Thursday,12,October,2017,21:19:01:41892
VCDS Version: 17.8.0.1 (x64)
VIN: WAUZZZ4G6GN156921 License Plate: A6 12.10.2017
Mileage: 18552km-11527mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 3B 42 44 46 52 53 55 5F 62 69
6D 72 84 85 8F 90 AC
VIN: WAUZZZ4G6GN156921 Mileage: 18552km-11527miles
17-Instruments -- Status: Cannot be reached 0100
84-Night Vision -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Cannot be reached 0100
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 BP HW: 04L 907 309
Component: R4 2,0L EDC H23 1661
Revision: 85H23---
Coding: 0A254012242601080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021BP 002006
ROD: EV_ECM20TDI01104L906021BP_002.rod
VCID: 74EDACECDF188BE69E-8020
Part No SW: 4G0 927 166 N HW: 0B5 927 156 K
Component: 0B5 20 TDIRdW H03 0003
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 387558DC83F02F8672-806C
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A69E41606579829B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41833538D02A6E4EC5-8014
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Coding: 01A8700E000000000000
VCID: 7BFF87D0FA46C49EDF-802E
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 CB HW: 4G0 820 043 CB
Component: KLIMA 2 ZONEN H14 0112
Serial number: 12021600111583
Coding: 34010908210000
ASAM Dataset: EV_AirCondiBasisUDS 003009
ROD: EV_AirCondiBasisUDS_003.rod
VCID: 61C3D5B870EA0E4EE5-8034
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [009] - Signal Amplitude Too Low
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:34
Compressor current: actual value: 0 mA
Outside air temperature: 18.0 °C
Temperature after evaporator: 15.59 °C
Engine speed: 0 /min
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001292050602
Coding: 0105C01440349FE0C1014083000018000F9CE7082E08020100000854EF01130200400034030000
VCID: 71E3A5F8A80ABECE75-8024
Component: WWS57X 160106 H38 0080
Serial number: 160120102054
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 61375912
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AM HW: 4G0 941 531 AM
Component: E1 - LDS H07 0044
Serial number: 26 05 2014 00000920
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: CD49C218000000000001
03608 - Humidity Sensor in Fresh Air Intake Duct
Fault Status: 01100101
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:33
00496 - Sensor for Vehicle Leveling; Front
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:34
03725 - Control Module for Seat Belt Tensioner; Left Front
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:38
01539 - Headlights Not Adjusted
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:51
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1008LJD4
Coding: 30333130313630323637554A304C34473053
VCID: 3B7F47D0B2C6049E9F-806E
Serial number: 3575HRB405H3U1OO394R
Serial number: 3585HRB40553U1OO49BO
Serial number: 3515JRB400E557DQ70UA
Serial number: 3525JRB405L3HTVKN8M/
Serial number: 3554VRB40593F0KMEO3X
Serial number: 3564VRB400S5593QNQ78
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862PBE000LD
Coding: 000014
VCID: 3B7F47D0BAC6049E9F-806E
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 18 01 2016 E0047797
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb
Part No SW: 4G8 920 934 D HW: 4G8 920 934 D
Component: TDieRdw H11 0106
Revision: 09001102 Serial number: 658150216596043
Coding: 13AF0A000B410008010000
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K.rod
VCID: 32616AF4658CC5D64C-8066
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002157595
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 001028
ROD: EV_GatewPkoUDS_001.rod
Serial number: 1851869103
Voltage stabilizer:
5080 - Front Left belt tensioner control module
U107C 00 [009] - No communication
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:34
Voltage terminal 30: 12.2 V
Voltage terminal 15: 12.1 V
Control Module temperature: 19 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
U1101 00 [009] - Active
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:34
Voltage terminal 30: 12.1 V
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720NDSL2
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 336F6FF09A96CCDE47-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011C17014000628002080002
VCID: 47972B20F60E507E0B-8012
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:33
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000002 Serial number: 0000655919
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106_AU57.rod
VCID: 3A7142D4BDFC3D9684-806E
Revision: 00002001 Serial number: 0396325988
Coding: 0100063800B930008320080428010F470000000000000000000000000000
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:33
Component: TSG BF H03 0511
VCID: 46892624F1044976F0-8012
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:33
