2012 VW Sharan steering module coding
DanPhil
Denmark
C?ID=255627
Please help, this i my first post.
I have a 2012 Sharan in Denmark in Europe where the buttons on the MFSW stopped working and an Airbag light came on.
I found another control module with the same part no. but cant seem to get it working. I keep getting a "G85 no basic setting" fault. I have spent a ton of time trying to find the correct coding, and a way to carry out the basic setting, but to no avail.
Here are the two auto scans with the two different modules installed.
Original module 5K0953569L
Thursday,19,October,2017,23:10:40:54256
VCDS Version: 17.8.0.1 (x64)
VIN: WVWZZZ7NZCV016765   License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 25 2B 37 42 44 46 4C 4F
          52 53 56 61 62 69 6D 72 77 BE BF
VIN: WVWZZZ7NZCV016765   Mileage: 340150km-211359miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
   Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
   Component: R4 2,0L EDC   H26 9236
   Revision: 44H26---    Serial number:
   Coding: 001D001A043401080000
   Shop #: WSC 32912 056 526860
   ASAM Dataset: EV_ECM20TDI01103L906018HJ 003007
   ROD: EV_ECM20TDI01103L906018HJ.rod
   VCID: 79F999FBF80AA28ECD-802C
4481 - Cruise Control Switch (E45)
          P0568 00 [032] - Implausible Signal
                    Mileage: 340150 km
                    Date: 2017.10.19
                    Time: 01:54:50
                    Engine speed: 0.00 /min
                    Coolant temperature: 17 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 11.780 V
                    Cruise Control System (CCS): switch position-Bit 0: 192
                    Cruise Control System (CCS): status-Bit 0: 204
                    Cruise control switch-off: irreversible-Bit 0: 255
                    Cruise control switch-off: reversible-Bit 0: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Engine control module reset status-Bit 0: 0
                    Engine control module reset status-Bit 8: 0
                    Cruise control switch-off: irreversible w. brake intervention-Bit 0: 0
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 340150 km
                    Date: 2017.10.19
                    Time: 01:54:50
   Part No SW: 02E 300 054 S    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2701
   Revision: 05351113    Serial number: 00001108311622
   Shop #: WSC 00020 790 00000
   VCID: 264382879134FD76D0-8072
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 N    HW: 7N0 614 109 N
   Component: J104   C3 450M VDDB 0021
   Revision: --H07---    Serial number: 00000004714339
   Coding: 0027162
   VCID: 387F5CFF4B807B8672-806C
                    Reset counter: 219
                    Mileage: 340150 km
                    Date: 2012.03.11
                    Time: 01:55:03
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.50 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0802
   Revision: 00085000    Serial number: 0153677623
   Coding: 03100C
   Shop #: WSC 00020 999 39850
   ASAM Dataset: EV_KESSY_PQ35GP A01018
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 33656BD39AE698DE47-8066
   Part No SW: 5K0 907 044 FL    HW: 5K0 907 044 FL
   Component: Clima-Sharan  H18 0204
   Revision: 00001002
   Coding: 0200104509
   Shop #: WSC 00020 999 00000
   VCID: 7AFB86F7FD0CA996C4-802E
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20130815000000126761
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0048
   Revision: BC011001
   Coding: 40590A3B89251AC0500800C0740081E443511308476D2DF26480C720A2C1
   Shop #: WSC 00020 790 12345
   VCID: 3B7543F3BAB6509E9F-806E
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110818  31  0032
   Serial number:         110825132653
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y11M09D03h01m34s18S1
   Coding: 0280BB
                    Reset counter: 4
                    Mileage: 340150 km
                    Date: 2012.03.11
                    Time: 02:00:15
                        Term 15 Off
                    Voltage: 11.90 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28261125002238
   Coding: 118101
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 397959FBB88A628E8D-806C
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag01X H07 0013
   Serial number: 003GFPK31ZLA
   Coding: 003158
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E734AE7A1A445B6B8-806A
   Serial number: 3493ETS60CE42E1149D+
   Serial number: 3503ETS607A87DE149D2
   Serial number: 3513ETS60F50DDB149D1
   Serial number: 3523ETS60C3F7DE149D9
   Serial number: 35540TS60E105CF14DDT
          B1000 1B [137] - Resistance Too High
                    Mileage: 340150 km
