2009 vw cc P2295
aljb320
Long Island
C?ID=174376
Hello everyone hope everyone had a great summer.
Hey I have been chasing an electrical gremlin (ghost), on my 09 cc 6 speed manual, I will try to explain as best as I can.
Every once in a while I get a P2295 short to ground MIL fault. I noticed that this ONLY happens when I cycle the key to accessory and or to start (without actually cranking the engine, NOT pressing the clutch to start). If I start the engine every time I never get this fault. In addition, it happens every 2 to 4 or 5 cycles of the push key NOT with every cycle of the key. I have been through every wire looking for shorts but have not found any. Again once I clear the code and actually start the car I never get this code, I can drive like this for weeks with no issues but as soon as I cycle the key to accessory or start without starting the engine (every 3 to 5 cycles) the fault returns, no other issues with the car. Runs and drives great, I’m thinking either the push key is faulty or computer.
Work done to the car, some for the issue and others as preventative maintenance:
tank fuel pump, HPFP, fuel injectors, rail fuel pressure sensor, MAF, and complete tune up, intake valve clean. Most recent balancer shafts replaced due to seized left hand shaft (the one that runs the water pump).
this fault hasalways been there since I purchased the car used with 114K on it.
CAR HAS NO TUNES (Non chipped ECU) All OEM.
Any suggestions?????? LoL
Wednesday,30,July,2014,14:53:21:09643
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: License Plate: CC CODE
Address 01: Engine Labels: 06J-906-026-CCT.clb
Control Module Part Number: 06J 906 026 AF HW: 06J 906 026 AF
Component and/or Version: MED17.5 TFSI 2,0 3318
Software Coding: 0404010A18070160
Work Shop Code: WSC 05314 000 00000
VCID: 6ED306D979B2AE6E79B-803B
008853 - Fuel Pressure Regulator Valve (N276)
P2295 - 000 - Short to Ground - MIL ON
Fault Status: 11100000
Date: 2047.15.31
Time: 31:63:63
Temperature: 95.0°C
Temperature: 58.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.573 V
Readiness: 0000 0100
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
It would be good to refer to your previous post about this issue, for a complete history. Also, it would be good to post a complete un-edited Auto-Scan of the entire car (wrap it in [ CODE ] [ /CODE ] tags without the spaces). What you posted is from the engine only, and it's definitely not current as it's dated in July and identical to your other thread.
Jason
Keithuk
Stoke on Trent, England
C?ID=122432
A little tip from Uwe you can use [NOPARSE ] [/NOPARSE ] without spaces either side of [CODE ] Full AutoScan [/CODE ] without saying no spaces.
[CODE] Full AutoScan [/CODE]
I have to show spaces else you won't see the code.
Gone But Not Forgotten
Yeah.............first don't do that!
Time for a battery?
Voltage: 12.573 V This says WEAK!
Always post the entire scan as other DTC's help in understanding issues and config............
Always pay attention to DTC stamps.........data!
golfi_vend
Tartu, Estonia
C?ID=195131
Time for a battery?
Please educate me, the uneducated.
How is this weak? Fully charged battery is 12.6V, the car wasn't running on the time of the fault happening.
Experience more than anything and seeing things like this.
How he described the issue during the key selection.
To me its close enough with all the crazy modules coming online.......... the age of the car for an issue...... maybe with an ignition switch issue undefined condition.
I am just guessing without a complete auto-scan......theorizing the most obvious in my head........
The BCM's seem to flake out during a crank of load and you may not see it during that glitch.
Before I condemned the ECM.......... I would want to know that battery is perfect and grounds where all good if in fact the valve was verified good/new and no wiring was in error.
Not looking to educate the uneducated.......just an opinion based on what I see and was presented.
More data is needed.........