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001745175
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_AU57.rod
VCID: 316365F8608AFECE35-8064
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 03FA02202A130200
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
VCID: 366956E489E4D9F660-8062
Coding: E01400
Coding: E01400
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
10 Faults Found:
U1014 00 [137] - -
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:35
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:36
5350720 - Left Matrix High Beam
C1175 54 [137] - Missing Calibration / Basic Setting
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:36
5350976 - Right Matrix High Beam
C1176 54 [137] - Missing Calibration / Basic Setting
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:36
5342449 - Output Stage for Matrix Headlamps; Left
C1164 F1 [137] - Incorrectly Coded
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:35
5342705 - Output Stage for Matrix Headlamps; Right
C1165 F1 [137] - Incorrectly Coded
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:35
5538082 - Temperature Sensor for Left Static Cornering Lamp
C1171 01 [009] - Electrical Failure
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:37
5538338 - Temperature Sensor for Right Static Cornering Lamp
C1172 01 [009] - Electrical Failure
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:37
5538083 - Static Cornering Light; Left
C1083 F0 [009] - Current Coding Electrical Malfunction
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:37
5538339 - Static Cornering Light; Right
C1084 F0 [009] - Current Coding Electrical Malfunction
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:37
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 044 D HW: 4G1 035 044 D
Component: MU-H-LN-EU 051 0389
Serial number: A734B0GB009861
Coding: 01750101FF0A000013110001000A00132F0006E5F1700100DF
VCID: 204590BC3B604746AA-8074
Subsystem 1 - Part No SW: V03 959 801 FA HW: -----------
Component: ECE 2016 --- 0134
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY804CZG
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349PBN00036
Component: Gracenote2 --- 1012
7199 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:38
Voltage terminal 30: 12.5 V
BAP-BAP_Function_ID: 02
Component: TSG HL H03 0511
Coding: 010815004000628002080002
VCID: 49932D18E01AA60E1D-801C
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0137
Revision: 7B001001 Serial number: 0321735575
Coding: 0100000202000000
Shop #: WSC 06745 128 28888
Part No SW: 4G5 959 107 C HW: 4G5 959 107 A
Component: HDSG-Modul H02 0049
Revision: 13002001 Serial number: 023400023
Coding: 111104C021
ASAM Dataset: EV_HDSGAu571 001022
ROD: EV_HDSGAu571.rod
Component: TSG HR H03 0511
Address 84: Night Vision (J853) Labels:* None
Part No SW: 4G0 907 547 A HW: 4G0 907 547
Component: NV-ECU-Gen3 H08 0107
Serial number: 622352400201442
Coding: 300100
ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
ROD: EV_NightVisioGen3AE4AU64X.rod
VCID: 2C5D748C47A8932606-8078
Camera For Night Vision System:
Subsystem 1 - Part No SW: 4G0 980 552 HW: 4G0 980 552
Component: NV-CAM-Gen3 H03 0006
Serial number: 623466500F1423900418
4107 - No Basic Setting
B2010 00 [009] - -
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:56
Image processor: error number-Image processor: error number 2: 00 00 00 00
Image processor: error number-Image processor: error number 1: 52 60 00 02
Voltage terminal 15: 12.30 V
Dynamic calibration-Dynamic calibration: yaw angle offset: 0.00 °
Dynamic calibration-Dynamic calibration: pitch angle offset: 0.70 °
Dynamic calibration: status-Dynamic calibration: pitch angle offset: 0.00 °
Dynamic calibration: status-Dynamic calibration: OFF
Dynamic calibration: status-Distance traveled with active dynamic calibration: 16512 km
Status of actuator test: not active
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Coding: 60140000
ROD: EV_OnBoardCamerDPC.rod
0552 - Control Module For Camera
C110A 54 [009] - Missing Calibration / Basic Setting
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:52
Outside air temperature: -41.0 °C
Voltage terminal 15: 12.0 V
Control Module temperature: 0.0 °C
0208 - invalid data record
B2005 00 [009] - -
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:34
Control Module temperature: 23.0 °C
0773 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:35
0730 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 68
Mileage: 18552 km
Date: 2017.10.12
Time: 21:08:35
Address 8F: Pretens. Frt Left
Address 90: Pretens. Frt Right Labels:
VCID: 55ABF168ACA2F2EE89-FFFE
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 160250422
ROD: EV_RDCMA00100_008.rod
VCID: 2F67638076BEE83E23-807A
End-------------------------(Elapsed Time: 07:01)--------------------------