                    Date: 2017.10.19
                    Time: 02:07:57
   Part No SW: 5K0 953 501 BM    HW: 5K0 953 569 L
   Revision: FF010040    Serial number: 20110826300250
   Coding: 1102240000
   Shop #: WSC 00020 999 12345
   VCID: 76E392C7C914CDF6A0-8022
227339 - Windshield Wiper Switch
          B1145 13 [008] - Open Circuit
                    Reset counter: 3
          B1149 13 [008] - Open Circuit
                    Reset counter: 3
365080 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 174
                    Mileage: 338693 km
                    Date: 2017.09.20
                    Time: 14:26:22
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 7N0 920 870 E    HW: 7N0 920 870 E
   Coding: 140F01
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
   VCID: 346768CF9FE89FE65E-8060
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 4
                    Mileage: 340150 km
                    Date: 2017.10.19
                    Time: 02:00:14
   Part No: 7N0 963 271 C
   Component: Zuheizer        051 2730
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000041
   Shop #: WSC 14871 002 1048576
   VCID: 346768CF57E89FE65E-8060
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 010911F1000826
   Coding: 468002
   Shop #: WSC 18402 001 1048576
   VCID: 387F5CFF8B807B8672-806C
                    Reset counter: 3
                    Mileage: 340150 km
                    Date: 2012.03.11
                    Time: 02:00:13
   Coding: 000007
   VCID: 6ADBB6B78DAC191634-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000200154005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E537AA771C4B53628-807A
   Part No SW: 1T0 035 680 B    HW: 1T0 035 680 B
   Component: RNS-MID       H42 1400
   Revision: AB001001    Serial number: VWZ6Z7L6060056
   Coding: 0C000400040000A000
   Shop #: WSC 00059 204 00057
   VCID: 2D517DAB74C2CE2E11-8078
   Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000119594057
   Coding: 01153E20D000411011
   VCID: 4487380FC7482F66EE-8010
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.324 1002
   Revision: 1AH03733    Serial number: 00112510085601
   Coding: 0000258
   VCID: 3C7740EF7FB857A696-8068
   Component: EZE_2         H40 1620
   Coding: 050B0500
   VCID: 6FEDA7A3BE4EFC3E63-803A
   Component: J245EE20SKB13  H02 0220
   Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000119645344
   Coding: 01153E20DE00411011
   VCID: 43853B13C246285ED7-8016
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000223613
   Coding: 0024167
   VCID: 356155CB5C9286EE69-8060
   Component: Batt.regelung H40 1620
   Coding: 030B115A
   VCID: 71E9A1DBA87AEACE75-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900520182
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 F    HW: 7N0 959 795 B
   Component: TSG HL        H03 0403
   Revision:             Serial number: 0000119652542
   Coding: 01007C200000411001
   VCID: 46832207F1741D76F0-8012
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00000157211198
   Coding: 410C040001000000
   VCID: 73E5ABD3D266D8DE87-8026
   Part No SW: 7N0 959 107 B    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0803
   Revision: 41011001    Serial number: 238100143
   Coding: 0733334003
   ASAM Dataset: EV_HDSGVW428 201133
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 366352C789948DF660-8062
   Component: TSG HR        H03 0403
   Revision:             Serial number: 0000119654210
Address 77: Telephone        Labels: RETROFIT77.lbl
   Part No SW: KTC 364 96P     HW: KTC 364 96P
   Component: SWP:3.31.6      H24 0216
   Shop #: WSC 21977 142 74100
   VCID: 3E734AE769A445B6B8-806A
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 11333621
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 387F5CFF83807B8672-806C
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 11333606
   ROD: EV_AST.rod
End-------------------------(Elapsed Time: 04:16)--------------------------
New control module with the same part no. 5K0953569L
Thursday,19,October,2017,22:50:43:54256
          P0568 00 [047] - Implausible Signal
                    Mileage: 340080 km
                    Date: 2017.10.17
                    Time: 22:28:50
                    Engine speed: 780.50 /min
                    Normed load value: 37.6 %
                    Coolant temperature: 55 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 14.380 V
                    Cruise control switch-off: irreversible-Bit 0: 0
                    Cruise control switch-off: irreversible w. brake intervention-Bit 0: 1
4482 - Function Restriction due to Implausible Message(s)
          U1112 00 [032] - -
                    Mileage: 340080 km