A fresh battery will net closer to 12.8 V from what I see static and if the meter or VCDS went below 12.5 in less then 15 minutes I'd say the battery is junk or needs a charge.
aljb320
Long Island
C?ID=174376
thanks guys, yes this is an older scan but I was just trying to show the actual fault. I will post actual full scan, I too was wondering about the battery and/or switch myself, I apologize for not posting the complete vagcom in my previous thread, I will add full scan as soon as I can, thanks again.
aljb320
Long Island
C?ID=174376
Hello guys Ok I had some time for more trouble shooting, first I connected a battery charger and confirmed that as for the battery voltage, I still have the fault when I cycle the key only, when I start the engine no issues car runs great, maybe key ignition key (I hope)or computer (hope not).
Friday,05,September,2014,18:25:07:09643
VCDS Version: 12.12.3.0
Data version: 20140822
VIN:    License Plate: 9-05-14
                      VCID: 6ED306D979B2AE6E791-803B
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 96.0°C
                    Temperature: 58.0°C
                    Voltage: 12.446 V
Readiness: 0110 0101
full scan:
Friday,05,September,2014,18:24:11:09643
VIN: WVWNL73CX9E525403   License Plate: VW CC 9-05-14
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62 65
          72
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 AF    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    3318
   Revision: AAH03---    Serial number: VWZCZ000000000
   Shop #: WSC 05314 000 00000
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000786096436
   Coding: 0000373
   Shop #: WSC 05311 000 00000
   VCID: 2B55CFCD8A209B461EF-807E
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 E    HW: 3C8 907 336 E
   Component: Climatic      120 0102
   Revision: 00003001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_SE36.rod
   VCID: 2F6DDBDD7638E766327-807A
   Revision: 00H54000    Serial number: 00000008816376
   Coding: E7848B8110041A0043970F001700000000091A475C00017C174000000000
   Shop #: WSC 05124 123 12345
   VCID: 3365D7AD5210C38656F-8066
   Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 080808 022  0602
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     150908 054  0402
   Coding: 00209133
   Shop #: WSC 05124
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0409886
   Coding: 0000000
                    Reset counter: 56
                    Mileage: 187735 km
                    Date: 2003.14.11
                    Time: 06:20:38
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__313 VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPJM12QW
   Coding: 0012595
   VCID: FAFBBA89B5FA72CE559-80AF
   Subsystem 1 - Part No: 3C8 959 339
   Component: BF-Gewichtsens. 001 0003
   Subsystem 2 - Serial number: 00000000001L9T
   Subsystem 3 - Serial number: 0007.06.080000100000660097ÿ†63
   Subsystem 4 - Serial number: 660097ÿ†6333FTS669872138 ÿ†63
   Subsystem 5 - Serial number: 72138 ÿ†6343FTS651502258 ÿ†63
   Subsystem 6 - Serial number: 02258 ÿ†6353ETS6NIIUUVNJ ÿ†63
   Subsystem 7 - Serial number: UUVNJ ÿ†6363ETS68OSTUVNJ ÿ†63
   Subsystem 8 - Serial number: TUVNJ ÿ†6374CTS6NJPVUVNR ÿ†63
   Subsystem 9 - Serial number: VUVNR ÿ†6384CTS6ESMUUVNR ÿ
   Subsystem 10 - Serial number: UUVNR ÿ
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AK    HW: 3C0 953 549 AK
   Component: J0527               0025
   Revision: 00030000    Serial number: 3C5953507CP
   Coding: 0000511
   VCID: 75E129B51CE49DB6B8B-8020
   Subsystem 1 - Part No: 3C8 959 537
   Component: E221__MFL-TAP   H2ÿ 0021
   Coding: 00000226
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 970 B    HW: 3C8 920 970 B
   Component: KOMBI         H19 0023
   Coding: 240A00
   Shop #: WSC 05311 115 12345
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 2B55CFCD42209B461EF-807E
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P088290CDE
   Coding: F980FF070013021002
   Shop #: WSC 05311 123 12345
   VCID: 26433EF991C2A62EC11-8073
   Part No SW: 3C8 919 965     HW: 3C8 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1614128T01P202
   Coding: 0000002
   VCID: F5E1A9B59CE41DB638B-80A0
   Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 09146 444 10150
   VCID: 73E517AD1290838696F-8026
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000001
