2001 VW Jetta Catalytic Problem
ClassicWolves
Idaho, USA.
C?ID=319721
So i have no idea if my Catalytic Converter is good or not. But based on what i can tell and it doesn't seem normal to have 1.5v on my upstream o2 sensor. and why the downstream is so lean looking. Heres a provided picture of the data i took a screen shot off. Throw out any suggestions for me, cuz i'm hoping not to replace the converter if necessary. O2 Sensors are not my fortae.
Engine? 2.0 or 1.8T?
Mileage on car?
Any faults?
How old are the sensors?
Gone But Not Forgotten
ClassicWolves
Idaho, USA.
C?ID=319721
Thursday,26,October,2017,10:37:56:15605
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
Dealer/Shop Name: Owner - Jacob B.
VIN:    License Plate: WOLVES
Mileage: 308720km-191829mi   Repair Order:
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
   Mileage: 308720km-191829miles
Address 01: Engine        Labels: 06A-906-032-AZG.clb
   Part No: 06A 906 032 DS
   Component: 2.0l R4/2V      G  *3664
   Coding: 00001
   Shop #: WSC 00066
   VCID: 72BD2465BDBCEEC75DE-5184
16804 - Catalyst System; Bank 1
            P0420 - 35-00 - Efficiency Below Threshold
16990 - Internal Control Module
            P0606 - 35-10 - Processor Fault - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
            P1103 - 35-10 - Performance too Low - Intermittent
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 C
   Component: ABS FRONT MK60      0103
   Coding: 0004097
   Shop #: WSC 00066 000 00000
   VCID: 2A0DFC0550ECE60725E-5184
   Part No: 6Q0 909 605 F
   Component: 04 AIRBAG VW6  0202 0003
   Coding: 12340
   Shop #: WSC 00066
   VCID: 3A2DCC45A54C568755E-5184
   Part No: 1J0 920 905 J
   Component: A4-KOMBIINSTR. VDO V52
   Coding: 07202
   Shop #: WSC 23337
   VCID: 2E05F01569048A27F96-5184
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0Y2676623
   IMMO-IDENTNR: VWZ7Z0Y2676623
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B92E6DB3B0DCD7ABA-5184
   Part No: 1J0 959 799 AJ
   Component: 61 Zentral-SG Komf. 0001
   Coding: 04096
   Shop #: WSC 00066
   VCID: 065568B5A134E267616-4B1E
   Subsystem 1 - Part No: 1J1959801C
   Component: 61 Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 61 Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 61 Tõrsteuerger. HL0002H
   Subsystem 4 - Part No: 1J4959812C
   Component: 61 Tõrsteuerger. HR0002r
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
End----------(Elapsed Time: 05:19, VBatt start/end: 12.1V/12.1V)-----------
Given the fault code: "Internal Control Module - Processor Fault", all the other data coming from this ECU has to be taken with a grain of salt.
ClassicWolves
Idaho, USA.
C?ID=319721
Well as far as i know this ECU Fault has just poped up recently. 1 week ago. It only showed a P0420 and the P1103 code seemed to come and go, it'd be there one day and be gone the next. Ok i have another question, im assuming i should replace the ECU at this point. Where would be a great place to purchase a NEW or Reman ECU?
Look above /\
Nope not yet..........
ClassicWolves
Idaho, USA.
C?ID=319721
Sounds good, and once i figure out what you mean entirely even with that sheet provided ill post that data. How much do you want for a replacement ECU? My budget max for this car is 1,000$ Cuz im trying to factor in o2 Sensors about 100$/ea, a Replacement Converter 400$. Cuz if i figure that it does need a new converter and a new upstream sensor, might as well replace the rear o2 sensor as well. Id like to get one as cheap as absolute possible, stock.
I will hook you up with a set of Factory complete OXS sensors and a brand new ECU & with included data transfer from core submitted for VIN and Immobilizer at $850 USD + freight fully insured.
We have new aftermarket CAT's & that are EPA/CARB certified 50 state legal for $750 USD + freight.
Try doing the default first please........& check the MAF and FPR.
ClassicWolves
Idaho, USA.
C?ID=319721
WSC: 00066, Software Code: 00001
Change your WSC to something other than the 00066 and recode the controller to 00001
You must setup VCDS in the config for tester number WSC and importer ID first please!
WSC 12345
Importer ID # 444 for USA
Tester/equipment # 54321
ClassicWolves
Idaho, USA.
C?ID=319721
MAF: 3.17g/s - 3.31 g/s Idle. 7.17-7.28 2,000 RPM. I cant find the Fuel Pressure one.
ClassicWolves
Idaho, USA.
C?ID=319721
I changed the numbers as said as well
ClassicWolves
Idaho, USA.
C?ID=319721
Im sorry you just have me really confused
Please perform the config in VCDS as aforementioned and save it .....then recode the controller 0x01-07-00001 .......after so, post a new auto-scan.
Then we can start readiness tests one by one.......after we have verified the above.
ClassicWolves
Idaho, USA.
C?ID=319721
 Thursday,26,October,2017,12:46:39:15605
Workshop Code: 444 12345 054321
          75 76
   Coding: 00001
   Shop #: WSC 12345
Readiness: 0110 1101
   Coding: 0004097
   Coding: 12340
   Shop #: WSC 00066
   VCID: 3A2DCC45A54C568755E-4B5C
   Coding: 07202
   Shop #: WSC 12345
   Coding: 00006
   Shop #: WSC 00066
   Coding: 04096
   Shop #: WSC 00066
   Component: 61 Tõrsteuerger. FS0002F
   Component: 61 Tõrsteuerger. HL0002r
   Component: 61 Tõrsteuerger. HR0002H
End----(Elapsed Time: 05:17, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
Great job OP........
Ok lets do a TV alignment 0x01-04-060 4th field should say ADP-ok
If so start car and check it while at idle now in measuring blocks 0x01-08-060
Is all ok?
ClassicWolves
Idaho, USA.
C?ID=319721
yes it say A.D.P OK. TV Sensor 1 is @ 10.5, sensor two at 87.5, Throttle steps counter is 0, and ADP OK
