Steering wheel controller retrofit
kreativ
Hidden
C?ID=108852
Hello
I have just swapped my old steering wheel electronics in my Octavia 3 MY2016 from 5Q0 953 569 A to 5Q0 953 569 B to support steering wheel heater.
While trying to recode the module I get error 31 access denied :confused: I can't code byte 00, bit 4-6 which will allow the ecu to accept if I have GRA or ACC installed other bits work fine
5Q0 953 569 B is also installed in new Octavia FL MY 2017.
My ACC has stopped working and I can't recode from 8410 to E400 so ecu will accept that I got ACC, right now says no css installed. I don't remember to use any login code before coding?
Also error in Motor electronics with no communication with steering wheel controller :-?
I have swapped old pins from 16pin connector to 14pin connector:
16pin
pin1 kl30
pin2 kl31
pin3 can low
pin4 can high
pin5 GRA
pin6 J623 kl50
pin7 J519 kl86s
pin8 LIN
pin9 not in use
pin10 not in use
pin11 not in use
pin12 not in use
pin13 not in use
pin14 J519 kl15
pin15 not in use
pin16 J519 kl15
14pin
pin1 kl30 (Steering wheel heater)
pin2 kl31
pin3 not in use
pin4 kl31
pin5 can low
pin6 can high
pin7 GRA
pin8 kl31 (Steering wheel heater)
pin9 not in use
pin10 J519 kl15
pin11 J519 kl15
pin12 J519 kl86s
pin13 J623 kl50
pin14 LIN
New electronics
   Part No SW: 3Q0 953 521 AM    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0185
   Revision: FF033033    Serial number: 20150129500568
   Coding: 8410
   Shop #: WSC 13464 345 64685
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
   ROD: EV_SMLSVALEOMQBLRH_VW27.rod
   VCID: 7BFEEF37F224289EDF-802E
Old electronics
Address 16: Steering wheel (J524)       Labels:| User\5Q0-953-569.lbl
   Part No SW: 5Q0 953 521 M    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160202501318
   Coding: E400
   Shop #: WSC 24567 354 49275
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 3C7C2C2BB7AAEFA696-8068
Full autoscan
Sunday,22,October,2017,11:32:49:49480
VCDS Version: 17.8.0.1 (x64)
Dealer/Shop Name: VAG SERVICE
Workshop Code: 345 13464 064685
VIN: TMBJB9NEXGxxxxx License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 47 52 55 5F 65 6C 6D
A5
Address 01: Engine (J623-CYVB) Labels:. User\04E-906-027.lbl
Part No SW: 04E 906 027 GR HW: 04E 907 309 BL
Component: R4 1.2l TFS H23 2394
Revision: R4H23---
Coding: 01190072234419080000
ASAM Dataset: EV_ECM12TFS01104E906027GR 001005
ROD: EV_ECM12TFS01104E906027GR.rod
VCID: 7AF0EA33FD1E1196C4-802E
CAN Converter 01:
4714 - Steering Column Control Module
U0212 00 [039] - No Communications
Mileage: 38392 km
Date: 2017.10.22
Time: 11:21:36
Engine speed: 752.00 /min
Normed load value: 37.6 %
Coolant temperature: 43 °C
Intake air temperature: 12 °C
Voltage terminal 30: 14.347 V
Outside air temperature: 11 °C
Absolute intake pressure: 48 kPa abs
Engine torque: 35.7 Nm
Fuel level: 14.00 l
Oxygen sensor bank 1 sensor 1: specified value: 1.0000
Intake camshaft bank1 active operating mode-Bit 0: 0
Intake camshaft bank1 active operating mode-Bit 8: 0
Overrun cut-off-Bit 0: 0
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. User\3Q0-907-379.lbl
Part No SW: 5Q0 614 517 BH HW: 5Q0 614 517 AD
Component: ESC H25 0507
Revision: 00000000 Serial number: 62736000001017
Coding: 1C076A911429116C007D060041C6243856288800608224723423F000408703
ROD: EV_Brake1UDSContiMK100IPB_035_SK37.rod
VCID: 78F4F03BC3120386B2-802C
Address 08: Auto HVAC (J255) Labels:| User\5Q0-907-044.lbl
Part No SW: 565 907 044 AJ HW: 565 907 044 AJ
Component: Climatronic 083 X069
Revision: 00001K00
Coding: 0201000440010001100500410010102A
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
VCID: 63CEB7576A94F05EF7-8036
Air quality sensor:
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 [008] - -
Reset counter: 122
