- Mar 9, 2015
- 413
- 274
- Australia
- C?ID=241363
Hi,
Just wondering if anyone had seen a similar set of faults?
The car had been driven and was parked up when the CEL was lit and a SS fault came up on the MFD, car went into limp mode.
He turned the car off and on again, CEL was cleared but SS fault remained.
Autoscan:
Cleared faults, checked for obvious coolant leaks, checked seating of plugs for the obvious sensors.
The car has a downpipe but no intake modifications.
Checked realtime air intake temp its now recording 50C. Ambient temp is 28C.
Cycled ignition a few times and no further faults.
Autoscan:
Saturday,07,October,2017,13:07:56:02396
VCDS Version: 17.8.0.1 (x64)
VIN: TMBKE9NE7F01 License Plate:
Mileage: 50978km-31676mi Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
VIN: TMBKE9NE7F01 Mileage: 50978km-31676miles
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0010
Revision: --H13---
Coding: 0C1D00324424010B0000
Shop #: WSC 73430 031 00120
ASAM Dataset: EV_ECM20TFS0215G0906259 001014
ROD: EV_ECM20TFS0215G0906259.rod
VCID: 6BDE350F828CAC1E4F-803E
9 Faults Found:
23096 - Intake Air Temp. Sensor (G42)
P0113 00 [032] - Signal too High
17789 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [032] - -
Mileage: 50953 km
Date: 2017.10.06
Time: 17:36:14
Engine speed: 700.75 /min
Normed load value: 8.6 %
Coolant temperature: 84 °C
Intake air temperature: 60 °C
Voltage terminal 30: 12.871 V
Engine: operating status: IS
Engine temp. management actuator: raw value: 2109
Engine temperature management actuator: stop open: 136
Engine temperature management actuator: after-run stop: 3956
RVC_SP: 6.25 °
RVC_AV: 131.72 °
RVCPWM: 0.000 %
15034 - Fuel Pressure Sensor (G247)
P0190 00 [032] - Circuit Malfunction
15376 - Fuel Pressure Regulator Valve (N276)
P2294 00 [032] - Open Circuit
15197 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 00 [032] - Electrical Malfunction
16986 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [096] - -
Mileage: 50953 km
Date: 2017.10.06
Time: 17:36:11
Engine speed: 704.00 /min
Voltage terminal 30: 12.792 V
Engine temp. management actuator: raw value: 2106
RVC_SP: 201.95 °
RVC_AV: 131.52 °
RVCPWM: 20.935 %
14866 - Camshaft Position Sensor (G40)
P0340 00 [096] - Malfunction
15015 - Turbocharger Bypass Valve Control Circuit
P0033 00 [032] - Malfunction / Open Circuit
15120 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0108 00 [032] - Signal too High
Readiness: 0010 0001
Part No SW: 0D9 300 041 T HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4512
Revision: 03253104 Serial number: TFK01410190684
Shop #: WSC 73430 031 00063
ROD: EV_TCMDQ250021_VW37.rod
VCID: 29520F0748F07E0EFD-807C
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 C HW: 3Q0 907 379 C
Component: ESC H32 0384
Revision: 00000000 Serial number: 62994000000569
Coding: 1C0793915422296E0079060641CA2938C92A9400608294F600410030C009
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034024
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
VCID: 3A70C04BBD56C59684-806E
Part No SW: 5E0 907 044 K HW: 5E0 907 044 K
Component: Climatronic H03 0907
Revision: 00001K06
Coding: 02110004000100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 003017
VCID: 2D5AFB177C18622E11-8078
Air quality sensor:
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011429701995
Coding: 0F001A42C24722FB47E04000000C07280000000000000000000000000000
Shop #: WSC 73430 790 00120
ROD: EV_BCMBOSCH_013.rod
VCID: 000472A39B0A5F468A-8054
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 140926 041 0570
Serial number: 141002151112
Coding: 065DDD
Component: RLHS 037 0059
Serial number: S4Y14M11D07H04M41S27
Coding: 00885D
5898 - Bulb for Rear Left Side Turn Signal
B12D0 15 [008] - Open or Short to Plus
Reset counter: 43
Mileage: 49168 km
Date: 2017.09.12
Time: 08:45:52
12554 - Bulb for Left Back-up Light
B12CB 15 [008] - Open or Short to Plus
Reset counter: 56
Mileage: 49733 km
Date: 2017.09.20
Time: 17:34:08
