I desperately need help with find the correct code for parking brake ecu. We have changed the ecu but when we try to code the new (used) ecu when only get answer that coding was not accepted. The scan is from the old ecu that also says that coding is wrong, despite the fact that that ecu was used previously in that car.
Thanks in advance
//Kjell Soderberg
Thanks in advance
//Kjell Soderberg
Monday,16,October,2017,09:48:37:01232
VCDS Version: 17.8.0.1 (x64)
VIN: WVWZZZ3CZ6E110322 License Plate: XFO017
Mileage: 192150km-119396mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72
VIN: WVWZZZ3CZ6E110322 Mileage: 192150km-119396miles
Address 01: Engine Labels: 06F-906-056-BLR.lbl
Part No SW: 06F 906 056 AM HW: Hardware No
Component: MED9.5.10 G00 7553
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 05314 000 00000
VCID: 74DF9F6D17BFFFE69E-8020
006215 - Please check DTC Memory of ABS Controller
P1847 - 004 -
Temperature: 78.0°C
P1653 - 001 -
Fault Status: 01100001
Mileage: 192158 km
Date: 2017.10.09
Time: 02:37:21
Temperature: 78.0°C
Readiness: 1110 0001
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658246637
Coding: 0010000
Shop #: WSC 05311 000 00000
VCID: 3057537DA32783C63A-8064
Reset counter: 181
Mileage: 192158 km
Date: 2017.10.09
Time: 02:13:15
Reset counter: 181
Mileage: 192158 km
Date: 2017.10.09
Time: 02:13:15
Reset counter: 181
Mileage: 192158 km
Date: 2017.10.09
Time: 02:13:15
Reset counter: 181
Mileage: 192158 km
Date: 2017.10.09
Time: 02:13:15
Reset counter: 181
Mileage: 192158 km
Date: 2017.10.09
Time: 02:13:15
Reset counter: 181
Mileage: 192158 km
Date: 2017.10.09
Time: 02:13:15
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 Q HW: 3C0 907 044 Q
Component: ClimatronicPQ46 042 0202
Revision: 00042004 Serial number: 00000000000000
VCID: 2F555001BE199C3E23-807A
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000002186210
Coding: 088E8F0700041A00000A00000F00000000095D435C0000
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 150107 003 0205
Coding: 00046997
Shop #: WSC 05311
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 F HW: 3C0 909 605 F
Component: 01 AIRBAG VW8 029 2421
Revision: 08029000 Serial number: 0039USLS224+
Coding: 0012337
VCID: 2961BE1980FDF20EFD-807C
Subsystem 1 - Serial number: 6332MSME0B723440
Subsystem 2 - Serial number: 6342MSME0C0E5A18
Subsystem 3 - Serial number: 6351HTS67SDQ4RH2
Subsystem 4 - Serial number: 6361HTS69SDEK4U2
Subsystem 5 - Serial number: 6371VTS69SDUH7A3
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 B HW: 3C0 953 549 B
Component: Lenksäulenmodul 005 0010
Revision: 00005000 Serial number: 3C9953507E
Coding: 0000112
VCID: 2B6D44118A01E01E0F-807E
Component: Lenkradmodul 007 0050
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 870 P HW: 3C0 920 870 P
Component: KOMBIINSTRUMENT VD1 4240
Revision: X0033000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 30392 001 1048576
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05929009B
Coding: 3DFD8C04C22002
VCID: 2171A639F8CD3A4EA5-8074
Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
Component: IMMO 038 0367
Revision: 00038000 Serial number: VWZCZ000000000
VCID: 32535975AD2BB1D64C-8066
Subsystem 1 - Part No: 3C0 905 861 C
Component: ELV 023 0350
3C0905861C ELV 023 0350
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2365
Coding: 0000181
VCID: 365B65654143ADF660-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Component: KSG PQ46 ELV 038 0455
Coding: 0091020851030E763804941570084F0B603C00
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000180
VCID: 37456861464954FE7B-8062
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0010000
Fault Status: 11101101
Reset counter: 183
Mileage: 192152 km
Date: 2017.09.26
Time: 01:25:10
Voltage: 11.49 V
Count: 236
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 181
Voltage: 12.01 V
Count: 171
000 - - - MIL ON
Reset counter: 181
Voltage: 12.01 V
Count: 170
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2E2492179
Coding: 0040400
VCID: 335D5C715231B8DE47-8066
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703
Component: Tuer-SG 021 2505
Coding: 0000144
VCID: 70D7937D63A7C3C67A-8024
Address 69: Trailer Labels: 1K0-907-383-V1.clb
Part No SW: 1K0 907 383 HW: 1K0 907 383
Component: ANHAENGERELEKTR 001 0020
Coding: 0000001
VCID: 6AE38115457B391634-803E
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704
Coding: 0000144
VCID: 71D1967968ADCACE75-8024
End-------------------------(Elapsed Time: 01:12)--------------------------
