2B55F5E98A03B26256-807E
   Component: Wischer 300806 020  0501
   Coding: 00040853
   Shop #: WSC 66565
   Component: RLS     110414 054  0403
   Coding: 00340141
   Shop #: WSC 66565
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0STKC9
   Coding: 0013111
   Shop #: WSC 01269 785 00200
   VCID: 3D71CBB164772CD2F8-8068
   Subsystem 1 - Serial number: 6332MSME1329655BD
   Subsystem 2 - Serial number: 6342MSME120509672
   Subsystem 3 - Serial number: 6352QSME14301B1FD
   Subsystem 4 - Serial number: 6362QSME1348131DC
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0000034
   VCID: 7AFB00AD35D9DBEA9D-802F
   Part No SW: 1K0 920 873 B    HW: 1K0 920 873 B
   Revision: V0003000    Serial number: VWZBZ0F0503310
   Coding: 0023103
   Coding: 0023103
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 020610F2001428
   Coding: E9837F1E40020200000002
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 F
   Component: Haldex 4Motion      0115
   Coding: 0000001
   VCID: 55A17311BC07D492D0-8000
   Component: IMMO            VDD 1610
   Shop #: WSC 01342 020 12345
Address 37: Navigation        Labels: 1K0-035-191.lbl
   Part No SW: 1K0 035 191 D    HW: 1K0 035 191 D
   Component: J401                0303
   Revision: 00018000    Serial number: VWZ1Z2H8044242
   Coding: 0041400
   VCID: 23451DC9E2D37A22EE-8076
                    Reset counter: 25
                    Mileage: 184730 km
                    Time: 17:44:31
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         005 0971
   Coding: 0000183
   VCID: 3979DFA1705F10F2D4-806C
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   VCID: 3467EE95573DED9A07-8061
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component:    KSG PQ35 G2  020 0203
   Coding: 00900A005103487F00020505E0000F02407F40
   VCID: 03057D4942139A22CE-8056
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000182
   VCID: 3A7BC0AD75591BEADD-806F
   Part No: 1T0 907 357
   Coding: 0000004
   VCID: 74E72E9517BDAD9AC7-8021
Address 56: Radio        Labels: 1K0-035-191.lbl
   Component: R                   0303
   Coding: 0041400
                    Reset counter: 25
                    Mileage: 184730 km
                    Time: 17:44:31
   Coding: 0000144
   Part No SW: 5K0 959 704     HW: 5K0 959 704
   Component: Tuer-SG         007 2106
   Coding: 0000144
   Shop #: WSC 01279 785 1012551
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D51FBF1B417BC5248-8078
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
End-------------------------(Elapsed Time: 03:13)--------------------------
golfi_vend
Tartu, Estonia
C?ID=195131
This problem is now solved after 2 years. :)
VW Tool ODIS did some magic and now fault is dissapeared.
Tuesday,23,February,2016,04:02:44:36026
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWZZZ1KZ7Wxxxxxx   License Plate: MINU OMA DOOR R.LEFT
Mileage: 230770km-143393mi   Repair Order:
Scan: 01 03 08 09 15 16 17 18 19 22 25 37 42 44 46 52 55 56 62 72
          76 77
VIN: WVWZZZ1KZ7Wxxxxxx   Mileage: 230770km-143393miles
   Component: R4 2,0L EDC G200SG  9967
   Coding: 0000172
   VCID: ED9282F8F41DC45625-80B8
   Revision: 00H13001
   Coding: 0006786
   VCID: F2A89184ED231BAEF8-80A6
   Part No SW: 5K0 907 044 GM    HW: 5K0 907 044 GM
   Component: Climatronic   H19 1212
   Revision: 00001004
   Coding: 0018000002
   Shop #: WSC 00066 123 00119
   VCID: FCB4BFBC77675DDEA2-80A8
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 8
                    Reset counter: 122
                    Mileage: 230434 km
                    Date: 2016.02.21
                    Time: 20:38:32
9479699 - Control Circuit for Front Left Seat Heater
          B10A6 13 [009] - Open Circuit
                    Reset counter: 122
                    Mileage: 230763 km
                    Date: 2016.02.23
                    Time: 00:26:26
   Part No SW: 3C8 937 049 AC    HW: 3C8 937 049 AC
   Component: Bordnetz-SG     H64 3205
   Revision: 00H64000    Serial number: 00000004701270
   Coding: EF0A0E87001E1500FF148A00140000008039360D6410010C004000000000
   Coding: 00040853
   Shop #: WSC 12345
   Coding: 00338733
   Shop #: WSC 12345
   Coding: 0013111
   VCID: BD3272B8E4FD94D6D5-80E8
   Coding: 0000732
   VCID: FAB8B9A4B55363EEB0-80AE
   Subsystem 1 - Part No: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6   H07 0023
   Coding: 00000226
   Part No SW: 1K8 920 873 A    HW: 1K8 920 873 A
   Coding: 171F01
   Shop #: WSC 00020 999 12345
   VCID: B2285184E5A35BAE38-80E6
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 1K0 815 007 BC
   Component: Standheizer     041 4709
   Revision: 00041000    Serial number: 09011075000000
   Coding: 0021012
   VCID: E680FDD4D1EBF70E64-80B2
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 28011400F13305
   Coding: 350002
   Shop #: WSC 74565 123 12345
   VCID: F2A891842D231BAEF8-80A6
   Coding: 0000001
   VCID: B02C5B8C23AF69BE4E-80E4
   VCID: EA9889E40DF3D36E40-80BE
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 H
   Component: RNS-MID       H64 5238
   Revision: AB001001    Serial number: VWZ6Z7M7174093
   Coding: 00000402040000A10000
   Shop #: WSC 46949 133 86817
   VCID: BB367CA03AE99AE6EB-80EE
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V13  8350
   Coding: 0000246
   VCID: B93A66A8F0D5A8F6F9-80EC
   VCID: B424579CD7B7559E2A-80E0
   Coding: 00900A005103483E00020F0FE0008FCA507F40
   VCID: 8346C440C2992226E3-80D6
   Subsystem 5 - Part No: 1K0 947 291 F
   Component: Innenraumueberw.009 4809
   Coding: 00000000
   Shop #: WSC 66565
   Subsystem 6 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Subsystem 7 - Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Coding: 0000502
   VCID: BA3879A4F5D3A3EEF0-80EE
   Coding: 0000004
   VCID: F4A4979C9737159EEA-80A0
   Coding: 0000208
   Shop #: WSC 66565 257 1012551
   VCID: B83C63ACCBDFB1FE06-80EC
   Coding: 0000208
   VCID: AD1242F8349D045665-80F8
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0982
   Revision: --------    Serial number: 35502105137557
   Coding: 020100010100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_SE36.rod
   VCID: A404A7DCAF57C51EBA-80F0
End-------------------------(Elapsed Time: 01:49)--------------------------
Jef
HQ
The only magic I see here is the soft coding changed.
Still has the same 1K0 959 703 K part number. And the software level is still 0913.
Soft coding went from 0000144 t0 0000208. That means the following was added to the coding:
+0000064 - Door Exit/Warning Light installed (PR-QQ4)
If there was a reflash, it would appear to be the same as what it had before. But if it fixed the issue, I'm not going to question success too much.
Thanks for the follow up scan. :thumbs:
Spacewalker
Poland
C?ID=159607
Do a 1+2+4+8+16+32........ is difficult this time
golfi_vend
Tartu, Estonia
C?ID=195131
Nope it did some magic. Coding is changed, because i added exit lights after years.
I did observe the process and it did write something directly to module blocks.