Mileage: 38143 km
Date: 2017.10.14
Time: 18:21:00
Dynamic environmental data: 02 86
Voltage terminal 30: 13.4 V
Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 865827011601WR
Coding: 0C000B66424722FB4FE44004001C17280000000000000000000000000000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 030E97D78AD4505E97-8056
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 160109 041 0570
Serial number: 160122211328
Coding: 065DDD
Component: RLHS 037 0059
Serial number: S2Y16M02D01H05M26S53
Coding: 028877
Address 10: Park/Steer Assist (J791) Labels:| User\5Q0-919-298.lbl
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417617042
Coding: 0271167841
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000_VW27.rod
VCID: 50A4689B0B227BC65A-8004
13637426 - Databus
Reset counter: 133
Mileage: 38392 km
Date: 2017.10.22
Time: 10:55:55
13679386 - Databus
Reset counter: 133
Mileage: 38392 km
Date: 2017.10.22
Time: 10:55:54
Address 13: Auto Dist. Reg (J428) Labels:| User\5Q0-907-567.lbl
Part No SW: 5Q0 907 567 H HW: 5Q0 907 567 F
Component: ACC3 H08 0096
Serial number: 15041375030095
Coding: 00000400FE030B
Shop #: WSC 00666 120 190603
ASAM Dataset: EV_ACCBoschMQB 001023
ROD: EV_ACCBoschMQB_SK37.rod
VCID: 408458DBDB428B46CA-8014
0269 - Databus
U1121 00 [047] - Missing Message
Reset counter: 93
Mileage: 38392 km
Date: 2017.10.22
Time: 11:23:52
Control Module temperature: 18 °C
Voltage terminal 15: 14.8 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1043 - Automatic Distance Control
B10E7 F0 [047] - Disconnected
Reset counter: 93
Mileage: 38392 km
Date: 2017.10.22
Time: 11:23:52
Part No SW: 3Q0 959 655 AQ HW: 3Q0 959 655 AQ
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SNP10LUNP
Coding: 98FCC000000000005C5400CC000800000065
Shop #: WSC 73430 790 00000
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0D1AB1EFDC90162EF1-8058
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169593B31011650114
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169592B02021690339
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 454 001 201 16
Serial number: 3576U000000D0470091%
Subsystem 4 - Part No SW: ----------- HW: 454 001 301 16
Serial number: 3586U00000020650091W
Subsystem 5 - Part No SW: ----------- HW: 454 802 312 15
Serial number: 3516RF00877090000002
Subsystem 6 - Part No SW: ----------- HW: 454 801 812 15
Serial number: 3526R5FE87D09000000S
Subsystem 7 - Part No SW: ----------- HW: 454 801 512 15
Serial number: 3556V87EA8709000000R
Coding: 8410
Address 17: Instruments (J285) Labels:| User\5G0-920-XXX-17.lbl
Part No SW: 5E0 920 750 B HW: 5E0 920 750 B
Component: KOMBI 325 6422
Coding: 07AD0A806C8C000801887A0F5001000000000000
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 234EF7572A14B05EB7-8076
Address 19: CAN Gateway (J533) Labels:| User\5Q0-907-530.lbl
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004450738
Coding: 030500047F085700CF00025C080F00010001050000000000000000000000
Shop #: WSC 19460 666 12345
ROD: EV_GatewLear_013_VW37.rod
VCID: 79F2F53FF8181A8ECD-802C
Subsystem 2 - Part No SW: 3V0 919 719 C HW: 3V0 919 719 C
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000D0487060916
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001601212150
131596 - Steering Column Control Module
U0212 00 [008] - No Communications
Reset counter: 133
Mileage: 38393 km
Date: 2017.10.21
Time: 13:45:04
Supply voltage: Terminal 30: 11.9 V
Terminal 15: OFF
197169 - Controls in Steering Wheel
U108E 00 [008] - No Communications
Reset counter: 133
Mileage: 38393 km
Date: 2017.10.21
Time: 13:24:44
Supply voltage: Terminal 30: 11.6 V
Terminal 15: On
197423 - Unknown Error Code
U1236 00 [009] - -
Reset counter: 80
Mileage: 38124 km
Date: 2017.10.14
Time: 14:38:46
Terminal 15: On
