Golf mk7.5 admap - strange happenings?
I recently posted an auto-scan for a Golf mk7.5 on the reference thread which I obtained from a colleague on a local forum (thank you ozmale). The scan shows that the car has a couple of new modules that I had not seen before on an MQB vehicle - @ address hexD6 and hexD7. Thankfully, ozmale agreed to send me the admaps for these modules - see below:
[B][B]admap-D6-7P5-941-591-AD.CSV[/B][/B]
;SW:7P5-941-591-AD   HW:7P5-941-591-A ---  Light Ctrl Left 2
;Component:LED1L         H06 0005, Coding:
;EV_LED_PLUS_L_KEBODAVW416,001003,EV_LED_PLUS_L_KEBODAVW416_VW37.rod
;Monday,16,October,2017,19:09:07:14718
;VCDS Version: Release 17.8.0 (x64)  Data version: 20170721 DS276.2
;VCID: 7EA40FAAF074E217296-802A
IDE00036-Vehicle equipment code,00 00 00 00 00 00 00 00 00 00 00 00 ,12
IDE00047-Parameter set version,---- ,4
IDE00048-Parameter set part number,----------- ,11
Elapsed Time: 00:01
[B]admap-D7-7P5-941-591-AD.CSV[/B]
;SW:7P5-941-591-AD   HW:7P5-941-591-A ---  Light Ctrl Right 2
;Component:LED1R         H06 0005, Coding:
;EV_LED_PLUS_R_KEBODAVW416,001003,EV_LED_PLUS_L_KEBODAVW416_VW37.rod
;Monday,16,October,2017,19:09:25:14718
Elapsed Time: 00:01
Apart from the fact that two modules are exactly the same but with different address locations (which I assume is kosher in CAN protocols), I'm interested in why IDE00047 & IDE00048 is reporting a string of dashes? Is this likely to be true, or perhaps a "quirk"?
Eric
HC800000
Well, not quite, the component fields and ASAM IDs show their respective positions, L vs R.
VCDS does not make up strings like that, save for "N/A" and "Unknown". If I had to guess, I would say those modules (or the firmware that was reused on them), when used in cars where they are required to be more "intelligent" need a parameterization to tell them what to do.
