Sunday,15,October,2017,09:57:57:57399
-- Windows Based VAG/VAS Emulator Running on Windows 7 x64
Version: 17.8.0.1 (x64)
VIN: VSSZZZ5FZJR026299 License Plate: VJI 737
Mileage: 994km-617mi Repair Order:
Chassis Type 5F-SE37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: VSSZZZ5FZJR026299 Mileage: 994km-617miles
03- Brakes -- Status: OK 0000
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HB HW: 04E 907 309 BH
Component: R4 1.4l TFS H26 4418
Revision: R7H26---
Coding: 01190032232419082000
Shop #: 00049 770 00124
Dataset: EV_ECM14TFS01104E906027HB 001006
ROD: EV_ECM14TFS01104E906027HB.rod
VCID: 6BD266E08265C71E4F-803E
CAN Converter 01:
Address 03: Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 61727000001269
Coding: 18EE8A92242221720779060940CC2418512484E0600224733020F078C002430000000012121212B835351919323200
Shop #: 00049 770 00222
Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_SK37.rod
VCID: 78F849ACC3337C86B2-802C
Part No SW: 5F0 907 044 AK HW: 5F0 907 044 AK
Component: Climatronic H05 1801
Revision: 00001K09
Coding: 04100004200114011005000000101020
Dataset: EV_ACClimaBHBVW37X 006145
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
VCID: 6FEA72F0B67D3B3E63-803A
Air quality sensor:
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 [008] - -
Reset counter: 51
Mileage: 36 km
Date: 2017.09.29
Time: 07:32:26
Dynamic environmental data: 02 86
Voltage terminal 30: 12.8 V
Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: MQBAB H H36 0253
Serial number: 01001718401419
Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 091E3C68A8D9750EDD-805C
Subsystem 1 - Part No SW: 5F2 955 119 A HW: 5F2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 170529 041 0574
Serial number: 170619115642
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY17102146R
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000070101860
Subsystem 4 - Part No SW: 81A 907 658 HW: 81A 907 658
Component: G397_FSS H02 0003
Serial number: 20007341X81A90765800
Coding: 40006C
7 Faults Found:
10506 - Bulb for Left Tail Light
B12BE 15 [008] - Open or Short to Plus
Reset counter: 81
Mileage: 876 km
Date: 2017.10.10
Time: 16:41:18
10762 - Bulb for Right Tail Light
B12BF 15 [008] - Open or Short to Plus
Reset counter: 81
Mileage: 876 km
Date: 2017.10.10
Time: 16:41:18
11018 - Bulb for Left Brake Light
B12C2 15 [008] - Open or Short to Plus
Reset counter: 81
Mileage: 876 km
Date: 2017.10.10
Time: 16:41:39
11530 - Bulb for Right Brake Light
B12C3 15 [008] - Open or Short to Plus
Reset counter: 81
Mileage: 876 km
Date: 2017.10.10
Time: 16:41:39
919560 - Light Switch
B126A 29 [008] - Signal Implausible
Reset counter: 63
Mileage: 441 km
Date: 2017.10.03
Time: 10:39:01
1050628 - Lamp 1 for Contour Lighting of Door; Front Right
U1178 00 [008] - No Communications
Reset counter: 50
Mileage: 35 km
Date: 2017.09.26
Time: 16:28:03
1050884 - Lamp 2 for Contour Lighting of Door; Front Right
U1205 00 [008] - No Communications
Reset counter: 50
Mileage: 35 km
Date: 2017.09.26
Time: 16:28:03
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 B HW: 5QA 919 283
Component: 4 KanalH07 0044
Serial number: 000308419617179
Coding: 0600040001
Dataset: EV_EPHVA14AU3700000 009033
ROD: EV_EPHVA14AU3700000_009_VW37.rod
VCID: 499EFC68E859350E1D-801C
1080083 - Rear Parking Sensor(s)
B107B 13 [008] - Open Circuit
Reset counter: 81
Mileage: 876 km
Date: 2017.10.10
Time: 16:41:36
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Component: BOSCH H10 0620
Coding: 2D00008151FF8428949C814500300400000000000000000000
Dataset: EV_ACCBOSCHVW416 002005
ROD: EV_ACCBOSCHVW416.rod
VCID: 3C7095BCB78B90A696-8068
2172 - Databus
Reset counter: 81
Mileage: 876 km
Date: 2017.10.10
Time: 16:41:41
Dynamic environmental data: 02 8D
Control Module temperature: 16 °C
Voltage terminal 15: 13.3 V
Velocity_vehicle_reference: -0.97 m/s
Longitudinal_acceleration_vehicle_reference: 1.20 m/s²
Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W4PCXEFEN
Coding: 98CCC000000000005C0000CC008800000065
Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW27.rod
VCID: 0506305884C1116EB9-8050
Subsystem 1 - Part No SW: ----------- HW: 454 002 006 17
Serial number: 357000000001C9303729
Subsystem 2 - Part No SW: ----------- HW: 454 002 006 17
Serial number: 35800000000BF3D4172T
Subsystem 3 - Part No SW: ----------- HW: 454 802 806 17
Serial number: 351004D7832100000004
Subsystem 4 - Part No SW: ----------- HW: 454 802 806 17
Serial number: 3520045C92F10000000F
Subsystem 5 - Part No SW: ----------- HW: 454 801 306 17
Serial number: 3550094A912100000006
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 GD HW: 5Q0 953 549 F
Revision: -------- Serial number: 04071704220653
Coding: 1400
Dataset: EV_SMLSKLOMQB 020002
VCID: 7EF45FB4E11742B6F8-802A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5F0 920 950 E HW: 5F0 920 950 E
Component: KOMBI 303 0310
Coding: 27A40A002B80060001886A011000000080000000
Dataset: EV_DashBoardVDDMQBAB 009060
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 295E5CE84819150EFD-807C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW High 433 4303
Revision: -------- Serial number: 0006563502
Coding: 030100F42F085700EB000248080F00010001070000000000000000000000
Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 3362BE809AD55FDE47-8066
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G1050300617
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75886000001706221CCC
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: FS 011 0032
Serial number: 0000263940871
Coding: 00100220DC01040100001000
Dataset: EV_DCUDriveSideEWMAXCONT 006001
VCID: 479AFA50FE4DC37E0B-8012
65593 - Switch for Central Locking
B122D 29 [009] - Signal Implausible
Reset counter: 10
Mileage: 1048574 km
65652 - Motors for Central Locking
B122B 13 [008] - Open Circuit
Reset counter: 50
Mileage: 1048574 km
Component: EPS_MQB_ZFLS 129 1072
Coding: 8107
Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 4586F058C441D16EF9-8010
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: BFS 011 0032
Serial number: 0000264928913
Coding: 00100220DE01040100001000
Dataset: EV_DCUPasseSideEWMAXCONT 006001
VCID: 4684F754F947DA76F0-8012
Part No SW: 5QA 035 858 B HW: 5QA 035 858 B
Component: MU-S-ND-ER H41 0462
Serial number: SEZAZ2T1154425
Coding: 04736001D70A000011110101008808002F0101C601200500C6
Shop #: 02391 785 00200
Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE26.rod
Subsystem 1 - Part No SW: 5F0 919 606 HW: 5F0 919 606
Component: ABTm-2_8- H41 1042
Serial number: SEZ8Z9T6C00L46
Subsystem 2 - Part No SW: 6P0 919 866 R HW: -----------
Component: ECE1 2017/18 --- 0820
End-------------------------(Elapsed Time: 03:51)--------------------------