   VCID: F2EB92A9ED8A0A8E1D9-80A7
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1533
   Revision: 71009005    Serial number: 00000520588806
   Coding: 0001463
   VCID: 408F886113A6681EDBD-8015
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.074 0401
   Revision: 1AH02234    Serial number: 00081630202002
   Coding: 0000258
   VCID: 3663EEB94162D6AE711-8063
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 RDK 051 0221
   Coding: 1A910F8001860C7612041415F08A8F0E085C01
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1533
   Revision: 71009005    Serial number: 00000273488812
   Coding: 0001462
   VCID: 41898D6518AC6116D43-8014
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000127218
   Coding: 0000057
   VCID: 285F30C19BD6B05EF3D-807D
   Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Component: J388   TUER-SG HL   0309
   Revision: 43004101    Serial number: 00000000587601
   Coding: 0001168
   VCID: 3169DDA5A80CF196243-8064
   Coding: 0100101
   Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
   Component: J388   TUER-SG HR   0309
   Revision: 43004101    Serial number: 00000000584144
   Coding: 0001168
   VCID: 326BD2A9AD0ACA8E5D9-8067
Thank you for posting the auto-scan........
Please have the firmware update of the engine control unit performed, as you are behind in programming level.
aljb320
Long Island
C?ID=174376
Jack sorry but can you help me with this, how do i do a firmware update of the engine control unit.
aljb320
Long Island
C?ID=174376
is this only a dealer function?
aljb320
Long Island
C?ID=174376
Ok I finally found the problem, i piggy backed a wire directly from 12v to the n276 pin 2 connector and cycled the key a bunch of times with 100% success. The problem child is the engine bay fuse and relay box part 3c0937125, now I have to get locate one. After I removed the fuse box I checked it again on the work bench and this time ( I'm guessing from moving the box around) I got a small amount of resistance from. The fuse 17 to the back of the wi that feeds the n276 hpfp. Once again thanks to all for your input and assistance.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Nice sleuthing!
Thanks for letting us know what you found. Too often these threads trail off into nothing and we never find out what happened.
Jason
I have found that an inspection of fuses and fuse boxes is best done with each fuse removed and with my eyes now under light with magnifier.
Uwe's style glasses are a serious consideration I have pondered............They have adjustable magnification.
Using a diode light or meter voltage test just doesn't cut it for fuse checking.
Since fuses are load related......... they should always be done with the correct test light to check the ability to carry current or amp probe.
If corrosion is there you will see it through the resistance or illumination of the light.
To many are afraid of load test lights and been brain washed into safety diode testers verse taught properly.
Screw hope...........I'm American............ I want change now! Not banned supersized soft drinks/or magazine restrictions as a solution.
Thank you for posting your find.......... it is most appreciated. Insures basics won again...........
aljb320
Long Island
C?ID=174376
Ok I just odered one (yes used, I'll take my chances) same part number and correct layout as mine. once I confirm everything works I will try to pull apart my faulty box to see what the hell is going on inside and post pics here if I can, thanks.
What part # did you order and was curious what a used unit went for?
Did you get a filter with regulator?
Did you check with OEM to see if you qualified for both as a campaign or service action?
There are 4 different pumps for this car..............
aljb320
Long Island
C?ID=174376
part ordered was 80 bucks free shipping (fuse and relay box part 3c0937125). What filter are you refering too, and I did not check with OEM for any campaigns, thanks.
aljb320
Long Island
C?ID=174376
As for the pump I remember installing the OEM part number I purchased from ECS tunning.
aljb320
Long Island
C?ID=174376
Also to add as for the initial problem with the short to ground fault only when I cycle the key to accessory what would the pump or filter have to do with it, I'm not being a wise ass Im just trying to understand your question, thanks.
