No Cruise Control after MFSW Install with new clock spring and Stalks 2011 GTI
MikeLyons27
United States
C?ID=104983
I am having an issue with my Cruise control not working after the MFSW upgrade in my car. I am also getting some fault codes there weren't there before. I am thinking they are related to a coding issue, but I am not sure what to change? I installed a 5K0 953 507 AH (Clock spring and Stalks) 5K0 419 091 (MFSW), 5K0 971 584 C (Steering wheel harness)
All the buttons work on the wheel now, they light up. The horn works, blinkers work, and wipers...The only thing that doesn't work is my Cruise control. Attached is the before and after scan.
Any help would be great.
--Mike
Before
Friday,02,May,2014,00:56:07:34944
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWGV7AJ6BW123687   License Plate:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AP    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH18---    Serial number:
   Coding: 0403010A18070160
   VCID: 74C910381733AFBE8FF-8021
   Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
   Component: ESP MK60EC1   H31 0106
   Revision: 00H31001
   Coding: 114B600C492400FD881106EC92200041B70800
   VCID: 78D12408CB5BCBDEA37-802D
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_SE36.rod
   VCID: 75CF2D3CD449B6B6B81-8020
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R014Z11
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3957E10CB8D112D69C9-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0005FCK400
   Serial number: 3572MSME036D2058ZZZU
   Serial number: 3582MSME70284358ZZZV
   Serial number: 3512QSME2C56711EZZZ$
   Serial number: 3522QSME321C6417ZZZS
   Serial number: 35527SME5F234C23ZZZM
   Crash sensor for front airbag; passenger side:
   Serial number: 35627SME4A176723ZZZH
   Part No SW: 5K0 953 507 BA    HW: 5K0 953 549 C
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JJ5000E1
   Coding: 5080140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 70C11C28AB2B939E6B7-8025
147462 - Terminal 15
          B1148 12 [008] - Short to Plus
                    Fault Frequency: 171
                    Reset counter: 81
                    Mileage: 59010 km
                    Date: 2039.14.23
                    Time: 12:27:45
226057 - Ignition Starter Switch; Terminal S
          B1147 F1 [008] - Open or Short to GND
                    Fault Frequency: 52
                    Reset counter: 80
                    Mileage: 57687 km
                    Date: 2039.14.05
                    Time: 17:27:43
   Part No SW: 5K6 920 971 C    HW: 5K6 920 971 C
   Coding: 270F01
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 354FED3C94C9F6B6781-8060
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 091010F1002062
   Coding: E9807F0640061200000002
   VCID: EDFF855CF419FE76C01-80B8
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EAF58E400DF7E94EA53-80BF
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668751036
   VCID: 2773377456659426FAD-8072
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H58 0319
   Serial number: VWZAZ2M0027834
   Coding: 04010021010006000000000A
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 256F3D7C24698636C81-8070
   Component: NAR_V3_(0037)  0037
1048615 - Rear Left Audio Signal Output
          B1108 13 [009] - Open Circuit
                    Fault Frequency: 24
                    Mileage: 57659 km
                    Date: 2039.14.05
                    Time: 08:13:50
1048669 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 214
                    Mileage: 57659 km
                    Date: 2039.14.04
                    Time: 14:42:46
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2151
   Coding: 0001268
   VCID: 334BD32452BDE886565-8066
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 3147D92CA8A1DA96249-8064
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Coding: 0001268
   VCID: 3449D03857B3EFBE4FF-8061
   Coding: 0001232
   Shop #: WSC 01357 011 1012551
   VCID: 354FED3C5CC9F6B6781-8060
   Coding: 0001232
   VCID: 364DEA3041CFFDAE71B-8063
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668719714
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 3245D62065A7E18E5D3-8067
Now:
Monday,01,September,2014,16:36:02:34944
VCDS Version: 12.12.2.0 (x64)
050217 - Implausible Data Received from Steering Column Control Module
               U0429 - 000 -  - Intermittent
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:29:44
                    Temperature: 98.0°C
                    Temperature: 67.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.065 V
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -  - Intermittent
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:28:41
                    Temperature: 97.0°C
                    Temperature: 69.0°C
                    Voltage: 12.065 V
   Revision: 00H31001
   Revision: 00009001
   Coding: 0000001002
   Part No SW: 1K0 937 086 L    HW: 1K0 937 086 L
   Component: BCM PQ35  M   104 0615
   Revision: 00104 AE
   Coding: 65180A3880272AC400080081700085C442010086534D8D60648020200040
   VCID: 3957E10CB0D112D69C9-806C
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 30091  26  0512
   Coding: 009795
   Coding: 00003031
   Revision: --------    Serial number: WHRPIuswHHHTf
   Coding: 188A100000
   VCID: 76CD2A30C94FBDAEB1B-8023
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0120646
   Coding: 820000
0516 - Databus
                    Reset counter: 133
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:24:34
49675 - Control Circuit for Ignition Key Lock Solenoid
          B114A 13 [009] - Open Circuit
                    Reset counter: 133
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:24:34
229211 - Cruise Control Switch
          B1154 13 [008] - Open Circuit
                    Reset counter: 173
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:28:39
   Coding: 270F01
                    Reset counter: 128
                    Mileage: 66449 km
                    Date: 2043.14.21
                    Time: 00:34:52
   Coding: 04010041010006000000000A
   Component: NAR_V6N  0051
1048659 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 128
                    Mileage: 66449 km
                    Date: 2043.14.21
                    Time: 00:35:10
                    Reset counter: 128
                    Mileage: 66449 km
                    Date: 2043.14.21
                    Time: 00:35:05
   Coding: 0001270
   Revision: 00H17000
   Coding: 0001270
   Coding: 0001232
   Coding: 0001232
Did you fix this yet?