Address 3C: Lane Change (J1086) Labels:| User\5Q0-907-686.lbl
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0397002611
Coding: 02011103
ROD: EV_HREntryHella_VW32.rod
Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386) Labels:| User\5QX-959-X93-42.lbl
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000184101889
Coding: 001D0920D000048000001100
Shop #: WSC 73430 790 12345
VCID: 479643C7FE6CBC7E0B-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000008759673
Coding: 010200
Address 44: Steering Assist (J500) Labels:| User\5Q0-909-144.lbl
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 1303
ROD: EV_SteerAssisMQB.rod
VCID: 448C54CBCF5A9766EE-8010
Part No SW: 3Q0 035 466 A HW: 3Q0 035 466 A
Component: MIB2_amp_P_SK H02 0250
Revision: 00000001 Serial number: SKZ8Z1FAS0154T4
Coding: 0373020000AA002AAA0000000000
ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
ROD: EV_AMPMst16C4Gen2ALPI_SK37.rod
VCID: 2D5A116F7CD0762E11-8078
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000184002559
Coding: 001D0120DC00048000001100
VCID: 46884EC3F966A576F0-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000008766521
Coding: 190200
Address 55: Headlight Range (J745) Labels:| User\7P6-907-357.lbl
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 03CA00003F010000
Shop #: WSC 45308 001 104857
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels:| User\5Q0-035-864.lbl
Part No SW: 5Q0 035 864 A HW: 5Q0 035 864 A
Component: MU-S-N-ER H24 0252
Serial number: SKZAZ2S8217100
Coding: 037302010000000011110002000800002F0300E401200100C6
Shop #: WSC 73430 790 00063
ROD: EV_MUStd4CTSAT_SK26.rod
VCID: 31620D1F60E812CE35-8064
Subsystem 1 - Part No SW: 5E0 919 605 M HW: 5E0 919 605 M
Component: ABT_Std-2_Nav H35 8074
Serial number: SKZ6ZET0722076
Subsystem 2 - Part No SW: 5L0 051 236 T HW: -----------
Component: ECE1 2017/18 --- 0820
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000012225
ROD: EV_RDKBERU30_006_VW36.rod
VCID: 346C040B9FFA27E65E-8060
Address 6C: Back-up Cam. (J772) Labels:| User\5Q0-980-568.lbl
Part No SW: 5Q0 980 568 A HW: 5Q0 980 568 A
Component: RVC Compact+ H07 0180
Coding: 017302010600201F000040
ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
ROD: EV_CamSysRVRVCARPANAMQBAB_006_SK37.rod
VCID: 3B7E2F37B2A4E89E9F-806E
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 75
Mileage: 38086 km
Date: 2017.10.12
Time: 17:57:24
ARA_error_bits: 0
0.0000 s
Reason: Environmental conditions
current likeliness: 0.0000
passive
Address 6D: Trunk Elect. (----) Labels:| User\5E0-959-107.lbl
Part No SW: 5E0 959 107 A HW: 5E0 959 107
Component: HDSG-Modul H01 0746
Revision: 42001001 Serial number: 006600643
Coding: 1233074002
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462_SK37.rod
VCID: 2A501A734D3E6116F4-807E
Address A5: Frt Sens. Drv. Assist (R242) Labels:| User\5Q0-980-653.lbl
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000493200
Coding: 0101010001030308000300010100000100
ROD: EV_MFKBoschAU370.rod
6553600 - Databus
Reset counter: 133
Mileage: 38392 km
Date: 2017.10.22
Time: 10:55:56
Control Module temperature: 12 °C
Outside air temperature: 11.5 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 11.6 V
System run time: 3.5 s
1123593 - Databus
Reset counter: 133
Mileage: 38393 km
Date: 2017.10.21
Time: 13:22:53
Control Module temperature: 26 °C
Outside air temperature: 17.0 °C
Voltage terminal 15: 11.5 V
System run time: 6.4 s
1123601 - predictive route data
B1630 02 [008] - Signal Failure
Reset counter: 129
Mileage: 38146 km
Date: 2017.10.16
Time: 06:08:33
Control Module temperature: 51 °C
Outside air temperature: 14.5 °C
Vehicle speed: 49.92 km/h
Voltage terminal 15: 14.6 V
System run time: 1226.8 s
End-------------------------(Elapsed Time: 05:24)--------------------------
