Bought Touareg, engine light came on
powerd
Australia
C?ID=316618
Hi All
I recently bought a used 07 Touareg, sight unseen from an auction. I knew I was taking a chance, but was out of the country at the time and was willing to take the risk because it had the right spec. I was a 3.0 V6 diesel, with air suspension and the light coloured Nappa Leather (I hate black interiors), with low kms (83,000). And looked clean except for a small scrape on the front right corner - just the paint, will be easily fixed if I bother.
I will be using it offroad including for towing my offroad camper trailer through the outback here in Australia. On the way back to home I bought a VCDS from Mount Performance in Sydney (thanks Ben for the good service and advice). Essential, I think, given where I will be travelling and the fact I don't want to pay the large servicing costs of the VW dealer here. I am not a mechanic, but I have mucked about with cars since I was young, and I also own a '78 Jaguar XJ-S, so it is hard to frighten me with anything automotive!
Anyway, while driving back from Melbourne, the engine light came on. I took a risk and kept driving, as the vehicle was running fine. So once I got home I connected up the VCDS and recorded the following fault.
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached - Intermittent
Fault Status: 00100001
Fault Frequency: 38
Mileage: 136240 km
Date: 2017.01.05
Time: 11:11:14
RPM: 1008 /min
Torque: 39.0 Nm
Voltage: 12.08 V
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
Readiness: 0 1 0 0 0
I couldn't find the P3135 fault number in the Wiki, but examining the adjacent 3137 and 8 faults, they seemed to be related - wear in the plastic stepper motor rods being the potential culprits. I then searched varied VW/Audi forums and came up with some other suggestions - check fuse 12 in the plenum fuse box, check wiring and connector to the stepper motor. Also to move the arms manually and see if they are sticking - which one might have been. Be careful not to dislodge the lower end socket off the ball as I did - its a bugger to get back on.
Anyway, I did these, and then cleared the fault codes, started the engine and hooray! No fault - it used to reappear after just a few throttle movements - and it hasn't come back after two days of decent driving. I also added some Wynns diesel engine system cleaner - no idea if this stuff has any benefit, but gave it a try.
I assume the 0001 after the fault code refers to the engine bank, but which bank is one? The left or right, as you look at the engine.
Hope this info is of use to someone. And the fault doesn't reappear.
Otherwise, car is great, has a cheap older Chinese replacement satnav without a CANBUS module, poor quality and throws a fault. Will probably replace with a new one with the module and better quality/useability/interfacing.
Nice! :thumbs:
Would you be willing to share a complete Auto-Scan with us for posterity? We don't don't see a whole lot of V6 TDIs of that vintage.
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum.
When you have a problem/query you ALWAYS post a full AutoScan of the vehicle in question, whether there are any error codes or not. There is more useful system info in there, how the car is equipped and configured.
As Uwe says.
Yep. But he doesn't have a problem. He's already fixed it and is reporting the fix for posterity. ;)
powerd
Australia
C?ID=316618
True, is all OK now except for fault from radio as the cheapo older Chinese replacement (presumably to get Bluetooth and Nav, as my vehicle didn't have it from the factory, or else the original died) doesn't have a CANBUS module.
Happy to post the scan anyway. Here it is. This is the base autoscan I did when I first set up the VCDS.