                    Date: 2017.10.17
                    Time: 22:28:50
          U1113 00 [047] - -
                    Mileage: 340080 km
                    Date: 2017.10.17
                    Time: 22:28:50
   Coding: 0027162
                    Fault Frequency: 11
                    Reset counter: 219
                    Mileage: 340080 km
                    Date: 2012.03.09
                    Time: 22:08:38
                    Hex Value: 0x0000
                    Voltage: 13.75 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
                    Fault Frequency: 11
                    Reset counter: 219
                    Mileage: 340080 km
                    Date: 2012.03.09
                    Time: 22:08:38
   Coding: 03100C
1070343 - Bulb for Ignition/Starter Switch Illumination
          B11A7 11 [008] - Short to Ground
                    Reset counter: 254
   Revision: 00001002
   Coding: 0200104509
   Slave 1:
   Revision: BC011001
   Coding: 004DBD
   Coding: 0280BB
            000 -  -
                    Reset counter: 219
                    Mileage: 340150 km
                    Date: 2012.03.11
                    Time: 01:39:44
                    Voltage: 11.80 V
   Coding: 118101
   Coding: 003158
          B1000 1B [136] - Resistance Too High
                    Mileage: 338683 km
                    Date: 2017.09.19
                    Time: 21:36:37
   Part No SW: 5K0 953 501 BL    HW: 5K0 953 569 L
   Revision: FF010042    Serial number: 20130903101581
   Coding: 1102140000
   VCID: 75E195CBD412C6EEA9-8020
   Coding: E20000
226838 - Turn Signal Switch
          B1144 12 [008] - Short to Plus
                    Reset counter: 4
                    Mileage: 340080 km
                    Date: 2017.10.17
                    Time: 22:27:26
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
                    Reset counter: 218
                    Mileage: 340080 km
                    Date: 2017.10.17
                    Time: 22:26:53
          U108E 00 [008] - No Communications
                    Reset counter: 4
                    Mileage: 340150 km
                    Date: 2017.10.19
                    Time: 01:35:25
1140738 - Steering angle sensor
                    Reset counter: 218
                    Mileage: 340080 km
                    Date: 2017.10.17
                    Time: 22:25:52
                    UBat: 14.40 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Coding: 140F01
          U1111 00 [008] - -
                    Reset counter: 3
                    Mileage: 339773 km
                    Date: 2017.10.16
                    Time: 00:11:57
   Coding: 0000041
01444 - Under-Voltage Shut-Off (Automatic)
            000 -  -  - Intermittent
                    Reset counter: 239
                    Mileage: 339421 km
                    Date: 2012.03.02
                    Time: 07:44:21
   Coding: 468002
                    Fault Status: 00110100
                    Reset counter: 2
                    Mileage: 339773 km
                    Date: 2012.03.08
                    Time: 00:11:56
   Coding: 000007
                    Fault Status: 00100111
                    Reset counter: 3
                    Mileage: 339004 km
                    Date: 2012.02.15
                    Time: 16:25:47
   Coding: 0000258
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 219
                    (no units): 4.0
                    Voltage: 11.30 V
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 218
                    Mileage: 340080 km
                    Date: 2012.03.09
                    Time: 22:31:37
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Reset counter: 219
                    Mileage: 340150 km
                    Date: 2012.03.11
                    Time: 01:39:27
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 4
   Coding: 050B0500
   Coding: 0024167
                    Reset counter: 3
                    Mileage: 339004 km
                    Date: 2012.02.15
                    Time: 16:25:47
   Coding: 030B115A
   Coding: 0733334003
   ROD: EV_AST.rod
   ROD: EV_AST.rod
These are not the same part number. Same hardware part number, yes, but what counts is the Software part number. The original is 5K0-953-501-BM, while the replacement is 5K0-953-501-BL. Have you verified that they are compatible and have the same application?
DanPhil
Denmark
C?ID=255627
I don't know if they are compatible, (how can i check this?) and the only difference application-wise is the new module has the cruise on the tip of the turn signal stalk (according to the coding) and is from a newer model Tiguan.