                    Reset counter: 173
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:28:39
Keithuk
Stoke on Trent, England
C?ID=122432
B11CF, U0429, P1698, B11CF are in Rosh-Tech Wiki the rest are in my EODB II Fault Codes software link on the intro link in my signature.
Which is basically check fuses, wiring and Read Measuring Value Blocks (MVB).
MikeLyons27
United States
C?ID=104983
Uwe - I've tried clearing the error, but it keeps popping back up. I checked the connections in the steering wheel module, and all of them look secure. Does anyone know exactly what connector it is for the Cruise control switch so I can check it specifically?
KeithUK- I haven't check the fuses, what fuse controls the Cruise control? I believe the wiring is ok, but what specific connector is for the cruise control so I know to check it? I would like to try your software if I can. Does it work with VCDS? or is it is own program?
How do I download it?
I was planning on putting together a DIY on the install, and I took some pictures. Attached are a couple of pictures of the wiring. There where 3 main plugs - a white one that plugs in all the way to the right, a black connector with a red tab, and a Yellow connector. There was also a 2 pin black connector that didn't connect to anything? When I was removing the stalks, I noticed the connector wasn't plugged in, and I thought that was the way it was supposed to be...
https://www.dropbox.com/s/np7fxtr7xvsv05q/photo%201.JPG?dl=0
https://www.dropbox.com/s/5krp5hgsyduorvk/photo%201%281%29.JPG?dl=0
https://www.dropbox.com/s/n4zz70ietonirq0/photo%202%281%29.JPG?dl=0
https://www.dropbox.com/s/229dqz3gbvuctvd/photo%204.JPG?dl=0
Keithuk
C?ID=122432
You need a 2011 GTI wiring diagram for fuses probably ElsaWin, as VW don't supply them, the handbook says.
At the time of print we are unable to provide an up-to-date overview of the locations of the fuses for the electrical consumers. This is because the vehicle is under constant development, because fuses are assigned differently depending on the equipment level and because several consumers may use a single fuse. You can get more information about the fuse layout from a Volkswagen dealership.
I've been to my dealer and they can't provide a fuse listing. I only state fuse if the error code says Short to Ground/Earth as it will blow a fuse first.
Mk6 fuses
It works on any Windows PC.
PM me and I will send you the link
jakematic joined my other forum this week so he has downloaded it.
MikeLyons27
United States
C?ID=104983
ok, so I figured out what was wrong with the cruise control a few weeks ago. I know this is an old thread but I thought it would be good to have for archive purposes. The issue was that the cruise control switch was not seated correctly in the stalk itself! I popped off the cover of the cruise control stalk, and noticed that when the cruise control switch was engaged, the little leaver inside would not move. I simply placed the pin for the switch correctly in the leaver and problem solved! I attached a few pics:
https://www.dropbox.com/s/1noyevmdmdrp22v/2014-12-07%2014.43.10.jpg?dl=0
https://www.dropbox.com/s/5a1ukkn71zt8z3e/2014-12-07%2014.43.28.jpg?dl=0
https://www.dropbox.com/s/a434ox4rwrsh93m/2014-12-07%2014.43.45.jpg?dl=0
https://www.dropbox.com/s/eknevunv91nx20u/2014-12-07%2014.44.25.jpg?dl=0
https://www.dropbox.com/s/73ca75su33jgdfl/2014-12-07%2014.44.44.jpg?dl=0
https://www.dropbox.com/s/25gt9gg6bmr57pb/2014-12-07%2014.45.07.jpg?dl=0
https://www.dropbox.com/s/hlc8h5ky6gd7bat/2014-12-07%2014.45.25.jpg?dl=0