Sunday,15,October,2017,14:07:05:16208
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN: WVGZZZ7LZ8D032824   License Plate:
Mileage: 84520km-52518mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 34 46 55 56 68 69 76
VIN: WVGZZZ7LZ8D032824   Mileage: 84520km-52518miles
68-Wiper Electr. -- Status: OK 0000
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 7L0 907 401 D    HW: 7L0 907 401 D
   Component: 3.0L V6TDI  G000AG  0030
   Revision: --H05---    Serial number: VWX3Z0G1662054
   Coding: 0011775
   Shop #: WSC 31414 790 00001
   VCID: 2C020C493A18C267D72-5184
                    Fault Frequency: 38
                    Mileage: 136240 km
                    Date: 2017.01.05
                    Time: 11:11:14
                    RPM: 1008 /min
                    Torque: 39.0 Nm
                    Voltage: 12.08 V
                    Duty Cycle: 88.8 %
                    Duty Cycle: 80.9 %
                    Duty Cycle: 80.9 %
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No SW: 09D 927 750 FA    HW: 09D 927 750 FA
   Component: AL 750 6A           0992
   Revision: 00H61000    Serial number:
   Coding: 0004456
   VCID: 72BED231D8BCD4975DE-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 K    HW: 7L0 907 379 K
   Component: ESP ALLRAD MK25E1   0302
   Revision: 00H53001
   Coding: 0004482
   VCID: 41DC4DFDADCA3F0F144-8014
   Part No SW: 3D0 909 139 B    HW: 5WK 485 04
   Component:    Kessy            6840
   Revision: 68406620    Serial number: VWX3Z0G1662054
   Coding: 0000232
   Shop #: WSC 30355 000 1048576
   VCID: 280AF0592EB0EE4733A-807C
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AD
   Component: CLIMAtronic R/L     4326
   Coding: 0020520
   VCID: 72BED231D8ECD4975DE-8026
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2000
   Revision: -0004---    Serial number: --------------
   Coding: 600004002B221C000000000000000000
   VCID: 005A88F9E640F6075BA-8054
01494 - Bulb for Parking Lamps; Left (M1)
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234  39 VW8T       0250
   Revision: 92011025    Serial number: 0039P002T2J3
   Coding: 0013113
   VCID: 7AAEFA11809CACD715E-802E
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 F
   Component: J527                3601
   Coding: 0010011
   VCID: 42DE42F1A8CC24170DE-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 885 R    HW: 7L6 920 885 R
   Component: J285 KOMBI-INST.    7520
   Revision: KHH06V02
   Coding: 0007101
   Shop #: WSC 30030 000 1048576
   VCID: 4BC06FD59FC6E55FFE8-801E
01304 - Radio
                    Reset counter: 58
                    Mileage: 136178 km
                    Date: 2017.01.03
                    Time: 16:00:22
                    Fault Frequency: 54
                    Reset counter: 53
                    Mileage: 136278 km
                    Date: 2017.01.12
                    Time: 08:04:17
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 885 R
   Component: J533  GW-K-CAN TP20 7520
   Coding: 7FE2E78B40046003
   VCID: 70BAD839D6A0E687ABA-8024
01304 - Radio
                    Reset counter: 58
                    Mileage: 136178 km
                    Date: 2017.01.03
                    Time: 16:00:22
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 015C8DFDED1AFF0F544-5184
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 J
   Component: LUFTFDR.-CDC- 3C3P1 3125
   Coding: 0015521
   VCID: 3A2E3A11C01C6CD755E-806E
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L6 959 933
   Component: 14 HSG              7124
   Coding: 0000065
   Shop #: WSC 08335 002 1048576
   VCID: 7F580B059BEE89FF220-4B1E
   Subsystem 1 - Part No: 7L0 959 701 R
   Component: Tuersteuergeraet FS 6302
   Subsystem 2 - Part No: 7L0 959 702 R
   Component: Tuersteuergeraet BF 6302
   Subsystem 3 - Part No: 7L6 959 703
   Component: Tuersteuergeraet HL 0202
   Subsystem 4 - Part No: 7L6 959 704
   Component: Tuersteuergeraet HR 0202
   Subsystem 5 - Part No: 7L0 907 719 A
   Subsystem 6 - Part No: 7L6 951 171 B
   Component:    Innenraumsensor  0020
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Component: AFS-Steuergeraet    0001
   Revision:   H02       Serial number:
   Coding: 1288579
   VCID: 392C251DC51A67CF5C4-806C
   Component: AFS-Lst.-Modul l    X008
   Coding: 00000019
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    X008
   Coding: 00000019
Address 56: Radio
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 A
   Component: J400__ Front Wiper  5101
   Coding: 0000341
   VCID: 382A2019FE507EC7A3A-806C
   Component: RLS     260907 046  0204
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000001
   VCID: 382A2019FE107EC7A3A-806C
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
It does show some prior faults which are not occurring now, although the rear park globe open circuit has shown up once (it's working when I check it, but I'll just replace the globe and see if that gets rid of it permanently) and the RR door locking fault also showed up again once too. It manifests as the door occasionally not unlocking in response to the remote - other doors OK so may not bother, or else one day I will pull off the door card and check connections etc. Don't use the back seat much so not a problem for me.
Happy reading and analysing.
Cheers
powerd
