Evan output test help
Lgibson
C?ID=41716
In 001 output tests I'm stuck at the Start/Next bar. Whining sound activates under hood but never stops as I click thru the sequence of tests. There is no report of pass/fail or any change in the Start/Next bar. I believe I read outputs are done with engine off?
Related details:
Readiness looks to be set even tho I do not believe the SAI pump is functional. How can that be?
I'm awaiting a new Pressure Retention Valve which I believe to be related to 16825 and difficult starting after refuel, so the codes predate that. Cleaned the MAF per Jack as well
               Address 01: Engine       Labels: 022-906-032-AXK.lbl
Control Module Part Number: 022 906 032 AF
  Component and/or Version: MOTRONIC ME7.1  G   0003
           Software Coding: 00003
            Work Shop Code: WSC 27441
                      VCID: 4FA6E5278D5AAD66527-5120
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
            P1103 - 35-10 - Performance too Low - Intermittent
16523 - Oxygen (Lambda) Sensor B1 S2
            P0139 - 35-00 - Response too Slow
16825 - EVAP Emission Control Sys
            P0441 - 35-10 - Incorrect Flow - Intermittent
                Address 02: Auto Trans       Labels: 01P-927-733.lbl
Control Module Part Number: 01P 927 733 CG
  Component and/or Version: AG4 Getriebe 01P    4893
           Software Coding: 00000
            Work Shop Code: WSC 00000
                      VCID: 7AF064F36658D8CED59-095C
01192 - Torque Converter Lock-Up Clutch
            04-10 - Mechanical Malfunction - Intermittent
Address 02: DTCs cleared
Address 01: DTCs cleared
What's the source of the sound?
Nor is one expected. Output tests simply turn things on. You then check that they are working based on sound, or by using a multimeter or test lamp, or whatever other method is appropriate for that output.
There are some exceptions (particularly on certain TDIs) but in general, yes, engine not running.
ECUs typically do not set readiness bits do not get set to fail unless/until you clear fault codes.