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 237
Mileage: 49467 km
Date: 2017.09.16
Time: 17:04:40
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331430200729
Coding: 0031151051
Shop #: WSC 73430 790 00063
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 3D7ACB57AC78F2AEA1-8068
Part No SW: 3Q0 959 655 AA HW: 3Q0 959 655 AA
Component: Airbag VW20 012 0200
Revision: -------- Serial number: 003NYPN3L1QU
Coding: 98FCC000000000005C000000008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7DFA0B57ECF832AEE1-8028
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169595B01111440286
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169594B02111440063
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 454 001 410 14
Serial number: 3576U00000039B01511$
Subsystem 4 - Part No SW: ----------- HW: 454 002 110 14
Serial number: 3586U000000ED740711D
Subsystem 5 - Part No SW: ----------- HW: 454 802 410 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R262C1E05000000+
Subsystem 6 - Part No SW: ----------- HW: 454 802 410 14
Component: SideSensor_Pr 111 0148
Serial number: 3526R09F22205000000Z
Subsystem 7 - Part No SW: ----------- HW: 454 802 709 14
Component: FrontSensor_D 114 0149
Serial number: 3556V34A0C5040000002
Part No SW: 5Q0 953 507 DF HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 04111404221695
Coding: 1410
ROD: EV_SMLSKLOMQB_009_AU37.rod
617752 - Selector Lever Park Position Lock Switch
B1162 29 [024] - Signal Implausible
Fault Frequency: 9
Reset counter: 70
Mileage: 49511 km
Date: 2017.09.17
Time: 14:29:13
Operating time: 104810 min
Supply voltage: Terminal 30: 14.5 V
Vehicle speed: 14 km/h
Voltage at switch: 4.98 V
Terminal 15 status: active
System status: 30
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5E0 920 756 HW: 5E0 920 756
Component: KOMBI 304 4270
Coding: 27A509082980000801086A001000000000000000
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 67D6493F9E64887E2B-8032
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0002678360
Coding: 030100342F085900EF00026E1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72E0286BA5A67DD68C-8026
Subsystem 2 - Part No SW: 5E0 919 719 B HW: 5E0 919 719 B
Component: E221__MFL-PR6 H05 0130
Serial number: 000000000A0201141014
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 5201484803
Part No SW: 5Q4 959 393 B HW: 5Q4 959 393 B
Component: TSG FS 009 0014
Serial number: 0000122931976
Coding: 001C01208001048000001100
VCID: 4280B8ABD5868D56DC-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004227119
Coding: 1D0200
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8103
ROD: EV_SteerAssisMQB.rod
VCID: 3776D97F8E44D8FE7B-8062
19460 - Databus
Fault Frequency: 46
Reset counter: 9
Mileage: 49091 km
Date: 2017.09.11
Time: 13:18:03
Motor status: 00
Supply voltage: 13.50 V
Temperature: 43.0 °C
KFC: 4C
KFA: 00 04
Environmental conditions: 20
uioUdNotFilt_xdu16: 13.58 V
uAdSensI_SwitchedKl30_xdu16: 13.59 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Part No SW: 5Q4 959 392 B HW: 5Q4 959 392 B
Component: TSG BFS 009 0014
Serial number: 0000124384001
VCID: 4182B7A7D080964EC5-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004343760
Coding: 050200
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 03DE02003F010000
VCID: 4084B2A3DB8A9F46CA-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Part No SW: 5E0 035 045 D HW: 5E0 035 045 C
Component: MU-H-N-RW H43 0371
Serial number: A314J0E7510022
Coding: 03735208FF00000011510001001100002F0001D601000100F6
ASAM Dataset: EV_MUHig6C3HBAS 001041
ROD: EV_MUHig6C3HBAS_SK37.rod
VCID: 1F4611DF06B480BE93-804A
Subsystem 1 - Part No SW: 5E0 919 606 HW: 5E0 919 606
Component: ABT_High H60 0030
Serial number: SKZ8Z9PT600AEF
Subsystem 2 - Part No SW: V03 959 801 EN HW: -----------
Component: ROW 2015 --- 0039
Part No SW: 5E0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 141021201735
VCID: 69D24F078870BE0E3D-803C
End-------------------------(Elapsed Time: 04:04)--------------------------
