HEX V2 not working at all
leonomassive
C?ID=307243
I have the HEX V2 using the USB interface. I connected it to my laptop and started up the VCDS application. The HEX V2 plug flashes green twice on one side and turns off. It is unable to recognize the HEX V2 device and does not make any connection. I clicked test and I got the pop up " Ross-Tech USB interface Not Found". Please help , what should I do?
What's the behavior of the LEDs if you plug it into a car? (No computer, just a car)?
Shaun
With interface plugged in, try opening the VCIConfig utility and checking for updates.
leonomassive
C?ID=307243
Hex V2 no response
I have the hex v2 diagnostic tool and was initially trying to scan my Audi B6 1.8t. When I plugged everything up to the port, the Hex v2 flashed yellow constantly and never turned green... What does that mean? It won't let me scan the vehicle at all.
Also, I tried updating my software to see if that might be the problem and it doesn't recognize the Hex v2 when it's plugged into my laptop, I tried all 3 USB ports and nothing worked. What do I need to do to get this working? Please help.
Flashing yellow when just plugged into a car is correct/normal.
I'm guessing you have a defective USB cable. Do you have a regular USB A to USB B "printer" cable somewhere you can try?
We'll get another USB cable sent out to you. Please confirm you're still at the same address we shipped the HEX-V2 to.
leonomassive
C?ID=307243
It flashes yellow constantly with no connection to the laptop. When I try to update after clicking config , the "update" is not clickable.
I'll try the usb A Or B cable in the morning.
Yes I'm at the same address that it was shipped to. (Zip code 32207), thank you for posting promptly. I really appreciate you.
leonomassive
C?ID=307243
I tried a printer USB A/B cable and connected it to the car. The Hex V2 tool flashed maybe green 3-4x (on the left side of the tool) then flashed yellow continuously. I received a "Failure to communicate" message.
Now when I plug it up to the laptop alone using the printer USB A/B cord, it didn't do anything(no lights flashing).
Shoot an e-mail to Support@... and we'll get you an RMA for the whole thing so we can check it out. Please include a link to this thread.
Thanks, we received the email. You will have a reply from me shortly.
Internal ref to RMA Number 171030RA2
leonomassive
C?ID=307243
Thank you. I appreciate your help.
geforce007
C?ID=303008
hi there any chance you can help me.
am having the same issue with my lead.
tried everything and nothing seem to work.
Mike@Gendan
Swansea, UK
C?ID=57030
When you say the same issue, is the LED behaviour the same?
If you just plug it into the USB (not the car), what colour are the LEDs?
geforce007
C?ID=303008
Hi thanks for getting back to me.
If I plug only the USB in I get nothing no led at all.
geforce007
C?ID=303008
I plugged it into car.
I get about 3 green flashes on the left side a quick ref green then stays flashing yellow.
Mike@Gendan
Swansea, UK
C?ID=57030
Silly question, but I have to ask. I assume the other end of the USB cable was plugged into a PC at the same time?
Do you have any other USB cables you could try? Just a standard printer cable will do.
geforce007
C?ID=303008
Hi I get the same if I plug it into car with laptop or without laptop I get same.
I have a brand new printer lead that works and tried that.
geforce007
C?ID=303008
Am getting unknown usb device in device manager
Mike@Gendan
Swansea, UK
C?ID=57030
Have you used a power invertor to power your laptop from the car's 12v socket while using VCDS by any chance?
I could be wrong but it sounds to me like it could be a ground loop failure.
geforce007
C?ID=303008
Nope not used one I did have like I always have the laptop charger plugged in along with extension lead.
