Golf 7.5 R-Line (RoW)
Thanks "Ozmale" (from VWWatercooled forum)
Thursday,12,October,2017,19:21:39:14718
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN: WVWZZZAUZJW044403   License Plate: GOLF R-LINE
Mileage: 136km-84mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 3C 42 44 47 4B 52
          5F A5 D6 D7
VIN: WVWZZZAUZJW044403   Mileage: 136km-84miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---
   Coding: 0125003224641D083000
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D8638E6AD12698F80C-8038
   CAN Converter 01:
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0CW 300 041 B    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1006
   Revision: 00005026    Serial number: CU501707036041
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 3430ED828EB8F8478F2-8060
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 61677000001274
   Coding: 01FA8AA124242170477B060040C62980512484E26002947338225038C2A2430000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 79AE1CB6E95AC52F1C4-802C
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0449034708
   Coding: 032C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3C20C5A2A6E83007472-8068
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0012001420010000110500001210142A
   ROD: EV_ACClimaBHBVW37X_006_VW27.rod
   Air quality sensor:
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001720602582
   ROD: EV_BCMBOSCH_018.rod
   VCID: 08486972A2B0ACA713A-805C
   Component: WWS    170626  042 0551
   Serial number:         170710073235
   Component: RLHS  042 0105
   Serial number: S4Y17M07D28H16M48S49
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST001PAD9M00000
   Coding: 181901
197904 - Central Locking
          B140A 4B [008] - Over temperature
                    Reset counter: 44
                    Mileage: 12 km
                    Date: 2017.10.04
                    Time: 09:28:20
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617202
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   VCID: 50F881121A60A4678BA-8004
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 330067C159FFC428949C810580300600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   ROD: EV_ACCBOSCHVW416.rod
   VCID: 3E24CFAAB0F42217696-806A
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR36H3YR
   Coding: 98CCC000000000005C000000008800000065
   VCID: 094E6C76B9BAD5AF0C4-805C
   Belt Pretensioner left:
   Serial number: 34169677E25071740130
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E26071740796
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: 35700000000D4719952M
   Subsystem 4 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: 358000000005DC21162F
   Subsystem 5 - Part No SW: -----------    HW: 480 401 407 17
   Serial number: 3510001B12552CE2630U
   Subsystem 6 - Part No SW: -----------    HW: 480 401 507 17
   Serial number: 3520001B32600D3522BQ
   Subsystem 7 - Part No SW: -----------    HW: 480 401 707 17
   Serial number: 3550001AB25E6132324Y
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 26071704220115
   Coding: 0C10
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         407 3193
   Coding: 27A401186F88000801886B0B5401000080000000
   VCID: 2A0CF3FA5C7CBEB725E-807E
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 30061710521670
   Coding: 030100347F085700FB00025C1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3332EE9E8BB6FF7F968-8066
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29170001432830107272
   Coding: 2DFFFF
   Serial number: 2313704704
   Revision: 00000000    Serial number: 17000179804001
   Coding: 5D00000000000000
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QG712162
   Coding: 0014000000000500018280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
Address 3C: Lane Change (J1086)       Labels:* None
   Component: HRE_Master    H12 0080
   Serial number: 0446906955
   Coding: 02011203
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3D26C8A6BDF2390F70C-8068
   Lane Change Assistant 2:
   Serial number: 290617EFT00796
   Coding: 003B1320D201048000001000
   VCID: 43D2BE5EDB164FFF068-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000015503192
   Coding: 0D0000
   Coding: 9307
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 3A2CC3BAACDC0E3755E-806E
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD00RZVT
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI_VW37.rod
   VCID: 2E04FFEA6094D297F96-807A
   Serial number: 03071710800638
   Coding: 000000070100164E01000101020000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_VW37.rod
   VCID: 72BC2B9AB42CB6775DE-8026
   Serial number: 300617EFU20813
   Coding: 003B1120DE01048000801000
   VCID: 42DCBB5AC40C46F70DE-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000015697448
   Coding: 150000
   Part No SW: 5NA 035 045 A    HW: 5NA 035 045
   Component: MU-H-N-RW     H54 1121
   Serial number: A849G0HS005641
   Coding: 027310080000000051510002000808001F0106F601200402DF
   VCID: 3634D78A98C4EA57B16-8062
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT2065365
   Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
   Component: ROW 2017  --- 0062
   Compact Disc Database:
   Component: Gracenote2  --- 4012
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 18071711P21189
   Coding: 000307000000010100022354C150A90084000E200000
   ROD: EV_MFKBoschMQBB_VW36.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA40FAAF074E217296-802A
Address D7: Light Ctrl Right 2 (A27)       Labels: None
End----------(Elapsed Time: 02:10, VBatt start/end: 13.3V/13.3V)-----------
WENHAI
China
C?ID=331126
hey,can you give this car DiagnosticProtocols by OIDSengneering?WVWZZZAUZJW044403
WENHAI
China
C?ID=331126
dfgdsfgdsfgsdfgsdfgsdfgsdfgsdfgsdfg
darkchina811
ITALY
C?ID=333184
could I ask you for an admap of module 10? thank you!
darkchina811
ITALY
C?ID=333184
no need for it anymore :P
sasha
Australia
C?ID=287611
@DV52 saved me, thanks for posting! :thumbs:
